Old 11-16-2010, 12:39 AM   #776
maxpowr
Member#: 159243
sg3 Turbo Tek Tuned
Hakt Ecu e85 30r 6spd
i drive it every day, 7 days a week, 300 miles a week. 1000 miles into the new motor. 3000 miles into the 6 speed. i'm ready to e-tune! well sort of. i wanna be ready to tune!
Old 11-16-2010, 12:44 AM   #777
maxpowr
Member#: 159243
sg3 Turbo Tek Tuned
maybe the jumpers shot, but i have used it at least 30 times this year and have never removed it. i just disconnected it and retried. no dice. same issue. same voltage difference.
Old 11-16-2010, 12:46 AM   #778
maxpowr
Member#: 159243
sg3 Turbo Tek Tuned
as you can see the ecu is linked to the laptop....i guess i'm gonna try ROMRAIDER for answers...
Old 11-16-2010, 01:01 AM   #779
STi Mikey
Member#: 114631
2007 11.5 @ 118
Stock Turbo Record Holder
4.36v = jumper problem
Take your jumper out, cut the clip, and splice the 2 wires. Not an awesome option, but it should work
STi Mikey is offline   Reply With Quote
Old 11-16-2010, 01:30 AM   #780
maxpowr
Member#: 159243
sg3 Turbo Tek Tuned
where you been all day, mikey? i've read 100 threads with 1000 different explanations.
i never take the jumper out so what difference does it make if i splice it? i don't like cutting my harness, but i don't see the harm in this.
you don't think its the crimp connectors on the longer wires to the green connector switch? i don't either, cause its like an on-off. it does turn the green connector "on".
i guess you have a reason for thinking 4.36v is def a jumper problem. probally past experience.
i hope its the jumper and not the actual wire.
funny thing is, i break the green connector, and the blue connector ends up being a problem? maybe that blue connector has been hit or miss for sometime. i have had open source problems since the beginning...and like every step of the way.
guess i'm lucky i haven't brickt yet already.
Old 11-16-2010, 01:34 AM   #781
maxpowr
Member#: 159243
sg3 Turbo Tek Tuned
i can't believe how much more there is to learn about this car. i have spent everyday for 4 years thinking about this car, and have yet to bore of it. i guess michelles right, i am obsessed.
Old 11-16-2010, 01:47 AM   #782
Phatron
Member#: 36033
CEO PhatBottiTuning
2006 STi GTX3582 + Meth
Well, IMO u need to look at the last thing you did before u had this problem and that would be the green connector switch job.
Do u go into test mode if u flick ur switch and go to acc?
Phatron is online now   Reply With Quote
Old 11-16-2010, 07:18 AM   #783
02RexWI
Member#: 165141
^I dont know if it would do it in the Acc position, I think the ignition has to be in the On position to go into test mode.
02RexWI is offline   Reply With Quote
Old 11-16-2010, 07:43 AM   #784
maxpowr
Member#: 159243
sg3 Turbo Tek Tuned
goes into test mode in the on poisition. i think the switch was working, although i have now since cut it out. i can put it back in. i think the problem is in the jumper block like mikey said. he must be on to something to post with such conviction.
i live by that moto ron..."what was the last thing you messed with?"
Old 11-17-2010, 12:07 PM   #785
maxpowr
Member#: 159243
sg3 Turbo Tek Tuned
So i cut the white connector that the blue jumper connects to. I twisted the two leads together. Now i cant even get in. Fails to connect.
Old 11-17-2010, 12:35 PM   #786
02RexWI
Member#: 165141
Ecu flash doesn't connect to the car's ECU at all?
Old 11-17-2010, 01:24 PM   #787
di2co
Member#: 105648
2006 STI
wrb
Maybe a dumb question but did you strip the wires before twisting them together?
I would beg, borrow, or steal a multimeter so you can actually troubleshoot the issue. Start by checking continuity and resistance through your green test connector switch and wiring extensions. Then check continuity through your "twisted" wires. I don't have the 16bit ecu pinout but they're floating around. If your wiring mods are as they should be (which I suspect is not the case) start moving down the harness until you find the issue.
If you grab some piercing leads you can essentially isolate the wiring you've done and check the connections that you've made. You won't find a faulty connection by checking at your splice unless there is a problem at your switch.
