#1 |
Member#: 254768
TXIC
Vehicle:2011 STi Sedan SWP |
**If the mods are reading this, I would ask that you combine the other threads into this one**
Okay, lets get to it. Several people have been looking into information regarding the rear fog light available for the 2011 WRX/STI Sedan in Japan & UK trim levels. I was able to have a friend locate it in Japan. So to answer the question for the guys/gals interested in adding it to their USDM WRX/STI, below is the entire assembly along with the part numbers shown on the packages. This way you have the information to source it yourself. With this being one of the first (if not the) sets in the US, I wanted to share the information. **CLARIFICATION** This does NOT mean that the assembly is a direct fit. I am still awaiting my STI to arrive to figure out installation. On to the Pics! ![]() ![]() Entire Assembly of Parts ![]() Misc Clips ![]() Threaded Clips to hold side ![]() Rear Fog Harness ![]() Rear Fog Lightbulb ![]() Rear Fog ![]() (1) Red Lens P/N 84913FG420 (1) Harness P/N 84981FG050 (1) Lightbulb P/N 84920KE010 (4) Plastic Clips P/N 909205126 (6) Bolts P/N 901000344 (2) Threaded Clips P/N 902510032 Hope this information is useful. I will be back on this thread to update with install pics. I would ask that anyone who can add useful info to this thread to please do so. Good luck guys! -Scott
#2 |
Member#: 161333
NESIC
Vehicle:'09 wrx '08 ninja 250r |
edit...nvmd... didn't read that it was for the sedan... jumping to pics ftl.
sedan fog location.. ![]() nice work. Last edited by dwf137; 10-30-2010 at 01:57 PM. Reason: sedan. |
#3 | |
Member#: 254768
TXIC
Really? I post up to help out and this is what I get? First response with bad information? You don't know what you are talking about. This rear fog is for the 2011 Sedan model GVB. I guess I can delete this thread. |
#4 |
Member#: 248293
Tri-State
Vehicle:2010 2.5i hatch SSM |
would this fit the '10 2.5i wagon? If you know by any chance
EDIT Above post answered my quesiton |
#5 | |
Member#: 161333
NESIC
maybe next time you should be more descriptive in your title, because not every 2011 wrx/sti fog light will be the same. i have edited my post. |
#6 |
Member#: 254768
TXIC
If the Mods could add sedan to the title it will clear things up. Thanks for the UK Sedan picture. That will better illustrate the location. Last edited by scotheocelot; 10-30-2010 at 03:09 PM. |
#7 |
Member#: 259779
Grats man.
#8 |
Member#: 222833
NWIC
Vehicle:. Guess who's back. Back again. |
#9 |
Member#: 123843
NESIC
Vehicle:2006 SGM WRX S2 Let LED's light your way! |
The only thing I can say is WOW!!
![]() ![]() ![]() You did exactly what I would have done and that is to source everything. No cutting or splicing or hack-job. One suggestion: get yourself a red LED bulb: http://www.v-leds.com/Exterior-LED/B...10367-1-2.html Trust me, get one. I have experience with OEM and aftermarket rear LED lamps that are relatively small like the OEM one you have and an incandescent bulb will get hot and tend to melt the housing. An LED bulb produces almost no appreciable heat and so you can expect to avoid the possibility for any melting to occur. |
#10 |
Member#: 161333
NESIC
something i am very curious about though, did you find a source for a new turn signal stalk that includes the rear fog control? The oem switch is just an additional "turn" on the stalk.
I'm in the middle of setting up a rear fog for my hatch and I was considering sourcing one out in lieu of installing a non-oem switch. |
#11 | |
Member#: 254768
TXIC
#12 |
Member#: 134010
NESIC
Vehicle:2007 WRX bren-t00ned UGM |
It's all combined into one switch on the stalk. One turn up switches on the front, a second turn up switches on the rear.
