Welcome to the North American Subaru Impreza Owners Club Tuesday March 19, 2024
Old 10-16-2010, 02:02 PM   #26
CarTuned
Member#: 42203
Originally Posted by jdmSpecC760 View Post
any output pictures??
Here is pic with the driver side HID installed. The line looks fairly straight cut, but I'm not parked on an even surface. I'll take some better pics tonight for a better comparison.
Oh, and I haven't been flashed either...just saying.
CarTuned is offline   Reply With Quote
Old 10-16-2010, 02:07 PM   #27
Derek E
Member#: 202183
2008 WRX Sedan
Stage II
the second box is the igniter fyi
should have just bought a limited :-/
Derek E is offline   Reply With Quote
Old 10-17-2010, 10:50 AM   #28
CRAZYHAWK
Member#: 198067
2009 IMPREZA 2.5i 4d
WHITE Premium
This shows light above the cut-off, that lights overhead signs. I did not post this picture. The car seams to be about 5 feet from the wall.
Light intensity is inversely proportional to the square of the distance from the source.
At 30' there is 1/36 of the glare at 5'. Two cars approaching eachother, each going
30 mph, would close the distance, 30', in a third of a second. To see any glare they
would have to be looking to their left. They should be looking straight or slightly to the right down the road
This picture was taken 30' from a wall.
[quote=Byzantium;32186309]Are you high? +'08 projectors work great with HIDs?
CRAZYHAWK is offline   Reply With Quote
Old 10-17-2010, 11:15 AM   #29
syndromeofthedown
Member#: 190627
Just my 2 cents. 95% of the people on these forums are stupid impenetrable rejects who want a car like a Subaru because it's "cool" much like smoking was in the 70's/80's. The other 5% with automotive knowledge and common sense, continually try, time and time again to educate you blathering morons about what is "right" when doing DIY projects. Listen to these 5% please!!! It's actually probably less than 5% actually. From the ****ty ****ing welds that you post to your ghetto ricer HID's, listen to these people. BTW, if you've properly pulled off a real retrofit with out removing the "squirrel finder" the light you see above your cutoff is OK!!! This subtle light is intended to illuminate road signs but not to blind oncoming traffic. Most of us have REMOVED the squirrel finder while doing our real retrofits. Please do yourself a favor and do a REAL retrofit.
syndromeofthedown is offline   Reply With Quote
Old 10-17-2010, 11:29 AM   #30
CRAZYHAWK
Member#: 198067
WHITE Premium
The light below the cut-off, is not high to the left, and not dazzling oncoming traffic.
Old 10-17-2010, 05:38 PM   #31
aleutdude
Member#: 129089
06 Impreza2.5Bug-i
I've just completed a retrofit on my '06 2.5i. I'd been running a PNP kit with the squirrel plate mod(bent down and painted flat black) due to time and money considerations. I will be taking pics of the output tonight and hopefully I will get to post some on a few threads. There is simply no substitute for a real retro done with projectors designed for HID capsules(bulbs).
Old 10-17-2010, 05:54 PM   #32
XanRules
Member#: 157348
I Thlammed My
Penith in the Car Door
Old 10-17-2010, 07:01 PM   #33
steverx05
Member#: 128269
I'm just curious, but are you having trouble locating the glare in the picture above that is "high" and "to the left"? Because there is plenty of it.
steverx05 is offline   Reply With Quote
Old 10-17-2010, 07:15 PM   #34
burnout8488
Member#: 191843
2005 Legacy 2.5i
Scratched OBP
Originally Posted by CarTuned View Post
That looks really bad. Notice how you can see the details of the headlight on the halogen side, and the entire headlight is washed out with light on the right?
At least bend your squirrel shield down dude. That just looks like a blob of glare driving down the road.
burnout8488 is offline   Reply With Quote
Old 10-17-2010, 09:26 PM   #35
CRAZYHAWK
Member#: 198067
WHITE Premium
Did you miss posts #28 and #30?
Old 10-17-2010, 09:55 PM   #36
XanRules
Member#: 157348
I Thlammed My
Steve, we've had this conversation. Crazyhawk can't tell the difference between his kit and a retrofit.
Old 10-17-2010, 10:25 PM   #37
steverx05
Member#: 128269
I haven't missed anything at all. I love how you always reference that picture you took too. It's too dark to even use it as a basis for any kind of argument. Here it is bumped up to an appropriate brightness level. You can see the piss poor cutoff and you can also see the glare, especially on the yellow pole which is HIGH and TO THE LEFT.
