#1 |
Member#: 261612
Vehicle:2011 WRX 5 Door NF Performance Stage 1 |
Got a fairly conservative "Stage 1" road tune on my 2011 WRX. Baseline and after tune information is included. Only changes to the car are an SPT Cat Back Exhaust and the 16" steelies and winter tires. RomRaider log was used to create the dyno plot using Virtual Dyno set for the DynoJet calibration (which the Virtual Dyno developers have calibrated the software to). Numbers look about right for a DynoJet. I'm very happy with how the tune turned out. Much smoother and pulls noticeably hard through the low/mid range and up to the top end. Torque increase is very nice
![]() Feel free to discuss! Event: Stage 1 Road Tune Location: MN Ambient Temp: 40F Elevation: 725ft Weather: Cloudy Road Conditions: Flat Tires: General Altimax Artic 215/55R16 ![]() Car: 2011 WRX 5 Door Tuner: Nuke Dyno Info: Virtual Dyno - DynoJet Calibration Transmission: Stock 5 Speed Gear: 3rd Target Boost: 17psi Target AFR: Unknown Fuel: 91 Octane Unleaded Engine/Power Modifications: SPT Cat Back Exhaust Driveline Modifications: None Suspension Modifications: None Other Modifications: 16" Steel Wheels Baseline: Peak HP at RPM: 264hp@6,000rpm Peak Torque at RPM: 285hp@3,200rpm Stage 1: Peak HP at RPM: 275hp@6,000rpm Peak Torque at RPM: 324hp@3,500rpm ![]()
#2 |
Member#: 63738
NWIC
Vehicle:2011 WRX Silver |
Very nice. Can't wait to get a tune for mine, but I'm going to have to
#3 |
Member#: 191290
MAIC
Vehicle:09 OPB SM WRXsedan 85 BMW E30 M2 Rallycrossr |
Nice numbers. Your stock numbers are almost identical to my 09 stock (also with SPT catback), which was done on an in-shop dynojet.
but prepare for everyone to come in here and start saying how bogus those stock numbers are, because they always do, no matter how many stock 09+ wtx dynos we post up here with almost identical numbers, lol.... |
#4 |
Member#: 218771
Tri-State
Vehicle:2006 Mustang GT Vert Babyboomer White |
Congrats on some great numbers. I just went stage two last night, can't wait to get some miles on the tune and really rip on it!
#5 | ||
Member#: 261612
The program can also be set for Mustang dyno's. If you change it to that setting the numbers (both baseline and stage 1) are very, very close (within a couple hp) to the numbers that COBB shows on their dyno plots. I'm looking forward to getting a downpipe eventually. Stage 2 sounds like a good place to aim for. I probably won't go anywhere past that, though. |
#6 |
Member#: 34084
Vehicle:2002 wrx |
The Tq increase looks right on target. The Hp increase is a little low, probably due to the 91 octane. Most stage 1 increases are around 30 hp and 40 tq give or take. Good job none the less! What was the target AFR? and how does it look now? Most stock afr's look like crap...
#7 | |
Member#: 261612
#8 |
Member#: 210644
MWSOC
Great #'s! Thumbs up for Nuke. He also tuned my 04' sti on e85.
#9 | |
Member#: 108089
MWSOC
Vehicle:2003 WRX NF Performance |
A few more hp can still be made but he is happy with it, so we'll leave it at that. |
#10 |
Member#: 261612
#11 |
Member#: 258917
Vehicle:2011 WRX SWP |
Thats a nice increase over stock, especially for a conservative tune. Man I wish I had a tuner close by.......
#12 |
Member#: 26933
BAIC
Vehicle:2006 STI CGM |
#13 |
Member#: 261612
How do you tune remotely?
#14 |
Thanks Sir Alex!
Moderator Member#: 88606
MWSOC
Vehicle:2011 GMC Sierra 1990 Miata |
They, like a few others, can get your mod list and create an ecu ROM that they email to you. You'd have to flash it, do some WOT pulls, and send the logs back for them to make some minor tweaks and send you a revised ROM. Not quite as good as having them in the car doing the work, but it works.
#15 | |
Member#: 36033
SCIC
Vehicle:CEO PhatBottiTuning 2006 STi GTX3582 + Meth |
i cant magically change any different parameters if im sitting in your passenger seat. there is literally no difference in doing the pull with me in the passenger seat.....or emailing me the log 5 minutes later. the only thing being in person helps with is trouble shooting problems. nuke, was this in OS? http://forums.nasioc.com/forums/show....php?t=1410201 |
#16 | |
Member#: 261612
#17 |
Member#: 108089
MWSOC
Ron, this was with both Ecuflash & RR
#18 |
Member#: 82965
I take it these figures are at the flywheel?