The rear fog is only supposed to be used with heavy fog/rain as the light is very bright and not very safe to use otherwise. The rear fog helps other drivers see your car when visibility is very low. |
#13 | |
Member#: 161333
NESIC
if you can find a source for one of the stalks and want to buy a few, I'd likely buy one, depending on the price. a rear fog should be as bright as your brake lights. leaving it on in clear conditions confuses and annoys drivers. I use it frequently in the winter in Seattle since it rains almost all the time and visibility on the highways is horrible. |
#14 | |
Member#: 254768
TXIC
Thats exactly why I want this, besides the cool factor. We have snow in the winter, torrential rainfall in the spring and really bad fog in the fall so I would like to have something in the back that will be easier to spot. I usually just tap my brakes sooner so people wont follow too close. I will see about sourcing the stalk out. If the hatch here has rear fogs, couldnt you just get a stalk from your local dealer? |
#15 |
Member#: 134010
NESIC
#16 |
Member#: 262030
Tri-State
Nice..I'm sure it'll fit. BTW is the salt & pepper part of the assembly?
#17 |
Member#: 225601
MAIC
Vehicle:2009 WRX Black |
it be cool if there was a way it flashed when you tapped your brakes kinda like the f1 cars
#18 | |
Member#: 258998
Tri-State
Vehicle:2011 Outback Sport Blue Pearl/Steel Silver |
14.5 Rear light: All cars must have a red light in working order throughout the Event which: - has been supplied by an FIA designated manufacturer; - faces rearwards at 90° to the car centre line and the reference plane; - is clearly visible from the rear; - is mounted nominally on the car centre line; - is mounted 300mm (+/-5mm) above the reference plane; - is no less than 595mm behind the rear wheel centre line measured parallel to the reference plane; - can be switched on by the driver when seated normally in the car. The two measurements above will be taken to the centre of the rear face of the light unit. |
#19 |
Member#: 259405
VIC
Vehicle:2011 Impreza STI 4dr Satin White Pearl |
So can I get the kit in canada?
#20 |
Member#: 117776
MAIC
Vehicle:2011 WRX Limited 5dr WR Blue Pearl |
Who'd you source through? I want to do this for my hatch.....
#21 |
Member#: 132458
NWIC
Vehicle:Okie Dokie Fine |
so JDM yo....
![]() I know its not just JDM....I'm making light of the fact that I think its stupid. carry on. |
#22 | |
Member#: 134010
NESIC
![]() Properly used rear-fog lights are very helpful in the case of imclimate weather. Now the jokers that leave them on 24/7, that's another story. ![]() ![]() |
#23 |
Member#: 213232
International
Vehicle:08 Impreza WRX dark mét. |
Funny. We here in Europe, specially Switzerland, are doing everything for clean the car from this rear fog lights.
You don't have the rear fog lights on the hatch and sedan but you want them... |
#24 | ||
Member#: 123843
NESIC
We want the JDM foglamps for the USDM 2004-2005 models and and others outside of the US want the same YMM USDM lamps for their JDM/AUDM/EDM cars. Go figure? ![]() Quote:
Most people in the U.S. don't understand the need, let alone the proper use of a rear fog-lamp because it is not a required item in the States. But if you do look at some States' motor vehicle laws, they actually allow for the use of rear fog lamps and if properly installed (e.g. at least 4 inches / 10cm from a brake lamp). |
#25 |
Member#: 254200
Vehicle:2008 WRX - 316hp Rally Blue |
My Redneck neighbors have these on the hitches of their F350's
| Thread Tools | |
| Display Modes | |
| B9 Tribeca amber rear signals and rear fog light | DomozitoLK | Tribeca Forum | 4 | 02-01-2007 12:42 AM |
| Rear Fog Light Mod, Anyone done it? | wrxEMT | Interior & Exterior Modification | 4 | 11-23-2001 12:21 PM |
| ('93-'01) Rear fog lights on 2002 WRX US models ?? | ginowrx | Impreza Forum | 15 | 06-15-2001 06:34 AM |
| Rear Fog Light Kit | HRE | giulio | Interior & Exterior Modification | 19 | 05-12-2001 06:48 PM |
| Rear Fogs lights-uk Subarus come with? | MichiganRS | Interior & Exterior Modification | 9 | 12-15-2000 09:03 PM |
