South West Impreza Club
Go Back   NASIOC > NASIOC Chapters > South West Impreza Club Forum -- SWIC
Old 01-13-2011, 03:14 AM   #301
mc06STI
Member#: 244681
2006 Impreza wrx STI
SGM
Originally Posted by kpluiten View Post
Thanks. It's not the best write up, but I hope it's somewhat interesting.
this is a great write up and its interesting to read. i personally dont like reading long paragraphs. but this stuff is Great!
mc06STI is offline   Reply With Quote
Old 01-13-2011, 10:23 AM   #302
Z0rr0
Member#: 23123
15 WRX 6MT
07 Legacy SpecB
Also make sure to coat the pinch bolt in anti-seize as well. These bolts are notorious for rusting like crazy and becoming one with the knuckle resulting in a snapped bolt when you try to remove it.
This +1
But the good news is the bolt that breaks is only like $2 from CSS.. i bought 2 just in case I had to have my passenger bolt removed by a machine shop, after it broke, i didn't even bother with the driver's side.
Z0rr0 is offline   Reply With Quote
Old 01-13-2011, 10:41 AM   #303
kpluiten
Member#: 120273
06 WRBWRXWGN
Now with 100% more Spec-C
Originally Posted by Z0rr0 View Post
This +1
Yeah, I usually buy new ones for any car I work on that is even slightly rusted. A $2 bolt and a bit of anti-seize beats the hell out of $40-60 machine shop visit... and another $2 bolt.
This is where experience pays off. I can feel when that bolt is going to snap now and I jump straight to the torch and hammer rather than just turn it harder.
Old 01-16-2011, 01:30 AM   #304
blkscooby
Member#: 44422
2009 G8 GT
Cammed, sprayed, stalled
Good work Ken. Leave no stone unturned... We could use you at Mike's house to finish the GN.
blkscooby is offline   Reply With Quote
Old 01-16-2011, 03:38 AM   #305
Stick8373
Member#: 259060
2014 BRZ
Gah! I got rear-ended this weekend and forgot all about calling you. Damnit. I'll take a few bucks off for making you wait so long. I'll be in Tucson for the holidays (Thursday on) so we'll get something going! Sorry again! Thanks for the patience.
Got it!! Thanks for the shipment. Build looks sick!! Great work ...
Stick8373 is offline   Reply With Quote
Old 01-21-2011, 04:47 PM   #306
madmax_087
Member#: 197077
1992 Dodge Ram W150
BAN CORINATOR
Glad this thread is living up to its name...
Where is this wagon at Ken?
You still have it?
I dont think you do!
I think you sold the wagon, and are photoshopping old pictures every once in a while until you find a built one to buy that you can say you did yourself!
My whole life is a LIEEEEEE
madmax_087 is offline   Reply With Quote
Old 01-21-2011, 06:07 PM   #307
kpluiten
Member#: 120273
06 WRBWRXWGN
You still have it?
I have a clutch to do in a customer's car this weekend, but I should have some good time tonight and on Sunday to make some good progress. I hope to get the following done:
-Front suspension assembled and installed
-Rear hubs assembled
-Bushing installed on rear hubs and lateral links
-Rear subframe assembly assembled
-R180 assembled
-Fuel tank put back into the car
Tall order, but hopefully it will work out.
Old 01-25-2011, 11:27 AM   #308
kpluiten
Member#: 120273
06 WRBWRXWGN
Well... I was WAY less productive this weekend because the clutch and other things took way longer than expected. I did get some stuff done though.
The first thing I did was take care of the bushings that needed to be pressed into the lateral links. I decided to go with Group-N bushings in every location I could for the car over poly bushings for a variety of reasons. One issue with the Group-N bushings is that they are not a two piece design like most of the aftermarket solutions and as such, they are hard to install, especially given their much higher durometer (firmer rubber).
Initially, I tried to lube up the lateral links and bushings with the Energy Suspension silicon grease, but I still couldn't manage to get the bushings into the arm. I would get them in there about 75% of the way, but then they would bulge to the point I felt I would damage them if I continued to press them.
In response, I made a couple of "funnels" that went from the bushings unloaded diameter to a couple thousandths smaller than the lateral link hold diameter. The funnels has a very slight angle of taper; in the case of the lateral links, it went from ~35mm to 33mm in a 1.5 taper. I also put a radius on the leading edge to prevent and bushing cutting. Armed with this tool, installation went way smoother. This tool is very similar to the Subaru special tool shown in the service manual.
First I lubed the funnel slightly and inserted the bushing needed (there are three different types of lat link bushings and they must be installed in the right lat links for proper performance.
Next I used the press to push the bushing into the funnel, usually about halfway down.
After that I carefully align the tool hole with the hole in the lateral link. They must be concentric to prevent any cutting/slicing/damage to the bushing being pressed. I then clamped the entire assembly to the press block with a ball joint press. This was chosen because it has a hole in the end which can be pressed through. I had to clamp the tool down to keep it from lifting off of the lat link while the bushing was making the transition from the tool to the link. If it lifted, the bushing would extrude out between the two and become damaged. At $10 a pop, that could get expensive very fast. I used an impact socket to give the press some extra reach.
