Old 11-01-2010, 05:18 PM   #26
tobyport
Member#: 261691
2011 STi
PBP
Where did you source? Has anyone contacted japanparts.com?
tobyport is offline   Reply With Quote
Old 11-01-2010, 05:29 PM   #27
scotheocelot
Member#: 254768
2011 STi Sedan
Originally Posted by Big-E View Post
We want what we don't have and you don't want what you have.
We want the JDM foglamps for the USDM 2004-2005 models and and others outside of the US want the same YMM USDM lamps for their JDM/AUDM/EDM cars.
Go figure?
Great response! Basically yes we love what we cant have over here. Maybe our fellow Subbie owners can work out an international trade. You guys ship over the UK options like the adjustable spoiler, roof vane and rear fog & Recaro seats. We (USA) will give you a 4" plastic piece, non adjustable spoilers and fatty mcgee seats
scotheocelot is offline   Reply With Quote
Old 11-01-2010, 05:47 PM   #28
ianw33
Member#: 198293
very true
ianw33 is offline   Reply With Quote
Old 11-01-2010, 06:12 PM   #29
SomeoneWhoIsntMe
Member#: 160814
2002 WRX Wagon
I'm thinking about doing one of these in my rear bumper after my friend bought a wagon with an evo rear fog installed on it
http://www.rallylights.com/detail.aspx?ID=4287
SomeoneWhoIsntMe is offline   Reply With Quote
Old 11-01-2010, 06:17 PM   #30
GuamSTI
Member#: 210071
04 STI
Just curious the 04' STI models do they have a rear fog lamp when sold in Europe?
GuamSTI is offline   Reply With Quote
Old 11-01-2010, 11:06 PM   #31
steverx05
Member#: 128269
You guys will be lucky if this is mostly plug-n-play. The one for the hatch, not so much. I had to run a wire all the way from the fuse panel under the dash, back to the hatch to run the rear fog. I just wired mine to turn on with my front fogs so I didn't have to source the Euro stalk.
steverx05 is offline   Reply With Quote
Old 11-02-2010, 11:51 AM   #32
Officer Cartman
Member#: 187416
2011 WRX Sedan
Thanks for doing the legwork Scott.. Can you give us a ballpark figure on what the parts cost? (Are we talking cheap like $50, or more like $500?)
I have rear fogs on my other car, but in 11 years I've probably used them less than 5 times. So I'm thinking about just getting the reflector and accompanying hardware needed to mount it, but skipping the actual light/harness.
Ricey? Maybe, but I like the way it looks..
Officer Cartman is offline   Reply With Quote
Old 11-02-2010, 02:22 PM   #33
ETacv
Member#: 134010
2007 WRX bren-t00ned
UGM
It seems that the placeholder for the rear fog is there, just need to remove that trim piece.
ETacv is offline   Reply With Quote
Old 11-02-2010, 04:26 PM   #34
Son of Zartan
Member#: 216279
2014 Crosstrék
really nice find!!!
shame on the naysayers who make jokes about JDM parts . Dont kid yourselves, cause we know you'd be the first in line to buy JDM recaro seats if they became available here for 04+ models!
Son of Zartan is offline   Reply With Quote
Old 11-02-2010, 04:51 PM   #35
scotheocelot
Member#: 254768
2011 STi Sedan
Total Parts Cost w/Shipping was $155 USD. Once I have time to install it, I may not need all of the parts I have shown. These parts were selected by Subaru as an assembly. So say you needed to replace the entire rear bumper and its accessories, you would need all of these parts. However, just replacing the plastic piece on our USDM may not require all items shown.
If I have to, I will find a similar connector to this rear fog plug that will allow me to pin my own connector and run the wire to the relay for the front fog light options which I will not use. The front fog light relay and wires should be there since its a dealer option. If that is the case I will simply buy the stalk for the USDM front fog light operation and simply tie it to the rear instead. This way it gives a clean factory look and operation. Otherwise you can simply add your own switch on the column or dash as you see fit.
I went by the local dealer who has a STI on the showroom, got underneath and checked the backside of the plastic panel. From what I can tell is it has clips on both sides that hold it in place. It is a separate piece from the rest of the rear diffuser so it can be removed and replaced with the rear fog. However, until mine comes in and I can take the bumper off to get a clear view of what is back there to mount, I do not know how plug and play the light is.
Scott
Old 11-02-2010, 05:24 PM   #36
steverx05
Member#: 128269
Originally Posted by Son of Zartan View Post
really nice find!!!
Joke is on them...this isn't even a "JDM" piece, it's technically "EDM".
