#1 |
Member#: 262190
Vehicle:2011 Wrx DGM |
Has anyone dynoed theirs? I keep hearing "Oh they rated the HP to the wheels this year. So it really has 3xxhp" The dyno results I have seen have baselines ranging from 219awhp to 240+awhp. Idk maybe its just me but thats a pretty big difference for stock. Those dynos were from the cobb site:
http://accessecu.com/dyno/ Im unaware of any dynos in my general area otherwise id be here posting results lol
#2 |
Big Ron
Moderator Member#: 18062
MAIC
No one on the planet earth can equate chassis dyno to engine dyno. What it says on subaru.com is the HP rating. What is says on XXXXX dyno is what it says. NEVER the twain shall meet.
#3 |
Member#: 240688
W. Canada
Vehicle:06 WRX |
Don't worry about the absolute number, look at your baseline number and then compare the after numbers. Dyno #'s are all but useless unless you have a before/after xyz mod. They tell you how much you've gained, or lost. Someone posts results from a lower reading dyno at elevation and everyone tells them their car is broken...
#4 |
Member#: 259833
NESIC
Vehicle:2011 WRX limited 4dr WRB !!!! |
Dyno racing is fun...until you realize you're arguing about numbers that don't mean to much.
Results and driver are what matters. This has all been covered on another thread |
#5 |
Member#: 262190
I was just interested, I guess ill just wait to dyno after I get some goodies
#6 | ||
Member#: 261612
Vehicle:2011 WRX 5 Door NF Performance Stage 1 |
STI, 2008, 233/253, Barnes, Andrew STI, 2008, 239/258, COBB Tuning STI, 2008, 247/245, Hoffman, Aran STI, 2008, 245/242, Motorsports, Performance STI, 2008, 236/238, Pickett, Rob STI, 2009, 243/245, Diens, Tim STI, 2010, 228/239, COBB Tuning STI, 2010, 226/240, Pentimonti, Tony STI, 2011, 236/227, Mitchell, Mario STI, 2011, 250/254, Pease, Dave STI, 2011, 251/255, COBB Tuning STI, 2008+, 239/245, AVERAGE WRX, 2009, 231/239, Brackenbrough, Mike WRX, 2009, 241/239, Braun, Jeremy WRX, 2009, 233/248, Keenan, MJ WRX, 2010, 244/258, COBB Tuning WRX, 2010, 244/258, Branen, Charles WRX, 2010, 246/259, Gill, Evan WRX, 2011, 223/255, COBB Tuning WRX, 2011, 251/255, Miller, Josh WRX, 2011, 218/251, Vonali, Ritter WRX, 2009+, 237/251, AVERAGE You can see that even though the STI has a much higher HP and TQ rating than the WRX, they dyno in the same range. Of course there is considerable variation from car to car, but in the end the averages are pretty close. Seems to be a reasonable amount of data to back the assumption that 09+ WRX's are under-rated. Maybe this is just me rationalizing my WRX purchase ![]() Quote:
#7 |
Member#: 265266
The best way to really see the results of any modification, is get your baseline dyno pull.. then when you add parts, hit the dyno again...
But the baseline is the most important.. bone stock.. then let the mod bug bite! |
#8 |
Member#: 143391
MWSOC
Vehicle:2007 WRX TR R.I.P Colin! :( |
Thous dyno # posted for the STI and WRX leave out one important factor.
The gear the pull was done in. The WRX was most likely done in 3rd while the STI was done in 4th. I have a seen a Cobalt SS S/C that has gearing vary close to the WRX do a pull in 3rd then do one in 4th not 15 min later and show a 35hp loss. Then do another 3rd gear pull and show almost the exact same #s it did on the first pull. Later. |
#9 |
Member#: 201483
SCIC
Vehicle:2010 WRX WRBM |
They also have completely different gearing ratios... The STi is always done in 4th because that is one of the longer gears, the wrx in 3rd for the same reason. Should we all just start doing 1st gear dyno pulls so everyone is closest to equal?
#10 |
Member#: 261612
So a 3rd gear pull on a dyno set up for a 3rd gear will give a different result than a 4th gear pull on a dyno set up for 4th gear?
#11 |
Member#: 201483
SCIC
No. Dynos are set up and calibrated for what your gonna use them for.
#12 |
Member#: 110783
Tri-State
Vehicle:2010 WRX Satin White Pearl |
Dynos are just tools for tuning. Dyno before and after mods to see any increases in whp. Go to the track to see how fast it is.
| Thread Tools | |
| Display Modes | |
| 09 wrx with 235s off an '11 wrx | irish44j | Member's Car Gallery | 16 | 11-09-2010 08:01 PM |
| '11 WRX 5-door suspension upgrade totaling < $1k | KMA2 | Brakes, Steering & Suspension | 29 | 09-04-2010 11:26 AM |
| It appears that the '11 WRX will have red stitching on.. | lovin' it | News & Rumors | 18 | 08-15-2010 08:51 PM |
| Satin Black wrap on 08+STi/'11 WRX? | AccelerationIsLife | Interior & Exterior Modification | 2 | 08-04-2010 12:09 PM |
