Old 12-30-2010, 06:07 PM   #2026
bschweig
Member#: 179006
2008 STi GR
This is my old setup...Block just rebuilt and many many new parts (incl a Dom 3 XTR)... will post that once dyno'd
e85 is likely one of the best things i have done to the car. i will never go back.
inj. duty cycle pushes 90% at WOT.
Numbers
Dyno: Dyno dynamics
Tuner: Harvey Epstein
The Boost Creep Ltd - Dyno Tuning and Automotive Services in Longmont Colorado[/url]
Baseline (actually an AP Stage 1 flash): 207 whp
Wheel HP: 411
Wheel TQ: 420
Ambient Temp: 60
Elevation: 5280
Car Info
Year: 2008
Engine Management: AccessPort V2
Turbo: Dom 3.0r
Intercooler: Perrin FMIC
Meth Kit: -
Injectors: Bosch EV14 - 1000
Intake/Inlet: Perrin CAI, Perrin silicone inlet
Headers: Perrin
Uppipe: Perrin
Downpipe: Perrin
CBE: Perrin
Other Power Mods: E85, Blitz sbc i-d spec r, Irridium plugs (1 step cold), Warlbro fuel pump
Link to tuner:
The Boost Creep (new shop, Longmont, CO)[/url]
bschweig is offline   Reply With Quote
Old 01-10-2011, 02:25 PM   #2027
SurfGuruJeff
Member#: 148974
2010 STi Hatch
Took my car to the track.
I made 13 passes, and every time I was spinning all 4 tires in 1st gear. Conditions are terrible because the track got flooded and there is still dirt/sediment all over the area. Also under powered from a pre-turbo exhaust leak.
@ RaceLegal Qualcomm Stadium in San Diego
Best time of the night was an 8.282 (1/8th mile)
Car weighs 3340lbs No Driver, full tank of gas. 3515lbs with me in it.
7. 316whp 352wtq / SurfGuruJeff /05 STi/ VF39 / [email protected] / 850cc + 85% / 10 ft
Some guy with a G35 made a video of just how bad the track conditions were. That's me zipping by him.
SurfGuruJeff is offline   Reply With Quote
Old 01-13-2011, 10:10 PM   #2028
jr4jc
Member#: 76834
2005 STI
crystal metalic gray
ok chime in and let me know what you think!??!
i just had my 05 sti motor rebuilt, the guy who did the work, said i had 2 cyclinders with broken ringlands, the car had been driven a bit while trying to rule out other problems. the builder said that there was a lot of black gunk on the intake, he blames the e85 and said it probably was degrading something in the fuel system.
I wonder if it was just from burning so much oil. it burned a lot of oil over the last months before the rebuild, long story.
e85 or oil or >????
jr4jc is offline   Reply With Quote
Old 01-13-2011, 10:21 PM   #2029
Maxwell Power
Member#: 190729
oil burning. See it all the time on engines not running e85.
Old 01-13-2011, 10:34 PM   #2030
jr4jc
Member#: 76834
2005 STI
cool that is what i thought,
i really like running e85.
thanks
Old 01-13-2011, 11:03 PM   #2031
jr4jc
Member#: 76834
2005 STI
i drove the car home carefully, 30 miles from the builder, with my e85 map and a tank full of 93oct. the builders computer would not work to change my map, my pc is not working with rom raider either. so the builder drove it with the e85 map and the a/f ratio's were ok. so can i drive it 970 more miles on the e85 map, since i won't be getting on it till i change the oil and the fuel back to e85. or do i need to find a way to get the 93oct map on the car???
Old 01-13-2011, 11:47 PM   #2032
Maxwell Power
Member#: 190729
you're better off running that tank dry and continuing with the break in on e85. Just change the oil more frequently to minimize any contamination from the fuel. I swapped over to e85 130 miles into my break in and then threw the bitch on the dyno. Tuned her to 500whp and had zero issues. I'm not recommending that for you because I have no idea how good of a builder you have.
You have to be rich as hell on an e85 map running 93 octane. Rich is no good for break in. Taking a fresh motor and making a ton of carbon deposits in it is an absolute waste.
