Old 12-04-2010, 10:29 AM   #26
preludeIVgen
Member#: 258688
Still same trouble with mine. Using ecuflash 1.29 I get:
[13:32:46.535] denso02_bootloader_cmd_start
[13:32:47.768] denso02_bootloader_cmd_start
[13:32:49.000] denso02_bootloader_cmd_start
[13:32:50.232] denso02_bootloader_cmd_start
[13:32:51.465] denso02_bootloader_cmd_start
[13:32:51.886] kernel get version
...then an error message pop-up.
Ecuflash 1.42 doesn't recognize the interface cable at all. Seems like a good chap, but I'd love to see this writeup from a client of his.
preludeIVgen is offline   Reply With Quote
Old 12-04-2010, 11:10 AM   #27
lethaldose
Member#: 189360
What was the rest of the error message?
Main thing about 02/03 ECU's with our cable is timing. When we first tested these with ECUflash 1.42.25.xx and our drivers you had to confirm ECUflash before the cooling fans performed their test cycle. (only with 02/03 cars) 04+ didn't matter.
The fans kick extremely fast so it does take a few attempts to get it right. I've had some mixed results from people regarding the bugeyes, had many that had no issues after they got the timing down, then had some that would still have an error.
I'm going to get my hands back on an 02 next week hopefully and confirm again with all latest versions of the software and make a video guide to solving the timing issues.
lethaldose is online now   Reply With Quote
Old 12-05-2010, 02:39 AM   #28
preludeIVgen
Member#: 258688
that, sir, would be amazing. I'm committed to seeing this work, your help will be of great assistance to everyone!
Old 12-05-2010, 08:56 AM   #29
lethaldose
Member#: 189360
not a problem man i started this whole thing to help out because i hated paying 100 bucks+ for a V1.3 cable haha. I confirmed these when i first tested them out ( at the time i was doing a hybrid build for an 02, and had an 03 down for a 2.0 rebuild) so i had plenty of access to them.
The only year model i didn't personally confirm was the 2000 JDM model but i had two customers over seas test and confirm no problems. I will let you guys know something asap.
Old 12-05-2010, 02:49 PM   #30
mtnbikeman123
Member#: 77939
00 GF Rustbucket
Subscribed for an answer. I have an 02 and having the same issues, tried as many combination of timing as possible, no dice.
mtnbikeman123 is offline   Reply With Quote
Old 12-05-2010, 03:15 PM   #31
robtmc
Member#: 23659
Chapter/Region: HIIC
2002 WRX Sport Wagon
Platinum Silver
Same here, watching to see if this can work.
Cody, if you don't mind, can you post decent resolution pic of the components on the interface board? I have looked at several of the "Vag" cables, and all are different. And none like the 1.3 Openport configuration I have the schematic and a photo of. Lots of little things like unconnected DTR/DSR lines and such that the Tactrix part does use. The 12V line to pin 11 has evolved from a constant on regulator, to one switched by the RTS line.
If you do not want to show the guts, I understand. Just trying to figure out if it is a mimic of the original 1.3 or a functional equivalent.
robtmc is offline   Reply With Quote
Old 12-05-2010, 07:56 PM   #32
preludeIVgen
Member#: 258688
Does anyone else get this message when using ecuflash 1.42?
[11:52:19.828] Using interface FT232R USB UART A400h162
[11:52:19.828] interface close
[11:52:19.843] unable to connect to vehicle interface.
[11:52:19.843] interface close
Old 12-07-2010, 06:32 PM   #33
Big Joe
Member#: 3722
2002 WRX Wagon
I get the same log and the error message just says error see log.
