![]() Brakes & Suspension Forum sponsored by The Tire Rack |
#801 | |
Member#: 90513
Tri-State
Vehicle:2003 wrx wagon black |
I went from take off springs to rce wagon springs. I can't remember what my ride heights were. If I could get a spring that had sti take off ride heights with rce stiffness I'd buy it in a heartbeat. Still looks good. ![]()
#802 | |
Member#: 33629
MAIC
Vehicle:03 WRX Wagon WR Blue |
I thought thats what RCE Blacks were supposed to do on maybe just a few mm lower. R- |
#803 |
Member#: 135252
RMIC
Vehicle:2002 WRX Wagon 86% Operational :( |
Blacks are I believe 10mm lower than STi takeoffs, so figure 20mm drop on a WRX? The Wagon springs are 30mm drop I believe. I've been waiting for a set of Blacks in the FS section for months now but they're rare.
#804 |
Member#: 107618
Tri-State
Vehicle:2006 OBP WRX Wagon PrecisionTuned/TiCSuspen. |
Alright, so I've been trying to figure out the ride heights of each type of RCE spring on a wagon as I am researching for my suspension setup. I've looked at way too many wagon suspension threads and RCE springs thread. I gathered all the tidbits of info I could find from here and there, RCE's website and some PMs with labcoat and I think I was able to figure it all out. This, generally speaking, are the ride heights with no spacers:
stock ride height = 15.25/14.25in = 387/362mm Wagon ride height = 14.00/13.75in = 356/349mm => 31/13mm drop = 18mm diff. Black ride height = 13.80/13.50in = 351/343mm => 36/19mm drop = 17mm diff. Yellow ride height = 13.50/13.13in = 343/333mm => 44/29mm drop = 15mm diff. Spacers (for reference) 3/8” = .375in = 9.5mm ~ 10mm ¼” = .25in = 6.35mm ~ 6mm Here's how I calculated the numbers: 1) stock and wagon heights were straight from Myle's wagon springs gauge thread: http://forums.nasioc.com/forums/show...hlight=gauging 2) Labcoat has yellow springs on his car, 13.5in all around with 3/8" rear spacer, that's how I got the yellow ride height 3) RCE's website posts the drop of both blacks and yellows on an 04-07 STi, I just took the difference, added them to the yellow ride height to figure the black ride height 4) I also decided to figure out the difference between the F&R drops so the bigger the difference, the more even or level the car will be. As you can see, the wagon springs were made to be the most level because they were made for wagons and the blacks and yellows were for the 04-07 STi sedans. Got it, check, I know - what about the differences in using different top hats, strut housing, etc.? If someone can figure that out, that would be great but I'll just consider those differences negligible. And I also wanted to get all of the spring rates for reference: Stock (06-07 wagon)= 163/132lbs/in = 2.9K/2.4K Wagon = 278/259lbs/in = 4.9K/4.6K Black = 285/269lbs/in = 5.1K/4.8K Yellow = 295/275lbs/in = 5.3K/4.9K Based off of these numbers, I think I will go with the blacks and no spacers now. Superorb made me think about the spacers and issues they might cause from just having another part in the system. At least for now, the blacks and no spacers. If I am off with my numbers, please let me know. This should help wagon folks out who want RCE springs but don't know which to get. |
#805 |
Member#: 135252
RMIC
^^ You can use the saggy butt spacer without worry, I'm using a set now with no problems. There's honestly no way to screw it up.
I was pretty sure the RCE Blacks were less drop compared to the Wagon springs and the Yellow springs were more drop than the wagon springs. Are the mm drops you listed for these springs on a Wagon? |
#806 |
Member#: 33629
MAIC
kenliu84
The only reason to not use spacers is if you don't want to use you rear strut bar and a 3/8" spacer. The rear studs wont being long enough. The fix is hammer or press them out and use a nut and bolt kit on the up side the nut and bolt will be stronger. Ry- |
#807 | |
Member#: 107618
Tri-State
The wagon springs setup was easy to get, I got it from RCE's thread as I linked above. The yellows setup was taken from labcoat, who posted his numbers in another thread and we've been communicating via PMs. For the blacks, I calculated the difference of the posted drop numbers on RCE's website and added the difference to labcoat's numbers. That's how I got the black setup numbers, I did not get them from someone who was actually running blacks. So I guess it is theoretical. |
#808 | |
Member#: 107618
Tri-State
Hey, you know that metal "cover" in the rear? What if that was removed and the tophat was showing? Would that cover being removed provide enough thread on the bolts for the rear brace? Last edited by kenliu84; 09-23-2010 at 12:12 AM. |
#809 | |
Member#: 180570
South East
Vehicle:2002 WRX Wagon WR Blue |
http://www.clubwrx.net/forums/suspen...k-springs.html |
#810 | |
Member#: 107618
Tri-State
#811 | ||
Member#: 33629
MAIC
Ok I used a vice and a socket and a cheater pipe on the the Vice handle. So when you are done getting the studs out you put the bolt in like the stud came out then the saggy butt on then the nut holds it all in place. I was unsure about this assembly but it went together just fine and I have had no problems. Quote:
R- |
#812 | |
Member#: 33629
MAIC
R- |
#813 | |
Member#: 207118
NWIC
Vehicle:2003 Wrx Wagon |
labcoat - are you getting any rubbing at all at the 13.5"? do you load much in your wagon? I just pulled the trigger on some rce's/dspecs from TiC, trying to decide if I want to put in the 1/4" spacers or not. For me it isn't so much about look, just the future potential for rubbing (I've got 225/45/17's on the 'original' P7's +53, and 225/50/16 Pilot Sport A/S on the stockers for winter) With the 1/4 spacers, I'll be at an even 14" both front/rear. How much does evening out the car alter the geometry/handling? I ordered the 1/4" spacers, but I'm 50/50 on if I want to install them or not. |
#814 |
Member#: 33629
MAIC
I have only had rubbing hitting a bad Hwy seam at 60-70mph hard and the rubbing was noticeable but not OMG. that was with a light load form a road trip.
