Old 12-03-2010, 06:58 AM   #1
danchiiik
Member#: 254323
Default Help with ROTA Grid Fitment for 02 WRX
Hey, im looking to purchase white rota grids for a 02 wrb wrx.
Would 18 x 9.5's with a 35 offset fit without rolling the fenders?
would i need a spacer to clear the brakes?
would there be any problem with having these wide rims on a stock wrx suspension?
Im also looking for a -4 camber, what would i need to buy in order to have a -4 camber with these rota grids.
and about the tires, are there any pros/cons to stretched and non stretched tires because i really like the stretched tire look.
Would running this setup affect the suspension in any way?
I dont know much on this therefore im looking for help from you guys that have ran or are running this setup or know about it.
Thanks!
danchiiik is offline   Reply With Quote
Old 12-03-2010, 09:44 AM   #2
sc00by4life
Member#: 97135
you'll need to roll fenders. Those will clear wrx brakes just fine, however they will not clear brembos without a spacer if you ever decide to upgrade.
what the **** do you want -4* camber for? That is completely unnecessary and unneeded.
If you are scared of modifying your fenders, you WILL have to stretch your tires. If you did some research, you'll see that it decreases overall grip and will aid the tires in breaking loose (due to a super stiff sidewall). Theres always the chance of popping a bead on a pothole as well. The point of stretching tires is to GO LOW, so if you are at stock height....I'd walk away from this.
It wont effect the suspension, but it will look immensely stupid unless you are on coilovers and LOW. There are a few examples of people buying aggressive fitments on stock suspension in the Members Car Gallery, and it looks retarded. Aggressive fitments on subarus covers alot of points in order for to get the look you want. Camber (not -4*, but you will need to run 2*+ depending..), ride height (LOW), willingness to modify fenders (roll, pull, etc), and a proper suspension set-up that can handle all of that.
This isn't a super friendly fitment if you don't understand all the characteristics that go into this type of set-up.
Old 12-03-2010, 10:26 AM   #3
nhat
#Belieber
Member#: 140163
03 STi
hellaflunctional
the wheels will but tire size will dictate whether or not you rub on the fenders
seriously?
yup, it'll look incredibly stupid.
there is absolutely NO way for you to get even close to -4* camber on stock suspension
like as stated before, it's gonna look really stupid with stock suspension.
nope, it'll just look really stupid.
Thanks!
next time, search. this topic has been covered over and over and over. and please don't give us the 'i'm busy, i don't have time to search.'
nhat is offline   Reply With Quote
Old 12-03-2010, 10:34 AM   #4
danchiiik
Member#: 254323
thanksfor the infoo!
Old 12-03-2010, 10:43 AM   #5
danchiiik
Member#: 254323
seriously?
Rolling the fenders isnt much of a big deal. If you took the time to actually read instead of being a smartass, i asked what would i need to buy have -4 camber, obviously talking about suspension. I also said that i dont know much about this topic so by you replying to me as if im an idiot, well... you're the idiot. all i asked for was help so if you wanna act like a moron, pick another thread.
Old 12-03-2010, 10:55 AM   #6
VDMTom
Member#: 105226
08 Impreza
Coilovers, maxing out top camber plates and getting SPC/Eibach camber bolt kit infront will yield you to -4* camber.
I've done it.
VDMTom is offline   Reply With Quote
Old 12-03-2010, 11:58 AM   #7
danchiiik
Member#: 254323
I've done it.
http://yhst-16298468643776.stores.ya...aboforsuw.html
http://www.racinglab.com/spc-camber-kit-subaru-006.html
are either of these the bolt kits your talking about? they both say -/+1.75 camber so im assuming with coilovers id be able to get -3.5 - -4.0 camber?
Also what decent coilovers are there that arent too pricy (under $1,000)
Old 12-03-2010, 06:59 PM   #8
sc00by4life
Member#: 97135
If you are comfortable spending $1000, then spend a little bit more and get some Stance for ~$1500. They come with camber plates front + rear. I am able to get about 3* of camber with just the plates.
Old 12-04-2010, 05:28 AM   #9
danchiiik
Member#: 254323
yea a friend of mine used to have a bugeye and he had stance gr+ pro coilovers but he was able to get -4 camber all around. This is his old car and what im going for...
Old 12-04-2010, 11:33 AM   #10
Byzantium
Member#: 207826
85k 2002 WRX
Correct Fitment Crew #034
That car is an abomination. I warned you exactly why in your ClubWRX thread. There is not a single good reason for hellaflush to even exist. Everything about it detrimental to the car, its ride, and your wallet.
