Old 01-23-2011, 03:42 PM   #26
DiRTyDT
Member#: 265537
Originally Posted by Ashby View Post
kinda along the same lines, where to get replacement grommets/rivets that you just snap/press into place? you know the ones that hold the front bumper on, my wheel well is missing a few
Let us know what you find. I broke all 3 off my drivers side wheel well this morning. I bought a couple from auto-something store and they don't fit right.
DiRTyDT is offline   Reply With Quote
Old 01-23-2011, 04:57 PM   #27
danrheller
Member#: 258706
Obviously we had to tap something....but the car has NEVER hit anything nearly hard enough to crack a bumper....and yes..it's plastic.....plastic is pretty strong though, with this many cars getting a cracked bumper in the same location...seems like a weakpoint to me.
danrheller is offline   Reply With Quote
Old 01-23-2011, 06:43 PM   #28
wrxdrvr
Member#: 79222
'09 STi 297.5 WHP
Well obviously it DID hit something hard enough to break/crack it... Sorry but that's just how I see it, and that's how Subaru or anyone else who you would like to see paying for it will see it. (insurance, Subaru rep...) JMO
EDIT; I guess what I've been trying to say is, that I don't think it broke by itself, I KNOW mine didn't... It isn't that cheap of a piece... Again, JMO
wrxdrvr is offline   Reply With Quote
Old 01-23-2011, 08:36 PM   #29
GotWRX?
Member#: 254167
2011 WRX Sedan
SSM
i think it may be a problem with the 2011's.....every 2011 i hear of with a cracked bumper is on the lower drivers side, we found a crack in our today when doing the fmic.
Hmm...Not yet convinced that its a common problem, like the rattling passenger door, but my bumper cover cracked at that exact location from scraping a steep driveway last week. Totally underestimated the steepness. Crack started at the one of the empty holes on the underside of the bumper and spread 3-4 inches upwards. I'm guessing those holes are to attach a lip, but seems like a good place for a crack to start. Took of the bumper yesterday and applied some dry wall joint tape and 3M Bumper Repair on the inside. Seems to be holding up for now. Ill get it replaced if it gets worse.
GotWRX? is offline   Reply With Quote
Old 01-23-2011, 09:18 PM   #30
danrheller
Member#: 258706
I'm not saying they just form cracks. But they are clearly a bit weaker in that spot because a bunch of people seem to have a crack in the same spot.
Old 01-25-2011, 06:37 PM   #31
littlewhitewagon
Member#: 103068
11 STI sedan
Install the lower lip so it has something to hold it together... then it makes you more mindful to not smash your expensive lip on everything...
littlewhitewagon is offline   Reply With Quote
Old 01-29-2011, 03:21 PM   #32
davidmount
Member#: 173026
2003 WRX
Sorry to say I've seen about 4 of these at work. Seem to crack all the way through to, try contacting local dealer to have pictures taken of the damage and ask them to contact Subaru. But...Subaru is skittish about the damage, especially when the word impact is used or they see a scraping under the front part of the lower lip. Our local FOM actually wants to know when this is happening so Subaru can decide if there is something wrong with the new model.
davidmount is offline   Reply With Quote
Old 02-01-2011, 09:34 AM   #33
blindgoldfish z
Member#: 218009
2011 WRX 5-door
I noticed the grommet hole on my driver's side is has a crack through it. I don't see the crack spreading to the rest of the bumper yet.
I haven't hit anything harder than air with the car so far (only 1,500 miles on it).
blindgoldfish z is offline   Reply With Quote
Old 02-01-2011, 09:46 AM   #34
mightyatom
Member#: 250679
2011 wrx premium
grayer as the years go by
So i just posted this about my 2011 wrx hatch (http://forums.nasioc.com/forums/show....php?t=2127261). I just went and looked and the grommet's were broken on the passenger side as well. FWIW, the bumper was hit fairly hard by someone turning around in a parking lot and the bumper was all gashed up but did not crack. I could see, however, that with all this cold weather we've had up north, those bumpers would get more and more brittle(easier to crack)
mightyatom is offline   Reply With Quote
Old 02-01-2011, 10:10 AM   #35
MSMStannyl
Member#: 267225
2011 WRX Limited 4DR
Is this really something new? What I mean is that hasn't this same "body kit" been on the STI's for like 2-3 years? Does anyone know if this has been a problem with them for the last few years or is this a 2011 WRX thing? Personally, I haven't had any issues yet. I've got 4000 miles on mine. Then again, I've been lucky enough to have not hit or scraped anything. I'm pretty anal about stopping short of curb's or those curb stops they put in parking lots. Every since my last car which was a hell of a lot lower than my Subaru I've learned to stop short of hitting anything.
BTW, someone mentioned something about getting a front lip? Anyone know where there might be pics of this front lip? I'm interested...
MSMStannyl is offline   Reply With Quote
Old 02-01-2011, 11:10 AM   #36
kennyyu
Member#: 235524
2011 WRX 4DR
Just go to the dealer and ask for push clips. Should be fairly cheap
kennyyu is offline   Reply With Quote
Old 02-01-2011, 02:10 PM   #37
brandlee
Member#: 254676
2011 WRX Limited
My 11' WRX hit a pile of snow in 5 mph and it cracked on the middle of the bumper cover. If you press the cover by hand, you'll find it's not a strong structure and there is no support in the middle bottom part. That's why it breaks easily. A front lip might be a good way to strength the structure... a little bit.
brandlee is offline   Reply With Quote
Old 02-01-2011, 07:36 PM   #38
Lboogie
Member#: 171611
GH WRX Stg.1
SSM
winter temps + plastic + "mysterious" impact of a 3000Lb object = crack
Lboogie is offline   Reply With Quote
Old 02-01-2011, 09:07 PM   #39
brandonk_5
Member#: 268700
2011 WRX Sedan
Obsidian Black Pearl
Crashing isn't cheap...
