Old 10-18-2010, 05:52 PM   #1
infiniti0505
Member#: 249427
2006 WRX
Default Custom Intake Heat Shield?
I just ordered the SPT intake for my wrx and wanted to fabricate a custom head shield for the intake. Mainly for a fun project. Has anyone done this before if so can you post pictures?
infiniti0505 is offline   Reply With Quote
Old 10-18-2010, 06:06 PM   #2
Badler
Member#: 133597
Can't you just buy the optional heat shield that they already make for it?
Old 10-18-2010, 06:18 PM   #3
imma_stocker
Member#: 97043
08 STI
02 Z28 - project
To make a DIY heat shield you'll need: aluminum sheetmetal from Home Depot, a good metal drill bit, a power drill, tin shears, something to bend and crease over (angle iron, 4x4 wood post on a saw horse, etc.), and plenty of washers.
I think Koji made one before. You'll have to search in the Interior & Exterior section.
Old 10-18-2010, 08:57 PM   #4
Jessekrs123
Member#: 236927
2015 BRZ, 93 Legacy,
1984 BRAT
I have made my own out of some sheet metal I found sitting around the house. Here are some pics. You can just bolt the shield up to the airbox bracket holes.
As said before, all you need is sheet metal, metal shears, and a cabinet edge or something 90 degrees to bend it on. Measure and drill out the holes, then bolt it up.
Jessekrs123 is offline   Reply With Quote
Old 10-18-2010, 09:06 PM   #5
Subikid90
Member#: 239233
1998 LGT
Shouldnt the shield be the other way, keeping the hot air away from the filter?
Subikid90 is offline   Reply With Quote
Old 10-18-2010, 09:13 PM   #6
Jessekrs123
Member#: 236927
1984 BRAT
It is the right way, what do you think I'm slow in the head? Here is a better shot WITH the filter on.
Old 10-18-2010, 09:16 PM   #7
Subikid90
Member#: 239233
1998 LGT
Ah the other picture made it look like it was on the other side of the filter. I want to make something similar but I have ABS crap in the way...
Old 10-18-2010, 09:19 PM   #8
Jessekrs123
Member#: 236927
1984 BRAT
Yes no ABS on my whip. I prefer it that way, I had ABS in my other Subaru and I hated it, I think it is stupid and makes you stop slower. I'll just pump my brakes and keep from locking the steering myself.
Old 10-18-2010, 10:27 PM   #9
ZeroDrift
Member#: 184324
1999 Impreza 2.5RS
Here are a few of my first prototype.
ZeroDrift is offline   Reply With Quote
Old 10-18-2010, 11:55 PM   #10
infiniti0505
Member#: 249427
2006 WRX
Yea I could. But it comes down to... Spend 70 bucks plush shipping or spend 0 and have a little fun fabricating a heat shield.
Btw those DIY heatshields look clean! What was the total time put into fabricating those?
One more question... this maybe a stupid question but how do some metals have that purplish/blueish discolor look to them?
Old 10-19-2010, 12:08 AM   #11
ZeroDrift
Member#: 184324
1999 Impreza 2.5RS
I cant recall how long I spent on mine, but I'd guess in the order of 10 hours or so over several days with many beer and lunch breaks.
That design gave way to the next version posted here: http://forums.nasioc.com/forums/show....php?t=2058032
As far as the discoloration, steel and titanium can have the burnt look with anodizing or perhaps with heat. I don't believe you can heat discolor aluminum as it just melts with out changing color- perhaps a special type of anodizing?
Old 10-19-2010, 11:13 AM   #12
Jessekrs123
Member#: 236927
1984 BRAT
I spent about 1.5 hours on mine. Making measurements, cutting, sanding out the corners, painting, and bolting it on. Ofcourse mine is not nearly as well put together and as elaborate as ZeroDrift's heatshield is.
Old 10-19-2010, 12:56 PM   #13
Subikid90
Member#: 239233
1998 LGT
I think I am going to make something similar to yours for now, maybe I will just box the abs stuff in with the filter...
Post your custom intake heat shields sc00ter Interior & Exterior Modification 10 01-19-2010 11:42 PM
Looking For used Subaru SPT intake Heat shield just the heat shield For 06 WRX Cobb2006WRXJR Private 'Wanted' Classifieds 0 11-13-2009 12:35 PM
FS:(AZ) SPT Short Ram Intake W/ Intake Heat shield satan's sled Engine/Power/Exhaust 14 12-05-2008 09:33 PM
SPT intake/heat shield and AEM V2 intake Subarudude2 Engine/Power/Exhaust 18 03-31-2008 11:59 PM
Custom short ram intake heat shield (clears Process West FMIC piping) prototypeWRX Member's Car Gallery 9 10-02-2006 11:14 AM
