Old 09-09-2010, 02:52 AM   #1
CKxx
Member#: 33458
Your BOV sounds lame
93 RX7+09 Forester
Default 2003 WRX Muffler ---> 2007 2.5i
Will a 2003 WRX muffler fit a 2007 2.5i?
CKxx is offline   Reply With Quote
Old 09-09-2010, 03:16 AM   #2
J-Chow
Member#: 104722
2006 2.5i - Gray
NO MORE MODS! I'm Done!
axelback only. Catback requires rotating of the flange or something like that iirc.
J-Chow is offline   Reply With Quote
Old 09-09-2010, 09:07 AM   #3
Gr3en
Member#: 160991
05 Corn Burner
Dirt Silver?
^^^ What he said.
Gr3en is offline   Reply With Quote
Old 09-09-2010, 11:11 AM   #4
RaineMan
Member#: 256727
2007 2.5I Wagon
Is it any louder to just do a muffler swap? I love the dual outlet stock mufflers that the older WRXs had and want a little bit more sound.
RaineMan is offline   Reply With Quote
Old 09-10-2010, 02:21 AM   #5
Audi20Tdriver
Member#: 206040
2009 Audi A4 2.0T
APR Stage 1
I would recommend searching the forum for wrx muffler chirp. Back When I had my 2005 RS I needed a WRX muffler for about a month between the loud crappy obnoxious setup I had for my first exhaust mod.. and the stromung setup with borla replicas I ended up getting.. Anyhow.. back then it was much more prevalent to have WRX mufflers from bug eyes swapped to the RS because there was only a year or two in age difference between the 04/ 05 RS and the WRX . It seems that lots of people reported the dual tipped WRX muffler making a chirping sound like a bird. Once the larger single tip WRX came out on the 05, the chirping went away.. the WRX axleback had basically zero impact on my car other then the larger silver tip looked nicer then the little RS one. The chirping was a result of usage on the RS..
Audi20Tdriver is offline   Reply With Quote
Old 09-10-2010, 02:29 AM   #6
EdHilario
Member#: 137398
2004 Impreza 2.5RS
Platinum Silver Metallic
My friend with a SpecR1 (Sonic Yellow 03 WRX) put his axleback on his sister's 07 2.5i with no problems. Just be sure to get a new gasket.
EdHilario is offline   Reply With Quote
Old 09-10-2010, 06:58 PM   #7
Audi20Tdriver
Member#: 206040
2009 Audi A4 2.0T
APR Stage 1
^ there will def be a chirp whether she has heard it or not yet. It is in the tip design.. can happen on any 02 -04 WRX axleback which is the twin tip years. Just thought I'd throw that out there to research.. most of the newer subaru crowd is prob not aware of such issues. Is it a big deal? that's up to the user..
Old 09-11-2010, 08:13 PM   #8
kero
Member#: 94299
2007 2.5i wagon mutt
Yes, I have a 04 wrx axleback that I had for a period of time and it chirped on start up, turn off and after revving the engine and idle falls down.
It was not that annoying, funny actually.....
Most interesting though is that with my UEL setup and no cats, the 04 wrx muffler had more burble than the 07 wrx axleback I have on now.
kero is offline   Reply With Quote
Old 09-12-2010, 10:06 AM   #9
CKxx
Member#: 33458
93 RX7+09 Forester
Thanks guys. It is for my girlfriend. She just picked up a 2.5i and I've got a couple WRX exhausts in my basement. She asked if I could make it a tiny bit louder.
Old 09-13-2010, 03:38 AM   #10
fenrizwolf
Member#: 188449
2007 2.5i NBP
Do Japanese want usdm?
Could you make mine a tiny bit louder too? lol
fenrizwolf is offline   Reply With Quote
Old 09-13-2010, 01:58 PM   #11
A1y50n
Member#: 130194
2007 Impreza 2.5i SW
Newport Blue Pearl
I have an 04 wrx axelback and truthfully, it's not any louder nor do I feel a difference in power. If anything, it's asthetically pleasing.
