Old 09-14-2010, 01:22 AM   #1
CKxx
Member#: 33458
Your BOV sounds lame
93 RX7+09 Forester
Default Has anyone deleted the factory oil cooler?
I parts-washed my oil cooler and it is starting to scare me that I can't get all the fluid back out. I didn't spin a bearing or anything, but the cooler was pretty grimey. Is there any way to just not use it and run an aftermarket cooler instead?
Obviously the coolant lines can just be bypassed. Has anyone made a way to attach a thermostatic sandwich plate straight to the block?
EDIT: Found my answer. Part number 15018AA050. Oil feed pipe from a 2.5i.
CKxx is offline   Reply With Quote
Old 09-14-2010, 01:30 AM   #2
ScoobyAficionado
Member#: 36575
'04 STi
Yes, mFactory, Greddy, etc. all make kits that can replace the stock oil warmer. You'll have to plug the cooling line going to it.
ScoobyAficionado is offline   Reply With Quote
Old 09-14-2010, 02:08 AM   #3
CKxx
Member#: 33458
93 RX7+09 Forester
Are you describing the sandwich adapters they make? They need to be bolted to the bottom of the factory cooler/warmer. I've already got one of those.
The bolt that holds the stock cooler on has male threads on both ends. The block is female threaded. You could just stick a sandwich adapter on the block, but you would need a custom threaded tube to hold it there.
Old 09-14-2010, 01:59 PM   #4
StandardSti
Member#: 171471
2002 35r wrx
You can get rid of it we do it all the time. Just go to the dealer and you can buy
part# 15018aa050. Its cost $5 and you just screw in the block and then screw the oil filter on. Then you just need to jump a hose from the water pump to the fitting in the block..
StandardSti is offline   Reply With Quote
Old 09-14-2010, 09:36 PM   #5
dexterous
Member#: 23553
2005 STI - Insanity!
2014 WRX - Daily
As you can see form the above pict, I dont have a factory oil cooler any more on my STI. The adapter is a thermostatic Mocal (200F) which works really well. I had to notch the oil pan just ever so slightly (just the edge of the lip) so that the adapter would fit correctly.
dexterous is offline   Reply With Quote
Old 09-15-2010, 01:26 AM   #6
CKxx
Member#: 33458
93 RX7+09 Forester
That is exactly what I want to do. I went and found a factory C6 Z06 oil cooler today, now I need that thermo plate. What thread size is the WRX/STi?
Old 09-15-2010, 12:00 PM   #7
04grocerygetter
Member#: 226522
2004 WRX Wagon
I'm thinking about doing this as well with my hybrid motor, since the stocker is probably full of metal... Only reason though would be cost/value because the oem is ~$200. Mine is going to be a DD so I dont think I necessarily need aftermarket.
04grocerygetter is offline   Reply With Quote
Old 09-15-2010, 11:25 PM   #8
theonlygreat
Member#: 65916
1996 Impreza WRX
Thread size is 20 x 1.50mm. Many adapters made for Hondas from around 1988-2000 should work as they use the same oil filter size as Subaru.
theonlygreat is offline   Reply With Quote
Old 09-16-2010, 03:12 PM   #9
dangerousatom
Member#: 70710
2002 04STi Swaped RS
w/PPGS & 02 Wagon w/PPGs
I dont run the cooler on either of my cars as well.
You need a "NA oil filter stud" or "NA oil stud" You can get it at the dealer for a few bucks or go to a junkyard and pull one off a NA car.....most likely the wont even charge you for it.
dangerousatom is offline   Reply With Quote
Old 09-16-2010, 07:23 PM   #10
04grocerygetter
Member#: 226522
2004 WRX Wagon
/\ So you deleted it completely and now have no oil cooler?
I live in AZ and I think oil temp is one of the reasons my rod bearing began to fail. So is it safe to run with no oil cooler at all?
Old 09-16-2010, 09:46 PM   #11
KillerBMotorsport
Member#: 198281
2005 WRX/STi
WRB of course
It's more a heater than a cooler. Your oil will take longer to come up to temperature. It will also stabalize temperatures somewhat, but not nearly as much as a conventional oil cooler. If I lived in a cold climate I'd be hesitant to pull it off, but down south I wouldn't be concerned at all.
Old 09-16-2010, 10:06 PM   #12
seanathanq83
Member#: 173241
2002 s256 twinscroll
now with one more gear
i just ordered mine, i am going to bend the factory hard line for a little cleaners look, will get some pictures when i get around to it
seanathanq83 is offline   Reply With Quote
Old 09-16-2010, 10:32 PM   #13
dangerousatom
Member#: 70710
Hell Ya! that thing is a joke! With my custom setup my oil temps usually run cooler than my water temps anyway.....this is not a daily driver....... I also run a remote oil filter so I have a qt extra oil in the loop and the 5 feet of 3/4" braided hose acts more like a cooler than the stock water loop one ever would. I have an oversized custom radiator and the water box that the turbo feeds from that holds nearly 10x the stock box h20.
