Old 09-01-2010, 12:25 AM   #1
suberdave
Member#: 101865
88 GL-10 STi
Default Hybrid axles "The Missing Link"
The Missing Link to the R180 install with R160 hubs...
So I needed to install an R180 diff with my 6 speed swap, but did not want to install the rear R180 rear hubs.
So I did some research and found that the inner cup of the R180 axle shaft could be joined to an R160 axle shaft with the aid of a custom CV race.
I did much research online and made many long distance phone calls and found a CV company that could make me the custom race that I needed.
Problem was that like many things in manufacturing, they would not make me just 2, I had to have 10 min made.
So if anyone else wants to do this same thing... PM me I have extras to sale...
left is 2005+ STI inner race center is custom STI / WRX Race Right is 2002 WRX inner race
This is how it works.
You must use 05+ STI inner shafts with 8 balls on the race and cage. the 04 and earlier have 6 balls and will not work with this custom race.
First take apart both shafts.
Remove the CV boot clamps. if you do this right you can reuse them.
Next remove the retaining ring holding the inner joint together.
Next the Snap ring at the end of the shaft.
and it is now apart...
Now put it back together using the WRX shaft, the custom race, and the STI inner joint.
And now you have a custom shaft to install your R180 diff in your Subaru using your stock hubs...
-=Suberdave=-
www.suberdave.com
suberdave is offline   Reply With Quote
Old 09-01-2010, 01:25 AM   #2
minifreak
Member#: 116914
2006 WRX Wagon
Obsidian Black
This would be a nice alternative to sourcing Spec B axles. If this was available a earlier I wouldn't have to buy a set of STi hubs just to run R180.
minifreak is offline   Reply With Quote
Old 09-01-2010, 01:33 AM   #3
mowgli29
Member#: 203438
GREAT post Suberdave! I've heard for wayyyyy too long now that "it just won't work," or "you have to get DSS hybrid axles."
Let me be the first to say, "THANK YOU!" for being such a pioneer. I'm certainly excited to put my set to good use, and I'd certainly think there are plenty of fellow members itching to do the same!
BTW, any idea where the best place to get boots would be? I actually went to most local places, as well as the dealership, and nobody had them. Certainly universal boots aren't my only option, are they? If so, know of any decent ones?
mowgli29 is offline   Reply With Quote
Old 09-01-2010, 02:53 AM   #4
kpluiten
Member#: 120273
06 WRBWRXWGN
Now with 100% more Spec-C
Sticky! Great work.
Old 09-01-2010, 03:04 AM   #5
181stLeader
Member#: 184183
1996 Impreza RSTi
V8 EJ207 Aerosim Carbon
Nice work! too bad I just installed 5x114.3 hubs this past weekend PM me pricing on the hybrid inner race. I may have somebody interested in this.
181stLeader is offline   Reply With Quote
Old 09-01-2010, 04:21 PM   #6
hybrid gti 2
Member#: 67004
02 vf30 pnp wagon
silver and cf
Oh nice. Thanx for posting that!
Sending pm
Old 10-15-2010, 04:42 PM   #7
nxwrxfx
Member#: 92011
02 EJ207 STi HTA68
05 EJ257 Baja 18G-XT
Awesome thread!
I agree this should be stickied!
PM'd as well!
nxwrxfx is offline   Reply With Quote
Old 10-16-2010, 09:44 AM   #8
fastwrx25
Member#: 126441
03 bugeye
much props for you to getting this done.
Old 10-20-2010, 07:44 PM   #9
tpc0531
Member#: 252936
Check your email, I'm interested is a set.
tpc0531 is offline   Reply With Quote
Old 10-20-2010, 07:59 PM   #10
M4c0770
Member#: 225851
07 Spec Wannabe
Limited in San Remo Red
Arrow
Nice job... I might be interested. Got Pm! rops:
M4c0770 is offline   Reply With Quote
Old 10-26-2010, 09:50 PM   #11
MRF582
Member#: 48219
. Always drive
the race line .
Can you post a top down (lengthwise) view of the R180 and Hybrid R160/R180 driveshaft assemblies next to each other? The axle lengths according to technical documents disagree greatly but they don't take the inner and outer joints into consideration. Perhaps the fully assembled dimensions are close enough.
Thanks.
MRF582 is offline   Reply With Quote
Old 10-26-2010, 10:56 PM   #12
mowgli29
Member#: 203438
Thanks.
Sorry, no pics here, but I wondered the same thing, so I did a test fit before fully assembling them...when the shafts are completely parallel to the ground, they should theoretically be "pushed in" the most. While they were indeed very close to bottoming out in the cups, there was a wee bit of room to spare, so I went for it.
I've had no issues yet, and have run them for 3500 miles so far.
Old 10-26-2010, 11:20 PM   #13
scby rex
Member#: 104878
02 wrxbastardchild
aw, MPS 2.34 breaking in
Sounds like a waste of money and time to me, why not just get the knuckles and be done with it. What happens when one of your rear axles snaps then you have to buy ten more. When you could just spend 150 bucks and get a new r180 axle.
Old 10-27-2010, 12:49 AM   #14
mowgli29
Member#: 203438
Maybe I'm taking your statement the wrong way, but it seems rather arrogant and bit ignorant. Take a second and think about it...
Personally, I wanted a halfway decent LSD in the rear, but I didn't want to have to run Brembos.
