Welcome to the North American Subaru Impreza Owners Club Saturday February 28, 2015
Old 08-22-2010, 12:19 PM   #76
yo_its_ok
Member#: 6493
I use a snap-on 1" hole tool and some soapy water when cutting into SS to keep the weld area clean and cool the bit. Best bet is to get the hole just right to fit snug, if its too loose, tack on one corner and bring it up, and fill in the "slight" gap you may have.
yo_its_ok is offline   Reply With Quote
Old 08-22-2010, 01:02 PM   #77
Crazy_pilot
Member#: 164242
1992 SVX
2008 Spec B
Sounds good. My system is only mild steel, so it's a bit easier to work than an SS one.
Crazy_pilot is offline   Reply With Quote
Old 08-29-2010, 01:35 AM   #78
Crazy_pilot
Member#: 164242
1992 SVX
2008 Spec B
Finally finished the front half of my system. See the first page of this thread for the cat-back parts.
2" piping with an offset cat from Magnaflow:
I heart welding
Two of those under the car:
Flanges I cut on the CNC mill at school welded to a Magnaflow 2-1 main cat. Yes, I have 3 converters.
Left side pipe tacked in place:
Right side pipe being finish welded:
All done the front pipes:
Old 08-29-2010, 01:39 PM   #79
XplicitRacingDesign
Member#: 242434
2004 WRX STi
Blue/Charcoal Grey 2 tone
Originally Posted by sidewayz View Post
built this today. Mazdaspeed Protege downpipe for a t3/t4 system.
lots o pie cuts here.
that tight radius bend going to the flange looks like it was tons of fun to make! haha. props to you and your patience.
XplicitRacingDesign is offline   Reply With Quote
Old 08-29-2010, 04:26 PM   #80
yo_its_ok
Member#: 6493
O man, Mazda MP3, I had to make one for a customer, damm water neck was so damm close, I made an extension on the water neck to move the hose 3" forward and 2" towards the passenger side with a slight downward kick just to clear the 3" d/p, and yes mad pie cuts.
One of my tougher jobs on a big turbo B16 in the shop.
Old 09-07-2010, 11:43 PM   #81
Krang
Member#: 134272
Chapter/Region: HIIC
2002 WRX Wagon - WRB
ej207 v8 vf37
This seems like the right place to ask this... I am looking to reduce the overall volume of my exhaust system, without using cats. I plan on using a 3" borla hush catback to accomplish this, but I'm looking for an even quieter ride. What would be the best product to use to reduce decibles? Muffler, or a resonator? What are the differences? It would need to be a 3" design and I am looking to maintain flow while decreasing noise.
Krang is offline   Reply With Quote
Old 09-07-2010, 11:47 PM   #82
RooSTi93
Member#: 228032
2009 STi
Anyone have a side exit exhaust by any chance
RooSTi93 is offline   Reply With Quote
Old 09-08-2010, 02:00 PM   #83
albersondh
Member#: 196882
08 WRX
Sort of. I built a 4" dp that connects to a 4" cut out. The cut out is obviously side exit 4". This is on my 08 WRX.
albersondh is offline   Reply With Quote
Old 09-08-2010, 11:40 PM   #84
yo_its_ok
Member#: 6493
I've done a side exit, but not on a Subie. I used a Vibrant race muffler in place of cat, and a Vibrant Ultra Quiet oval resonator on my Sentra, was quieter than my VRS exhaust w/ Magnaflow muffler.
Old 09-11-2010, 02:45 AM   #85
jzk25
Member#: 179120
Lowmount manifold.
Moroso warranty revoked.
Turbo GSX1400.
EG33 WRX.
Plenty more.
jzk25 is offline   Reply With Quote
Old 09-11-2010, 04:03 AM   #86
jzk25
Member#: 179120
My 68 Toyota Crown 2JZ exhaust manifold.
TO4Z EJ25 Headers.
Old 09-11-2010, 04:51 AM   #87
jdmSpecC760
Member#: 151598
04 Flared STi
i like this thread some amazing work
jdmSpecC760 is offline   Reply With Quote
Old 09-11-2010, 05:43 AM   #88
jzk25
Member#: 179120
Name dropping.