Old 11-02-2010, 06:03 PM   #37
GuamSTI
Member#: 210071
04 STI
Let's do it!
Old 11-02-2010, 07:53 PM   #38
Big-E
Member#: 123843
2016 STI LTD
CWP
Since the rear fog lamp is not a requirement in the US, I would guess that the wiring will not be in place on a USDM model. But again, we'll see what happens when you take care of this on your car.
Big-E is offline   Reply With Quote
Old 11-26-2010, 08:16 AM   #39
oobe
Member#: 175385
2011 STI Sedan
any update on the installation of this? My STI will be here soon and I'd like to get one of these.
oobe is offline   Reply With Quote
Old 11-26-2010, 12:47 PM   #40
steverx05
Member#: 128269
The USDM GDs have the wiring ready to go for a rear fog...the GR hatch does not though. It will be interesting to see how plug-n-play this piece is on the new sedan.
Old 11-26-2010, 01:25 PM   #41
STI 2 NV
Member#: 31748
'15 WRB WRX
For the STI only?
STI 2 NV is offline   Reply With Quote
Old 11-26-2010, 01:32 PM   #42
steverx05
Member#: 128269
Originally Posted by STI 2 NV View Post
For the STI only?
Looks like you guys have the same rear bumper so all of this should technically work on the new WRX sedan as well.
Old 12-21-2010, 09:57 PM   #43
tobyport
Member#: 261691
2011 STi
PBP
Default GR Rear Fog Install
US Piece is actually one piece that runs all the way across. So the piece must be cut in two places to allow for the fog light. Also, I'm studying this on a lift and 1) looks like rear bumper must be removed in order to properly install the light 2) I have not found any plug/play wiring available. Has anyone else tackled the GR Rear Fog Install?
Old 12-22-2010, 12:02 AM   #44
Moneym3593
Member#: 157376
2015 CWP STI Sedan
Ordered June 3rd, 2014
the bumper does not have to be removed... you can bend it out a little from under.. also the wiring is super easy... i wired mine to my brake light so that it comes on with the brakes.. harness that comes with it has all the clips that you will need for install.. also i bought mine on japanparts.com.. comes as a kit.. intsall took about half hour from start to finish...
Moneym3593 is offline   Reply With Quote
Old 12-22-2010, 12:12 AM   #45
steverx05
Member#: 128269
That's not the correct way to wire the rear fog light. It should be wired to the stalk (or separate switch) in the cabin to be used in inclement weather only. It's the one and only purpose for the light. You already have enough brake lights on the car the way it was designed, it's useless to wire this as a FOURTH brake light.
Old 12-22-2010, 12:13 AM   #46
Byzantium
Member#: 207826
85k 2002 WRX
Correct Fitment Crew #034
So, why exactly do you need these again?
Byzantium is offline   Reply With Quote
Old 12-22-2010, 12:22 AM   #47
steverx05
Member#: 128269
It's to keep people from slamming into the back of your car in really bad weather.
Old 12-27-2010, 11:22 AM   #48
Louie
Member#: 43393
2014 Audi a6
Daytona Gray
So where can you order these? I was going to hit up the posts department at my subie dealer since you provided the part numbers.
Louie is offline   Reply With Quote
Old 12-27-2010, 11:24 AM   #49
Byzantium
Member#: 207826
85k 2002 WRX
Because the stock tail lights are not bright enough?
This is going to be the next useless Hella Supertone-esque mod isn't it.
Old 12-27-2010, 12:32 PM   #50
Evil STI
Member#: 36792
2015 Z/28 (Vader)
Gold chains & meatballs
I'm wondering how this rear fog light activates the brake pedal in the car behind you. Bluetooth?
The truth is that I can purchase red reflective tape and accomplish what most people are trying to do- adding something interesting to show off on their cars in the Members Gallery.
Evil STI is offline   Reply With Quote
B9 Tribeca amber rear signals and rear fog light DomozitoLK Tribeca Forum 4 02-01-2007 12:42 AM
Rear Fog Light Mod, Anyone done it? wrxEMT Interior & Exterior Modification 4 11-23-2001 12:21 PM
('93-'01) Rear fog lights on 2002 WRX US models ?? ginowrx Impreza Forum 15 06-15-2001 06:34 AM
Rear Fog Light Kit HRE | giulio Interior & Exterior Modification 19 05-12-2001 06:48 PM
Rear Fogs lights-uk Subarus come with? MichiganRS Interior & Exterior Modification 9 12-15-2000 09:03 PM
