Go Back   NASIOC > NASIOC General > Warranty Issues & SOA Problems
Old 11-09-2010, 11:07 PM   #26
David920
Member#: 168092
2011 WRX 5-Door Prm
Obsidian Black
Originally Posted by 09rexwagon View Post
Mine usually does it more in the winter. The dealership replaced the cruise control clutch switch twice. That seemed to fix it but it always came back. I've given up.
FYI, there is someone who posted that they had this issue and the dealership replaced the clutch master cylinder and it never happened again. Who knows.
I agree with Irish....its only normal in the sense that tons of cars do it and the dealerships can't ever figure it out and it doesn't hamper functionality of the clutch etc. I just chalk it up to "it's what makes a Subaru a Subaru" .
Just got a call from service and they are replacing the clutch master cylinder (as you noted on your post). It should be ready Thurs evening. Hoping that fixes it as well.
David920 is offline   Reply With Quote
Old 11-10-2010, 09:25 AM   #27
09rexwagon
Member#: 216135
2011 Civic SI
STX #66, 06 S2000 STR 180
If this does in fact fix it, could you query the service folks at your dealer as to what actually is occurring in the MC? And whether or not it is indicative of a failure of the MC later on or just an annoyance?
09rexwagon is offline   Reply With Quote
Old 11-12-2010, 05:29 PM   #28
Saj5DJ
Member#: 209669
1997 Miata
Mines doing it too, but I figured out it was just the spring on the pedal. Annoying.
Saj5DJ is offline   Reply With Quote
Old 11-12-2010, 09:50 PM   #29
David920
Member#: 168092
2011 WRX 5-Door Prm
Obsidian Black
Well, they replaced the clutch MC and it seems to have fixed the problem. I asked the guy working at service (which I don't believe is an actual tech) if he knew what was the cause and wether it was an indication that it would have eventually did stop working.
He told me that they found the "click" coming from the clutch MC and that they replaced it. He also stated that this is a common click and that its just an annoyance. (sounded like a stock answer)..
I'm just happy it seems to be fixed. That "click" feel/noise was like nails on a chalkboard. The problem also started as a "once in awhile one click," then turned into a "its usually there click." There was also intermittent double/triple clicks, which seemed to be happening more often.
Here's with the triple click: (yes I changed my shoes)
Here's with 2 click, 1 click, no click...
Old 11-14-2010, 10:12 PM   #30
pahaekachilles
Member#: 258632
Has the clicks come back at all? Mine is doing single clicks and is driving me insane! Its not as loud as yours was but i can hear it (passengers cant). If this is a permanent fix, then off to the dealer i will go.
pahaekachilles is offline   Reply With Quote
Old 11-15-2010, 12:26 AM   #31
irish44j
Member#: 191290
09 OPB SM WRXsedan
85 BMW E30 M2 Rallycrossr
Originally Posted by Chader View Post
yep, that's the one I was referring to as well.
Since I"m out of warranty now (except powertrain) I'm not going to replace any parts with OEM that I have to pay for. Will probably go the same route as the guy above if I can find a competent welder!
irish44j is offline   Reply With Quote
Old 11-15-2010, 12:27 AM   #32
irish44j
Member#: 191290
09 OPB SM WRXsedan
btw, mine does it sometimes when I'm not touching the clutch at all...just the brake. So I KNOW it has nothign to do with the clutch M/C.
Old 11-15-2010, 12:36 AM   #33
scooby24
Member#: 56414
2004 Forester XT 5MT
Mine had a bad squeak in my G35 that was the spring in the clutch pedal assembly. I'd guess with a clicking it's the spring binding or popping.
I remedied it by using some lithium grease on the spring and working it into all the nooks and crannies.
For a truly rewarding experience, remove the spring entirely.
Doing this gave me the old school clutch feel back on the G and it was much easier to feel the engagement point.
scooby24 is offline   Reply With Quote
Old 11-15-2010, 09:23 PM   #34
David920
Member#: 168092
2011 WRX 5-Door Prm
Obsidian Black
So far so good. No click(s) so far!
Old 11-17-2010, 05:41 PM   #35
xluben
Member#: 261612
2002 WRX - 750WHP
9.5s @ 150mph
Same thing on my 1 month old car (2011 WRX)! First few weeks were click free, but now it happens every time I push down the clutch.
I brought mine in today and they came to the same conclusion. Master cylinder is on order and should be here in about a week.
The tech that I talked to assured me that it was not an indication of a pending failure, just an annoyance.
Great to hear, I hope it resolves my issue as well!
Old 11-17-2010, 05:51 PM   #36
09rexwagon
Member#: 216135
2011 Civic SI
Thanks for the info. Is the MC something the dealer will have in stock? Or will I have to pull what I did with Honda (my wife's 09 Accord was in the vin range of Accords with a creaky steering column, but the noise was very intermittent and I couldn't get it to reproduce in front of a tech...they also wouldn't order the part till they heard the noise......so I ordered the part myself as if I was going to pay for it....showed up, they reproduced and voila, the part was in the counter with my name on it...though now I wasn't paying ).
