Old 10-22-2010, 02:04 PM   #1
Turbovan
Member#: 168654
2005 WRX
some form of black
Default Sleeving a cracked cylinder?
I haven't been able to find much info on this subject, but what are the necisary precautions when sleeving a block with a cylinder that cracked? Should\can the block be welded? Is there a possibility of the block still being trash after being welded, and are there any tests the machine shop can do to check as to how severe/extensive the crack actually is?
Turbovan is offline   Reply With Quote
Old 10-22-2010, 02:55 PM   #2
john 1badSTI
Member#: 77470
04 sti [email protected]
on e85@ 30psi--spinning
As far as I know once the cylinder is cracked(compromised)it is not sleevable because the block has to have all its strength because the sleeves go in with a .003-.004 press fit.
john 1badSTI is offline   Reply With Quote
Old 10-22-2010, 04:27 PM   #3
Sinister redlines
Member#: 120641
05 HTA3586,BB 2.5L
Agreed^^^^ Plus its cheaper to just buy a different case.
Sinister redlines is offline   Reply With Quote
Old 10-22-2010, 05:40 PM   #4
Turbovan
Member#: 168654
2005 WRX
some form of black
Not if my plan is to sleeve anyways.
Now I can understand the crack being an issue if it extends too far towards the crank, but what if it appears to be isolated near the top of the bore? Since most of the stock sleeve is removed entirely anyways, how can one know for sure if the remainder has been compromised? Can a sonic test provide the necessary information? I have seen a few posts(three maybe) that state the block should simply be welded first, but no further information or apparent validation of this method.
Old 10-22-2010, 07:34 PM   #5
wrx_driver_2002
Member#: 25952
1995 Impreza Coupe
w/ "Extras" :-)
I would recommend calling darton and asking them. If they tell you it's no good, then I have a good bare case I'll sell you. I'll even ship it directly to darton for you if they're doing your sleeves.
wrx_driver_2002 is offline   Reply With Quote
Old 10-22-2010, 10:35 PM   #6
john 1badSTI
Member#: 77470
When they machine the block for the sleeves they do not remove all the aluminum around the factory sleeve and the darton sleeve has to have a strong shelf to sit on at the top in the middle and at the bottom and if the cases are compromised in any of these areas the sleeve will not have the support to stay in place and will move around and drop.Like posted above you are better off buying a used block for 3 to 4 hundred and have it sleeved instead of using a block thats questionable.If you are trying to do a sleeved block by trying to save money by reusing your cracked block---FORGET IT.
Old 10-23-2010, 03:31 PM   #7
Sinister redlines
Member#: 120641
05 HTA3586,BB 2.5L
Definately, why short yourself in a big build where the integraty could be compromised vs buy wrx_driver_2002's block and have a strong base platform with no questions. Trust me I just went through a major loss on a build because I substandard a builder vs paying a bit extra and having no problems. BTW I know it was mentioned before but make sure to have the main line checked after sleeves as it was found as a contributer to my builds failure. My mainlines where supposed to be checked but the builder failed to do so and missed my mains all being way out after sleeves where installed.
Old 10-23-2010, 03:45 PM   #8
john 1badSTI
Member#: 77470
^^^yes The Mains Have To Be Checked After Sleeving And Most Of The Time Have To Be Lined Honed To Make True Again.
Old 10-25-2010, 10:20 PM   #9
sackytar
Member#: 149262
03WR Rallycar/FXT/OB
PrimerGrey
Call element tuning. They will tell you why you shouldn't sleeve your engine.
Old 10-26-2010, 09:47 PM   #10
Sinister redlines
Member#: 120641
05 HTA3586,BB 2.5L
And yet many others say its fine as long as its done correctly.
Old 10-26-2010, 11:08 PM   #11
sidewayz
Member#: 5810
2001 S366 2.5RS
I have a customers engine being sleeved as we speak. This isn't something to have your local shmo machine shop do. I send my stuff right to Darton. Pay the money and get it done right
sidewayz is offline   Reply With Quote
Old 10-26-2010, 11:35 PM   #12
Sinister redlines
Member#: 120641
05 HTA3586,BB 2.5L
Exactly, Darton direct the only way for sure...
Old 10-27-2010, 12:11 AM   #13
Junior2JZ
Member#: 64908
10.8 [email protected] GR+
9.1/157mph 2015 STI
I will give you the exact measurement tomorrow, but if the crack is at the very top you can sleeve it. The top 1/2-3/4" section of the Darton sleeve requires cutting out the complete original sleeve. If the crack is at the top and only goes down a little bit it will be cut out anyway. You just have to make sure the crack doesn't keep going the way down. Also if the crack is only in the inner liner and doesnt reach the outside of the OEM sleeve you can also still sleeve it since it will be machined away.
Jr
Old 10-27-2010, 03:15 AM   #14
Turbovan
Member#: 168654
2005 WRX
some form of black
I will try to get pictures and or measurements here in a couple days. Darton has asked for pictures as well before they can answer so I guess they will be able to tell me what I need. After much more research I have seen how critical the stock liner is(at least for darton/dry sleeves), and how it could crack fairly easily from a sleeve being pressed in.
Old 10-27-2010, 02:34 PM   #15
Shainz
Member#: 171778
2002 Snail Wagon
Gray
1/2" is number. Just measured them on a block we are installing sleeves on
Jr
Shainz is offline   Reply With Quote
Old 10-30-2010, 05:39 AM   #16
STIV6
Member#: 27458
2003 STI
I cracked my block back in 2005, had it welded up, sleeved, pressure tested and after a few rebuilds for various different reasons and about 70,000km later its still as strong as ever. All the welding and sleeving was done by PMS in Qld Australia.
If its done right you wont have any future problems with it, i speak with first hand experience!
STIV6 is offline   Reply With Quote
Old 04-30-2012, 06:43 PM   #17
Razlin
Member#: 146635
06 WRX STI
Satin White Pearl +
Jr
Hrm. Need pics of how mine cracked.
Razlin is offline   Reply With Quote
Old 04-30-2012, 10:21 PM   #18
3MI Racing
Member#: 200987
They also say to only do oversized valves...Headgames says you get more from porting instead of valving if doing one or the other as you'll get better gains.
Which Darton, East or West?
Cracked Cylinder Head Minorityairsoft Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 5 01-09-2008 10:07 AM
cracked cylinder heads- how common? 3fordasho Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 1 02-07-2006 03:29 PM
Cracked Cylinder, Time to Swap? superjdk Subaru Conversions 4 09-10-2005 02:20 PM
Cracked Cylinder Wall, Help With Swap Options! superjdk Newbies & FAQs 1 09-08-2005 01:05 PM
Has anyone broken a rod or cracked a sleeve yet? supercompact Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 28 05-09-2004 09:36 PM