On a side not, my 11 wrx isn't showing any signs of cracks on the front bumper and I've 'tapped' a few snow banks while parking.
brandonk_5 is offline   Reply With Quote
Old 02-03-2011, 07:48 AM   #40
pdotblanchard
Member#: 261617
Mine is cracked these bumpers suckkk
pdotblanchard is offline   Reply With Quote
Old 02-03-2011, 09:32 AM   #41
BigfootDenny
Member#: 267781
2011 WRX Hatch
Default cracked wrx bumper...
Unfortunately, I joined the cracked bumper club yesterday with my 2011 WRX ....
tapped a snowbank at low speed on right front... tore a piece off the lower lip of the bumper and cracked it too... Amazing how flimsy and brittle the bumper seems. As many have stated, there is virtually no reinforcement for the cover. A bit disappointing to say the least.
If anyone has turned up affordable replacement options, I'd be interested in hearing of them. OEM, or aftermarket.
-BigfootDenny
FWIW -- my feeling is that the bumper covers are in fact low-quality, and much too fragile. Yes, it's cold up here now, but this very minor impact should not have fractured the cover, IMO.
BigfootDenny is offline   Reply With Quote
Old 02-03-2011, 09:35 AM   #42
patricksmith04
Member#: 116816
What are these things made of? Fiberglass?
patricksmith04 is offline   Reply With Quote
Old 02-03-2011, 02:27 PM   #43
playultimate2
Member#: 110645
2011 WRX Premium 5dr
Me too... lost a run in with some packed snow. My bad, but what do you guys think it will cost to fix?
Last edited by playultimate2; 02-03-2011 at 02:32 PM. Reason: figuring out pictures...
playultimate2 is offline   Reply With Quote
Old 02-03-2011, 02:32 PM   #44
Landin2010
Member#: 231674
2010 Impreza WRX
AWD does not make YOU a better driver!
Landin2010 is offline   Reply With Quote
Old 02-03-2011, 03:26 PM   #45
QwaktastiK
Member#: 219100
'09 WRX Premium 5dr
SWP Bilstein'd COBB Stg2+
Joined this club today. Needless to say, I have an '09 and don't know if repair or replacement is the better option. If it's the matter of $100-$200 I'd rather just get an aftermarket bumper or replacement OEM rather than repair. Any input would be greatly appreciated.
QwaktastiK is offline   Reply With Quote
Old 02-03-2011, 03:44 PM   #46
SomeoneWhoIsntMe
Member#: 160814
2002 WRX Wagon
SomeoneWhoIsntMe is offline   Reply With Quote
Old 02-03-2011, 09:43 PM   #47
BigfootDenny
Member#: 267781
2011 WRX Hatch
IMO, it's done. The bumper covers are $269... then you gotta get it painted... see my photo two posts above yours....
in the meantime... check out this thread / video which shows how easy it is to loosen the bumper cover (or remove it).
http://forums.nasioc.com/forums/show....php?t=1926975
Then you can easily re-fasten the plastic clip section that joins your fender and the bumper cover. Mine looked just like yours at the seam, but I re-fastened it today easily in 10 minutes using instructions in the video... hopefully the cover will hold together until I decide what to replace it with...
Old 02-08-2011, 04:26 PM   #48
DiscoGsus
Member#: 47646
0211 RallyWagon
DGM Sedan
I found out mine was cracked this morning.
I have 1400miles, with no impacts with cars, snowbanks, birds, or anything else.
I have scraped the underside of the front bumper on the outside edges (where its lower) But not enough to even get through the paint....
I have a 175,000mile 2002 WRX that I've rallycrossed and driven through hell and its never even lost a clip.
DiscoGsus is offline   Reply With Quote
Old 02-08-2011, 05:10 PM   #49
playultimate2
Member#: 110645
Thanks, Denny. With a little finesse, I was able to reseat the bumper cover so that unsightly gap is gone. I figure I'll get it replaced in the spring and be out about $600. I have no idea what painting and installation costs -- haven't called the shop yet.
Old 02-08-2011, 11:01 PM   #50
knighthawk1104
Member#: 241940
2011 WRX Hatch
wait these are made of plastic? not the usual polyurethane like other cars? im a little new to subaru but not that new to cars. it's shocking it's just plastic. my 2011 wrx hatch apparently has a crack also. i didn't see it yet but my dad told my mom which told me.
i think this just might be a minor fault in the design of these bumpers. i really hope they will do something about it because my rear bumper was in a hit and run so im not in the mood to fix the front bumper too.
EDIT: Here are my pics of the damage.
knighthawk1104 is offline   Reply With Quote
WTB : 02-03 wrx lower front bumper piece... 240WRX02 Private 'Wanted' Classifieds 2 06-28-2010 01:12 AM
cracking on front bumper OneArmedScissor Interior & Exterior Modification 1 05-01-2004 02:22 AM
'02 WRX wagon: lower front only? gordon Brakes, Steering & Suspension 28 02-22-2004 12:07 AM
CRACKED my front bumper!!!!. SFimpreza411 Bay Area Impreza Club Forum -- BAIC 4 06-30-2002 03:06 AM
Message Board Statistics All times are GMT -4. The time now is 07:55 AM.
