Welcome to the North American Subaru Impreza Owners Club Tuesday July 7, 2015
Old 12-29-2010, 04:10 PM   #1
Thunderpaw
Member#: 242205
2009 wrx
blue
Default Front / Rear Sway bar set up
Hey folks, looking to get Whiteline front 22mm and rear 20mm non adjustable for my daily driver. Was told since they're non adjustable that the stock endlinks would be fine. Do you foresee any problems with this set up? Thanks.
Thunderpaw is offline   Reply With Quote
Old 12-29-2010, 04:17 PM   #2
usfsfire42
Member#: 242630
.. Flu shot
technician.
No. Endlinks just tighten it up a little bit.
usfsfire42 is offline   Reply With Quote
Old 12-29-2010, 04:22 PM   #3
Brock31
Member#: 128115
2004 4EAT Wagon PSM
enginuity is cool
They should work fine for daily driving.
Let it be known that the stock endlinks have limitations when pushed. Increasing the stiffness of your f/r swaybars is going to increase the strain on the endlinks.
Look into picking up a quality set of kartboy endlinks. They are worth it.
Brock31 is offline   Reply With Quote
Old 12-29-2010, 07:31 PM   #4
Arnie
Member#: 1725
99 Subaru Impreza
GF silver
I would look into a 22mm rear adjustable instead. It will be a better balance and more fun, IMO. The adjustability I really recommend.
Arnie is offline   Reply With Quote
Old 12-30-2010, 10:18 AM   #5
Grocery_Getta_265
Member#: 232333
2013 GT 520HP/451TQ
Im running the rallitek HD endlinks on mine , with the eibach 25 mm fsb and the 22mm perrin rsb. i like this set up
Grocery_Getta_265 is offline   Reply With Quote
Old 12-30-2010, 10:56 AM   #6
kenliu84
Member#: 107618
2006 OBP WRX Wagon
PrecisionTuned/TiCSuspen.
I would say get both front and rear adjustable and increasing the rear to 22mm if you are still unsure where you will be going with your car (your goals). That way, if you ever do go further with your suspension mods, you have the option of going stiffer. With the whiteline adjustable rear swaybar, you get an effective range of 21-23mm sized stiffness and you'll only be slightly stiffer than 20mm NON-adjustable. I forgot about the fronts but if you go to whiteline's website, they have a video that explains the effective stiffness of their 2,3 and 4-hole adjustable swaybars.
In regards to installation and feeling the improvements, I recommend installing each one separately and drive the car around for a few days to feel the difference. Be careful if you go rear first; the rear may snap out depending on the type of driving you will do to test it out. It's nothing crazy, just be careful.
kenliu84 is offline   Reply With Quote
Old 12-30-2010, 11:09 AM   #7
byun
Member#: 258046
2011 Impreza WRX
I did whiteline adjustables 24/22 on mine, set up soft in the front and medium in the rear with stock endlinks and it's made a huge difference.
byun is offline   Reply With Quote
Old 12-30-2010, 06:27 PM   #8
Thunderpaw
Member#: 242205
2009 wrx
blue
Thanks for the insightful comments. I had thought about adjustables but was wondering how often people actually change their set ups but I do see the potential in case I ever do auto x (maybe after I pay the car off). Also looking to save a little money. The two non adjustable sways will cost a tad over $300 whereas the adjustables plus KB endlinks will get me close to $600. But if you're going to do it, do it right. Thanks.
Old 12-30-2010, 07:22 PM   #9
kenliu84
Member#: 107618
2006 OBP WRX Wagon
I set it and forget it and don't really take full advantage of the adjustability. But in your case, you can set them at the lowest settings, and when you are ready, then adjust them stiffer. Ready as in you are ready to auto x or upgrade to aftermarket endlinks. So, just the swaybars, adjustable will only run you a little bit more money. Consider used as well in your local forums. Happy modding.
Old 12-30-2010, 08:14 PM   #10
Thunderpaw
Member#: 242205
2009 wrx
blue
Roger that. Happy New Year.
WTB: used set of aftermarket front/rear sway bars for 04 sti Panic Private 'Wanted' Classifieds 4 03-30-2010 09:21 AM
Hotchkis Competition Sway Bar rear sway bar setting? Batman wrx! Brakes, Steering & Suspension 5 02-23-2009 02:45 AM
Question on rear sway bar set up IronMosher Brakes, Steering & Suspension 2 01-12-2004 05:08 PM
Will cusco rear sway bar bolt up to factory sway bar mounts? waitandbleed92 Brakes, Steering & Suspension 3 03-21-2003 07:58 PM
Whiteline adj rear sway bar settings? H8YNERS Brakes, Steering & Suspension 16 07-26-2002 05:08 PM
