Welcome to the North American Subaru Impreza Owners Club Monday May 25, 2015
Old 10-28-2010, 12:29 PM   #1
xluben
Member#: 261612
2002 WRX Sedan
10.3s @ 139mph
Default xluben's 2011 WRX: Spec B 6 Speed and Rotated PTE 6266
|xluben's 2011 WRX | NF Performance | Project Dark Knight |
|Spec B 6 Speed | Rotated PTE 6266 | 576WHP / 530WTQ |
Dyno Plot:
6266 vs. VF52:
Rotated Turbo Setup:
Quick Pull:
Quick 40-140 video:
Here's another video:
3rd Gear Pull @ 32psi (boost gauge goes wacky above 30psi)
2nd Gear Brake Boost, 3rd, 4th @ 30psi
50-100MPH is ~4 sec for the 3rd Gear Pull
60-130MPH is ~8 sec for the 2nd, 3rd, 4th Pull
Exhaust Video:
Engine:
  • 703 Casting Case Halves
  • Manley Turbo Tuff Rods
  • Manley Coated Pistons
  • Stock Subaru Crank
  • ACL Race Series Main Bearings
  • ACL Race Series Rod Bearings
  • Balanced Rotating Assembly
  • Covert Oil Pickup
  • MAP H11 Head Studs
  • TGV Deletes
  • FujiK of NF Performance Head Porting
  • GSC Beehive Springs
  • Stock Valves
  • Stock Cams
Intake/Exhaust/Fuel:
  • PTE 6266 V-Band Journal Bearing Turbo
  • Fobia Twin Scroll Header
  • Fobia Rotated 1.5 Scroll V-Band Uppipe
  • Fobia Rotated 3" V-BandDownpipe
  • Fobia Rotated 4" Intake
  • Fobia Rotated/SD FMIC Piping
  • TurboSmart HyperGate 45mm EWG
  • TurboSmart RacePort 50mm BOV
  • COBB 3" Cat Back Exhaust
  • FMS FMIC w/GS Thermal Coating
  • GrimmSpeed MBC
  • Walbro 465 Fuel Pump Hardwired
  • FiveO Motorsports 1600cc Injectors
  • Fuelab FPR at 55psi
  • COBB AP Speed Density Tune
Drivetrain/Transmission
  • 2011 STI 6 Speed Transmission
  • Legacy Spec B High Speed Gears
  • 08+ STI Shift Linkage
  • Kartboy Shifter and All Bushings
  • Anarchy Motive Heavyweight Knob
  • ACT XT Pressure Plate
  • ACT Unsprung 6 Puck Disc
  • STI Clutch Fork
  • STI Clutch Slave Cylinder
  • Braided SS Clutch Line
  • TIC Transmission Crossmember Bushings
  • 08+ Impreza AT Driveshaft
  • R160 3.54 Final Drive Rear Diff
  • STI Starter
Suspension/Wheels:
  • Enkei RPF1 17x9" +35 Wheels
  • 255/40R17 Federal 595 RS-R Tires
  • RCE Black Springs (Stock Struts)
  • Whiteline 22mm Front Sway Bar
  • Whiteline 22mm Rear Sway Bar
  • RalliTEK HD Front Endlinks
  • RalliTEK HD Rear Endlinks
  • 2011 WRX Stock Wheels (Winter)
  • 225/45R17 General Altimax Arctic Tires (Winter)
  • GrimmSpeed Master Cylinder Brace
  • StopTech SS Brake Lines
  • StopTech Street Performance Brake Pads
  • ATE SuperBlue Brake Fluid
Interior/Electronics:
  • Defi Boost Gauge
  • Defi Oil Pressure Gauge
  • SMY Dual Gauge Cluster
  • AEM UEGO Digital Wideband O2 Gauge
  • Omni Power 4 Bar MAP Sensor
  • Recaro ProRide Baby Seat
Exterior:
  • V-Limited Front Lip
  • Red Tail Light Overlays
  • Flapatax Mud Flaps
  • GrimmSpeed License Plate Relocation Kit
  • GrimmSpeed License Plate Delete
  • OEM Scoopless Hood
  • VG Shark Fin Antenna
  • Yakima Roof Rack
Chronological:
2011 WRX Purchased: 10/21/10
MODE Shifter: 11/03/10
SPT Exhaust: 11/07/10
Winter Wheels: 11/12/10
Stage 1 Tune: 11/18/10
COBB Downpipe: 12/19/10
Stage 2 Tune: 12/19/10
IPR TMIC: 1/14/11
Forge BPV: 1/14/11
Defi Boost Gauge: 1/15/11
SMY Dual Gauge Cluster: 1/19/11
Walbro Fuel Pump: 1/27/11
Kartboy Front Shifter Bushings: 1/29/11
DIY Seat Bolster Mod: 02/07/11
