Welcome to the North American Subaru Impreza Owners Club Saturday December 27, 2014
Old 08-20-2010, 05:37 PM   #26
Bariga
Member#: 179846
07 STi Limited
EFR 7670 TS
^ good for you
Old 08-20-2010, 06:06 PM   #27
k mier
Member#: 98000
05 sti e85@420hp
I'm seriously considering a twinscroll 35r setup for my next build being under the impression spool is considerably quicker than it's rotated equivalent. Not to be an azz, but why so laggy?
k mier is online now   Reply With Quote
Old 08-20-2010, 06:38 PM   #28
john 1badSTI
Member#: 77470
04 sti 10.51@138.5
on e85@ 30psi--spinning
Originally Posted by Bariga View Post
^ good for you
HEY hey don't take what I said the wrong way I am not down playing your car I am just trying to say that your big cams are not the reason for how it spools.
john 1badSTI is offline   Reply With Quote
Old 08-20-2010, 06:49 PM   #29
wrxwhat
Member#: 87653
500 hp STI / 1100hp
Supra T / Stock G35
Being dyno'd in 3rd gear probably has something to do with it bud.
wrxwhat is offline   Reply With Quote
Old 08-20-2010, 07:40 PM   #30
john 1badSTI
Member#: 77470
04 sti 10.51@138.5
^^^^you may be right didn't catch what gear the pull was done in usually done in 4th with a 6 spd
Old 08-20-2010, 07:41 PM   #31
godforbid67
Member#: 137168
06 Built SGM WRX
35r, PPG, 280's, PSS9.
Yeah, definetly not the cams. I wouldnt even consider 272's "big". I am running 280's my self but a smaller bolt on turbo.
Maybe its just the dyno?
Does it spool the same on the street Bariga?
Either way 500 wheel is 500 wheel
Chris
godforbid67 is offline   Reply With Quote
Old 08-20-2010, 07:42 PM   #32
godforbid67
Member#: 137168
06 Built SGM WRX
Ohh, very good point. I didnt see that.
That explains A LOT.
Old 08-20-2010, 08:02 PM   #33
Bariga
Member#: 179846
07 STi Limited
EFR 7670 TS
ill post some logs
Old 08-20-2010, 08:15 PM   #34
Nuke209
Member#: 108089
NF Performance
I like...ALOT!
Old 08-21-2010, 01:24 AM   #35
Homemade WRX
Member#: 33782
96 bastard child
search FIRST, then PM!!!
I am running bigger custom kelford avcs cams than 272's with a single scroll hta86/.82 and see over 20 psi by 4100 so I am not going to point the finger at the cams being the reason for laggy spool-up.
which cams are you one? what's the lift? just curious, not doubting. you are also on a .82 Ar. You are also like 16% or so smaller turbine AR than this engine...just saying.
Old 08-21-2010, 02:20 AM   #36
john 1badSTI
Member#: 77470
04 sti 10.51@138.5
yeah I know but the hta86 does have a 4mm bigger compressor wheel also.And the cams are right about 282 int and exh with 11.3mm lift on int and 11mm on exh.I would have to look the specs up on the card for the .050 duration.And the cams were decided on by Kevin Ban himself,I gave him hwat I had and what I wanted and thats what he grnd for me.So far these cams have allowed me to pick up almost 40mph on the back half of the 1/4 on 30 psi.
Old 08-21-2010, 11:37 AM   #37
Homemade WRX
Member#: 33782
96 bastard child
gotcha! What CR are you on? continuing the curiosity information probing
Old 08-21-2010, 03:05 PM   #38
Equilibrium Tuning
Member#: 26933
2006 STI
The spool doesn't look too bad for 3rd gear and a 1.06 a/r housing. This is about how a .82 a/r single scroll would spool in 3rd gear.
-- Ed
Old 08-23-2010, 02:23 AM   #39
ASU
Member#: 164551
2006 Brotastic STi
Land of beer and laws
Im running the Kelford 272s as well, you can get it to spool up a bit more quickly but you and Dom are going to have to sit down and play with the AVCS a little bit, when you have modded cars like ours it takes more than a day of tuning to get it running perfect.
ASU is offline   Reply With Quote
Old 08-23-2010, 03:06 AM   #40
Bariga
Member#: 179846
07 STi Limited
EFR 7670 TS
Yeah that could be true, your dyno log looks very good maybe its because you have a BorgWarner
Old 08-23-2010, 06:41 AM   #41
alcoolaid
Member#: 134949
'07 SWP STi
Instagram | arthurlam89
Is there a 4th gear pull graph? 20psi @ 5000rpm is quite laggy imo.
