Welcome to the North American Subaru Impreza Owners Club Monday July 6, 2015
Old 09-09-2010, 09:39 PM   #1
00LGTP
Member#: 172618
2000 RS
BRP
Default 05+ manifold project
i am currently in the process of putting a 07 2.5i IM on my 2.5rs.
im pretty sure i have everything i need planned out, just need to get parts and physically do it.
i have found very little info about people doing this, which is why i wanted to see what info you guys have obtained.
any info will be helpful, im open to all suggestions.
00LGTP is offline   Reply With Quote
Old 09-11-2010, 01:35 AM   #2
williaty
Member#: 71092
2005 2.5RS Wagon
Regal Blue Pearl
The only difficulty is in mounting the throttle since you have a cable throttle and the 05+ IM is for DBW. There's some brackets and things you'll have to have custom fabbed at a machine shop to allow the cable throttle to function.
Old 09-12-2010, 10:33 PM   #3
wmdoucette
Member#: 192709
2007 2.5iSE Wagon CG
2001 2.5RS Coupe RBP
and fab some sort of port for the Idle air to flow through. My best idea right now is to hog out the hole in the TB, tap an AN Pipe-flare fitting in and do the same somewhere on the intake manifold.
wmdoucette is offline   Reply With Quote
Old 09-12-2010, 10:34 PM   #4
williaty
Member#: 71092
2005 2.5RS Wagon
Regal Blue Pearl
Isn't the entire idle-air apparatus integrated into the throttle body?
Old 09-14-2010, 11:40 PM   #5
00LGTP
Member#: 172618
2000 RS
BRP
i compared gaskets and came to the conclusion that my stock RS TB will bolt up, but that stupid IACV passage has to be in the way.
i have a TB spacer, so i block it off on the manifold side, drill a hole/install fitting, run a hose from that fitting to the IM plenum.
done!
cable will be easy, small bracket.
the map sensor!
im going to port out on of the EGR holes, only need about a 1/8" all the way around, polish it up nice and pray i did a good job and that O ring will seal. i can always use sensor save gasket sealer.
bolting it up will be no harder of bolting on another plate to the stock EGR threads and drilling holes with bolts for the map.
you guys know it will work!
if you guys get a chance, let me know what you think about this for the fuel system.
http://www.rs25.com/forums/f13/t1427...-his-hose.html
Old 09-15-2010, 11:39 AM   #6
renob123
Member#: 41986
'06 STI/'85 Brat
Nice! Thanks for putting this out there for everyone.
Aside from zzyzxx running one in the 300hp NA car, does anyone have any info on the gains that can be achieved by swapping to the newer manifold?
Jacob
renob123 is offline   Reply With Quote
Old 09-15-2010, 05:31 PM   #7
00LGTP
Member#: 172618
2000 RS
BRP
Jacob
i havent found anything, which is why i made this thread.
more brains on the job is a good thing.
Old 09-15-2010, 05:33 PM   #8
renob123
Member#: 41986
'06 STI/'85 Brat
Ahh, so you plan to post some of the gains or a flowbench or something? I'm very interested.
Jacob
Old 09-15-2010, 05:39 PM   #9
00LGTP
Member#: 172618
2000 RS
BRP
ill post pics and explain how i did things but i cant be bothered by a flowbench.
dont get me wrong i would love too, but im a full time college student and (Automotive Technology and Management) i have limited time.
Old 09-15-2010, 05:47 PM   #10
renob123
Member#: 41986
'06 STI/'85 Brat
That's cool. I was asking about gains, and you said that was why you made this thread. I'd call it more of a how-to, which is great, but I wanted to see the gains.
Jacob
Old 09-15-2010, 05:52 PM   #11
00LGTP
Member#: 172618
2000 RS
BRP
Jacob
lol yea guess " how to" is more like it.
butt dyno for now, real dyno when the chance pops up in the future.
Old 09-15-2010, 05:55 PM   #12
renob123
Member#: 41986
'06 STI/'85 Brat
Cool. Until then, does anyone else have any ideas of the actual gains from this swap? I've never heard of any. I've just heard zzyzxx saying they used it.
Jacob
Old 09-16-2010, 08:33 AM   #13
Storm
Member#: 5218
96L Most Over-
Developed Beater
Contact 42 Autosports. They've done it and came to the conclusion that the stock intake tract can't provide enough air to make it an all out winner. There are more details, but you should contact them to get the whole story.