Kartboy Rear Shifter Bushing: 02/16/11
GrimmSpeed Master Cylinder Brace: 02/17/11
Red Tail Light Overlays: 02/19/11
Flapatax Mud Flaps: 02/26/11
AEM Cold Air Intake: 02/28/11
GrimmSpeed EBCS and MBC (Hybrid Boost Control): 02/28/11
Fiveo Motorsports 1200cc Injectors: 03/05/11
Custom E85 Tune: 03/05/11
Whiteline 24mm Adj. Front Sway Bar: 04/21/11
Whiteline 22mm Adj. Rear Swaybar: 04/21/11
RalliTEK HD Front Endlinks: 04/21/11
RalliTEK HD Rear Endlinks: 04/21/11
BC Racing Inverted Coilovers: 04/21/11
AEM UEGO Digital Wideband O2 Gauge: 05/23/11
Whiteline 22mm Adj. Front Sway Bar: 05/27/11
GrimmSpeed License Plate Relocation Kit: 06/02/11
Fast Motorsports (FMS) Front Mount Intercooler (FMIC): 06/07/11
OEM Scoopless Hood: 06/13/11
Yakima Roof Rack: 06/27/11
Invidia Q300 Exhaust: 07/22/11
Invidia Catless Downpipe: 07/22/11
Blouch 20G-XT-R Turbo: 9/17/11
GrimmSpeed License Plate Delete: 9/22/11
GrimmSpeed Turbo Heat Shield: 9/23/11
Gold 04 STi BBS Wheels: 09/28/11
KSTech 73mm Intake: 10/01/11
Tial MV-R 44mm EWG, GrimmSpeed Uppipe and Crosspipe: 10/13/11
Omni Power 4 Bar MAP Sensor: 02/06/12
Stock Exhaust: 02/18/12
Blown Motor - Cracked #2 Piston: 02/22/12
Built Shortblock: 03/05/12
TGV Deletes: 03/05/12
AMR 3" Hard Inlet: 03/05/12
Mach V Awesome 17x9" Wheels: 03/21/12
Dunlop Star Spec 255/40R17 Tires: 03/21/12
GFB 50/50 Hybrid BOV: 03/31/12
Turbo XS 50/50 Hybrid BOV: 04/05/12
ACT HD Pressure Plate: 04/06/12
ACT Street Light Flywheel 04/06/12
ACT Sprung 4 Puck Clutch Disc: 04/06/12
Dyno @ MAP: 462WHP / 492WTQ: 04/11/12
RCE Black Springs: 04/14/12
TurboSmart Kompact BPV: 04/18/12
StopTech SS Brake Lines: 04/18/12
StopTech Street Performance Brake Pads: 04/18/12
ATE SuperBlue Brake Fluid: 04/18/12
Koni Adjustable Dampers (Rear): 04/26/12
Koni Adjustable Dampers (Front): 04/27/12
besthaticouldo Shift Knob: 05/08/12
All-In-One Flip Key Mod: 05/16/12
In-Cabin MBC Relocation: 05/22/12
SPT Exhaust: 05/26/12
Blown 5 Speed - Stripped 3 Gear: 06/02/12
V-Limited Front Lip: 06/13/12
[url="http://forums.nasioc.com/forums/showthread.php?p=37362985#post37362985"]DIY Bumper Vent: 06/13/12[/URL]
PAR Built 5 Speed: 07/06/12
Stock Exhaust: 07/15/12
Forge BPV: 07/16/12
TurboSmart Dual Port BPV: 07/19/22
Removed Clutch Delay Valve: 07/22/12
Greddy Ti-C Catback: 08/10/12
PTP Turbo Blanket: 08/12/12
Hand Wash and Wax: 09/08/12
Invidia Equal Length Header: 09/25/12
PAR Straight Cut 2nd Gear: 10/14/2012
Kartboy Pitch Stop Mount: 10/14/2012
Cusco Motor and Tranny Mounts: 10/14/2012
Mach V Awesome Decals: 10/18/2012
2 Year Anniversary!: 10/24/2012
Stock Wheels and Winter Tires: 10/28/2012
Stock Exhaust: 10/28/2012
ARK GRiP Exhaust: 11/02/2012
PTP Lava Turbo Blanket: 11/10/2012
GReddy SP Elite Exhaust: 11/14/2012
Exhaust Comparison Photos: 11/18/2012
Kartboy Shifter Comparison: 11/20/2012
VG Shark Fin Antenna: 01/14/2013
Photos Before/After Editing: 01/16/2013
Recaro Baby Seat: 01/28/2013
17x9" RPF1 (Black Background): 01/31/2013
17x9" RPF1 (White Background): 01/31/2013
DCCD Pro Photos: 01/31/2013
STI 6MT Swap Info: 02/11/2013
New Motor and Rotated PTE6266: 03/22/2013
Old 10-28-2010, 12:30 PM   #2
xluben
Member#: 261612
2002 WRX Sedan
10.3s @ 139mph
Click the photo for more images from the same post!
