Old 12-16-2010, 05:03 PM   #1
Tut4u2
Member#: 40424
05 STi
Post DIY Brembo Front and Rear caliper rebuild
Like most people with WRXs, I recently acquired some Brembos and I decided to rebuild them just for piece of mind. A good number of people split the calipers apart but I'm not a fan of that methods for a couple of reasons:
1. The bolt are stretch bolts and I rather not re-use them
2. There are no torque specs for those bolts
3. Brembo doesn't offer an o-ring replacement for the calipers
4. Even the service manual rebuilds them as I'm about to show
That being said, I'm sure splitting the calipers isn't going to cause any catastrophic damage, but I'm just uncomfortable with doing and there's plenty of space with the caliper being together to do the work.
The first step was to figure out which rebuild kit to buy. Mach V (Fastwrx.com) offers the Brembo Rebuild Kit and their own Mach V Rebuild Kit. I elected to use the latter, because it was cheaper and the quality seemed pretty good. Keep in mind if you buy the Brembo kit you only need to buy ONE for BOTH calipers, with the Mach V kit you need to TWO kits to do BOTH calipers.
Here are some pictures comparing the two:
Brembo kit is on top here
Brembo on the left. You can tell it has a smoother finish
Up close
Thickness is the same as far as I can tell
Dust boots. Brembo on the left
The rear kit. Brembo on top. The rear dust boots are gray instead of black.
Next up...the actual rebuilding.
Tut4u2 is offline   Reply With Quote
Old 12-16-2010, 05:03 PM   #2
Tut4u2
Member#: 40424
05 STi
It doesn't really matter which side you do first, but I would say choose a place with a lot of lighting, take your time, and be patient. These are your brakes, so don't rush it.
Lets look at the front first.
My calipers were loaded, yours might not but here's what I did.
1. Take out the two clips out of the cross pins. A pair of pliers will work well.
2. You can use a punch or the other end of the pliers to get the cross pins moving out of the caliper.
3. Other side; samething.
4. To help get the pin out, reduce the tension on it by pushing the spring down.
5. Here's what you should have when you get everything out.
6. Now you have to get the dust boot out of the caliper. There's a little hole in the caliper so you can stick a small screw driver in there and pop it out. Just be careful and work it around. The boots come out easy and with no force.
7. Once you get the boots out of the calipers, repeat for the other 3 pistons. next up we need to get the pistons out of the caliper. Grab a piece of wood, stick it between the calipers, grab your air gun, and stick the gun where the brake line would go
8. Modulate how much air you use, since the pistons do come FLYING out. Once the pistons are out, loosen up the bleeder valves, and you can simply wiggle the pistons out.
NOTE: There will be residual oil where in the housing so be careful.
NOTE: The pistons are different sizes, obviously, and just note which side the pistons came out of. They are color coded if you forget.
9. Next up is getting the actual seal out. Use a small screw driver and get it out. It doesn't stick or anything so its easy to get out. Take note not to scratch the housing. BE PATIENT.
10. Once you remove the other three seals, grab your new seals and some brake fluid. Pour some brake fluid into a cup and be generous. I used Super Blue simply because it was on the shelf and its nice because I switch between the Motul and the Blue so when I bleed the brakes I can know when the fluid is completely changed.
Old 12-16-2010, 05:03 PM   #3
Tut4u2
Member#: 40424
05 STi
11. Dip the seals in the cup of blue and let them soak for a little
12. Clean up the pistons and lube up the inside of the caliper.
13. Put the appropriately sized dust boot on the piston and gently pull it down. Keep pulling it down up the boot sits flush the piston. There should be no lip or anything. It should look like this.
14. Dip the piston in your cup of brake fluid and put the piston back into the caliper. I don't have a picture of this but its pretty self evident.
NO PICTURES but here are some tips.
  • Put the piston in STRAIGHT
  • Push the piston in as gently as possible until you feel some resistance
  • Then hold the caliper as if you are hugging it and push the piston in with your fingers tip
  • Apply EQUAL pressure with both hands and it will go..TRUST ME
  • You don't need to use a vice, clamps, or anything. Equal force and be patient. If there's a lot of reistance, take out the piston, clean it, relube it, and try again.
Here's a picture of how to push them back in.
15. Repeat for the remaining pistons and close off the bleeder valves.
16. Move on to the other caliper.
17. Clean up residual brake fluid.
18. Congrats! You're done with the front. Time for the rears.
Old 12-16-2010, 05:04 PM   #4
Tut4u2
Member#: 40424
05 STi
The rears are the same process as the fronts. Nothing special, except two less pistons but here are the pictures regardless.