Old 09-11-2010, 11:56 AM   #89
Srtkr
Member#: 228025
07 Forester XT
Ill post my buddies side exit, on his sti in a bit
Srtkr is offline   Reply With Quote
Old 09-11-2010, 10:51 PM   #90
Krang
Member#: 134272
ej207 v8 vf37
Originally Posted by jzk25 View Post
Name dropping.
So sick. Not as sick as the lowmount H6, but close!
Old 09-14-2010, 01:09 AM   #91
Crazy_pilot
Member#: 164242
1992 SVX
2008 Spec B
EG33 WRX.
Details/build thread on this anywhere? This excites me in ways only a twin turbo H6 can.
Old 09-14-2010, 05:56 AM   #92
jzk25
Member#: 179120
It's in hiatus. Waiting for the owner to get cashed up/motivated/etc.
Old 09-14-2010, 02:10 PM   #93
rickybobby2
Member#: 176068
Dont really know how to post pictures so if this works here's a couple
By obiwankenoji at 2010-09-14
rickybobby2 is offline   Reply With Quote
Old 11-09-2010, 07:25 PM   #94
crazychrisra
Member#: 259720
1997 Legacy GT-B
Originally Posted by bjm View Post
They had the choice of either of these and chose the top set because of the larger primary pipe diameter.
Same two sets here. The set they used is on the left
here is the logo cast onto the flanges
Who makes this header? I just picked up the unequal length version, but haven't found any information on it.
Thanks,
Chris
crazychrisra is offline   Reply With Quote
Old 11-11-2010, 11:33 AM   #95
edub32
Member#: 263209
Wow exhaust looks great
edub32 is offline   Reply With Quote
Old 11-13-2010, 12:13 AM   #96
biggreen96
Member#: 12535
vf39 93 Legacy Wagon
92 Legacy Rally EG33'd
Awesome, awesome work you guys. I am to the exhaust stage in my EG33 Legacy Rally Car project. I'm a total exhaust noob. I need to whip up a tighter fitting exhaust than the stock Y pipe but am unsure of the material to use. I am going to reuse the stock cast headers to retain that durability. So what is a good material to use? I want to keep it cheapish so I can build 2 and have a spare.
biggreen96 is offline   Reply With Quote
Old 11-13-2010, 05:59 PM   #97
Crazy_pilot
Member#: 164242
1992 SVX
2008 Spec B
Check out the system I did for my SVX (post #5 and 78 in this thread). I just went with off the shelf mild steel tubing. If you don't want to run cats then the whole thing would be quite inexpensive.
Old 11-14-2010, 01:05 AM   #98
faucon
Member#: 218575
Here's mine, TBE on my 04' FXT. The exhaust line(but DP and piping is) isn't all tig weld but the goal of the project was to learn how to tig:
Stock Tip on Dynomax muffler
faucon is offline   Reply With Quote
Old 12-05-2010, 06:39 PM   #99
King of Poop
Member#: 177880
2002 Wrx Wagon 6sp
Where can I get some cake
WOW!!! Lots of good work. I wish some of you guys were closer to me. I'd offer some powder coating work
King of Poop is offline   Reply With Quote
Old 12-06-2010, 02:21 AM   #100
tobylazur
Member#: 150289
2006 SV650N
1972 Travelall
I'm interested in both of these. Recently moving, and the place I'm moving into I need a quieter exhaust. Did run the resonator before or after the race muffler?
Also, I'm really interested in making a side exit exhaust for the wagon too.
tobylazur is offline   Reply With Quote
FS: 2 STI hood scoops, stock STI exhaust, 2.5RS/TS/OBS custom exhaust, and more! dlong27 NESIC Private Classifieds 18 03-12-2010 04:11 PM
Another Exhaust thread, sorry:Building a custom performance exhaust? agilitymaneuver Normally Aspirated Powertrain 1 09-02-2008 01:59 AM
Custom intake thread Machine Age Victim Member's Car Gallery 4 04-27-2004 03:25 PM
Custom Exhaust - Skips Exhaust Plaistow NH WRXBanish New England Impreza Club Forum -- NESIC 3 11-14-2003 07:50 PM
Trade! my custom Exhaust on your RS Exhaust! SONofSAM Bay Area Impreza Club Forum -- BAIC 7 04-13-2002 03:15 PM