Big Joe is offline   Reply With Quote
Old 12-08-2010, 08:28 AM   #34
preludeIVgen
Member#: 258688
Come on Cody! Let's see a writeup/video of this working... i think we've all been pretty patient
Old 12-10-2010, 10:18 PM   #35
mtnbikeman123
Member#: 77939
00 GF Rustbucket
Tried to sync the cable again, this time I followed this process, still no luck. I have logged successfully though so I assume the cable is working correctly. I would appreciate some input here
Old 12-10-2010, 10:37 PM   #36
scoobystas
Member#: 26568
2003 Yellow Bugeye
Version 8-Vf37
dude get your money back if its that much of a hassle. Even the vag com cables on ebay for $12 will log with rom raider.
at this point, if you have an 02-03...you pretty much have to buy a tactrix cable.
scoobystas is offline   Reply With Quote
Old 12-10-2010, 10:47 PM   #37
MykuL
Member#: 122451
01 RSTI w/07 EJ257
6MT Brembos BBSs Interior
Cody from BFM has tested these as fully functional with a USDM bugeye, and has said he'll try to get a clients bugeye back to do a full walkthrough next week.
I'm limited on time as I'm now officially overdue for an inspection, so I broke down and bought a Tactrix 1.3 cable off a member here; worked on the first try for both reading and flashing.
But BFM is trying to offer a solution for the absurd price of a Tactrix cable. Hopefully they pull through for us bugeye owners!
MykuL is offline   Reply With Quote
Old 12-10-2010, 11:16 PM   #38
scoobystas
Member#: 26568
2003 Yellow Bugeye
Version 8-Vf37
tactrix working on the first try, you've just proved my point, you get what you pay for
Old 12-10-2010, 11:33 PM   #39
MykuL
Member#: 122451
01 RSTI w/07 EJ257
Unfortunately yes, we're stuck paying for the engineering behind the Tactrix cable for now . I wasn't trying to disprove your point, just trying to rally some hope!
Old 12-10-2010, 11:48 PM   #40
robtmc
Member#: 23659
Platinum Silver
The design of the 1.3 cable is not mysterious, just time and $$ intensive to make your own.
There ARE significant differences in the Tactrix versions and the Vagcom stuff. Ecuflash code is written to talk to a Tactrix cable, or one with the same functionality. That is why I requested a photo of one of the BFM PCB component layouts. I could determine from there with a degree of certainty how faithful the part was to a real 1.3 (or 1.2) cable.
Will wait to see what is forthcoming. No way I will pay $50+ for another version of a Vagcom, but if it is indeed a functional reproduction.......... Would save me time making my own from a recently bought Vagcom that will not work with Ecuflash (no surprise, but i thought, What the hell). Does not share the same circuitry. Really only needs a few components totaling less than $20 from Digikey and some handiwork with wiring.
Old 12-13-2010, 03:55 PM   #41
lethaldose
Member#: 189360
I will be getting my hands on an 02 late next week to do some videos on timing the cables and confirming that they work.
I've switched manufacturers of the blank OBD cables/chips that i use a few times since i originally tested them on the 02/03's. I've had some people with no problems then some with problems, so i want to make sure its not a particular brand/source that is causing my problem. So i've got 2 of my latest ones ready to test out and one of the originals as well as a straight up tactrix V1.3 cable. So i will do a video pitting them against each other so i can show the timing difference with our cable for syncing.
I'm already piecing up a "how-to" video on installing the drivers, and going through ECUflash. Which the majority already knows, but its nice to have something to refer to none the less.
I will post the links up to my findings ASAP!
Old 12-14-2010, 01:38 PM   #42
Subyaddict
Member#: 228469
2003 Wrx Wagon
Good deal. I bought cable from you yesterday.
