Welcome to the North American Subaru Impreza Owners Club Tuesday July 7, 2015
Old 03-19-2009, 10:29 PM   #776
Durmiente
Member#: 75771
2002 WRX Wagon
#87 STX
Originally Posted by mulva View Post
1 stock and 1 aftermarket like you. I've read that about .7 positive camber is gained after going to sedan struts which seems pretty accurate if you're getting -2.5.
-Tom
To get more, consider
1. slotting struts
2. camber/caster plates
Durmiente is offline   Reply With Quote
Old 03-24-2009, 09:01 PM   #777
draco159
Member#: 204121
2005 WRX Wagon
So are the RCE lowering camber plates a good thing to pick up for my 05 wagon? I plan to run the RCE wagon springs/Tokico D/Group N tophats all around. And is the only place to get the the RCE website? Cus I checked just now and it says they are sold out.
draco159 is offline   Reply With Quote
Old 03-24-2009, 09:13 PM   #778
BIGSKYWRX
Member#: 7958
09 GH B+
I'd go RCE non-lowering plates w/ the RCE wagon springs- you don't need the extra drop in front
TIC might also be carrying the RCE plates, but if RCE is out- likely TIC is out too
BIGSKYWRX is offline   Reply With Quote
Old 03-24-2009, 11:51 PM   #779
RaceComp Engineering
Member#: 54202
ASK ABOUT NEW RCE
SWAY BARS FOR STI
We are making a batch of about 5-10 lowering GD plates by mid next week. Any interested call us. Dont know when the next batch will be.
11-5 eastern time, mon-fri.
Myles
RaceComp Engineering is offline   Reply With Quote
Old 03-26-2009, 09:27 AM   #780
Durmiente
Member#: 75771
2002 WRX Wagon
#87 STX
do the non-lowering camber plates add stack height? <-- (thus, raising the car ~0.25" from stock tophats)
The lowering camber plates should increase travel, correct? I was thinking of using those in tandem with the lower strut DREX mod (for Konis) to get obscene amounts of travel for a future GC setup on the Konis.
Old 03-26-2009, 10:09 AM   #781
BIGSKYWRX
Member#: 7958
09 GH B+
no they are 0 raising (and 0 lowering)- unlike most plates that do add to stack height
the lowering ones would add travel- if your thinking GC in the future you very well might want to consider the lowering ones, otherwise w/ the RCE wagon springs the lowering from the springs is just about right as is IMO ~ 30mm
Old 03-26-2009, 11:00 AM   #782
Turn in Concepts
Member#: 93646
Many Track Records
Let us help you go fast!
We TRY and keep an inventory of RCE stuff, but it goes quick.
Myles
One set is mine. Put me down for it, and charge me if you'd like.
Old 09-04-2010, 04:01 PM   #783
GTWORX.com
Member#: 97303
2009 WRX and Boxster
Gray and Black
So we had a gauging interest thread and it was closed do to inappropriate material.
I take full blame for that as I posted 1 innocent pic of Scarlett Johanson. None the less she has nothing to do with springs so it was closed.
I thank all those who have ordered this most recent round of wagon springs and expect updates soon on production of the new batch of wagon springs.
M.
GTWORX.com is offline   Reply With Quote
Old 09-05-2010, 08:46 AM   #784
Dentt42
Member#: 180570
2002 WRX Wagon
WR Blue
Actually Myles is being nice, I was the bad puppy that wizzed on the carpet. Apparently, boredom at work, combined with too much enthusiasm for an upcoming project turns me into a teenage boy*.
The thread got closed, but for my penance, if anyone has any questions I'll paste the info from it on this one.
*As a former teenage boy, I mean no insult to the teenage boy community. I have the utmost respect for teenage boys and their enthusiasm for the female form.
Dentt42 is offline   Reply With Quote
Old 09-05-2010, 10:02 AM   #785
Superorb
Member#: 135252
2002 WRX Wagon
86% Operational :(
Why not just use the RCE Yellow spring with a saggy butt spacer? Drop is almost identical, and spring rates are pretty similar too. Plus, Yellows are still available sold in many places.
Superorb is offline   Reply With Quote
Old 09-05-2010, 11:08 AM   #786
Dentt42
Member#: 180570
2002 WRX Wagon
WR Blue
Mostly out of a compulsion to have to not have to make a sedan part fit a wagon. The spacer is just one more thing to add on. I know yellows work, but personally, it's just knowing you had the part that was engineered with your car in mind.
Old 09-05-2010, 11:15 AM   #787
Superorb
Member#: 135252
2002 WRX Wagon
86% Operational :(
I understand that, but there are many wagon owners who already have the (inexpensive) spacers, so instead of waiting for a group buy that could take forever you could just buy the yellows from RCE or elsewhere right now. I have the spacers, so when I find a pair in classifieds that is within my springs budget I'll go that route. $340 for springs is just too much for me.
