Old 08-11-2010, 12:37 PM   #51
sti robot
Member#: 110932
1999 e36 m3
titan silver
Just bought an alpha-bid one and will try it (04 sti) soon.
sti robot is offline   Reply With Quote
Old 08-11-2010, 02:39 PM   #52
bign
Member#: 107740
05 STI - WRB
01 GSX-R 750
Bought one for my 05 sti from alpha-bid and it works. Just had to find ecuflash 1.29a. Couldn't get it to work with 1.42
bign is offline   Reply With Quote
Old 08-14-2010, 11:39 AM   #53
WRX_936
Member#: 188003
2007 Sti
Anyone had success with a vagcom being able to read/write to an 06 wrx ecu? If so, how? I can data log just fine with romraider, but when trying to read the ecu with 1.29a, i get a kernel blah blah error but not enough info to see what went wrong, 1.42 will not even remotely try to connect.
WRX_936 is offline   Reply With Quote
Old 08-16-2010, 06:07 PM   #54
sti robot
Member#: 110932
1999 e36 m3
titan silver
Just got my alpha bid vag com. Interestingly enough my winxp netbook (dell mini 10v) recognized it an installed it with the ftdi drivers automatically. I'm thinking it's because I have already installed some FTDI usb/serial drivers for my arduino stuff.
I'll try and log after dinner and update this thread.
EDIT: I ended up updating the ftdi driver from 2.0 to the 2.8.x from the link on the OP.
Old 08-16-2010, 09:59 PM   #55
sti robot
Member#: 110932
1999 e36 m3
titan silver
Works well for logging. I won't check ECU flash until I unmarry my accessport.
See here: http://forums.nasioc.com/forums/show....php?t=2036991
Old 08-25-2010, 09:46 PM   #56
wrx07ltd
Member#: 255954
Hi!
I have a WRX 2007 USDM and using the VAG-COM cable, i'm able to datalog with RomRaider....and Learning View is working well too...
But i'm unable to use EcuFlash..
I connect the 2 green connectors and when I try to read the Ecu, it writes this is the log window:
ssm2_init
ssm2_init
ssm2_init
ssm2_init
ssm2_init
ssm2_init
ssm2_init
ssm2_init
ssm2_init
ssm2_init
kernel get version
validating denso kernel ram area addr: FFFF0000 len: 0008
and then pop this error: An error occured. See the log for details.
In the .xml of my ecu in the rommetadata (A8DK100X.xml), the flash method is sti05.....so I choose 2005-2006 Subaru DBW models WRX/STI/FXT/LGT/Baja
Anyone know what i'm doing wrong??
btw I tried EcuFlash 1.29a and the latest version too...
thanks!!
wrx07ltd is offline   Reply With Quote
Old 08-25-2010, 10:46 PM   #57
scoobystas
Member#: 26568
2003 Yellow Bugeye
Version 8-Vf37
i've been trying to flash my 03 jdm ecu with this cable. i downloaded ecuflash 1.29a and it what happens is that no matter how quickly i turn the key and click the "ok" button, the radiator fan cycles. i've tried this at least 300 times and can't do it fast enough. this is not an issue with the openport 2.0 though, so i'm not sure what else is going on.
scoobystas is offline   Reply With Quote
Old 08-26-2010, 12:39 PM   #58
wrx07ltd
Member#: 255954
nevermind
I installed ecuflash version 1.31 and now its working!!
thanks!!
Old 08-26-2010, 03:16 PM   #59
scoobystas
Member#: 26568
2003 Yellow Bugeye
Version 8-Vf37
Originally Posted by wrx07ltd View Post
nevermind
thanks!!
do you have a link to where you downloaded the software for 1.31?
Old 08-26-2010, 03:35 PM   #60
wrx07ltd
Member#: 255954
http://www.mediafire.com/?onmrje22zei
here you are, ecuflash version 1.31
don't forget to get the newest ecu definitions for ecuflash:
http://www.romraider.com/forum/topic3808.html
Old 08-26-2010, 10:39 PM   #61
scoobystas
Member#: 26568
2003 Yellow Bugeye
Version 8-Vf37
^^^ downloaded....will trying flashing tomorrow.
Old 08-28-2010, 09:29 AM   #62
4x4skuns
Member#: 185228
Will this cable work with an 04 FXT with ECU flash/romraider? I was about to buy a tactrix, but this is quite a bit cheaper.
4x4skuns is offline   Reply With Quote
Old 08-28-2010, 03:43 PM   #63
scoobystas
Member#: 26568
2003 Yellow Bugeye
Version 8-Vf37
Uploaded with ImageShack.us
well i'm still not able to flash. i can log, i can open learning view. Can't flash. Notice it says test mode not detected...well that was because i clicked ok too fast. The next time i tried it said "ecu in test mode" but the fans still cycle, it doesn't let me compare the roms or flash.