Jay
Old 09-17-2010, 01:49 PM   #14
00LGTP
Member#: 172618
2000 RS
BRP
^^ send them an email, waiting for a reply.
does anyone know if stock 2.5i injectors will work with a WRX/STI aftermarket fuel rail?
gotta spend a certain amount on a FPR, so might as well do it while i have it apart and do a fuel rail/FPR combo. ebay sells come kits with lines and everything i need. normally i wouldnt mess with ebay stuff but machined aluminum is machined aluminum.
Old 09-17-2010, 02:02 PM   #15
RaineMan
Member#: 256727
2007 2.5I Wagon
Jay
So what you are saying is that the heads outflow the stock intake?
RaineMan is offline   Reply With Quote
Old 09-17-2010, 02:51 PM   #16
00LGTP
Member#: 172618
2000 RS
BRP
i think he means the stock intake tubing cant flow enough to see gain.
its not all about the volume of air, the runner lengths are long and P&P from the factory.
Old 09-17-2010, 02:57 PM   #17
RaineMan
Member#: 256727
2007 2.5I Wagon
OK... I think I get you. The IM can handle more flow than the stock tubing and filter provide. Certainly an good case for intake modification if I've ever seen one.
What about the heads? Can they handle more air than the stock intake can provide as well? Generally that's where you hit a wall when it comes to NA engines... if the heads flow less CFM than the IM or intake tubes then modifying the intake won't do you any good anyways.
Old 09-17-2010, 04:18 PM   #18
Storm
Member#: 5218
96L Most Over-
Developed Beater
Exactly.....the torquebox made for pre-05 cars has a small inlet and the CAI they developed for those cars ended up not being a good match for that manifold. The torquebox made for that unit was better, but still short of what they had prior to bolting it on. IIRC, the best gains came from a 4" cone filter (from a GTR) taped directly onto the TB.
The smaller volume of the 05 torquebox works well enough, but the inlet to it needs opened up substantially to let it work.
Jay
Old 09-17-2010, 04:24 PM   #19
RaineMan
Member#: 256727
2007 2.5I Wagon
So I take it the intake was redesigned for 06+? Just trying to figure out where my car fits in this.
Old 09-17-2010, 04:48 PM   #20
00LGTP
Member#: 172618
2000 RS
BRP
you already have the manifold i am putting on.
here is the fuel rail/line kit i was talking about earlier.
http://cgi.ebay.com/ebaymotors/High-...mZ280562461348
Old 09-17-2010, 04:56 PM   #21
williaty
Member#: 71092
2005 2.5RS Wagon
Regal Blue Pearl
05 and 06 are pretty much the same. The big change is between 04 and 05.
Old 09-17-2010, 05:37 PM   #22
RaineMan
Member#: 256727
2007 2.5I Wagon
And 07 is identical to 06 then?
Old 09-17-2010, 05:38 PM   #23
williaty
Member#: 71092
2005 2.5RS Wagon
Regal Blue Pearl
Yup45
Old 09-17-2010, 05:40 PM   #24
RaineMan
Member#: 256727
2007 2.5I Wagon
Ok... cool. Beginning to get an idea of what I've got under the hood now.
Old 09-17-2010, 07:28 PM   #25
williaty
Member#: 71092
2005 2.5RS Wagon
Regal Blue Pearl
Summary:
2002-2004=not much change
2005=big changes compared to 04
2006-2007=tiny changes compared to 05
Wanted - 04/05 wrx project car bossautosports Private 'Wanted' Classifieds 0 01-27-2010 05:54 PM
05 sti project, soon on 18x9.5 rota grids stilv Member's Car Gallery 88 09-25-2009 04:04 PM
05 sti project car.. only 25k miles! michsti Private Vehicle 'For Sale' Classifieds 1 07-13-2009 03:06 PM
Reverse Intake Manifold Project dunk Mid Atlantic Impreza Club -- MAIC 78 01-01-2009 11:36 AM
SoCal: 02-05 manifold, TGV's, injectors, throttle body, engine harness, turbo inlet MannyMohawk#5 Engine/Power/Exhaust 26 01-29-2008 11:25 PM