Old 10-17-2010, 10:27 PM   #38
WRXSIG
Member#: 83660
2013 WRX
Ice Silver
Yes....
WRXSIG is offline   Reply With Quote
Old 10-17-2010, 11:48 PM   #39
CRAZYHAWK
Member#: 198067
WHITE Premium
This picture is overexposed. The origonal was taken through the tinted window. The light above the cut-off is at least 5 stops darker than the light below. The wall behind the yellow pole is dark above the cut-off.
Here is a picture on a dark road from outside my car.
Old 10-18-2010, 02:38 AM   #40
CarTuned
Member#: 42203
I'll get right on that
Old 10-18-2010, 12:44 PM   #41
my name is joe
Member#: 171412
I cant believe people complain about small glare in post #28. STOCK halogens without projectors blind you more then that. Seriously guys? This is as worse as "dont buy a bugeye the tranny will break" when theres LOTS of people that have an 02-03 still running, only the owners of those cars that failed spoke up. How many threads do you see saying "my tranny is still alive!". Same **** with HID's.
my name is joe is offline   Reply With Quote
Old 10-18-2010, 03:23 PM   #42
aleutdude
Member#: 129089
06 Impreza2.5Bug-i
Morimoto H1 minis:
Highbeams augmented with Hella 500s-the Morimotos are bi-xenon. Bulb color temperature is 4300k:
The photos aren't the best as we are still learning how to take good nightshots but hopefully show the difference when projectors designed for HID are used.
Old 10-18-2010, 03:32 PM   #43
kbcr3
Member#: 44170
2010 Forester XT
05 and 09 honda ruckus
Has anyone looked into the costs of getting the full Subaru HID system and installing it in a 2011?
I ask because I'm in the market for a 2011 WRX, but only want the limited for the HIDs. Ideally, I'd want the base model with the Subaru HID system installed.
kbcr3 is offline   Reply With Quote
Old 10-18-2010, 04:27 PM   #44
CRAZYHAWK
Member#: 198067
WHITE Premium
TRS is selling a retrofit bi-xenon d2s kit for $330.
http://www.3gwrx.com/forum/index.php?topic=14903.0
Old 10-18-2010, 04:31 PM   #45
steverx05
Member#: 128269
That's probably one of the worst analogies I've ever heard but thanks for stopping by anyway
Old 10-18-2010, 05:10 PM   #46
howfast?
Member#: 102027
BugI Tsx retro lamps
for sale not listed pm me
its too bad ur not down here in so cal... DDM has a new location in Huntington Beach. We installed My buddies 55w 8000k (looks exactly like 35w 6k believe it or not) and for at least 6 months now its had absolutely no issues what so ever.DDM is popular with the bmw crowd and you know how snooty most of them are about their ish
howfast? is offline   Reply With Quote
Old 10-18-2010, 06:42 PM   #47
aleutdude
Member#: 129089
06 Impreza2.5Bug-i
This would be MUCH less expensive than new HID headlights from the factory by far.
Old 10-19-2010, 03:52 AM   #48
littlewhitewagon
Member#: 103068
11 STI sedan
Dude, 300 to get bi xenon? I'd almost be willing to do that on my STi!
littlewhitewagon is offline   Reply With Quote
Old 10-19-2010, 04:00 AM   #49
nicenice3074
Member#: 261381
That's true for sure.
nicenice3074 is offline   Reply With Quote
Old 10-19-2010, 04:02 AM   #50
AWDPirate
Member#: 131427
hmm not bad
AWDPirate is offline   Reply With Quote
2011 WRX Audio Wiring and Aftermarket DIY Help crosstip Car Audio, Video & Security 1 10-15-2010 04:11 PM
Chicagoland Peeps: 2011 WRX Sedan in our showroom!PICS ADDED! Evanston Subaru Mid West Subaru Owners Club Forum -- MWSOC 17 08-10-2010 05:16 PM
Heck yeah! Found real 2011 WRX Sedan Pics and video! Omega79 News & Rumors 90 08-08-2010 10:50 AM
KLight HID Bixenon Kit Intall w/ Pics impreza_GC8 Electrical & Lighting 10 06-20-2007 03:51 PM
GReddy FMIC Intall manual pics TampaWRX Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 6 02-06-2003 08:05 PM
