Welcome to the North American Subaru Impreza Owners Club Thursday September 18, 2014
Old 12-19-2010, 01:50 AM   #51
TheHighestCrew
Member#: 207133
Originally Posted by Big Joe View Post
I tried all kinds of tricks to read on an 02 WRX.
  • 5, 4, 3, 2, 1 seconds before keying ignition
  • Tried same time when keying the ignition (tried many times)
  • 0.25, 0.50, 1, 2, 3, 4, 5 seconds after keying (tried many many times)
  • Made sure the USB had BFM drivers (installed, uninstalled)
  • Installed 1.29, 1.3x, 1.42 versions of ecuflash (installed, uninstalled)
  • Cleaned OBD port
  • Checked green connectors on passenger side was connected
  • Tried ecuexplorer
  • Tried another laptop with XP
  • Checked and made sure green connectors on drivers side are connected
  • Flash block connected and not connected
  • 02 WRX does go to test mode when green connectors are connected, check light flashing, fans kick in
  • Learning view and romraider logging works fine
Tried Openport 2.0 = BAM, connects on first try.
thanks for the info
TheHighestCrew is offline   Reply With Quote
Old 12-19-2010, 02:45 AM   #52
lethaldose
Member#: 189360
video is up showing start to finish from unpacking drivers to running through the software. Also have an updated software/driver package to download as well
http://bustedfingermotorsports.com/f...php?f=32&t=104
Direct Download Video Link
Hosted on Youtube
http://www.youtube.com/v/dKwx7Tr1ZL4
New driver package
http://downloads.bustedfingermotorsp...mflashpack.zip
lethaldose is online now   Reply With Quote
Old 12-19-2010, 03:08 AM   #53
Uncle Scotty
OK Houston
we have an Uncle
Originally Posted by MykuL View Post
I was able to log with it no problem using Windows 7 32-bit on an '03 WRX.
As for flashing, yes, it will work with an '06 WRX.
How many Subies have you owned Uncle Scotty? I didn't know you had an '06 til now
ahhhhhhhhhhhh...but the BIG questions are still unanswered
the 03 wrx and the 06 are way not the same
and
the win7 32 bit and 64 bit area way not the same
I need ta know those answers
Old 12-19-2010, 11:48 AM   #54
seanathanq83
Member#: 173241
2002 s256 twinscroll
now with one more gear
32 bit or 64 shouldnt matter, i have used it on a mac lol havent tried logging because well romraider doesnt work for mac haha,
seanathanq83 is offline   Reply With Quote
Old 12-19-2010, 11:59 AM   #55
MykuL
Member#: 122451
01 RSTI w/07 EJ257
6MT Brembos BBSs Interior
and
No one has reported issues with the '06 I mean. No reason why it wouldn't work.
Just, as usual, us bugeye owners are stuck with picky ECU's
MykuL is offline   Reply With Quote
Old 12-19-2010, 09:19 PM   #56
quazimoto
Member#: 70395
It does. Thats why most people with the 64 bit have to run Romraider or Ecuflash in compatibility mode.
Old 12-19-2010, 09:21 PM   #57
MykuL
Member#: 122451
01 RSTI w/07 EJ257
Originally Posted by quazimoto View Post
It does. Thats why most people with the 64 bit have to run Romraider or Ecuflash in compatible mode.
Right, but they still run don't they? And it shouldn't affect the drivers?
Old 12-19-2010, 09:47 PM   #58
quazimoto
Member#: 70395
Depends considering BFM is providing the driver. The Tactrix cable driver comes from the Ecuflash software. Colby designed both Ecuflash and the Tactrix cable.......
Old 12-19-2010, 11:11 PM   #59
MykuL
Member#: 122451
01 RSTI w/07 EJ257
I stand corrected - I didn't realize 64-bit drivers could be dissimilar enough to cause the cable to not even work.
I'm sure Cody has a fix for that
Old 12-20-2010, 04:59 PM   #60
madmike90
Member#: 251829
2002 Wrx Sedan
recieved my cable today and the situation was rectified without even a slight hitch so i have to say AWESOME company to deal with.
-Mike
madmike90 is offline   Reply With Quote
Old 12-20-2010, 06:00 PM   #61
MykuL
Member#: 122451
01 RSTI w/07 EJ257
-Mike
Myth: You can flash and log on an 02-03 USDM WRX using the BFM cable.
Status: Confirmed????
Old 12-20-2010, 07:52 PM   #62
ScoobiePower
Member#: 144147
06 WRX Stage1
Just got my BFM Cable, works good so far. Was able to log a few runs in Rom raider and also pull CEL codes with Rom raider learning view.