I have a 8" sub and some tools in the back that is it for load most of the time. I can what being even will do handling wise it will likely change your corner weights but is it enough to count, I don't know R- |
#815 |
Member#: 135252
RMIC
#816 |
Member#: 207118
NWIC
RCE Wagons on the TiC setup (dspecs) with the com c mounts Should give 14" front and 13.75" rear from what I understand. With my current blown struts, my rear is at 14" and my front is at 15.5", so I may opt for 14" front and 14" rear just to be safe (unless that screws up how the car handles too much) |
#817 |
Member#: 33629
MAIC
I don't thinks its going to be very noticabe lto your handeling to use the the spacer and be even.
R- |
#818 |
Member#: 7958
Vehicle:09 GH B+ |
w/ the wagon springs I wouldn't use any spacer- not needed (like sedan springs)
the only reason I can think to add rear spacers w/ wagon springs is if you typically are carrying a lot of rearward weight |
#819 |
Member#: 107618
Tri-State
hey evil, if you want to make it even f&r from hub to fender, then you'll need the 1/4" spacer. Plus, you'll be on the safer side once you start loading the rear
#820 | |
Member#: 207118
NWIC
right, I haul about 30-50 lbs of gear most of the time, so I may just be on the safe side and use them. Can anyone who has had the RCE wagons on d specs for a while comment on how much they have settled over time? Any binding issues? |
#821 |
Member#: 7958
Vehicle:09 GH B+ |
it's not overly difficult to add spacers at a later date- I say try w/o first, if becomes an issue you can always add a spacer
I think the stance of the RCE wagon springs is perfect as is- not too high, not too low- kind of a goldilocks deal ![]() |
#822 | |
Member#: 124219
NWIC
Vehicle:2004 W(agon)RX Silver |
30-50 lbs doesn't effect the ride height from my experience. As for settling, there's pretty much none. Right after the install, it will sit a little higher, then it will be at height after you go to the grocery store to restock beer and back. |
#823 | |
Member#: 207118
NWIC
So I just got my setup, the TiC with dspecs and RCE wagon springs. My issue is that I'm at 14.5 f and 13.5 rear, and I was expecting the above numbers (14 and 13.75) I spoke with Clint and he is checking on the serial numbers for me to make sure nothing was swapped f/r, and thinks maybe I'm on the bumpstops in front. My question is - did those of you on rce wagons get new front bumpstops with them, and if so, how much shorter were they than stock? I'm guessing that perhaps that might be the issue. Also - is it right that in looking at the rear coils with the suspension loaded, there should be 4-5 coils touching? the front doesn't have any touching and are fairly spaced out. Thanks - Ed |
#824 |
Member#: 188079
South East
Vehicle:2003 Stg 2 Bug Wagon Sonic Yellow |
In the interest of helping, are you sure of your terminology? I ask because to me it doesn't make sense. Bumpstops are the rubber pieces around the strut shaft that keep the strut from bottoming out internally, causing damage. At rest, it does nothing. If you are in fact on the bumpstops at rest, that would mean the struts are almost completely compressed. IE, no travel.
Travis |
#825 |
Member#: 33629
MAIC
my stock bumps up front were ~3" ish tall the are cut down to like an ~1" IIRC
T_Racer69 I disagree with you assessment modern bump stops are some times in contact or near contact t stock hide hight. ezil71 is the ride overly harsh up front? R- |
| Thread Tools | |
| Display Modes | |
| front usdm sti springs w/ rear v7 sti wagon springs on bugeye wagon? anybody mixing? | fastwrx25 | Brakes, Steering & Suspension | 15 | 04-02-2008 09:27 AM |
| RCE springs on STI without Group N tops? | 06STIGO13 | Brakes, Steering & Suspension | 8 | 08-09-2007 10:35 AM |
| RCE springs on a bugeye | AllAWD | Brakes, Steering & Suspension | 4 | 08-05-2007 10:45 AM |
| RCE springs on stock struts | kennytwrx | Brakes, Steering & Suspension | 6 | 04-30-2007 03:01 PM |
| anyone have pics of RCE springs on 06 STI | boostedsti06 | Brakes, Steering & Suspension | 3 | 12-31-2006 06:48 PM |