1. The two retaining clips have to come out.
2. Push them out to help yourself.
3. Here's what you should have left
4. Just like the fronts, there's a location on the caliper that helps you get the dust boot off. Take both dust boots off.
5. Put a piece off wood in the middle, and use the air gun carefully to get the pistons out.
6. Once the pistons are out a little, take the dust boots off completely.
7. Loosen up the bleeder valves and take both pistons out.
8. Using a small screw driver, take out the seal.
Old 12-16-2010, 05:04 PM   #5
Tut4u2
Member#: 40424
05 STi
9. Let the new seal soak in place fluid before you put them in.
10. Clean off the pistons and install the new dust boots. Pull down the dust boots until they are FLUSH as seen above. The following is what YOU DO NOT WANT IT TO LOOK LIKE.
11. Soak the piston in fluid.
12. Simply push the piston back in like described above.
13. Move to the other piston.
14. Close the bleeder valves.
15. Clean off the caliper.
16. You're done!
Old 12-16-2010, 05:18 PM   #6
Tut4u2
Member#: 40424
05 STi
Somethings to note. The whole process took me about an hour and a half for all the calipers. Just be patient, and don't force anything. These are your brakes. I will update the thread once the car goes on the track come around Spring and will let you know how everything has held up.
Additional Tips:
  • If in the process of getting out the pistons, one piston comes out (or two pistons come out in the case of the fronts) and the other one doesn't budge then don't freak out. Simply push the piston that came out back in. Take off the bleeder valve on the side with the stuck piston and push air through the valve; that stuck piston will come out. If comes out slightly and not all the way, then repeat until it does. If you're still dead in the water, then put the old dust boot on and pry on the piston gently with a screw driver. Pry around the piston equally and be gently. DO NOT plug up the hole with the brake line goes in as that will pressurize BOTH side of the caliper and the unstuck piston will fly out at you.
  • If you don't have a small screw driver to get the inner seal out of the caliper and you're worried about scratching the calipers, then you can use a zip tie.
Links for reference.
Mach V Rebuild Kit: http://www.fastwrx.com/mavbrreki.html
OEM Brembo Rebuild Kit: http://www.fastwrx.com/subrcarekit.html
Superblue Brake fluid: http://www.fastwrx.com/atesupblurac.html
I hope this comes in handy.
Mach V Che!
Old 12-16-2010, 05:38 PM   #7
kumanchu
Member#: 146696
an additional tip would be:
wear gloves, brake fluid is highly carcinogenic.
kumanchu is offline   Reply With Quote
Old 12-16-2010, 05:58 PM   #8
GrimmSpeed
Member#: 136396
2015 WRX, 2012 WRX,
2013 BRZ, 2006 STI
Wow this is an awesome write up, thanks so much! This will be extremely helpful for people especially re-painting their brakes. I am thinking sticky!
Will
Old 12-16-2010, 06:27 PM   #9
kpluiten
Member#: 120273
06 WRBWRXWGN
Now with 100% more Spec-C
No, no it isn't. In fact, it's not very dangerous at all.
DOT 3 & 4 Fluids:
Acute Effects
Inhalation: Vapors are mildly to markedly irritating to the lungs depending on the exposure level.
Eye: Causes severe irritation experienced as discomfort or pain, excess blinking and tear production, with marked excess redness and swelling of the conjunctiva.
Skin: No adverse effects expected with exposure to skin. Brief contact may cause slight irritation. Prolonged contact, as with clothing wetted with material, may cause more severe irritation and discomfort, seen as local redness and swelling.
Ingestion: Ingestion may be fatal. May cause abdominal discomfort, nausea, and vomiting. May produce central nervous system depression and kidney damage.
Carcinogenicity: This compound contains no ingredients at concentration of 0.1% or greater that are carcinogens or suspect carcinogens.
Medical Conditions Aggravated by Long-Term Exposure: Pre-existing skin, eye, and respiratory disorders may be aggravated by exposure to this product. Impaired kidney function from preexisting disorders may be aggravated by exposure to this product.
Chronic Effects: Repeated exposure may result in drying of the skin and mucous membranes, causing irritation and dryness.
http://www.kmcoinc.com/DOT3%20Brake%...%289-09%29.pdf
http://www.kmcoinc.com/DOT4%20Brake%...%289-09%29.pdf
The brake dust poses a higher risk due to it's fine particle size and the compounds used in the friction and binder materials.
Old 12-16-2010, 06:30 PM   #10
Mach V Matt
Member#: 248892
2006 WRX Wagon
Vote for sticky!
Matt
Mach V Matt is offline   Reply With Quote
Old 12-16-2010, 07:24 PM   #11
OrbitalEllipses
Member#: 178811
2011 White Corolla
Over 400hp
Rebuilding brakes can seem like a daunting task, but all it takes is time, patience, and common sense.