Old 01-15-2011, 01:17 AM   #2033
jr4jc
Member#: 76834
2005 STI
hey thanks, i found a freind with a computer that runs romraider, and i have a 93oct map, so i'll put it on till it's broke in, then back to e85.
Old 01-17-2011, 02:15 PM   #2034
mxpop
Member#: 103776
2006 STI
mxpop is offline   Reply With Quote
Old 01-19-2011, 10:48 AM   #2035
Reuna
Member#: 151496
Originally Posted by mxpop View Post
"The turbo system uses the OEM exhaust manifolds with AQMS up and downpipes."
OEM twin scroll manifolds? they seem to be flowing pretty well.
Reuna is offline   Reply With Quote
Old 01-20-2011, 08:02 AM   #2036
sumfoo1
Member#: 82146
2005 Legacy GT
Default five-0 injectors
Originally Posted by Phatron View Post
Id suggest doing the top feed conversion, 1600cc five-0's, and keeping the stock FPR.
every car i've tuned with a FPR is finicky. They dont seem to keep consistent fuel pressure. And they dont seem to work exactly like stock......they seem to drop FP more and i've had to re-adjust the high MAFv range on almost all of them. I guess it could be installation issues but it seems to be a common issue across the board.
I think topfeeds and stock FPR will give better/more consistent results than big azz sidefeeds and a FPR.
So people are having good luck with the five-0 injectors? Better than the ID injectors?
In my opinion the injectors are your last line of defense against detonation so i want to make sure i have the best ones i can.
I need a setup that will run gas just fine but will run e85. I live in raleigh nc and there is 1 e85 gas station here (luckily near my house) other then state owned stuff so i plan to run e85 more like a "race gas tune". So i need something that will idle fine on gasoline but flow enough for ~420whp (max) on E85.
Thank you,
-foo1
sumfoo1 is offline   Reply With Quote
Old 01-20-2011, 08:12 AM   #2037
T3RMIN4L
Member#: 37434
I'd also like some more feedback on the five-o's as I'm considering dropping the ID1000's in favor of some five-o 1200's for the next e85 build.
T3RMIN4L is offline   Reply With Quote
Old 01-20-2011, 10:18 AM   #2038
Superorb
Member#: 135252
2002 WRX Wagon
86% Operational :(
Thank you,
-foo1
The station on 64? Fill out your profile so we know more about you.
Several people here have had great results with the five-0 injectors.
Superorb is offline   Reply With Quote
Old 01-20-2011, 11:53 AM   #2039
sumfoo1
Member#: 82146
2005 Legacy GT
It sounds like there are two then. Who on 64 has it ? I know there is one on 55 by RTP
Old 01-20-2011, 12:04 PM   #2040
Phatron
Member#: 36033
CEO PhatBottiTuning
2006 STi GTX3582 + Meth
i've never had any problems with them....so far...but crashtke was posting up some links to a vette forum yesterday where people were getting the wrong injectors and they werent flowing what they were supposed to.....
i havent heard of any troubles on subies yet.
Old 01-20-2011, 12:14 PM   #2041
sumfoo1
Member#: 82146
2005 Legacy GT
That's cool, I've just read the id1000/2000s were like the holy grail of injectors. They seem to idle great and run really well. Although to run them on a legacy you pretty much have to change the rails, fpr and convert to parallel fueling so any of those things could help with their reputation. I currently have a vf52 on stock injectors and fuel pump so the next step is more fuel, then probably start the modification circle over again with a bigger turbo (lol EFR is in the dreams still trying to make it in the budget.)
But the eventual goal will be 350-400 whp on stock bottom end (for as long as it lasts).
P.S. my profile is now updated
Old 01-20-2011, 12:25 PM   #2042
juanmedina
Member#: 133146
07 FPgreen [email protected]
WRX VF39+E85 12.0, 121mph
the fiveO 1200s already have been proven to work really well, I have them.
Did you guys get the account with FiveO?
I been thinking about my future setup, I need a fuel system to support a 35r size turbo.