Uh, what? It absolutely does affect the suspension and I find it odd that you of all people would deny that. He's throwing off his suspension geometry and putting additional stress on everything from the steering column all the way down to the hubs. These parts do eventually fatigue.
Byzantium is offline   Reply With Quote
Old 12-04-2010, 11:41 AM   #11
danchiiik
Member#: 254323
so your saying that having 18x9.5 rims on aftermarket suspension coilovers such as stance gr+ pro is bad?
Old 12-04-2010, 11:43 AM   #12
Byzantium
Member#: 207826
85k 2002 WRX
It's going to be bad on any suspension with the use you are wanting them for. Aside from the offset problems, no daily driven Subaru would justify anything over 8.5" wheels. Stance coilovers aren't the greatest choice either.
Old 12-04-2010, 11:58 AM   #13
danchiiik
Member#: 254323
they obviously arent the greatest, id like some cuscos or tiens but money money moneyyy unless your willing to buy me them =D
Old 12-04-2010, 12:06 PM   #14
feint05
Member#: 152984
2004 jewbaru
jewbuilt, polish tuned
you need coilovers with fr and rear camber plates, rolled fenders and a 235 tire
thats about as simple as i can put it.
i by no means agree with doing this
feint05 is offline   Reply With Quote
Old 12-04-2010, 12:08 PM   #15
Byzantium
Member#: 207826
85k 2002 WRX
235s are too small. 255s minimum.
Old 12-04-2010, 12:30 PM   #16
danchiiik
Member#: 254323
theres no way 235's will fit, i dont want stretched look. like byzantium said, 255's will do but im now iffy about 9.5"s... for the rear 9.5's are perfect but its abit too wide for the front
Old 12-04-2010, 12:32 PM   #17
danchiiik
Member#: 254323
rolling fenders isnt a problem but what does it mean to pull fenders?
Old 12-04-2010, 12:49 PM   #18
feint05
Member#: 152984
2004 jewbaru
You Basically Flare The Stock Metal Out Slightly, And I Agree Completely, But Look At The Agressive Fitment People Thats What They Do
Old 12-04-2010, 03:40 PM   #19
sc00by4life
Member#: 97135
he wont fit that with out pulling.
pulled fenders: (my old fitment)
I need to get some new pictures with my fitment now. 17x9 +10f/+15r w/ 255's.
Old 12-04-2010, 07:43 PM   #20
Kaycaz
Member#: 266012
rolling the fenders sounds expensive
Kaycaz is offline   Reply With Quote
Old 12-04-2010, 09:12 PM   #21
sc00by4life
Member#: 97135
thats not typically something you take into the shop to do.....
Old 12-04-2010, 10:03 PM   #22
jimbosv650
Member#: 261307
04 wrx wagon
about the cost of a baseball bat
jimbosv650 is online now   Reply With Quote
Old 12-05-2010, 12:53 AM   #23
sc00by4life
Member#: 97135
I was talking fitment wise :P.
Besides, he didnt ask if it would effect the actual performance of the suspension
Old 12-05-2010, 05:12 AM   #24
danchiiik
Member#: 254323
scooby4life... your car = gorgeous!
what coilovers do you have on?
Old 12-05-2010, 07:25 AM   #25
IMPREZive 02 WRX
Member#: 11436
1999 Impreza RS
eBay racing edition!
With stretched tires and -4* camber, you get maximum sidewall contact patch!
IMPREZive 02 WRX is offline   Reply With Quote
Help with rota grid 18x9.5 or 18x10 fitment MPerez865 Tire & Wheel 62 11-13-2010 10:05 AM
Need Help On Uppipe/Downpipe Choices for 02 WRX kylanmarlow Factory 2.0L Turbo Powertrain 13 06-01-2010 07:51 PM
Looking For Airbox With Scoop And Elbow For 02 Wrx! duslam00 Private 'Wanted' Classifieds 1 04-22-2009 09:40 AM
Need help with OEM part numbers for a WRX 02…. AXA Factory 2.0L Turbo Powertrain 8 01-06-2005 11:57 AM
Help With Defi VSD Basis on 02 wrx meshuggah Electrical & Lighting 2 03-03-2004 12:19 AM
Message Board Statistics All times are GMT -4. The time now is 11:17 PM.