Without referencing a guide I was able to rebuild my rear calipers last month, by taking my time, being patient, and using common sense. This is an excellent guide for those who need it!
Vote for sticky! (report the post and say STICKY!)
Old 12-16-2010, 10:28 PM   #12
Tut4u2
Member#: 40424
05 STi
I usually wear gloves, except I didn't feel like having the caliper or any of the tools slide around and potentially nick something as I was working. Everything causes cancer nowadays so I'm not really worried about it; if this brake fluid didn't get me then I'm sure someone's catless fumes will
Old 12-17-2010, 02:01 AM   #13
txl146
Member#: 32459
02 WRX VF34
Junior Tuned 301whp
great write up - your caliper needs a repaint!
Old 12-17-2010, 09:45 AM   #14
Scooby921
Merci Buckets
Member#: 88606
2016 Cayman GTS
Dark Blue Metallic
Originally Posted by Mach V Matt View Post
Vote for sticky!
Matt
No need to bomb my email inbox with reported posts
Link to this thread has been added to the Brake Supersticky under the maintenance section.
Scooby921 is offline   Reply With Quote
Old 12-17-2010, 09:58 AM   #15
Tut4u2
Member#: 40424
05 STi
DIY repaint with G2 paint coming soon
That was quick..haha.
I'm glad others with benefit.
Old 01-08-2011, 11:24 PM   #16
OrbitalEllipses
Member#: 178811
2011 White Corolla
Over 400hp
Bump for a question I have!
Any difference between the Brembo seal kit (the ~$90 one) and Subaru P/N 26297FE010? The kit from Subaru retails for $87.50, but can be had for ~$64. Last time I ordered a brake kit from Subaru it came with enough for both sides, just wondering what's going on with this one.
Old 01-11-2011, 01:37 PM   #17
Tut4u2
Member#: 40424
05 STi
Same kit.
Old 02-19-2011, 03:29 AM   #18
GrindingGears
Member#: 196637
Great thread.
Have you posted the paint DIY?
GrindingGears is offline   Reply With Quote
Old 03-30-2011, 07:01 PM   #19
DutchOven
Member#: 220629
2010 White WRX Hatch
2015 White WRX Limited
Wow $50 and $80 for just a few pieces of rubber?!?! Why is it so expensive
DutchOven is offline   Reply With Quote
Old 03-30-2011, 07:04 PM   #20
d000000000000000d
it says "Brembo' on it.....and if ya cant afford the price of admission....keep walkin
Old 03-30-2011, 07:07 PM   #21
DutchOven
Member#: 220629
d000000000000000d
lol affording it isn't the problem.. its just the fact that you're paying that much for rubber or whatever these things are made of
Old 03-30-2011, 08:31 PM   #22
dantastic
Member#: 66815
2005 WRX Wag -SOLD:(
CGM STX #125
The oldest trick in the book is to use a regular pencil to get the seal out
dantastic is offline   Reply With Quote
Old 03-30-2011, 09:36 PM   #23
OrbitalEllipses
Member#: 178811
2011 White Corolla
Over 400hp
I really had to wrestle with my seals and boots. They were cooked from the previous user, to the point of no longer retaining any properties of rubber but properties more akin to....say steel.
Old 04-18-2011, 02:31 AM   #24
DutchOven
Member#: 220629
So FastWRX's Rebuild kit is actually a centric kit but marked up because its for brembos.
Part number is 143.46018
If you google it, it's not $25 each.
Old 04-18-2011, 07:40 AM   #25
OrbitalEllipses
Member#: 178811
2011 White Corolla
Over 400hp
Rear is around ~$19/side and front ~$10/side (for Centric 143.46018 and 143.47008). FastWRX is a specialist, you always pay more from specialists. They're also a contributor to this forum, so take that how you want.
FS or FT: 04 sti brembo Front and Rear calipers and rotors. jbark1018 Suspension/Brakes/Handling 18 06-11-2011 04:18 PM
FS : Brembo front and rear calipers and rotors 5x114; excellent condition never tracked syoung0298 Suspension/Brakes/Handling 28 06-20-2010 11:30 AM
06 STI Brembo Front and Rear Calipers, Rotors, and Pads akito Suspension/Brakes/Handling 2 06-19-2010 06:19 PM
WTB: Your STi brembo front and rear calipers eclip5e NESIC Private Classifieds 19 04-29-2006 03:28 AM
FS: 04 STi Brembo Front and Rear Calipers netzr0 Private 'For Sale' Classifieds 3 08-06-2004 04:01 AM