ScoobiePower is offline   Reply With Quote
Old 12-20-2010, 08:48 PM   #63
mroseyred2007wrx
Member#: 250998
2007 WRX Impreza
red
Your beat bet is to get a Cobb
mroseyred2007wrx is offline   Reply With Quote
Old 12-20-2010, 09:06 PM   #64
MykuL
Member#: 122451
01 RSTI w/07 EJ257
Me? I have a Tactrix 1.3
Old 12-21-2010, 08:26 AM   #65
mtnbikeman123
Member#: 77939
00 GF Rustbucket
So have people flashed yet? I updated my drivers with the new driver pack and installed the supplied version of ecuflash but its been too cold to try read/flash on the car. Maybe tonight...
mtnbikeman123 is offline   Reply With Quote
Old 12-21-2010, 07:50 PM   #66
robtmc
Member#: 23659
Chapter/Region: HIIC
2002 WRX Sport Wagon
Platinum Silver
The el-cheapo Vag-com cables will do that as well. Reading and flashing 02-03's is what this thread is about.
robtmc is offline   Reply With Quote
Old 12-21-2010, 09:33 PM   #67
mtnbikeman123
Member#: 77939
00 GF Rustbucket
Tried again tonight, still wouldn't read from the ECU. Logging and learning view work fine so no change there. The only issue I can think of is my drivers, when I installed them, it wouldn't let me choose the driver so I had to go back and Update to get the supplied one loaded up. My "USB Serial Port" in the device manager, the Driver tab shows the FTDI 2.6.2.0 driver. This is the correct one supplied in the BFM package, right?
I also tried the FTDI 2.8.2 drivers, changing the port speed to 4800 baud(VAGcom successes), various timing combinations.
This is all with ECUflash 1.41.2483
Has anyone had any luck with the new BFM driverpack?
Old 12-22-2010, 10:14 AM   #68
Subyaddict
Member#: 228469
2003 Wrx Wagon
I received my BFM cable last night. I installed the new driver pack step by step using the video. RomRaider logger worked without a problem. Ecu flash did not. I had the green connectors together and the flash block installed(jumper wires in my case). I tried several times timing it differently and could get it to work. I kept getting the same error message. I will try again tonight and post the error messages after.
Subyaddict is offline   Reply With Quote
Old 12-23-2010, 05:20 PM   #69
ScoobiePower
Member#: 144147
06 WRX Stage1
I also can't get ECUFlash to read the ROM. I have tried everything the video showed.
Is there a way to change the COM port ECUFlash is trying to use?
06 WRX
The only ECU Flash I have is 1.42.2595, video shows 1.41.2483 is there a big difference?
Thanks.
Old 12-23-2010, 09:05 PM   #70
robtmc
Member#: 23659
Platinum Silver
Ecuflash should see your COM port, showing the device at the bottom right as FTDI XXX or similar. Tactrix cables show up as Tactrix xxxx. COM port ID is automatic as far as I can see, no control over it. You can pop the USB into another port, which will change the COM port Ecuflash sees, but doubt it will change a thing if it sees it before and no workee there.
Oh yeah, the word is that all Ecuflash versions after 1.29 check for a valid Openport device. No idea how BFM has it working with the 1.41 version as seen on the video if it is not a real Openport cable. Maybe they dropped the ID verfication?
Old 12-26-2010, 03:25 PM   #71
jputnam
Member#: 7348
2002 WRX Wagon
I've had one for a few weeks and I can run RomRaider, Learning view no problem. Simply cannot coax this thing into doing ECUFlash. same error as everyone else.
And yes - i've wached the video and run the included software as well as the latest version. As for Cody - he was a stand up guy when he kept missing delivery dates and took care of me in the end. My only question is - he has promised an 02/03 car but the video is an 04/05. Obviously not the vehicle that everyone is complaining about. Has ANYONE gotten this to work on an 02/03 car? Timing or not the error comes up immediatly long before the timing is an issue.
Jeff
02 WRX Wagon
jputnam is offline   Reply With Quote
Old 12-26-2010, 08:36 PM   #72
Subyaddict
Member#: 228469
2003 Wrx Wagon
I'm in the same boat as you man. I have tried every possible way to "time" this. I have run out of ideas. I'm starting to think that us 02/03 owners have been the the victims of some false advertising.
Old 12-27-2010, 06:28 PM   #73
SlowImport
Member#: 123720
2003 WRX Wagon
Platinum Silver Metallic
I just wish I could get their AEM UEGO cable to work for me.
So frustrating,
Josh
SlowImport is offline   Reply With Quote
Old 12-27-2010, 08:57 PM   #74
ScoobiePower
Member#: 144147
06 WRX Stage1
What is not working?
So frustrating,
Josh
Old 12-28-2010, 12:18 AM   #75
jputnam
Member#: 7348
2002 WRX Wagon
Default BFM cable
I'm officially giving up. I bought a Tactrix 2.0 cable today even though I'm not happy about it. Here is the kicker - while the money is irritating its not half as irritating as the 3 weeks I've wasted trying to make it work. If I had known that he hadnt really tested it on an 02/03 and that it wasnt going to work I would have just bought the Tactrix cable in the beginning. As expensive as the cable is, its still way cheaper than an accessport or equivalent. And unlike the AP I can use it on any Subaru from 02+.
Anyone with an 04+ car want to buy a BFM cable from me? We do seem to have proved it works just fine on 04-07 cars here in the forum. So for those people its a no brainer vs the tactrix. If anyone is interested drop me a PM.
Anyone try the K&N Typhoon Intake system for the WRX? BrysImpreza Factory 2.0L Turbo Powertrain 2 01-02-2002 02:03 PM
Anyone try the Eibach springs from Subaruparts.com? BrysImpreza Brakes, Steering & Suspension 1 09-20-2001 05:53 PM
Anyone try the Forge strut tower bar? dead-eye Brakes, Steering & Suspension 2 07-30-2001 09:00 PM
Anyone try the clear Subaru fog light protectors? Arnie Technical Forum Archive 3 08-22-2000 09:59 AM
Anyone try the AVS Sports? Tim Prudence Technical Forum Archive 14 07-28-2000 12:49 AM
