05-27-2009, 09:41 AM | #126 |
Member#: 178291
Vehicle:2007 Sti Ltd UGM |
Two questions?
1- So if my mechanic uses the plug in to read the code for an inspection (after DP install) I will pass right?? 2- How much will a catless DP change the exhaust noise of the car?
11-04-2009, 03:34 AM | #127 |
Member#: 227514
SCIC
Vehicle:2009 WRX Black |
What is how how do you prevent boost spike?
02-08-2010, 12:36 AM | #128 |
Member#: 226391
SCIC
Vehicle:01 Silverado |
i have an 05 wrx, i am planning to run a catless up pipe and catless downpipe. how long is it safe to run like that with out a tune? Also, i am going with the invidia divorsed, will i need any mods with the 02 sensor or run a egt resistor? thanks alot!
02-10-2010, 01:23 AM | #129 |
Member#: 236986
MWSOC
Vehicle:03 w r x Sonic Yellow |
this might be a dumb ? but idk. if i buy a 3in dp will it hook up stock to 03wrx or do i need to get 3in pipe? and if it installs to stock will the hp be the same or will it gain still?
thanks for the info also. helped a lot. |
04-06-2010, 04:11 AM | #130 |
Member#: 165617
NWIC
Vehicle:2007 sold:(STAGE2WRX Blur of UrbanGreyMetallic |
Will an Invidia dp that fits on an '06 STi fit on an '07 WRX? I looked and can't find it but really need to know ASAP. I'll keep looking, but if you know for sure, please post. Thanks much, sale pending.
04-08-2010, 04:06 PM | #131 |
Member#: 225024
Vehicle:2002 wrx PSM |
ive heard that running a catless downpipe and up pipe combo will/can cause boost spiking...is there any truth here or do i have it all wrong?
04-08-2010, 04:30 PM | #132 |
Big Ron
Super Moderator Member#: 18062
MAIC
You heard dead wrong. Boost spikes can be aggravated by a catless downpipe...mainly in 2.5L cars, but the CAUSE is the wastegate on the turbo NOT the downpipe.
04-12-2010, 02:24 PM | #133 |
Member#: 180460
SCIC
Vehicle:07 FXT WRB |
sweet FAQ helped alot.
09-18-2010, 01:05 PM | #134 | |
Member#: 257362
right now im running a invidia 3in with the stock catback, and it seems to run fine. i went to this from a full 3in tbe, and this seems to run smoother with the incresed back pressure. the dp is heat wrapped and im running a stage 2 ots map from cobb. i would recommend this for anyone looking for a quiet but powerfull setup. i also had a question about the heatwrap. I only wrapped the bellmouth to the first bend and coated the whole thing it the silicone paint (not sure how much that really does?). but awayways sould i wrap the rest or just leave it alone for the wet colorado winters? |
01-13-2011, 09:49 AM | #135 |
Member#: 268305
sweet
01-13-2011, 12:56 PM | #136 |
Member#: 269057
Thanks for the info.
02-19-2011, 09:46 PM | #137 |
Member#: 270575
Vehicle:02 wrx wagon 4eat wrb |
so let me get this straight? i can put a cat-less dp on my 02 with no tune without negative side effects?
also looked at the links with no success on the o2 fix? |
02-19-2011, 09:57 PM | #138 |
Member#: 207896
South East
Vehicle:11 STi limited Blue |
true that...only reason the dp plays a part is the lack of backpressure from a high flow cat...but it's still on the IWG thanks to the fact that EWG is the best way to go anyways...but yup, usually with a tune you can take care of it.
02-19-2011, 10:00 PM | #139 | |
Member#: 207896
South East
03-21-2011, 03:42 PM | #140 |
Member#: 243342
are the DP's on the 08-10 the same as on the 2011?
03-21-2011, 03:44 PM | #141 |
Member#: 265405
MWSOC
Vehicle:2013 Audi Black |
04-03-2011, 11:57 AM | #142 |
Member#: 230108
I just bought an '04 wrx...I want to put a catless down pipe on it with an exhaust and I live in CT. Will I have to put the DP on it, get it tuned...then take it off again to get emissions tested? Then redo this process everytime? I 'm confused, and new as you can see..
05-08-2011, 11:33 AM | #143 |
Member#: 207098
MAIC
Vehicle:STI :( Gone '14XV Gone, '10 FXT |
Found it
05-08-2011, 12:06 PM | #144 |
Big Ron
MAIC
You are asking a question that is answered in the Cobb Tuning documentation available for viewing and download from the Cobb website. You need to read it and not get the answer handed to you as it is CRITICALLY important to read 1000% of the documentation. If you still can't find the answer, call Cobb.
05-08-2011, 01:06 PM | #145 |
Member#: 207098
MAIC
Yes I don't have a computer, and I can't download it from my phone going to the library tomorrow than
05-18-2011, 02:12 PM | #146 |
Member#: 124498
TXIC
Vehicle:2002 WRB WRX |
I know you talk about having to replace the bolts on an aftermarket uppipe, but nothing is said about the downpipe and exhaust. Do these bolts normally not break and hence can be reused most of the time?
GC |
07-10-2011, 01:45 AM | #147 |
Member#: 287353
SWIC
Vehicle:2002 Wrx Silver |
ok so i installed my catless dp today and my buddy is telling me that it is horrible to drive it without a tune is this true can i damage anything without getting a tune soon?
07-16-2011, 11:40 PM | #148 |
Member#: 288629
Thanxx you
10-29-2011, 02:30 PM | #149 |
Member#: 299378
Question
I have a question, im new to nasioc and not sure where to post my question but if someone could helo me out it would be great. i have a 2009 subaru wrx, and im looking for a throttle body spacer. if anyone knows what brand and where i could get one id appreciate it! thanks.
11-12-2011, 06:02 PM | #150 |
Member#: 299433
Vehicle:2008 Subaru STI Black Paint Black Rims |
Will putting downpipe will degtease ur mpg ?
Similar Threads | ||||
Exhaust FAQ: Read if you are thinking of buying one! | Unabomber | Newbies & FAQs | 318 | 09-06-2021 04:50 PM |
Uppipe FAQ: Read if you are thinking of buying one! | Unabomber | Newbies & FAQs | 396 | 07-09-2020 02:25 AM |
Pulley FAQ: Read if you are thinking of buying one! | Unabomber | Newbies & FAQs | 120 | 01-29-2020 09:15 AM |
Turbo Timer FAQ: Read if you are thinking of buying one! | Unabomber | Newbies & FAQs | 93 | 06-22-2017 08:29 AM |
