Old 12-28-2010, 10:09 AM   #1
STI 2 NV
Member#: 31748
'11 WRB WRX Sedan
Default '11 WRX Burning Clutch Smell in Reverse
Hey guys, I tried a search, but did not come up with much. I have a '11 WRX and almost every morning when I back out of my driveway I get a burning clutch smell. I also get it on the occasional reverse out of a parking spot when I am out and about. If memory serves me correctly, I could have sworn I read the '09/'10's were experiencing some of this. I did get it a tad on my '10, but not as bad. This is my 5th WRX and, besides the '10, I have never experienced such. I have never had the issue on any of the other manuals I have owned. I have not changed my driving style, so it cannot be due to improper usage. I do have to feather the clutch a bit due where I am backing out from, but even that should not cause such a bad smell. Has anyone experienced this? Suggestions?
STI 2 NV is offline   Reply With Quote
Old 12-28-2010, 10:58 AM   #2
usfsfire42
Member#: 242630
.. Pepperoni nips
and big slits...
Take it to the dealer. If it "cannot be due to improper usage" then they should take care of you. They will probably say your riding the clutch. Which you might be a little to much
usfsfire42 is online now   Reply With Quote
Old 12-28-2010, 11:04 AM   #3
jay25RS
Member#: 4273
2011 GR-STI
& 2013 Impreza Sport
Could be the cosmoline... it kinda smells like stinky clutch.
Old 12-28-2010, 11:26 AM   #4
STI 2 NV
Member#: 31748
'11 WRB WRX Sedan
I would say it is possible I ride the clutch a tad due to the circumstance of where I have to back out from. However, it's not enough to cause such a strong smell.
Jay, why would I only get the smell in reverse if it were the cosmoline? Wouldn't I have it at other times?
Old 12-28-2010, 11:33 AM   #5
usfsfire42
Member#: 242630
.. Pepperoni nips
and big slits...
Ya I dont think riding the clutch even for 5 secs while backing out would cause the problem. Cosmoline? huhhhh I wouldnt think the clutch would be hot enough if hes just backing out from a cold start. Unless he had been previously driving and it happens no matter what
Old 12-28-2010, 11:58 AM   #6
jay25RS
Member#: 4273
2011 GR-STI
pure speculation! lol.
Old 12-28-2010, 12:02 PM   #7
STI 2 NV
Member#: 31748
'11 WRB WRX Sedan
Well you're no help.
Anyone else experiencing this in their '09-'11 WRX?
Old 12-28-2010, 03:50 PM   #8
usfsfire42
Member#: 242630
.. Pepperoni nips
and big slits...
I have'nt noticed it
Old 12-28-2010, 04:32 PM   #9
BenGSX
Member#: 210061
How long is your driveway / are you backing out at 9000rpm's?
I only ask because I have witnessed a friend (who will remain nameless) in a car (to remain nameless) with relatively quiet factory exhaust rev the piss out of his car whilst slipping the clutch in reverse to back out of spaces.. He didn't even realize he was doing it.. Without eyes on the tach he had no sense of the kind of RPM's he was spinning and it was just easier for him to gas it and lightly slip the clutch..
So - lots of rpm's - almost no application of clutch, just enough friction to make the car roll = possible burned clutch smell.
BenGSX is offline   Reply With Quote
Old 12-29-2010, 11:34 AM   #10
STI 2 NV
Member#: 31748
'11 WRB WRX Sedan
Driveway is short, but I have to go slow because I am backing into a road and I have to take it easy because I am up against a fence and cars to my left. I would say my RPM's are very low, maybe 2-3k. I definitely do not rev it hard, which I would be able to tell if I did because the '11's do have a decent exhaust tone. I really have to feather the clutch because if I let it off it will stall out from not enough RPM's, but if I give it too much gas I will go shooting back into the road. For the amount of feathering and time (5 seconds) there is no reason I should be getting the burnt clutch smell. I have driven other cars, not to mention previous WRX's, in a similar manner and never had any smell.
Old 12-29-2010, 12:39 PM   #11
usfsfire42
Member#: 242630
.. Pepperoni nips
and big slits...
since its under warranty take that beast in then. Do you really need to be at 3k to back up? Is the driveway that steep?
Old 12-29-2010, 12:43 PM   #12
STI 2 NV
Member#: 31748
'11 WRB WRX Sedan
I only hit that when I am backing through snow. It's typically in the 2k range. Even if it was at 3k or higher, there is no reason for the smell other than a possible clutch issue.
Old 12-29-2010, 02:08 PM   #13
BenGSX
Member#: 210061
Depends on how long you are sitting at 2-3k feathering the clutch - that is pretty unnecessarily high.. If you are holding yourself at the end of a driveway for some length of time (backing uphill) then i can see how you might smell some clutch..
For reference - I have a little 2.0, metallic 6 puck clutck, lightweight flywheel, and i still doubt I go over 1200 rpm when getting the car into reverse.. After than the car can idle around pretty easily in reverse..
Sounds like you are using the clutch to get through / over snow instead of your engine.. That could easily make the clutch nice and toasty.. You wont go shooting out into the road if you are properly using the clutch / rpm.
