Welcome to the North American Subaru Impreza Owners Club Sunday December 4, 2016
Old 01-05-2011, 06:01 PM   #76
juanmedina
Member#: 133146
07 FPgreen [email protected]
WRX VF39+E85 12.0, 121mph
Originally Posted by Phatron View Post
4th gear?
I think so.....
If is 3rd gear it would spool really close to my 49lb/min FP Green
Old 01-05-2011, 06:35 PM   #77
spdracerut
Member#: 269226
4th gear?
The boost plot shows 108mph at 6800rpms, so I'd assume 4th gear.
spdracerut is offline   Reply With Quote
Old 01-05-2011, 06:53 PM   #78
PERRINJeff
NASIOC Manufacturer
Member#: 74110
We always use 4th gear on our Dynapack. A few times i did 5th, but the way the Dynapack works, it doesn't really care as long as hub TQ doesn't exceeds its limit. On a 400WHP car 5th gear looses about 4HP over doing it in 4th. Compared to 15WHP on a traditional roller dyno (see this on a Mustang) its not that bad.
PERRINJeff is offline   Reply With Quote
Old 01-05-2011, 07:20 PM   #79
Airboy
Member#: 72829
2006 WRX
2015 WRX
PERRINJeff, what is the ramp rate that you use for the Dynapak?
Airboy is offline   Reply With Quote
Old 01-05-2011, 07:52 PM   #80
kevinh211
Member#: 56297
2013 Focus ST
2004 STi MSPT Tuned
edit..i assumed the green line was the gtx but its not.
kevinh211 is offline   Reply With Quote
Old 01-05-2011, 07:54 PM   #81
BenGSX
Member#: 210061
^^ Looks like what peaked out 100rpm quicker spool? That line is a regular gt3076.. Point here was that spool was not significantly affected.. Now lets see power.
BenGSX is offline   Reply With Quote
Old 01-06-2011, 12:09 AM   #82
PERRINJeff
NASIOC Manufacturer
Member#: 74110
Guys, sorry, i was going to just put up some graphs but its turned into so much more. Couple more hours and i should be done. I promise that it will be worth the wait!
Old 01-06-2011, 12:37 AM   #83
juanmedina
Member#: 133146
I can't wait...
Old 01-06-2011, 01:04 AM   #84
NSFW
Member#: 140444
05 Stage Free LGT
ATP 3076, 6MT, AVO FMIC
Can't wait to see the 3071GTX boost & power plots...
Old 01-06-2011, 03:17 AM   #85
PERRINJeff
NASIOC Manufacturer
Member#: 74110
Here you go! I also added this info to the first page so you wouldn't have to dig through the pages to find the good stuff!
Update 1/05/11
Dyno Results
This is what you have all been waiting for! Finally the "Proven Power" side of things. But first a few questions surrounding the GTX3076R and other GTX turbos.
  • The Question, "Is the GTX turbo Laggier then the GT turbo?" Answer, "NO"
  • The Question, "Is the GTX turbo going to make more power?" Answer, "YES"
  • The Question, "Is the GTX turbo better?" Answer, "See above answers"
  • The Question, "Is the GTX worth the extra money?" Answer, "YES"
  • The Question, "When can I get a PERRIN Kit with one of these?" Answer, "NOW if you ask nice"
The Setup
So my STI was used as the guinea pig for these turbos (along with a bunch of others recently) and its setup exactly like a normal PERRIN GT turbo kit car should be.
Parts installed: PERRIN Headers, PERRIN GT Turbo kit, PERRIN FMIC, PERRIN Catback, and our PWI-2 Methanol Injection kit, PERRIN EBCS Pro, Deatchwerks 850cc injectors and Walbro 255lph pump. The engine is built with Cosworth Rods, Pistons and bearings, and ARP Studs. Things to take special notes on are: Stock heads, Stock Cams, OEM head gaskets, OEM TGV housings in place and functioning and stock fuel rails with PERRIN Stumble fix installed.
We use 92 ocatane fuel here in Oregon, but like any big power car running on pump gas, we run 50/50 methanol. The kit is setup to flow about 800cc's per minute of methanol/water.
Tuning duties on this beast are controlled by a Cosworth ECPro standalone ECU. An Innovate Wide Band is integrated into the ECU as well as a gauge so i can visually see AFR as well as log it accurately. That along with a Omnipower 4 bar plug and play MAP sensor, so i am able to run the car to higher boost pressures. This part is a must for any turbo kit customer!