Old 11-17-2010, 06:38 PM   #37
Bruins1982
Member#: 240365
2011 WRX Premium
Sedan WRB
Mine clicks also. It has since about 100 miles. Not annoying yet, but I will address it if it gets louder. As for now, I have to be listening for it to notice.
Bruins1982 is offline   Reply With Quote
Old 11-17-2010, 06:46 PM   #38
xluben
Member#: 261612
2002 WRX - 750WHP
9.5s @ 150mph
The noise happens every time in my car. I just brought it in, they listened to it. Then the fooled around with it for an hour and a half, and then they called SOA (or somewhere else) and decided I did need a new master cylinder, and ordered it for me. Should take a week to come in.
Old 11-18-2010, 02:31 AM   #39
NismoSkylineGTR
Member#: 94622
every year there is a new problem damn i wonder if i should buy another subi
NismoSkylineGTR is offline   Reply With Quote
Old 11-23-2010, 08:57 PM   #40
jsmithotterbein
Member#: 214322
11 WRX Sedan
My 09 wrx did the same thing, i never had it looked at though.
jsmithotterbein is offline   Reply With Quote
Old 11-30-2010, 06:58 PM   #41
2011WRX
Member#: 251807
Well my 11WRX just had this clicking noise this morning. I got all the 11WRX issue - speaker buzz, boost gage light/needle.
Damn.... what's next?
2011WRX is offline   Reply With Quote
Old 12-03-2010, 12:48 AM   #42
coopermx
Member#: 239569
2010 WRX
Spark Silver
I just wanted to throw out an update: My pedal stopped clicking this week. It's been cold here for a while, so I don't think it's because of the weather. It had been clicking since September, but feels totally smooth and fine now. No idea why!
Max
coopermx is offline   Reply With Quote
Old 12-03-2010, 10:30 AM   #43
09rexwagon
Member#: 216135
2011 Civic SI
Max
Mine comes and goes. Generally when it 'goes' it's only for a week or two. Sometimes it seems weather dependent, but last winter it was worse than the summer and now this winter I had about a 2.5 week lull where it stopped. There really is no rhyme or reason .
Old 12-03-2010, 10:55 AM   #44
Robin2
Member#: 390
2011 WRX sedan
Plasma Blue
lol..... got this now... kinda annoying... only noticed as i had radio off.
Robin2 is offline   Reply With Quote
Old 12-03-2010, 11:44 AM   #45
Saj5DJ
Member#: 209669
1997 Miata
Same on my '09. I really think it's the spring...
Old 12-03-2010, 11:57 AM   #46
09rexwagon
Member#: 216135
2011 Civic SI
Yeah given that some of the 'fixes' have included the master cylinder, one of these days I'm going to disconnect the rod from the MC and test it to see if it still does it. If it does, then it's the spring and/or other mechanisms down there...if it stops, then it's the MC.
Old 12-06-2010, 08:29 AM   #47
Saj5DJ
Member#: 209669
1997 Miata
FWIW, mine hasn't done it months now, after pretty steadily doing it for around 2 months. The Subaru gremlins are fickle beasts.
Old 12-08-2010, 03:59 PM   #48
damonhimself
Member#: 235835
2011 WRX 5DR
Originally Posted by BAD MF STI View Post
Check those shoes...
I have the black/grey version on those Pumas :-)
damonhimself is offline   Reply With Quote
Old 12-08-2010, 04:52 PM   #49
scooby24
Member#: 56414
I'm telling you guys, the spring is held in by two clips. Pull out the spring, Lube it up and either put it back in, or just leave it out.
Try the clutch out for a day after removing the spring and I think you'll be amazing how much more you can feel the engagement point. Felt so much nicer on my G35.
Old 12-10-2010, 04:10 AM   #50
rexronin
Member#: 237796
Thumbs up
I had the same in my 09 rex, it's the cruise control engagment point
i took mine to the dealer and he told me thats what it was, they can order a new pedal and ***** but you'll forget about it
rexronin is offline   Reply With Quote
clutch pedal clicking noise GeLLo_Boi Newbies & FAQs 6 03-01-2008 09:37 PM
Clutch making clicking / ticking type noise t3ch9 Transmission (AT/MT) & Driveline 2 05-25-2006 03:25 PM
Clutch making a clicking noise popnfresh Transmission (AT/MT) & Driveline 0 06-10-2005 02:28 PM
Weird clicking noise when I put in first and let go of clutch m u f a s i s Transmission (AT/MT) & Driveline 22 02-20-2004 02:06 PM
Click noise when releasing clutch? NicGordon Transmission (AT/MT) & Driveline 0 10-24-2002 01:07 AM
