Old 02-20-2010, 02:12 PM   #51
RallySport Direct
NASIOC Storefront Vendor
Member#: 33174
We are Open Late!
888-457-2559 Every day!
The car should actually run better after the install, as there will be less and less oil in your intake track making it so that the octane of the fuel is being lowered by the oil.
Double check to make sure you do not have a vacuum leak and that the separator and the cap are tight.
RallySport Direct is offline   Reply With Quote
Old 10-11-2010, 08:59 PM   #52
Bark3rd
Member#: 205531
15 Jeep GC Diesel
If I experienced blow by before the install of this unit, yet almost no smoke, then after the install there is lots of blue smoke on startup and some under high boost, what would be the most likely explanation? Is there a period of time where just after install, previously accumulated oil (intercooler, etc) is cleared out (this is indicated in the install pictorial)? If so, why wouldnt the car have been smoking before the AOS was installed? Does the AOS somehow create a condition where more "force" is now present to blow out oil that accumulated previous to the install?
my brain hurtises
Bark3rd is offline   Reply With Quote
Old 10-12-2010, 10:26 AM   #53
RallySport Direct
Member#: 33174
We are Open Late!
After the install, their is a period of time where oil will still be in the system. This is a couple days while it gets sucked through the motor and burnt up.
However their should not be a increase of oil through the PCV system. And if you are having lots of smoke under boost and start up you need to have the vehicle inspected.
It could be a blown turbo, cracked piston ring, or cracked ring land. I would recommend having the vehicle looked at.
Kirill
RallySportDirect.com
Prova Air/Oil Separator, Prova gold oil cap ajtimm Engine/Power/Exhaust 12 03-29-2010 01:31 PM
PROVA Air/Oil Separator sszyma Engine/Power/Exhaust 3 02-28-2010 01:31 PM
FS: Nor Cal - Prova Air/Oil Separator and APS 65mm CAI ballz Engine/Power/Exhaust 13 10-17-2009 06:05 AM
WTB - Prova Air OIl Separator.... modliving Private 'Wanted' Classifieds 3 09-09-2009 12:01 PM