A1y50n is offline   Reply With Quote
Old 09-13-2010, 06:17 PM   #12
Audi20Tdriver
Member#: 206040
2009 Audi A4 2.0T
APR Stage 1
ya you won't notice anything from a WRX muffler. The 04- 07 STi might make that very SLIGHT difference, but on a bone stock system even that wont do much.
removing a resonator with one of those mufflers esp the STI would increase the sound.. the best thing to make the car a bit louder is to remove the intake silencer / resonator... or get an intake.. but I'm not a fan of what it does to the tq and that's a whole different thread..
Old 09-14-2010, 12:12 AM   #13
bmobs06
Member#: 252783
just do a full sti catback. im running that on my 06 obs and it's purrrrfecttt.... a little louder than stock and has a nice pur to it. yeah, i did have to cut the midsection and extend it about 3inchs but it's not as hard as people complain it to be.
bmobs06 is offline   Reply With Quote
Old 09-14-2010, 01:03 AM   #14
CKxx
Member#: 33458
93 RX7+09 Forester
I honestly may have two mufflers...I'll check tomorrow.
I will try the WRX muffler alone at first and see what she says. I'll definitely keep the STi version in mind. Thank you.
Old 09-14-2010, 11:23 AM   #15
larson701
Member#: 245655
2006 Impreza 2.5i
Bmobs06,
Was the section you added steel or SS?
larson701
larson701 is offline   Reply With Quote
Old 09-14-2010, 12:46 PM   #16
bmobs06
Member#: 252783
here's what i did; i dicked around with adapters at first cause that's what previous people did on their diy's. then it struck me duhhh...
i only had it clamped that day, the next day i got it welded. i only did the sti catback cause i only bought it for $80 with the downpipe.
Old 09-14-2010, 02:25 PM   #17
larson701
Member#: 245655
2006 Impreza 2.5i
Thanks! Many of the catbacks are 304SS, something I cannot work with. Clever kludge. The rust where your addition was made tells me that I could weld an extension to the pipe at some point.
My daughter and I work on her 2006 Impreza together. I am researching 'inexpensive' exhaust modifications. Making the car sound better is at the top of the list.
Old 09-14-2010, 03:21 PM   #18
bmobs06
Member#: 252783
if you can get a cheap wrx or sti midsection extending the pipe doesnt take much effort. all you got to do after is figure out what kind of axle back you want.
Old 09-14-2010, 07:45 PM   #19
swede978
Member#: 89233
99 RS Aspen White
08 Outback SWP
You need to get a "Thank you!"
Smart idea I just wish I would have thought about it.
swede978 is offline   Reply With Quote
Old 09-14-2010, 08:02 PM   #20
berylthemessiah
Member#: 227205
2007 Impreza 2.5i
this is what i did with a 05 wrx catback on my 07 2.5i, it made it a little louder but nothing to noticable, i got the catback for free and cost like 30-40 bucks to have a shop weld in the extension piece in place of the chamber, i also prefer how the tip looks
berylthemessiah is online now   Reply With Quote
2007 2.5i muffler drumaboi628 Normally Aspirated Powertrain 31 01-01-2008 08:20 PM
2007 2.5i muffler drumaboi628 Normally Aspirated Powertrain 0 12-29-2007 01:17 AM
2007 2.5i muffler drumaboi628 Subaru Conversions 5 12-28-2007 01:50 AM
2007 2.5i muffler stainless tip stormn Vancouver Impreza Club Forum -- VIC 10 08-25-2007 04:26 PM
2006 Impreza 2.5i 4eat -> Leagacy 2.5i 4eat w/ SPORTSHIFT cynt Subaru Conversions 0 07-23-2006 11:04 PM
Message Board Statistics All times are GMT -4. The time now is 04:18 PM.