Subyaddict is offline   Reply With Quote
Old 12-17-2010, 11:44 AM   #43
madmike90
Member#: 251829
2013 WRX Hatcn
i ordered mine on the 27th of November and still haven't got it on now the 17th of December. hopefully they resolve this somehow. he seems like a nice guy to deal with.
well see
madmike90 is offline   Reply With Quote
Old 12-17-2010, 12:14 PM   #44
seanathanq83
Member#: 173241
2002 s256 twinscroll
now with one more gear
i personally know cody, and have worked on alot of stuff with him, 02-03 even with a reg tactrix is complicated, i have been tuning cars for almost 3 years, and some times they can be really crappy with connecting, also there is a chance the ecu could be locked i have run into that before
these are almost identical to the tactrix 1.3 but half the price, there is no reason to buy the cruddy 2.0 when you have this as an option, its just like the bcs eveyone else sales its just a mac valve that you can buy all the parts and put them together for about 45 dollars, if you want to buy it for the name go ahead just know your paying 2-3 times as much
seanathanq83 is offline   Reply With Quote
Old 12-17-2010, 01:08 PM   #45
Uncle Scotty
OK buy Nates beans
westcoastroasting.com
s00000........
this cable WILL work with win7 64bit and an 06 wrx????
Old 12-17-2010, 02:18 PM   #46
MykuL
Member#: 122451
01 RSTI w/07 EJ257
Originally Posted by Uncle Scotty View Post
s00000........
I was able to log with it no problem using Windows 7 32-bit on an '03 WRX.
As for flashing, yes, it will work with an '06 WRX.
How many Subies have you owned Uncle Scotty? I didn't know you had an '06 til now
Old 12-17-2010, 04:45 PM   #47
scoobystas
Member#: 26568
2003 Yellow Bugeye
Version 8-Vf37
I'm with you on that one, i have no clue what he drives
Old 12-18-2010, 03:38 AM   #48
TheHighestCrew
Member#: 207133
so has anyone used ecuflash on the 02 wrx with the BFM cable? Seeing some talk that it may just be a timing issue? I am digging the price but don't want to order unless its working. I have Win7 64 bit if that is a concern.
TheHighestCrew is offline   Reply With Quote
Old 12-18-2010, 09:21 PM   #49
Big Joe
Member#: 3722
2002 WRX Wagon
I tried all kinds of tricks to read on an 02 WRX.
  • 5, 4, 3, 2, 1 seconds before keying ignition
  • Tried same time when keying the ignition (tried many times)
  • 0.25, 0.50, 1, 2, 3, 4, 5 seconds after keying (tried many many times)
  • Made sure the USB had BFM drivers (installed, uninstalled)
  • Installed 1.29, 1.3x, 1.42 versions of ecuflash (installed, uninstalled)
  • Cleaned OBD port
  • Checked green connectors on passenger side was connected
  • Tried ecuexplorer
  • Tried another laptop with XP
  • Checked and made sure green connectors on drivers side are connected
  • Flash block connected and not connected
  • 02 WRX does go to test mode when green connectors are connected, check light flashing, fans kick in
  • Learning view and romraider logging works fine
Tried Openport 2.0 = BAM, connects on first try.
Old 12-18-2010, 10:00 PM   #50
berserksti
Member#: 142113
^ Same thing happened when my friend Ron member BLUE STINGER tried to use one of these supplied cables on a 02 wrx to tune a car, tried many things and no worky. He pulled out his 2.0 tactrix cable and bam. Tried the 1.3 cable and it worked fine as well. This bfm cable did work on his gd sti just fine though. He said maybe there is a trick to it to get it to work on the earlier wrx's, maybe its just timing.
berserksti is offline   Reply With Quote
Anyone try the K&N Typhoon Intake system for the WRX? BrysImpreza Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 2 01-02-2002 02:03 PM
Anyone try the Eibach springs from Subaruparts.com? BrysImpreza Brakes, Steering & Suspension 1 09-20-2001 05:53 PM
Anyone try the Forge strut tower bar? dead-eye Brakes, Steering & Suspension 2 07-30-2001 09:00 PM
Anyone try the clear Subaru fog light protectors? Arnie Technical Forum Archive 3 08-22-2000 09:59 AM
Anyone try the AVS Sports? Tim Prudence Technical Forum Archive 14 07-28-2000 12:49 AM