Next I pressed the bushing into the link until I felt it bottom out on the press block.
With the clamp and tool removed, I was left with this:
Then it is just a matter of pressing it the rest of the way in. You usually have to press the bushing through until it looks like it is just about to start going through the link the other way. You do this to make sure the bushing flange pops out on the other side. Then you turn the link over and push the bushing back until it's centered. I had to go back and forth a couple of times to get it right.
Old 01-25-2011, 11:27 AM   #309
kpluiten
Member#: 120273
06 WRBWRXWGN
Next I did the Group-N trailing arm lower bushings in the rear hubs. The process was very similar to the lateral links and again I used a funnel tool. I had the hub apart already so there was plenty of room to work. Others have made tools to do the install while the hub is assembled or on the car. My funnel tool went from 45.5mm to 40mm over a 4 taper.
Old 01-25-2011, 11:29 AM   #310
kpluiten
Member#: 120273
06 WRBWRXWGN
Finished lateral links:
Old 01-25-2011, 11:35 AM   #311
kpluiten
Member#: 120273
06 WRBWRXWGN
The other good news is that the powder coater finished the rest of my parts last week and I got a chance to pick them up yesterday evening. The results speak for themselves.
I didn't get many good pictures, only some quick cell phone shots, but here it is:
BEFORE (I only had a shot of the rear of the caliper):
AFTER (the logo is powder too):
And here is the wheel color with a quick setup:
The brakes were done in a color called "Sweetpea Green" and the wheels were done "Super Black Chrome II" over a silver metallic base.
The wheels are a bit darker than expected, but they look really neat in the light. They are more gray when the light hits the silver base than they look in the above picture. I think it should look good on the car.
Old 01-25-2011, 11:41 AM   #312
02blkwagn19
Member#: 146496
02 WRX Wagon 2.1L
Built not bought. #0003
I like it man. Good call on the lime green.
Keep it up man! If you keep up with this heated pace you should be done within the next 2-3 years!
02blkwagn19 is offline   Reply With Quote
Old 01-25-2011, 11:49 AM   #313
KP
Member#: 147637
HJ's Ask
Hobbs. He knows.
I wouldn't hold your breath.
KP is offline   Reply With Quote
Old 01-25-2011, 03:22 PM   #314
madmax_087
Member#: 197077
1992 Dodge Ram W150
BAN CORINATOR
Rally Stuff
Uh, sarcasm?
Ken that color combo looks EFFING sick son. Effing sick. Im gonna come over to your house and hump your leg later.
Old 01-25-2011, 03:26 PM   #315
mc06STI
Member#: 244681
SGM
ken! That green is CRAZY. i love it. good choice!
Old 01-25-2011, 07:59 PM   #316
Battousai311
Member#: 214964
2011 WRX Premium
Spark Silver
+1, sick looking as hell
Battousai311 is offline   Reply With Quote
Old 01-25-2011, 09:33 PM   #317
kpluiten
Member#: 120273
06 WRBWRXWGN
Old 01-25-2011, 10:05 PM   #318
amroof
Member#: 211224
2005 Saabaru
Who knows
im gonna come steal all your parts and put them on my wagon they look sick!
amroof is offline   Reply With Quote
Old 01-25-2011, 11:06 PM   #319
05bluesti
Member#: 251804
05 WRB STi
ken, wish i woulda had my wheels powder coated with yours, if ya want to trade, im open to it haha
05bluesti is offline   Reply With Quote
Old 01-26-2011, 12:15 AM   #320
TwinscrollGT35R
Member#: 256810
kpluiten spotted... driving down Bell rd
TwinscrollGT35R is offline   Reply With Quote
Old 01-26-2011, 12:35 AM   #321
kpluiten
Member#: 120273
06 WRBWRXWGN
It ain't easy being green.
Old 01-28-2011, 09:14 AM   #322
madmax_087
Member#: 197077
1992 Dodge Ram W150
BAN CORINATOR
OMGHi2U
Oh man that is so sick! I wish my stove had four burners... What color is that? Taffeta White? I mean you are a really brave guy to get your entire stove powdercoated. Looking good dude, cant wait to see that thing in the back of the wagon.
Old 01-28-2011, 10:21 AM   #323
kpluiten
Member#: 120273
06 WRBWRXWGN
****in' Max.
Old 01-28-2011, 10:50 AM   #324
Evil Imports
Member#: 14732
+ 13 B8
You are a dick to everyone
****ing retarded
Evil Imports is offline   Reply With Quote
Old 01-28-2011, 11:32 AM   #325
Z0rr0
Member#: 23123
15 WRX 6MT
07 Legacy SpecB
I am master of Procrastination! subySerb Off-Topic 13 04-29-2008 03:29 AM
By Build Thread: 1991 Legacy Turbo with EJ20G Swap livestrong14 Member's Car Gallery 69 03-14-2007 08:59 PM
Some nice things can be borne out of procrastination [56k beware] sherifx Off-Topic 6 01-21-2007 09:18 PM
Tale of Two Cities: City of God and City of Lost Children Snoopy Off-Topic 7 11-07-2005 11:03 AM
Just sit right back and you'll hear a tale, A tale of a fateful nap... collegedropout Off-Topic 4 08-01-2004 09:36 AM