Practice
Old 12-29-2010, 02:56 PM   #14
STI 2 NV
Member#: 31748
'11 WRB WRX Sedan
Practice
It has nothing to do with practice. I've owned many manuals. Maybe I am gauging the RPM's wrong. I know there are times when I do have to rev it a bit higher, such as over the weekend with all our snow. I'll certainly pay more attention to how high I am revving. However, as I have stated, I have never had this issue before with any other WRX or vehicle, which leads me to believe it's a clutch issue. A clutch should not burn with a bit of feathering in reverse for 5 seconds.
Old 12-29-2010, 05:24 PM   #15
BenGSX
Member#: 210061
Depends on load..
5 seconds on a flat level parking lot or downhill then no..
5 seconds trying to climb through snow then possibly yes..
Old 12-29-2010, 10:31 PM   #16
STI 2 NV
Member#: 31748
'11 WRB WRX Sedan
It's on a flat driveway. In taking a closer look at my revs, on cold start-up, the car is already idling at 1500 rpms, so I will obviously rev to at least 2k. So, not sure how that could be considered too high.
Old 12-29-2010, 11:06 PM   #17
usfsfire42
Member#: 242630
.. Pepperoni nips
and big slits...
On cold start mine idles at the same numbers. I move out of my parking spot in reverse at 1500 or 2000. Any more than that is'nt needed. Unless your going up something steep.
Old 12-29-2010, 11:20 PM   #18
slimfit
Member#: 90597
2011 WRX Premium
I sometimes get the same smell only on cold starts. It's hard to pin point whether its the clutch or not. I have noticed it if the a/c compressor comes on. Could I be smelling the a/c clutch?
slimfit is offline   Reply With Quote
Old 12-29-2010, 11:37 PM   #19
Daijoubo-yo
Member#: 252612
2010 WRX 5dr
97 Lude Sh,99 Durango 5.2
If it's idling at 1500 already I wouldn't even give it gas, just feather the clutch and that should give you plenty of momentum. 1500 rpms is enough to fully release the clutch anyway. I don't have to worry about traffic though so I can't really accurately tell. Hopefully its just your clutch breaking in.
Daijoubo-yo is offline   Reply With Quote
Old 12-29-2010, 11:40 PM   #20
ricky0418
Member#: 236866
WR BLUE
i had the same problem with the 2010 wrx when it was a few days old, it went away, i dont have that problem now!
ricky0418 is offline   Reply With Quote
Old 12-30-2010, 01:52 AM   #21
ejhayes76
Member#: 267923
2011 Impreza 2.5i
I agree. My 1-2 week old 2.5i smells like something is burning off at times too. I'm not sure whether its clutch lining, heater, brake lining, cosmoline, etc. It is getting better at 8 days old, but still there. I wouldn't worry unless you car is months old.
ejhayes76 is offline   Reply With Quote
Old 12-30-2010, 02:07 AM   #22
lillie18soriano
Member#: 264494
not for an 09. trust.
lillie18soriano is offline   Reply With Quote
Old 12-30-2010, 08:07 AM   #23
STI 2 NV
Member#: 31748
'11 WRB WRX Sedan
I have to use a slight amount of gas. It's a relatively tight squeeze where I park, so I have to be careful backing up. The I have to factor in the road, which is between 15-20 feet back from where I park. I may just have to try some different techniques. However, I know some of the previous years experienced clutches burning up very quickly. I was reading over on ClubWRX and they have a thread going on such. Some people were losing 2 clutches before they even hit 30k miles. Driving spiritedly or not, that should not happen.
Old 12-30-2010, 02:19 PM   #24
BenGSX
Member#: 210061
A kid with little manual experience is naturally going to roast through clutches rather quickly on a higher horsepower AWD vehicle.. (And on Teh interweb everyone is an amazing race car driver with 1337 double clutching skills and have driven hundreds of manuals).
I smoked an oem clutch in 30k.. I definitely don't blame it.. This isn't my first turbo 4/AWD car.. I beat the holy mother-loving hell out of that thing and burned it down to the rivets. But I have enough experience to know that I did that.. Not the clutch.. - And it lasted about as long as any OE Organic would given the circumstances..
Also - So you are driving around while the car is still up at 1500 rpms? Don't believe in warmups?
Old 12-30-2010, 03:06 PM   #25
STI 2 NV
Member#: 31748
'11 WRB WRX Sedan
Sorry, but I don't have an extra 5-10 minutes every morning or after work to let the car warm up. How many people do that anyway every single time?
Clutch issue...random burning clutch smell subarumafia700 Transmission (AT/MT) & Driveline 2 08-02-2010 05:50 PM
Burning clutch smell and slipping zentrandi Transmission (AT/MT) & Driveline 3 05-06-2007 01:17 AM
Burning clutch smell, brand new car Balve General Community 5 11-10-2004 03:15 PM
Question for STi owners - burning clutch smell from reverse? avatarr Transmission (AT/MT) & Driveline 13 03-23-2004 09:19 AM
Burning clutch smell dragonglen Baja Forum 3 10-28-2003 11:20 PM
Message Board Statistics All times are GMT -4. The time now is 11:39 AM.