Forge BPV (1/14/11):
IPR TMIC (1/14/11):
Defi Boost Gauge (1/15/11):
SMY Clustermaker Dual Guage Cluster (1/19/11):
Walbro 255 Fuel Pump (1/27/11):
Kartboy Shifter Bushings (1/29/11):
DIY Seat Bolster Mod (02/07/11):
Kartboy Rear Shifter Bushing (02/16/11):
Old 10-28-2010, 12:30 PM   #3
xluben
Member#: 261612
2002 WRX Sedan
10.3s @ 139mph
GrimmSpeed Master Cylinder Brace (02/17/11):
Defi Oil Pressure Gauge (02/17/11):
Red Tail Light Overlays (02/19/11):
Flapatax Mud Flaps (02/26/11):
AEM Cold Air Intake (02/28/11):
GrimmSpeed EBCS and MBC (Hybrid Boost Control) (02/28/11):
Fiveo Motorsports 1200cc Injectors (03/05/11):
Custom E85 Tune (03/05/11):
Whiteline 24mm Adj. Front Sway Bar (04/21/11):
Whiteline 22mm Adj. Rear Swaybar (04/21/11):
RalliTEK HD Front Endlinks (04/21/11):
RalliTEK HD Rear Endlinks (04/21/11):
BC Racing Inverted Coilovers (04/21/11):
Old 10-28-2010, 12:30 PM   #4
xluben
Member#: 261612
2002 WRX Sedan
10.3s @ 139mph
AEM UEGO Digital Wideband O2 Gauge (05/23/11):
Whiteline 22mm Adj. Front Sway Bar (05/27/11):
GrimmSpeed License Plate Relocation Kit (06/02/11):
Fast Motorsports (FMS) Front Mount Intercooler (FMIC) (06/07/11):
OEM Scoopless Hood (06/13/11):
Yakima Roof Rack (06/27/11):
Invidia Q300 Exhaust and Downpipe (7/22/11):
Blouch 20G-XT-R Turbo (9/17/11):
GrimmSpeed License Plate Delete (9/22/11):
GrimmSpeed Turbo Heat Shield (9/23/11):
Gold 04 STi BBS Wheels (09/28/11):
Old 10-28-2010, 12:38 PM   #5
wrxspeed56
Member#: 207065
2002 wrx
instagram @wrxspeed56
I like the rims they put on the new wrx.
deff get some red taillight tint. car so clean.
wrxspeed56 is offline   Reply With Quote
Old 10-28-2010, 12:38 PM   #6
woWRX
Member#: 207901
2010 2.5i Prem
NBP
Saved for later...3
what is this i dont even...
woWRX is offline   Reply With Quote
Old 10-28-2010, 12:40 PM   #7
xluben
Member#: 261612
2002 WRX Sedan
10.3s @ 139mph
Tial MV-R 44mm EWG, GrimmSpeed Uppipe and Crosspipe (10/13/11):
Old 10-28-2010, 12:43 PM   #8
woWRX
Member#: 207901
2010 2.5i Prem
NBP
oh i see. sorry, im a noob. sick car though! the interior is beautiful.