#19 |
Member#: 261612
These are wheel horsepower numbers, calibrated for a Dynojet.
Here's the Mustang calibrated numbers: Car: 2011 WRX 5 Door Tuner: Nuke Dyno Info: Virtual Dyno - Mustang Calibration Baseline: Peak HP at RPM: 230hp@6,000rpm Peak Torque at RPM: 248hp@3,200rpm Stage 1: Peak HP at RPM: 240hp@6,000rpm Peak Torque at RPM: 283hp@3,500rpm ![]() Last edited by xluben; 11-30-2010 at 09:55 AM. |
#20 |
Member#: 36033
SCIC
well....they are whp, BUT the stock car was making 265whp.....which is equivalent to the factory 265 CRANK hp rating.......so you're pretty much walking a line of semantics.
It was taken on the road and is a whp reading....but one can also make the case that this software gives a CRANK hp reading based on the 265 whp equaling the factory 265 crank hp rating. |
#21 |
Member#: 82965
Sorry, you're saying a factory WRX has around 330bhp at the flywheel then? The factory car makes 265bhp at the flywheel. It definitely does not make 265 at the wheels.. 275 at the flywheel sounds right for a stage 1.
#22 | ||
Member#: 261612
If lower numbers will make you happy, look at the Mustang calibrated plot I just posted. 230whp / 248wtq (stock at the wheels) These numbers are right on what COBB and others have posted with Mustang dyno's. Assuming 20% loss that is: 288bhp / 310btq (stock at the crank) Which is well over the manufacturer rating. I know that could be argued for days, but I believe the WRX is highly under-rated. Presumably to keep STI's selling. If you compare the acceleration times between the WRX and STI, it isn't that hard to believe that the power would be similar. Assuming you can agree with the Mustang calibrated numbers, then all it comes down to is the software calibration for the Dynojet. The 14% difference is well within the range people see when comparing the two actual dyno's, and even a post in this thread claimed the Dynojet numbers looked like his (from a real dyno): http://forums.nasioc.com/forums/show...6#post32506536 So, if you're asking whether or not I think it could read 264whp/285wtq on some Dynojet's, then yes, I do think so. And if you really want to calculate that back to numbers at the crank, then I do agree with your 330bhp/356btq calculation. But the point really isn't the number. The point is the plot. Nuke gained 30+ ft-lb's of torque from 3k to 5k rpm's, and up to nearly a 50 ft-lb increase at some points. And if you ignore the hump near the peak of the stock hp curve, the tune added around 20hp from 3k rpm's on up. Feels good to my butt-dyno. ![]() |
#23 |
Member#: 63738
NWIC
#'s on a dyno r all going to b different due to different dyno's, opperators, and conditions. Glad u like ur tune and thanks for sharing. Good increase for a conservative tune
#24 |
Member#: 3687
MWSOC
Vehicle:MY99 GF4 JDM 6spd NF Performance |
I'mma have to get a ride in this!!!!
#25 | ||||
Member#: 261612
Virtual dyno also offers the ability to "calibrate" the dyno to your local dyno by entering a custom Cf value. I found a baseline run from an 09 WRX that was done on a local Dynojet dyno. It came in right between the Dynojet and Mustang numbers that the Virtual Dyno software gave me: Quote:
![]() Sure!!!! Maybe I can get a ride in yours too ![]() |
| Thread Tools | |
| Display Modes | |
| 2011 WRX stock vs. SPT Exhaust | O.C.D. | General Community | 259 | 09-16-2012 01:37 PM |
| 2008 WRX Stock vs. Stage II dyno tuning | Dyno Flash | Proven Power Bragging | 41 | 08-29-2012 10:05 PM |
| Decision: 2011 WRX new vs. 2008 STI w/ 9500 mi. | KURB21 | General Community | 39 | 03-23-2011 12:46 PM |
| 2011 WRX Stock Exhaust - Sedan vs Hatch? Sport Exhaust? | xluben | Newbies & FAQs | 72 | 11-08-2010 08:52 PM |
| 2011 WRX Base vs Premium | bm3r | General Community | 25 | 09-24-2010 07:37 AM |