Setup: Dyno we are using is our awesome Dynapack Dyno. Car is setup to run in 4th gear, starting at 2000 RPM and ending at 6800RPM. We use a settle time of 4 seconds, which means, the dyno holds the RPMS at 2000RPM for 4 seconds before the run starts. During this 4 seconds, we have the car at 100% throttle for about 2-3 seconds. The fans we use are not super crazy fans that flow 100MPH wind, but each fan flows exactly 28MPH (measured with our wind meter) and both are aimed at (not on) the intercooler). This doesn't provide perfect airflow to the intercooler compared to to driving on the street, but it does provide very accurate and repeatable results and if anything lower HP that you may see on the road.
All runs were done with the ECU reading about 30C intake temps, and this was very consistent. The dyno temp measured 58-60F. The dyno runs were done with about the same amount of time between them as well as coolant temps were always at 90C. The idea is we did it consistently to eliminate as many variables as possible.
Now with all that out of the way its time for the good stuff.
Garrett GT vs. GTX
If you do not know, this whole test is the GT3076R with a .82ar housing compared to the GTX3076R with the .82ar housing. We will leave out the other GTX turbos for now as well as the .63ar housings. I have really good results on the GT3076r.63 comparing it to a .82 that was swapped out and dynoed in about 1 hour. Its about 300RPM quicker spooling and that should be good enough to give you an idea how the GTX with .63 will perform in the spool department.
Car was previously tuned at 1.2bar, 1.5bar, and 1.7bar of boost with the GT3076R w/.82. The tune was not pushed to the limits by any means, meaning AFR target was .80-.79 Lambda (11.76-11.6AFR) running 50/50 meth. I did do runs previously at .81- .82 Lamda 11.9-12.0 and it was very happy, but added fuel for safety. Timing could have been bumped up about 2 degrees more as I found it could run that also. Either way, we re-dynoed the car with the previous tune (super safe) and did NO tuning between runs. I ran, 1.2, 1.5bar, and then 1.7 bar with just twisting the SI drive button. AFR's were perfect, engine noise low, and WGDC was right where I left it. I did do a 1.9bar run and AFR's were the same .79-.80 lambdo with no knock. I did this because i knew that some guys would be asking for a big power run. Below are the results overlaid with the GTX results.
Next up was time to swap the turbo. As you can see from the NASIOC posts I made with my iPhone, we started the swap and in less than 1hour it was back up and running. I did have help doing this to make it go as fast as possible.
1.2Bar of boost...
First run I was crossing my fingers, as I left the same tune in place. At 1.2 bar (17.4psi) of boost I was impressed with the response as it was almost exactly the same! I did a few hot and cold runs(Heat in the header is what I am referring to) and after comparing them to the GT3076R runs we just did, the GTX was maybe 50RPM laggier. No one will notice this! I am pretty excited as even at this lower boost levels, it gained power! 15WHP more makes it 370WHP which is very good for low boost!
Now at these boost levels, the GTX compressor wheel isn't really being utilized as it will be at higher PR's. The GTX wheel, according to Garrett, is more efficient by about 6% at redline, which means cooler charge temps. Typically this means denser air, and means if not accounted for that the AFR will be leaner. I only found the AFR to be leaner by a microscopic amount. This is something only visible using some of the Cosworth toolbox tools to see the average change. The AFR was leaner by .01 Lambda(.15AFR) showing its is more efficient!
The Cosworth ECU has closed loop boost control so it hits my target boost every run. This keeps it very consistent and eliminates some variables. The GTX on all runs needed about 2% more Wastegate Duty Cycle(WGDC). This shows the turbine needs a tiny bit more engery to spool the same. The Cosworth ECU also has a great visual way to see engine noise and using this to compare both turbos, its almost exactly the same. For the next few examples, I will make sure we cover WGDC, AFR, engine noise and of course power.
Again, keep in mind, ZERO tuning was done from the GT to the GTX at this boost level.
1.5Bar of boost....
With the twist of the I-drive we are now running 1.5 bar (21.75psi). Just like we saw at the 1.2 bar level, we gained power! Another 15WHP over the GT at this level is pretty good, again for no tuning. This is where I feel that 75% of our turbo kit customers fall into. It's that boost range that works ok with 91 octane and makes plenty of power to get you in trouble! No one would be disappointed with 430 WHP and 430 ft-lbs of TQ! I also think that this is what you would see on pump fuel setups.
