Old 08-24-2010, 01:25 PM   #1
BGPunk2001
Member#: 46134
Default I need assistance from the OT Helpdesk
Ok, so I got this new machine and we were installing oracle clients software and a java SDK on the computer. Part of this involved changing the classpath under environment variables in the system icon of the control panel.
Before I did this, my network drives would map at login through a batch file that gets run. Now it won't map the network drives at login after we installed everything.
For a brief fraction of a second a command prompt window flashes and after video-ing it, it says something to the effect of:
"(Something) is not recognized as an internal or external command, operable program or batch file."
I can't get a clear enough screenshot to figure out what that (Something) is. Has anyone ran into this problem? I guess I really need to find out what the program is first, huh?
BGPunk2001 is offline   Reply With Quote
Old 08-24-2010, 01:28 PM   #2
jumpinjusty
Member#: 239829
Turd Turbo Heap
T5 V70 and 745 TIC+M46
You have any out of place or "special" characters in your batch file?
Can you manually run net use commands on the local machine?
jumpinjusty is offline   Reply With Quote
Old 08-24-2010, 01:29 PM   #3
Brad Pittiful
Member#: 34931
this is why ill stick with my old phone
Brad Pittiful is online now   Reply With Quote
Old 08-24-2010, 01:54 PM   #4
Davemeister
Member#: 86577
2016 Supercoolmobile
Awesome Pearl Metallic
Stick a pause in the batch file, dummy.
Davemeister is offline   Reply With Quote
Old 08-24-2010, 02:04 PM   #5
BGPunk2001
Member#: 46134
Well I didn't have access to any of that.
Regardless, I talked our helpdesk guy into just letting me have a copy of the script on my machine locally, and I threw it in the startup folder. Problem fixed.
Old 08-24-2010, 02:30 PM   #6
BGPunk2001
Member#: 46134
Actually, I went back over the path variable, and I had overwritten the %systemroot% entries.
They are back in there and everything works fine.
Old 08-24-2010, 02:33 PM   #7
-=C=-
Member#: 7719
99 F-150 crew cab
with illegals in bed
yep...you made it to where the commands invoked in the batch file (whether "net use" or a vbscript or powershell or whatever) weren't running because the path variable didn't know where those commands were.
-=C=- is offline   Reply With Quote
Old 08-24-2010, 02:34 PM   #8
Davemeister
Member#: 86577
We had a borked installer once that was supposed to copy your path to a variable, append a new path, and then set your path to the content of that new variable.
What actually happened was that the copy your path to a variable part returned nothing and then your path only included the path to the new program. Ooops.
Old 08-24-2010, 02:46 PM   #9
SlickWRX
Member#: 17312
2015 WRX STI
Dark Grey Metallic
One time a client's custom inhouse designed HR system was updating environment values in the autoexec.bat and back in the 3.1 days. What it actually ended up doing was overwriting it with ONLY had the changes they wanted to make. I got to walk around for a few hours restoring the backup copies they fortunately made.
SlickWRX is offline   Reply With Quote
Old 08-24-2010, 02:55 PM   #10
iamchris
Member#: 106479
2005 9-2X Aero
Fluorescent Brown
Out of curiosity, which Oracle product are you using?
iamchris is offline   Reply With Quote
Old 08-24-2010, 03:38 PM   #11
BGPunk2001
Member#: 46134
Oraclient10g
Need assistance from the NWIC group 06_Aspen_STI North West Impreza Club Forum -- NWIC 1 05-31-2008 07:38 PM
need help from the OT engineers H-Dtech Off-Topic 67 02-05-2008 12:55 PM
Need help from the OT Photographers! Stray Cat Off-Topic 1 08-14-2007 12:40 PM
Need assistance from the windows/PC gurus out there! Krmnnghia01 Off-Topic 7 07-15-2006 11:36 AM
Cobb Tuning needs to ask for some assistance from the locals... Christian. Rocky Mountains Impreza Club Forum -- RMIC 0 01-30-2006 05:57 PM