Old 08-23-2010, 09:03 AM   #42
Josh083188
Member#: 254913
Nice numbers.
Josh083188 is offline   Reply With Quote
Old 08-24-2010, 02:00 AM   #43
Maxwell Power
Member#: 190729
I was honestly a little surprised by the lack of spool. I played with the AVCS quite a bit and it didn't yield much for gains in spool. Not sure why...
we have a few things to work on still with the tune, so I'll probably be giving the tune another shot pretty soon to see if I can lean it out a bit during spool and knock it down a few hundred rpm. I wonder if the 90 right off the turbo is affecting the performance much.
Interesting thing though, my 2.3L gets full boost by 4850rpm on a standard 35R .82 hotside. Mine has a small exhaust cam that really helps get the turbo spinning, but chokes out the top end. The CNC porting in my heads helps a bit too. You can see the power curve on this has practically no choke at all. I had really anticipated that the turbo would come in a lot sooner. I do need another 35R for my other car, so maybe I could buy this turbo from the OP and convince him to switch to a BW.
Regarding 3rd gear. This is an 07 so 3rd isn't as short as other sti 6mt's. I tune in 4th on the 07's as well. I use as many gears as possible to ensure the tune is ideal. I'll have to see if I have a graph from that on my dyno computer. One thing to think about though, if I published a graph of 4th gear, it wouldn't represent what the car does on the road. [disclaimer] With 07's, you have to be hauling ass to actually use 4th (>85mph) and it wouldn't/shouldn't happen on public roads. [/disclaimer]
As far as RPM is concerned: we blueprint our motors at MPS and perform a few mods to the oiling system. This car held over 85psi at 8500rpm. Looking back I should have shimmed the pump a little- in addition to the porting/polishing/deburring- to bump the pressure to 95psi (85 is the relief setpoint of this pump). This engine also has longer rods which help the engine maintain reliability at higher rpm.
Head work: When we put the +1mm valves in the head, we enlarged and radiused the valve seats. I did a little bit of cleaning up on the bowls as well to help the airflow.
anyway, we'll be at this car some more to see what we can squeeze out of it.
Old 08-24-2010, 02:02 AM   #44
Maxwell Power
Member#: 190729
your spool is remarkable in your car. Mostly due to the different turbo, smaller exhaust cam and ported heads.
Old 08-24-2010, 04:38 AM   #45
Bariga
Member#: 179846
07 STi Limited
EFR 7670 TS
Both turbos are about the same acording to Jeof at Fullrace, DW takes lead on the race gas though! Maybe Alcooland had better gas 94 octain?
http://forums.clubrsx.com/showthread.php?t=611432
he runs the same cams on his car maybe porting help a bit, Phil@Elementting says that poring doesn't do much rather then heaving +1 valves and big cams.
Or maybe hydra i holding me back some how////
Old 08-24-2010, 01:00 PM   #46
Maxwell Power
Member#: 190729
frankly I don't believe that graph. I've seen both these turbos in person on many occasions in all sorts of setups. The BW spools faster every time.
Old 08-24-2010, 02:50 PM   #47
Bariga
Member#: 179846
07 STi Limited
EFR 7670 TS
For the BW ill need to change downpipe a little, ill wait to see leons graph!
Old 08-25-2010, 06:59 AM   #48
alcoolaid
Member#: 134949
'07 SWP STi
When is leon's car done?
Old 08-25-2010, 09:01 AM   #49
domestic_abuser
Member#: 126696
2002 Fatbody bugeye
03 R1 09 Raptor 700R
Should have run the mild 2.34 block with bigger cams....that motor is the money!
domestic_abuser is offline   Reply With Quote
Old 08-25-2010, 01:21 PM   #50
Maxwell Power
Member#: 190729
Leon's turbo setup is installed. We are finishing his fuel system upgrade currently and his intercooler piping.
Soon as that's all done, he'll be on the dyno.
Maxwell Power Tuned, 2.35L GT35R 537whp and 9k rpm, 4K rpm power band Maxwell Power Proven Power Bragging 563 05-16-2012 09:28 PM
Maxwell Power Services aka GetaDomTune AwaySooner Vendor Reviews 7 03-11-2010 04:54 PM
+1 for Dom/Maxwell Power Jeff54 Vancouver Impreza Club Forum -- VIC 22 09-02-2009 03:22 PM
My new Maxwell Power Services engine is almost in !!! leonbmx North West Impreza Club Forum -- NWIC 13 03-23-2009 11:28 AM