During these runs the AFR was again leaner compared to the GT turbo, this time it was just under .01Lambda (.15AFR), but at redline it was just over .01 Lambda. Indicating cooler denser air and more efficient turbo as expected. On the dyno the AFR changes were not something we could see at all. This could be due to the wideband 02 sensor being located at the tailpipe versus my Innovate sensor is in the downpipe where its more accurate and faster. Engine noise this time around was slightly quieter.
Here is a quick shot the Pi ToolBox software that is what the Cosworth ECU uses. By far this is the most powerful datalogging software out there. I can overlay two runs by offsetting the time (or a value in the data) and compare runs exactly. You can see the engine noise graph at the bottom and start to see the GTX run (in green) and how the engine noise is quieter. This is just one of the many veiws i have setup to tune with.
1.7bar of boost....
Now we are starting to get to the sweet spot of the turbo. This time we are seeing 15-20WHP gain over the GT turbo. Again NO tuning is done but we see the same thing where, AFR is .01Lamba leaner, engine noise this time is about the same average. Making almost 470WHP and 470ft-lbs of TQ is very impressive for what this is. While this may only represent 20% of our turbo kit customers out there, who wouldn't want to take their existing 440WHP car to 470 with a simple bolt on part. Ok maybe not simple, but its not that hard.
1.9 bar of boost.
Ok so this is not normal and doesn't represent what customers normally do, but I had to push just a little. The 1.9bar (27.55psi) run on the GT3076R made about 450WHP. This is what we tell customers the cap is for this turbo. I have see more but its when customers really push to 30-32psi of boost(which tapers down at redline). But this is a lot of stress on a Suby engine! This is the only time I did tuning on the engine, and it was only fuel related. This higher boost level is where the the turbo starts to kick butt. Initial runs were showing 20WHP gain, but with only a minor tweak to the AFR curve, we saw 480WHP! While this was kind of a glory run, the engine noise was quieter (just barely), and the engine seemed very happy. Realistically customers that have any kind of wheel HP over 450, it becomes somewhat of a blur as the car starts to become scary fast. But either way, if we can now say that 480WHP is the cap for this turbo......sweet!
From all this it goes to show that the GTX turbo works and if tuned for, there is at least 20WHP to be gained. Why does it work, simple its more efficient, and it will do higher PR's. The PR(pressure ratio) is not really a Subaru thing as they typically don't get pushed past 30psi very ofter, but that efficiency thing is what makes this a great option. Here is the GT turbo and GTX Turbo compressor map overlaid with air flow from a 2.5L engine.
The graphs show air flow for a 2.5L engine plotted similar to the boost response found on the GT or GTX 3076R turbo. As you can see the plots really runs off the map on the GT compressor map at higher boost/airflow levels. The GTX really fits this engine better!
Could I have made more power? For sure! I think the GTX could have made more power for sure had I turned up the boost a bit more and really tuned the AFR and Timing, I could have hit 500WHP. But pushing 30psi to do so is a lot of stress on a Subaru engine (big bore/short rod issue). This is where a GT or GTX3582R would come into play. It can make 500WHP with a few PSI less, and blow way past the 500WHP barrier. I choose not to as this car is driven everyday and 30psi on the street is just stupid! I know, so is 25psi, but still.....
With speculation of this turbo acting like a GT3582R, why DIDN'T it make tons more power, well I think that is a simple answer. While the GTX3076R flows like a GT35R, the GT35R has a much larger exhaust wheel and there for has much less back pressure as well as more potential to flow more air. So while the GTX3076R compressor wheel flows enough for tons of power, the GT35R turbine wheel needs to be in place to push past the 500WHP mark.
So the question is, "Is the additional cost worth it?" Looking at the standard retail price for a Garrett GT3076R vs a GTX3076R, the GTX is only $230-$250 more. So in this case, I say yes! People spend that on crank pulley plus installation! In regards to the GT3582R vs GTX3582R the retail price difference is $700-ish. Without any proof (yet) the additional $700 is at least worth 20WHP over the other. Again, look at TGV housings and installation cost.Someone could easily spend $700 for housings/modification and installation. So with out proof that it makes any power, I say yes!
Question, "When can I get a PERRIN kit with a GTX turbo?".
Answer, they are available now, so.....now!
Final comments:
Your welcome Garrett......
One of the features Garret proclaims is quieter operation. After my first minute driving the car, i would absolutley agree! Its about half as loud as the old one. There is no way cops will here your turbo screaming from a couple blocks away!
I expect tons of questions, start asking! Email me, IM me, call me, i am here!
