Welcome to the North American Subaru Impreza Owners Club Sunday December 4, 2016
Old 10-09-2010, 06:17 PM   #1
Bugeyeballa
Member#: 163662
2005 661+ AWHP STi
Mineral White Metallic
Default Not enough fuel
Okay, built motor and everything is set up correctly. Only problem left is that my car isn't getting enough fuel to start. We check the plugs after attempting to start and there is barely any fuel on the plugs... One thing that came to mind is that the evac line near the feed & return hard fuel lines near the firewall is capped off. Does that vacuum line need to be ran or can it be capped?
Any help is appreciated
Bugeyeballa is offline   Reply With Quote
Old 10-09-2010, 06:40 PM   #2
sidewayz
Member#: 5810
2001 S366 2.5RS
Sure you have the fuel lines back on the rails correctly?
sidewayz is offline   Reply With Quote
Old 10-09-2010, 07:19 PM   #3
Bugeyeballa
Member#: 163662
2005 661+ AWHP STi
I'm pretty sure, it's the agency power kit. We have the top lines from the block going to the front side of each rail and the bottom lines to the top middle of the rails.
Does the evac vacuum line NEED to be hooked up?
Old 10-09-2010, 08:47 PM   #4
EROCS04SBRUSTI
Member#: 234397
2004 WRX STI WRB
15 DGM FXT
i read this on two threads awhile back that it needs to be hooked up for the regulator but i don.t know where i read it, search regulator-relocation or aftermarket installation-why not try it?
EROCS04SBRUSTI is offline   Reply With Quote
Old 10-09-2010, 11:13 PM   #5
sense of nature
Member#: 112759
2002 STi Mikey Tuned
SexyRP
I would say the lines are reversed
Old 10-09-2010, 11:36 PM   #6
john 1badSTI
Member#: 77470
04 sti [email protected]
on e85@ 30psi--spinning
the vapor return line by the m/cyl does not need to be hooked up, like above you have the lines at the firewall hooked up backwards I'll bet.
john 1badSTI is offline   Reply With Quote
Old 10-09-2010, 11:58 PM   #7
Bugeyeballa
Member#: 163662
2005 661+ AWHP STi
You mean tge fuel send and return lines?
Old 10-10-2010, 02:14 PM   #8
project_skyline
Member#: 153880
03 Evo VIII
2011 STI
The evap stuff doesn't matter but your FPR needs a vacuum source if thats what your asking about.
project_skyline is offline   Reply With Quote
Slight boost creep, not enough to hit fuel cut, should I be concerned? Rizen Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 8 11-28-2007 12:22 PM
Weird fueling issue. Not enough fuel, add a pump now insanely rich???A/F weirdness. Defiant Autospeed Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 21 11-19-2007 05:30 AM
Not Enough Fuel / Timing Question bluesube2000 Engine Management & Tuning 1 11-21-2005 10:51 PM
Enough fuel for 20psi? rupert Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 4 06-20-2003 04:58 PM
Enough fuel for 19.6psi on VF35? rupert Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 6 06-17-2003 01:15 PM
