Vancouver Impreza Club
Go Back   NASIOC > NASIOC Chapters > Vancouver Impreza Club Forum -- VIC > VIC Vendor Classifieds
Closed Thread
Old 09-01-2010, 03:49 PM   #1
dalesalignment&brake
Vendor Sales Rating: (47)
Member#: 173316
'13 BRZ
Default RCE/GTWorx updates for Sept 1st.
RCE Yellow Coilsprings are here, GTWorx Bilsteins in transit. We are hoping to have the kits shipping out by Sept 15th. A few spots are open at intro-pricing.
GTWORX struts by Bilstein/RCE Yellow coilsprings-GH chassis '08+WRX
INTRO-PRICE DROP-$1450 shipped
Finally something available for the '08 WRX where you don't have to break the bank.
Bilstein struts will transform your WRX into a cone eating monster when matched to a set of RCE Yellow springs.
Details:
Front:
Monotube, Gas, inverted struts.
NON DAMPING ADJUSTABLE.
For use with OEM springs or lowering springs and top hats.
Rear:
Monotube, Gas, shock absorber.
Adjustable sir CLIP for + 10 or -10mm rear height.
For use with OEM springs or lowering springs.
Shocks will come with dust covers and be powder coated.
and add a set of these:
RCE Yellow Springs
Specifically engineered for the '08+ WRX chassis- specs to come but very similar to RCE Yellows for the STI.
RCE Yellow Springs for '08+STI- in stock by Sept 15th
Following the release of our popular "Regular Guy" springs, RaceComp has produced a more aggressive lowering spring for the 08+ STI. These new springs lower the car approximiately 15mm and include new replacement bumpstops to maintain as much travel as possible on the lowering sensistive GR Impreza chassis. Spring rates are an aggressive 340 lbs/in front and rear.
Teaser pic courtesy of Myles at Racecomp Engineering
Following the release of our popular "Regular Guy" springs, Racecomp Engineering has produced a more aggressive lowering spring for the 08+ STI. These new springs lower the car approximately 15mm and include new replacement bumpstops to maintain as much travel as possible on the lowering sensitive GR Impreza chassis.
Spring rates are an aggressive 330 lbs/in front and 335 lbs/in rear. With a stance to match the performance, these springs utilize the knowledge RaceComp has gained from years of GR chassis set-up experience to maximize handling, retain ride comfort, and improve the look of your Impreza.
Racecomp Engineering’s goal was to help cure the crippling understeer that adds to lap times at the track and autocross course. Studying the design of the new GR suspension, a more aggressive performance spring has been produced that retains available bump travel, matches the OEM dampers, and works in conjunction with the new rear motion ratio. The result is a car that handles extremely well from corner entry to corner exit.
RCE swaybars are here!!!!!
Racecomp Engineering 25mm Swaybars for STi (2004-07)- pm for pricing
The Racecomp Engineering swaybar set will work well with stock springs, lowering springs, or coilovers. The settings for the front bar are 25.5 and 28.5mm. The settings for the rear bar are adjustable from 25.5, 27.0 and 28.5mm. You can run these and not have to go to a bar that is actually 27mm thick. 25.5mm physical diameter. 4142 Chrome Moly Heat treated and cold finished. Ends are hot forged on a 125 ton press. Includes polyeurathane bushings and lube. Washer tabs on front and rear to prevent walking.
Racecomp Engineering GR Sway Bars-
pm for pricing
These front and rear 25mm hollow 2 position adjustable swaybars are a must have for your 2008 and later Impreza STI. Featuring carefully chosen swaybar rates and a tubular design, these swaybars weigh less than other solid bars with a similar stiffness.
Racecomp Engineering GR Sway bars for the 08+ STI. Rear bar will fit the 2008+ Impreza / Impreza WRX.
Mounting Solutions
Introducing the first in an all new line of parts from GTWorx, the sister company of Racecomp Engineering. Drawing upon the extensive chassis design knowledge and experience that comes from designing several suspension and brake components with RCE, GTWorx is proud to announce their Camber Adjustment Pillowball Mounts for 2008+ Subaru Impreza GR chassis and 2005+ Legacy. These camber plates are currently intended for coilovers only, however, testing is underway for use with OEM style fixed perch struts.
Key features of these new front camber plates include a very low stack height, which means that these top mounts are non-raising at most camber settings. For a coilover at a given ride height, the user will have MORE bump travel with the GTWorx plate when compared to most other currently available plates on the market which raise the car substantially.
In addition, +.8 degrees of caster are built in to the camber plate, which helps minimize dynamic camber loss in a turn for the camber challenged Impreza chassis.
These lightweight alloy camber plates use the same high quality PROVEN pillowball bearing used in the popular Racecomp Engineering Camber Plates, which are known for smooth, long lasting, and quiet operation. Hardware is zinc coated stainless steel. Each bearing is rated at 37,000 lbs radial and 7,730 lbs axial force.
A fact worth noting is that the relatively straightforward and simple design means that these durable plates are available at a realistic price much cheaper than the popular Racecomp Engineering camber plates.
To be used with coilovers
Kool Brake Kit GD STI-in stock
This kit was designed to cool and vent the braking system, thus reducing rotor temperatures. Initial testing at Summit Point Raceway showed up to a 200 F drop in rotor temperature when using aggressive pads. Testing was done with Pagid Blue RS-42, Pagid Yellow RS-19 and the new RS-29 brake pads. Designed to work with both stock STi rotors and any aftermarket 2 piece rotor, this kit is available now.