Jeff PERRIN
503-693-1702
AIM ALTAPERRIN
[email protected]
Old 01-06-2011, 03:39 AM   #86
Phatron
Member#: 36033
CEO PhatBottiTuning
2006 STi GTX3582 + Meth
nice right up......no gtx30 vs gt35
i think thats one of the biggest questions......since the gtx30 comp map looks so simliar to a gt35...then question becomes why would i get the gtx30 if the gt35 has more power potential and only xxx rpm later spool.....
Old 01-06-2011, 04:18 AM   #87
juanmedina
Member#: 133146
Ron what do u mean by xxx? 100 or 900?
Ron's question will be answer we you guys overlay gtx30 with the gt35 at the same boost level and tuning.
are u guys planning on testing gtx35 vs the gt35? How much power do you loose by switching to the .63 AR housing?
Thanks for the test
Old 01-06-2011, 05:13 AM   #88
NSFW
Member#: 140444
05 Stage Free LGT
This is why I'm really looking forward to a GTX3071 vs GT3076 comparison.
For the 3071, the GTX does use a larger turbine than the GT. From the dimensions, it appears that the GTX3071 might use the same turbine as the GT3076. So I think it's reasonable to expect the GTX3071 to produce similar power to the GT3076. The big question is, how much faster will it spool up?
But don't get me wrong - the GT/GTX 3076 comparison is still pretty interesting in its own right. Thanks for posting it!
Old 01-06-2011, 10:23 AM   #89
wil06STI
Member#: 153228
02 WRX Fully Built
Sedona Red
Jeff, what's the Perrin Stumble fix?
Wil
wil06STI is offline   Reply With Quote
Old 01-06-2011, 11:07 AM   #90
LittleBlueGT
Member#: 96204
2013 STI GR
The GT3076R needed about 20% to hit 1.2 bar. On the GTX it was needing 22%. I know its only 2%, but it shows that the wastegate had to dump more exhaust pressure to control boost. Meaning more air flow was coming from the turbo.
I am a stickler for accuracy, so don't take this as an insult.
If the GTX turbo needed more WGDC to hit target, that means it was dumping less exhaust pressure to control boost. Higher WGDC means the WG is opening less, and more air is going past the turbine.
I theorize that the slightly bigger comp wheel (physically, not in lbs/min) requires a little more exhaust energy to spin.
Thanks for the rest of the work you did, very informative, done fairly as well.
I also would love to see the GTX3071 turbo done.
LittleBlueGT is offline   Reply With Quote
Old 01-06-2011, 11:12 AM   #91
Bad Noodle
Member#: 174442
2007 SuperWagon
I don't spell well
I have nothing to add except I love how you guys do research and share data...seriously, this thread is a engineering nerd's wet dream. I'm gonna save it for read at lunch...
Bad Noodle is offline   Reply With Quote
Old 01-06-2011, 11:23 AM   #92
kellygnsd
Member#: 32669
2007 2.34LR, EFR7670
LINK G4 hybrid STi
PerrinJeff,
What effect on spool do you think holding the cars at 2000 for 3 sec at full throttle had on spool of these units. Do you have any runs in which you didn't "brake" boost before the start of the run?
Old 01-06-2011, 11:33 AM   #93
stu
Member#: 25768
35R OFCDV3 Bugeye
Slowbaru
did you try any race gas while it was on there.
stu is offline   Reply With Quote
Old 01-06-2011, 11:40 AM   #94
jkopinga
Member#: 220799
2006 Impreza WRX
WRC Blue
Jeff,
Big thumbs up for the data. One can see when you do R&D you try to do it in the most proper way to collect meaningful data!! Keep up the good work. Looking forward for more data as ever. Would be nice if you could do some proper R&D on the new EFRs as well
Cheers,
Jasper Kopinga
CS Racing
Taiwan.
jkopinga is offline   Reply With Quote
Old 01-06-2011, 12:21 PM   #95
Clark Turner
Member#: 178047
02 WRX STI Spec C
Cool. Thanks for taking the time and effort Jeff. The GTX is really a nice upgrade to the old golden standard of turbos.
C
Old 01-06-2011, 01:01 PM   #96
PERRINJeff
NASIOC Manufacturer
Member#: 74110
Working on responding right now, but i had to move a couple of pics off the big post because of that dumb 10pic limit. Here they are.
Here are a couple other graphs to show the GTX at different boost levels.