Yes, I realize a person could use the FHI rear 2 pots and group n "gravel rotors," but either way, that's added expense. Stock brake pads and rotors are WAY cheaper than Brembo stuff. In addition, you (generally) can't run smaller than a 17" wheel with Brembos, which = FAIL for those who rally. I know I have no desire to shell out the cash for 17" snow tires, either; my 16" blizzaks have plenty of life left.
Brembos also add weight, which is stupid if a person doesn't need/want the braking capabilities of the Brembos.
Lastly, I'm not concerned about the axles breaking. I don't drive hard enough to break them, at least not any time soon.
It's my DD; I want to keep maintenance costs low, keep it reliable, but have some fun with it too. Its all about compromises, and for some people, hybrid axles fit the bill.
Old 10-27-2010, 01:02 AM   #15
AcquaCow
Member#: 36838
2001 SRP RSTi
2011 DGM WRX hatch
Pretty awesome work, man!!!
The good news is, if you ever needed to replace one of those axles, you could probably swap those parts over to the new one anyways...
AcquaCow is offline   Reply With Quote
Old 10-27-2010, 01:20 AM   #16
hybrid gti 2
Member#: 67004
02 vf30 pnp wagon
silver and cf
From what I can figure between hubs, brakes and related parts. This idea can save $800. That could go toward other mods. Rear only has 30% braking power. This is a no brain-er mod. If you race, maybe the brembo setup might be slightly better. Or maybe a larger kit even better. It simply offers options that have been desired for some time. As well to get stronger parts and cost effective lsd.
I don't know about others but I have broken many trans and diffs. Yet to break an axle. slice a boot sometimes but never straight up kill an axle. front or rear. So if I have to hybrid a few parts to get what I want ok. That's not so bad in order to get stronger parts and save $800 on pretty parts.
Old 10-27-2010, 01:23 AM   #17
mowgli29
Member#: 203438
egg jackery. totally agree.
Old 10-27-2010, 05:26 PM   #18
MRF582
Member#: 48219
. Always drive
the race line .
What material is your hybrid race made from? How does it compare to the stock units?
What sort of secondary operations does your hybrid race under go if any? For example, cryo treating, case hardening etc.
How does the 04 STI inner race differ other than 6 ball bearings versus 8? Is the OD of the race the same as an 05 STI or is it the same as the WRX? How do the ball bearing diameters differ?
Also, can you PM me your paypal address?
Old 10-30-2010, 02:03 PM   #19
suberdave
Member#: 101865
88 GL-10 STi
first off i will see what technicial info i can get for you on the races...
how they differ from 04- reces. they use 8 balls rather than 6. the spline count is different on the 04- (30) than the 05+(32). im not sure on the ball size, i would have to check on that.
I dont think you understand what we are doing here...
And who said anything about buying 10 axles? I can stop by my local parts house and pick up a WRX axle for about $60. the other parts can be swaped onto that axle.
Anyhow i have more races if anyone else is interested...
-=Suberdave=-
Old 10-31-2010, 06:31 PM   #20
MRF582
Member#: 48219
. Always drive
the race line .
Material specs would be nice. It will give some indication of how the part will hold up as it's exposed to cyclical loading. In the mean time, I'll try to research what material most stock units are made up of.
Old 11-02-2010, 09:50 PM   #21
suberdave
Member#: 101865
88 GL-10 STi
Email from company that made the races...
The races are made out of chromoly steel billet. They are heat treated to provide more strength and toughness than an OEM part.
The specific alloy and heat treatment we use is proprietary.
-=Suberdave=-
Old 11-03-2010, 06:21 PM   #22
hustleshark206
Member#: 182227
2000 MPS Built RS
1991 Leggy Turbo EJ22t
Some people like me would like to do a STi drivetrain swap but want to keep their 5x100 wheels. I have a lot of $$ into my 4 pot setup and am not interested in Brembos either. This gives us an option to do both.
Cheers to you Suberdave
Out of curiosity can you pm me a price for a set of these? Thanks!
hustleshark206 is offline   Reply With Quote
Old 11-03-2010, 06:32 PM   #23
MRF582
Member#: 48219
. Always drive
the race line .
Sent my donation/gift.
I was hoping you'd say chromoly since that's what the OEM parts are made from. Just didn't want to suggest an answer to you and have you say 'yeah'.
BTW, did you talk to Marty at Raxles in Gainesville, FL? Great guy. He helped me a few years ago when I was there and was in the process of rebuilding my axles.
Old 02-21-2011, 06:00 PM   #24
02 wrx roar
Member#: 199600
Hey bud pm me aprice or where to get these im very interested
02 wrx roar is offline   Reply With Quote
Old 02-21-2011, 06:13 PM   #25
mowgli29
Member#: 203438
Shoot a PM to SuberDave, the OP. He might still have some for sale. I bought mine from him.
and, UPDATE: I've got ~10,000 miles on the hybrid axles (with SuberDave's inner races), and all is well. Not a hint of a problem yet....knock on wood.
Hybrid axles Jpizzzle Transmission (AT/MT) & Driveline 7 02-22-2010 01:55 PM
"The Missing Link" Discovered in Germany? Jard Off-Topic 55 05-21-2009 04:21 AM
How did I miss "The Wire" for so long? Rice & Gravy Off-Topic 19 01-05-2007 06:56 PM
WTB:SOCAL: Hybrid Axles xplane Private 'Wanted' Classifieds 0 05-23-2006 12:25 PM
Do you miss "the monkey?" obyone General Community 6 11-15-2002 06:01 PM