It's possible you have a bad connection where you extended the test connectors to the switch and/or your connections to the switch are faulty. It's also possible you pulled on the harness too much and damaged it elsewhere.
Of course there is always the possibility that lightning has struck your car's test harness leaving it a smoldering pile of goo behind the dash. If this is the case see aforementioned multimeter statement.
The problem with just randomly "fixing" things without actually knowing the cause is that a faulty connection may work sometimes but it really ruins your day when it decides to stop in the middle of a reflash.
disclaimer: I'm not encouraging anyone to actually steal anything, it's a figure of speech.
R/ di2co
di2co is offline   Reply With Quote
Old 11-17-2010, 01:41 PM   #788
02RexWI
Member#: 165141
^I'll encourage stealing
J/K
Old 11-17-2010, 04:15 PM   #789
maxpowr
Member#: 159243
sg3 Turbo Tek Tuned
yeah, i hear ya. i'm either gonna head over to sj subyworks tonight or last minute motorsports friday. i'm not gonna cut anything else till we get a meter on it.
i'm feeling like i'm a bag of mortar away from a brick walled ecu. as easy as that connector came apart , i'm lucky i didn't brick it already.
Old 11-17-2010, 04:18 PM   #790
maxpowr
Member#: 159243
sg3 Turbo Tek Tuned
yeah ecuflash doesn't connect at all. i can learning view and RR logger , but when i try ecuflash, i flip the switch that connects the green connectors. turn the key to on and hit okay on the pc. it immediately stops and gives me a code that it can't connect.
i should have screen shot-ted it...
Old 11-17-2010, 04:54 PM   #791
IMPREZive 02 WRX
Member#: 11436
1999 Impreza RS
eBay racing edition!
That is absolutely a sign that the flash wires are not connected.
IMPREZive 02 WRX is offline   Reply With Quote
Old 11-17-2010, 05:47 PM   #792
maxpowr
Member#: 159243
sg3 Turbo Tek Tuned
I also believe the jumper wires are the problem. Over the years i have pulled on that shortass wire. I need the 02 wrx ecu pin-out. Still waitin on that email mr. Foy.
I will probally try and run a new wire from the ecu...back to the ecu?
Anybody ever attempt this?
Old 11-17-2010, 06:00 PM   #793
Phatron
Member#: 36033
CEO PhatBottiTuning
Old 11-17-2010, 07:34 PM   #794
maxpowr
Member#: 159243
sg3 Turbo Tek Tuned
thats funny...lol. i just did that. where are you doing your stand up act at tonight? the ladies room?
http://www.bakemono-imports.com/suby007.jpg
got this here...thank you nasioc
http://forums.nasioc.com/forums/show...=921315&page=2
Old 11-17-2010, 07:40 PM   #795
maxpowr
Member#: 159243
sg3 Turbo Tek Tuned
so jodie and i discussed that one wire is from the ecu. the other is a ground. when they are connected it grounds out. i don't know what that does when grounded but if i find the right wire, cut it and ground it, i won't have to worry about a jumper block ever again.
any imput is appreciated fellas.
can we hurry this up a bit , i wanna drag this car before the end of the season.
Old 11-17-2010, 07:41 PM   #796
maxpowr
Member#: 159243
sg3 Turbo Tek Tuned
friday the 26th of november is the last weekday test and tune.
Old 11-17-2010, 07:48 PM   #797
maxpowr
Member#: 159243
sg3 Turbo Tek Tuned
or maybe its this one...
jodie has the service manual for usdm 02 wrx, i guess we'll be fine.
Old 11-17-2010, 10:36 PM   #798
maxpowr
Member#: 159243
sg3 Turbo Tek Tuned
Old 11-17-2010, 11:15 PM   #799
02RexWI
Member#: 165141
Ground that bitch and don't look back
Old 11-18-2010, 07:13 PM   #800
RFoy91TSi
Member#: 57488
1998 GC8 EJ205 VF34
12.0@115 STi Mikey Tuned
dude my life does not revolve around your car and that's something that can easily be found with this cool new search engine called google.
RFoy91TSi is offline   Reply With Quote
Message Board Statistics All times are GMT -4. The time now is 09:11 PM.