Old 01-06-2011, 01:40 PM   #97
PERRINJeff
NASIOC Manufacturer
Member#: 74110
Good question, why get a GTX3076R if the GT3582R is cheaper and make more power. I can say that for a fact, the GT35R with a .63 housing is no where near as snappy on the road. Without doing the back to back runs (which will be very soon), either 3076R turbo is better below 4000RPM. On the dyno a GT3582R with .63 spools like a GT3076R with a .82, but the question is, does it make more power. I have tons of dyno graphs of customers cars with the GT3582R with .63 and at 22psi of boost they are making 430-450WHP and TQ. But we will do our own testing to really see how they compare on the same car, same dyno. I suspect that its because of the free flowing natures of the bigger exhaust wheel that it will make more top end power.
I am dynoing a friends GT35R with a .63 in a few days (has cams though) so we will get some good results there. Then if i have time swap to the GTX for a few runs we will get that. My intention is to do the GTX3582R on my car to keep things as consistent as possible.
Thanks for the test
For sure! I have the turbo here as well. Most likely not the .82 GT3582R but for sure .63 is planned right away.
I have the GTX3071 here, but i highly dout that its faster spooling. Or faster spooling enough that its noticeable. Because it DOES use the same turbine as the GT3076R and GTX3076R (60mm) i don't think its going to do anything but act like a GT3076R. I was hoping that it would use the smaller 56.5mm wheel which does make the turbo spool quicker by about 300-400RPM. (Tested on 08WRX where 3071w.82 hit full boost at 3600). But since it shares the same turbine wheel the only reason it will spool faster is for reasons the compressor wheel weighs less.
If you think about it, at the same given RPM/Load point the turbo speed will be the same between the two turbos (GTX3076 and GTX3071), but the 3071 will be slightly more efficient at the lower RPM points. So it may allow for a few more HP, but most likely not much different response. That is my guess, but i could be wrong.
Lets just say for argument sake that it does act like a GT3076R, then its not worth buying as it cost about $250 more. But who knows.
Sorry, it was late, i was on a roll with getting it done and just was thinking straight. Thanks for saying something, this morning my mind is much clearer. I changed it up a bit to make more sense.
Originally Posted by kellygnsd View Post
PerrinJeff,
On the bigger turbos, 2-3 seconds is the same as 4. Because the transient response is slower and boost doesn't hit until 4000 its not a big deal. BUt on a 08 WRX if we used a 3-4 second launch, it will be at 10psi before the run begins! So on those 2 seconds is perfect. On the GT turbos, you floor it at 2000 and boost starts at say 2psi and might climb to 3psi before the run starts. On an STI or WRX with stock turbo, you floor it at 2000 and it might start at 2-3psi, but by the time the run starts they can be at 8psi. What makes the most difference is hot header vs. cold header.
Nope no race gas. I wasn't going for the gusto to make the most power possible. It was more to show everyone the GTX and how it compares to the GT turbo. I am excited to see what other tuners and our customers get out of these with race fuel, built heads, and other crazy things!
Old 01-06-2011, 01:59 PM   #98
PERRINJeff
NASIOC Manufacturer
Member#: 74110
Originally Posted by jkopinga View Post
Jeff,
Cheers,
Jasper Kopinga
CS Racing
Taiwan.
I have never hear of EFR, what is that.........
Old 01-06-2011, 02:37 PM   #99
spdracerut
Member#: 269226
One difference between the 3071/3076/3582 will be transient response which you won't see on a dyno. So even of the GTX3071 only makes the same power as the regular GT3076, it should have better transient response on/off boost due to being lighter. So this shows up in driveability, not on the dyno. Though, looking at the compressor map of the GTX3071 vs. the GT3076, it looks like the GTX3071 has better efficiency at the high mass flow rates up until they both choke out.
The Cosworth ECU and data tool box looks badass........
Old 01-06-2011, 02:38 PM   #100
Phatron
Member#: 36033
CEO PhatBottiTuning
Jeff,
I dont wanna convolute your data by talking "different dynos" but im gonna
Is it a safe assumption that the gt numbers would be ~370-380 on a mustang and the gtx would be ~400-410 whp.
Got some new toys for the car. Pics inside... shady North West Impreza Club Forum -- NWIC 11 03-23-2009 10:25 PM
My new 107hp toy.. short Video inside RC0310 Member's Car Gallery 23 03-30-2007 12:56 AM
My new toy,WOOT *pic inside*. joe r North West Impreza Club Forum -- NWIC 23 10-16-2006 11:06 PM
Imprezaf's new toy! (pssst STi inside!) ZoomnWRX Tri-State Area Forum 29 06-26-2003 10:05 AM
Did you guys see my new toy? I know Goosey has... JGard Off-Topic 21 09-29-2002 11:30 AM