Old 08-30-2010, 04:51 PM   #64
wrx07ltd
Member#: 255954
Did you set the baud rate of the cable to 4800 in the device manager??
If it's for a WRX older than 06-07, you need the reflash connector from this page: http://www.tactrix.com/index.php?pag...hk=1&Itemid=53
Old 08-30-2010, 05:41 PM   #65
scoobystas
Member#: 26568
2003 Yellow Bugeye
Version 8-Vf37
yes i did set the baud rate to 4800. I used to have a tactrix openport 2.0 that tactrix is currently fixing for me, the mini usb design is weak and the soldering fails.
anyway, i only got this cable as a "quick fix" while i'm without my openport. Yes i have the reflash connector connected, i'm a seasoned flasher, lol, but i can't flash with this vag-com cable
Old 08-31-2010, 11:54 AM   #66
Drunkinchef
Member#: 145324
2007 Honda FIT
Storm Silver
I'm having the same issue that you are having. But with my02. Baud rate is correct, blue flash plug installed. As soon as I go to test write it will disconnect my obd2 and I have to restart the program to get it to start reading the ecu again. I get the same exact screen (kernal bla bla). Does anyone have a clue?
Drunkinchef is offline   Reply With Quote
Old 08-31-2010, 05:41 PM   #67
scoobystas
Member#: 26568
2003 Yellow Bugeye
Version 8-Vf37
Your fans instantly cycle? What do you mean it disconnects your obd2? Does your message say "ecu in test mode"?
Old 08-31-2010, 07:53 PM   #68
Drunkinchef
Member#: 145324
2007 Honda FIT
Storm Silver
It will say "ecu in test mode" then "bootloader" a few times. But as soon as it starts running bootloader I noticed that it loses the ecu. Ive used ecuflash and ecuexplorer. I have the same error code. But with ecuexplorer you can actually see in the left box it will say ecu disconnected after it recognizes it in test mode.
I'm able to read realtime data from ecuflash and explorer. Also able to adjust idle speeds. God forbid I try to test write~! lol
Old 09-03-2010, 03:03 PM   #69
Drunkinchef
Member#: 145324
2007 Honda FIT
Storm Silver
Any updates?
Old 09-06-2010, 03:43 PM   #70
Drunkinchef
Member#: 145324
2007 Honda FIT
Storm Silver
Hey guys. I found this from rosstech. The original manufacturer of the cable.
Here is the install guide
http://www.ross-tech.net/VCDS/downlo...0-6-manual.pdf
and here is the new software
http://www.ross-tech.com/vcds/download/current.html
I'll give it a try later. But it's worth a try.
Old 09-06-2010, 03:46 PM   #71
SoobZero
Member#: 157226
2004 STI
Just successfully flashed to a stock map using the VAG-COM on my 2004 STI. No problems whatsoever after I soldered a piggyback wire inside the vag-com unit for the needed voltage.
SoobZero is offline   Reply With Quote
Old 09-06-2010, 03:53 PM   #72
scoobystas
Member#: 26568
2003 Yellow Bugeye
Version 8-Vf37
let us know. I just got my openport 2.0 back but will still love to know if its possible to flash the 03 ecu with the vag-com cable. I will probably do 100% of my logging with this vag-com cable as its much beefier and resembles the tactrix 1.3 cable which doesn't have the weak mini usb connection.
Old 09-06-2010, 07:14 PM   #73
Drunkinchef
Member#: 145324
2007 Honda FIT
Storm Silver
It's a no go. The drivers basically disabled the com. No good. I need to get the new rom image on my ecu to pass inspection damnit! Why won't this work?!?!?!!!!!!!
Old 09-10-2010, 01:31 PM   #74
choleaoum
Member#: 255484
2003 WRX
'03 G35 Sedan / '06 R6S
Any news for the bug eyes? Can anyone confirm if it's working and how?
choleaoum is offline   Reply With Quote
Old 09-11-2010, 09:36 PM   #75
S10Crazzy
Member#: 255507
2009 Impreza
So Dirty I dont Know
Default 09 2.5i
Hey Guys Goes anyone know if the VAG-COM cable will work for a 09 2.5i?
Stupid question how do I find out if I have a 16bit ECU or 32bit?
S10Crazzy is offline   Reply With Quote
I Got VAG-COM cable and I need help!!!!! subi-bartimioli02 Open Source Reflashes 147 06-23-2011 12:45 AM
WTB Service: Get my Vag Com cable to work el dude MAIC Private Classifieds 3 10-04-2009 08:25 PM
Anyone in Phila. willing to share their Tactrix or vag-com cable? eek1 Tri-State Area Forum 4 09-12-2009 04:32 PM
Cant get Vag-com cable to flash my 04 FXT andy87t2 Open Source Reflashes 6 06-13-2009 12:35 AM
VAG-COM cable btlegacy Open Source Reflashes 4 05-31-2009 07:10 PM
Message Board Statistics All times are GMT -4. The time now is 06:32 PM.