Old 10-28-2010, 01:43 PM   #9
ptsmalls
Member#: 31960
2012 R
Nice interior shot. The '11 wheels are by far the best OEM wheels on any of the WRX's.
ptsmalls is offline   Reply With Quote
Old 10-28-2010, 01:47 PM   #10
kevpotts
Member#: 170156
2010 370z
white
Both car and pictures look great!
kevpotts is online now   Reply With Quote
Old 10-28-2010, 01:53 PM   #11
xluben
Member#: 261612
2002 WRX Sedan
10.3s @ 139mph
Completely stock Black 2011 WRX 5 Door:
Old 10-28-2010, 03:00 PM   #12
chester09
Member#: 214020
2013 WRX STI
No heated seats?
chester09 is offline   Reply With Quote
Old 10-28-2010, 03:05 PM   #13
xluben
Member#: 261612
2002 WRX Sedan
10.3s @ 139mph
Nope, not included on the base model. Wasn't something I was too interested in though. I park indoors overnight, so it's not a big deal even when it's cold out.
Old 10-28-2010, 03:06 PM   #14
chester09
Member#: 214020
2013 WRX STI
Weird how theres little differences in the models between Canada and the US. We get heated seats in the base.
Old 10-28-2010, 03:48 PM   #15
jonklein611
Member#: 117776
2011 WRX Limited 5dr
WR Blue Pearl
You also get Plasma Blue Pearl in the WRX......
Old 10-28-2010, 03:50 PM   #16
xluben
Member#: 261612
2002 WRX Sedan
10.3s @ 139mph
Canada!!!!!
Old 10-28-2010, 04:20 PM   #17
rabidfurball
Member#: 259533
2011 WRX Premium 5dr
Nice pics... I'm waiting for my own obp wrx. If you got the last one left in the country that explains why its been taking so long... Can't wait.
Car photo tip: turn the front wheel so it's facing the camera.
rabidfurball is offline   Reply With Quote
Old 10-28-2010, 04:25 PM   #18
pittsburghscoobie
Member#: 221812
MBP
damnnnnn that thing would look soooo good with no wheel gap and some meaty tires.
love the 11 5 doors
pittsburghscoobie is offline   Reply With Quote
Old 10-28-2010, 04:48 PM   #19
WRBlueByYou
Member#: 246057
2004 WRX
I'm officially jealous of you.
WRBlueByYou is offline   Reply With Quote
Old 10-28-2010, 04:49 PM   #20
Noisyninja
Member#: 157624
2011 WRX Hatch
I'm pretty sure the dealership here in Norwalk, CT had one because I saw it leaving the dealership the other day driven by what looked like a tech. Could have been sold already, I guess.
Noisyninja is offline   Reply With Quote
Old 10-28-2010, 05:04 PM   #21
OrbitalEllipses
Member#: 178811
2013 ****ing ricer
mobile >:(
I wish someone made OEM quality red/clear tail lights, but I am considering paint or overlays.
Your wish is my command!
www.bluebatmobile.net
Old 10-28-2010, 05:43 PM   #22
sroski
Member#: 233638
PBP
Yeah, like me!
Nice car man, looks good in black!
sroski is offline   Reply With Quote
Old 10-28-2010, 05:58 PM   #23
SkiWrex
Member#: 142559
02 PSM
Wagon VF39'd
Man I love the interiors of these 11's! The dark colors make it look so clean.
SkiWrex is offline   Reply With Quote
Old 10-28-2010, 07:02 PM   #24
xluben
Member#: 261612
2002 WRX Sedan
10.3s @ 139mph
Thanks. I'll have to remember to turn the wheel next time.
love the 11 5 doors
A drop would look great, but low cars in MN suck. I don't think I want to deal with the hassle. I'd rather have a winter machine!
Was it a black, 5 door, base trim? That's all I was looking for. There might have been other color/trim level hatches available.
I have contacted him and gotten all the ordering details. I don't know if I want to spend that much and then deal with the hassle of install.
Originally Posted by sroski View Post
Yeah, like me!
Old 10-28-2010, 08:27 PM   #25
cps102
Member#: 222776
'08 OBS
Yeah, really good interior shot. Straight outta the catalogue!
cps102 is offline   Reply With Quote
xluben's Pictures and Review of the SPT Exhaust for the 2011 WRX 5 Door Hatch xluben Car Part Reviews 26 11-08-2012 06:55 PM
My first post and my first Subaru, a 2011 WRX 5 door in white. Decade240 Newbies & FAQs 25 06-20-2012 01:48 PM
2011 wrx 5 door hatch with Rota 17"x7.5 +48 5x100 wheels? BretCutler Tire & Wheel 4 01-14-2011 08:05 AM
2011 WRX 5 Door Ruz4life General Community 55 10-13-2010 11:37 PM
2011 WRX 5 Door Ruz4life General Community 10 10-04-2010 04:02 PM