But at the same time in my daily driver ( 97 OBX w/03 WRX swap )I got rid of the oil cooler too. I have had zero issues with oil temps and I dont burn or use up oil more than 1/4-1/2 qt every 3k miles
http://forums.nasioc.com/forums/show...highlight=swap
Old 09-16-2010, 10:52 PM   #14
bhhamblin
n00b Moderator
Member#: 99397
15 WRX, 83 DR30,
93 R32 GTS-T, 93 R32 GTR
I got rid of the factory oil cooler on my car. I plugged the galleys in the block and also tapped fitting in the water pump and put a plug in it that way I didnt have to run that silly jumper coolant line.
You could do that or get an NA water pump, it has no fitting for the oil cooler.
bhhamblin is offline   Reply With Quote
Old 09-17-2010, 02:16 PM   #15
burkoser
Member#: 257985
2004 wrx TDO5 16G
18L
Default mishimoto oil cooler
I recently just purchased a mishimoto oil cooler with the sandwich plate adapter and lines etc. ive researched trying to find some instalation details but havent had any luck if anyone has used this oil cooler and succesfully installed it please post pics or some instructions lol mishimoto website has install guide for 350z and im thinking its prolly the same concept just wanna make sure. thanks
burkoser is offline   Reply With Quote
Old 02-03-2011, 10:35 PM   #16
methaddict
Member#: 159738
2004 WRB STi
Full Race TS, BW 8374 EFR
Can you post pics of the fitting you put into the water pump?
methaddict is online now   Reply With Quote
Old 02-04-2011, 08:50 PM   #17
slowmike
Member#: 24890
2002 Jackwagon
WRB GG
Where did you get that intercooler?
slowmike is offline   Reply With Quote
Old 02-04-2011, 08:58 PM   #18
slowmike
Member#: 24890
2002 Jackwagon
WRB GG
Last time I replaced my bottom end, I left the oil warmer off too and got a nipple that lets me install the filter directly to the block like an NA car. I was told that it would net me 5 more PSI in oil pressure however, I can't substantiate this claim as I have no oil pressure gauge. I can say that the engine hasn't eaten any rod bearings since I did it.
Old 02-04-2011, 09:11 PM   #19
dangerousatom
Member#: 70710
That is a Mazda RX7 FMIC from Ebay. I think I payed $149+s/h
........Just tigged on some mounting tabs and done
Old 02-04-2011, 09:16 PM   #20
the suicidal eggroll
Member#: 51961
2005 STi
Same here, oil pressure is solid, oil temperature is solid. Oil warmup doesn't seem to take any longer than it did with the factory warmer/cooler. Overall I'm happy with my decision.
Old 02-04-2011, 09:34 PM   #21
STimedic
Member#: 104765
02 STi :D
2011 PRP FXT T
^Will be emulating his oil cooler setup!
STimedic is offline   Reply With Quote
Old 03-23-2015, 01:33 PM   #22
shamrock 05
Member#: 120057
2015 WRX (base) 6spd
Well when Subaru switched to the GR chassis, I believe that only the STi came with a "oil cooler" and the WRX did NOT.
shamrock 05 is offline   Reply With Quote
Old 03-23-2015, 05:18 PM   #23
sense of nature
Member#: 112759
2002 STi Mikey Tuned
SexyRP
Uhhmmm....4 yr old thread bump?
Old 03-24-2015, 05:31 PM   #24
chmielewskityler
Member#: 413778
Im acually looking to do a delete and i called to order the part and they said this part number doesnt exist.
chmielewskityler is offline   Reply With Quote
Old 03-24-2015, 06:12 PM   #25
ghulands
Member#: 409793
ghulands is offline   Reply With Quote
Need a factory oil cooler for an 02' wrx that has not spun bearings. 240sxguy Private 'Wanted' Classifieds 1 01-03-2010 10:41 PM
has anyone tried the factory tweeters for legacy in an impreza turbocolin Car Audio, Video & Security 1 12-30-2004 09:55 PM
Has anyone packaged together a oil cooler kit for the WRX? BIGSKYWRX Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 21 04-12-2004 06:39 PM
Factory oil cooler vrg3 Private 'Wanted' Classifieds 3 01-12-2004 02:04 PM
Has anyone installed the oem oil cooler? BongMan Bay Area Impreza Club Forum -- BAIC 0 03-01-2001 05:18 PM