The Kool Brake Kit includes 12 feet of high quality, motorsport grade, high temperature hose far better then other options on the market. There is no need to upgrade. Stainless steel hose clamps are also included.
The RaceComp Engineering Kool Brake Kit is now exclusively offered in dry carbon fiber to improve unsprung weight savings. The spindle ducts are considerably lighter then the OEM dust shields that are replaced during installation
RCE Tarmac Zero and Tarmac 2 in stock for WRX and STI
RCE Yellows and Regular Guy springs in stock for '02-07 WRX and STI('02-03 WRX will need to update to '04+tophats)
We also have Whiteline, DBA, Hawk, STI GrpN in stock
We will match or beat any Canadian vendor pricing on Whiteline, DBA and Hawk. Email [email protected] with a competitor's quote.
__________________
[CENTER][CENTER][SIGPIC][/SIGPIC][/CENTER][B][I][COLOR="Red"]"We do pricing a little differently. Every price you see includes the shipping cost to our office(Surrey, BC), duties and exchange rate . This creates a built in cost savings, no hidden fees, and less hassles. The best part is we still have a price match guarantee!"[/COLOR][/I] [/B]
[COLOR=black]Service Center: 604 530 9160 [/COLOR] [COLOR=black]Email- [/COLOR]
[/CENTER]
dalesalignment&brake is offline
Old 09-09-2010, 08:17 AM   #2
Member#: 173316
'13 BRZ
Bump.
Check out the Dale's deal of the day thread.
RCE springs are on sale.
__________________
[/CENTER]
Old 09-12-2010, 02:53 PM   #3
j y
Member Sales Rating: (7)
Member#: 8829
GRB STI
Can we start scheduling GR yellow installs yet?
j y is offline
Old 09-12-2010, 05:06 PM   #4
jason t
Member Sales Rating: (3)
Member#: 37199
I will be calling everyone when the springs are at the shop. We can start booking then.
jason t is offline
Old 09-13-2010, 03:22 PM   #5
Petrie
Member Sales Rating: (8)
Member#: 1260
09 STi, DGM
04 WRX Stage 2, red
Get thee behind me Jeff
Petrie is offline
Old 09-13-2010, 04:05 PM   #6
j y
Member#: 8829
GRB STI
Mmm it's only been over 7 months since signing up for them. Even more antsy now that they're actually DONE.
j y is offline
Old 09-13-2010, 04:19 PM   #7
Petrie
Member#: 1260
09 STi, DGM
04 WRX Stage 2, red
Now it's about timing. I have the Powerflex ALK to be fitted first and then the springs. I have to time it right so that I only need one alignment. I'm fed up of having the 04WRX (on all season tires) out corner the STI.
Hopefully it's all done by the weekend.
Petrie is offline
Old 09-13-2010, 06:02 PM   #8
Member#: 173316
'13 BRZ
Anyday now,
come on fedex, people are waaaiiiittttiiiinnnnggg for these.
__________________
[/CENTER]
Old 09-13-2010, 10:58 PM   #9
Member#: 173316
'13 BRZ
RCE says they are in transit
__________________
[/CENTER]
Old 09-14-2010, 09:34 PM   #10
Petrie
Member#: 1260
09 STi, DGM
04 WRX Stage 2, red
ALK bushings are in (thank you RR, again).
Now just waiting on FedEx.
Petrie is offline
Old 09-17-2010, 02:10 PM   #11
Petrie
Member#: 1260
09 STi, DGM
04 WRX Stage 2, red
Are we there yet?
Petrie is offline
Old 09-17-2010, 03:01 PM   #12
alcoolaid
Member Sales Rating: (36)
Member#: 134949
'07 SWP STi
Instagram | arthurlam89
Kind of OT but I remember a while ago you guys were trying to see if there was a market for corner balancing. Is that something you're going to pursue/offer a service in the future?
alcoolaid is offline
Old 09-17-2010, 04:20 PM   #13
HRCboy
Member Sales Rating: (4)
Member#: 167075
08 STI & 999R
Last time I visited Jason.... the shop next to them has cleared out... so all the empty space is available now and it think it's in the works.
Can't wait... one stop shop for all your suspension needs!
HRCboy is offline
Old 09-17-2010, 11:14 PM   #14
Member#: 173316
'13 BRZ
RCE Yellow springs for GR('08+STI) will be at the shop Monday and will be ready for pick-up Tues.
I will call the guys who wanted installation to make appointments.
Finally they are here
__________________
[/CENTER]
Closed Thread
RCE/GTWorx updates, tons of Whiteline, DBA and Hawk in stock dalesalignment&brake VIC Vendor Classifieds 0 08-27-2010 10:12 PM
Attn. '08+WRX owners-$1350-GTWORX struts by Bilstein/RCE coilsprings inside dalesalignment&brake VIC Vendor Classifieds 11 05-25-2010 04:49 PM
FS: 08-10 WRX RCE T2 Coilovers w/GTWORX Front Camber Plates SlidewayzRacer Suspension/Brakes/Handling 2 05-07-2010 06:39 AM
WTB: RCE tarmac 2 with Gtworx camber plates Carbon888 Private 'Wanted' Classifieds 1 03-14-2010 11:48 AM
RCE/GTWorx Winter Install Specials GTWORX.com MAIC Vendor Classifieds 16 11-26-2006 01:52 PM