Old 09-05-2010, 12:38 PM   #788
labcoat
Member#: 33629
03 WRX Wagon
WR Blue
I would have rather had the wagon springs but yellows were good enough for me.
R-
labcoat is offline   Reply With Quote
Old 09-05-2010, 01:40 PM   #789
mmiller2002
Member#: 159286
2002 WRX Wagon,Com-C
RCE wgn sprngs/Konis/H6
Extra parts to clunk creak slip loosen etc. Less adapters is better.
mmiller2002 is offline   Reply With Quote
Old 09-05-2010, 01:55 PM   #790
labcoat
Member#: 33629
03 WRX Wagon
WR Blue
saggy but spacers are not going anywhere they fit snug. I wonder if Myles would comment if the wagon springs have a slightly higher or different rate in the rear to accommodate the increased weight of the rear of the wagon.
R-
Old 09-05-2010, 02:10 PM   #791
Fierysun
Member#: 82745
2005 Subaru STI
2003 EJ207 S204 Wagon
I have the RCE yellows on Ohlins FPS (awesome awesome struts) with 1/4" spacers on the back of my Wagon for over a year now.
The only way it can clunk, is if it's not tighten properly, otherwise everything stays put.
The RCE yellow have slightly higher spring rate than the wagon springs, but have a lower ride height all the way around.
Old 09-05-2010, 05:46 PM   #792
Superorb
Member#: 135252
2002 WRX Wagon
86% Operational :(
R-
If I remember correctly, the rear wagon springs are longer than the Yellows to compensate for the saggy rear.
Old 09-05-2010, 08:02 PM   #793
Member#: 54202
ASK ABOUT NEW RCE
SWAY BARS FOR STI
Wagons are 275/259 rate and Yellows are 295/275. We did a second prototype when we made wagons to make sure the rear wasnt low. The other pictures from wagon owners shows a very level car. Saggy butt shims arent needed with wagon springs on a wagon.
M
Old 09-05-2010, 08:53 PM   #794
labcoat
Member#: 33629
03 WRX Wagon
WR Blue
M
Thanks for the info Myles.
Old 09-20-2010, 04:51 PM   #795
Superorb
Member#: 135252
2002 WRX Wagon
86% Operational :(
Has anyone put RCE Black (regular guy) springs on a wagon with rear saggy spacer and without the lowering plates? I saw TurboJon's post, but I'd like to see pics without the front lowering plates. I'm trying to see if the RCE Black springs drop more on a wagon than the RCE Wagon springs do (I'd like less of a drop).
Old 09-20-2010, 07:05 PM   #796
kenliu84
Member#: 107618
2006 OBP WRX Wagon
PrecisionTuned/TiCSuspen.
just how much lower are the Yellows compared to the wagon springs? If wagon springs are not available when I am ready, I am willing to purchase the yellows and use saggy spacers to adjust for it. I just want to make sure I have the right numbers and purchase the right spacers
kenliu84 is offline   Reply With Quote
Old 09-20-2010, 07:56 PM   #797
BIGSKYWRX
Member#: 7958
09 GH B+
I thought I saw a relatively recent thread from RCE that they had wagon springs- might want to give them a shout
Old 09-20-2010, 07:57 PM   #798
cueball89
Member#: 90513
2003 wrx wagon
black
labcoat put yellows on his wagon and got 13.5" ride heights at all four corners with a 3/8" spacer in the rear.
yellows
13.5" front
13.125" rear without the spacers.
Blacks are 8mm higher in the front and 10mm higher in the rear.
Blacks on a wagon should sit at
13.9" in the front and
13.4" in the rear.
cueball89 is offline   Reply With Quote
Old 09-20-2010, 09:59 PM   #799
Superorb
Member#: 135252
2002 WRX Wagon
86% Operational :(
yellows
13.5" front
13.4" in the rear.
Thanks! So I'd be fine with the Black or Wagon springs as they appear to have pretty similar rates and almost the same lowering (I already have the rear spacer). I'd be pretty happy with ~14" F/R. Anyone know off hand what Sti takeoff springs on a wagon lower? (that's what I'm on now)
Old 09-20-2010, 10:10 PM   #800
labcoat
Member#: 33629
03 WRX Wagon
WR Blue
yellows
13.5" front
13.4" in the rear.
This is what I look like after some more settling.
R-
front usdm sti springs w/ rear v7 sti wagon springs on bugeye wagon? anybody mixing? fastwrx25 Brakes, Steering & Suspension 15 04-02-2008 09:27 AM
RCE springs on STI without Group N tops? 06STIGO13 Brakes, Steering & Suspension 8 08-09-2007 10:35 AM
RCE springs on a bugeye AllAWD Brakes, Steering & Suspension 4 08-05-2007 10:45 AM
RCE springs on stock struts kennytwrx Brakes, Steering & Suspension 6 04-30-2007 03:01 PM
anyone have pics of RCE springs on 06 STI boostedsti06 Brakes, Steering & Suspension 3 12-31-2006 06:48 PM