I wonder if my 1200cc with a FPR and one of the news fuel pumps (Deatschweks 300 or Aeromotive 340) will suffy. I am probably better of by switching to 1600cc with one of the new pumps.
The fiveO 1200s are bosh EV14, the 1600s are Denso EV6, does anyone know if the Denso EV6 are any good?
Thanks for the map Ron
Old 01-20-2011, 12:35 PM   #2043
Phatron
Member#: 36033
CEO PhatBottiTuning
well....you have it 2/3 right juan.
The topfeeds are ev14 and ev6.....the 1200cc sidefeeds are JECS...which i believe are merely modded stockers.
Yes i got the account....the problem is that they are already so cheap its hard to make any money after shipping and paypal fees.
I can get a good discount if i order 10-15 sets but i dont really like selling parts...too many questions. I like people who just buy stuff
Old 01-20-2011, 12:37 PM   #2044
juanmedina
Member#: 133146
well....you have it 1/3 right juan.
the side feed 1200 worked great according to Renosubby, 2/3
Old 01-20-2011, 12:39 PM   #2045
Phatron
Member#: 36033
CEO PhatBottiTuning
ninja edit. im probably gonna put my 1200cc sidefeeds in tonight.
Old 01-23-2011, 11:09 AM   #2046
wrxsubiemod
Member#: 165104
E85 SoCalPorting
Owner
whats going on guys, back from a long vacation hahahah. cars been garaged for months piecing new suspension components and gutting the hack out of her lol
Phatron I sent u a PM^ U should put those 1200cc in or sell them to me with a tuning bundle package lol.
wrxsubiemod is offline   Reply With Quote
Old 01-23-2011, 08:48 PM   #2047
STiled_04
Member#: 210933
2004 Impreza STi
Platinum Silver Metallic
430whp 420wtq / STiled_04 /04 STi / EJ257 + 30R / 11.7 @ 123mph / 1200cc injectors.
STiled_04 is offline   Reply With Quote
Old 01-23-2011, 08:50 PM   #2048
STiled_04
Member#: 210933
2004 Impreza STi
I have 1200cc side feeds. Custom made from two sets of stockers. Work great.
Old 01-23-2011, 08:52 PM   #2049
STiled_04
Member#: 210933
2004 Impreza STi
Originally Posted by juanmedina View Post
SORTED BY 1/4 ET
Code:
/1/4 mile               /      POWER       /       NAME    / Subaru Type / Engine-Turbo Setup  /   INJECTOR SIZE + IDC/   ELEVATION
1.[email protected]           /631whp 463wtq         /bertune  /05 wrx   /04 sti   / EJ257 + 6765  /1600    /0 ft.
2.[email protected]         /527whp 487wtq          /  cnstman       /04 WRX STI  /EJ257 + 35R .82 AR"      /1000 cc + 95%         /6200 ft
3.[email protected]           /546whp 440wtq         / 06rexwagon     /06 WRX wagon/ EJ255 + Dom4            /960 cc + 95%          /5400 ft
4. [email protected] /                        /GeneralTJI   /02 WRX wagon  / EJ20 + Holset HE351      /830cc + 84%            /4800 ft
5. [email protected]   /370whp 340wtq   /BenGSX (aka Bouncer)/05 WRX Wagon/ EJ205 + FP 68HTA                     /850cc + MAXED          /100 ft
6. [email protected] /328whp 369wtq       / juanmedina      /07 WRX TR   / EJ255 + VF39    /  [email protected] /860cc +  80.83        /1048 ft
7. [email protected]/333whp 335wtq         /thorne      /03 WRX     / EJ20  + VF39                                  /823cc +  80%    /
8. [email protected]      /334whp 318wtq         /chargerbry      /04 WRX     / EJ20  + EVO3 16g  /850cc +  88%    /500ft
9. [email protected] /358whp 405wtq          /Infamous1   /06 Legacy  / EJ255 + VF39      /816cc + 84%            /1000 ft
10.[email protected]          /285whp               / Guy on the corner /05 LGT      /EJ255 + VF52             /930cc +  75%          /5800 ft
[email protected]           /280whp and 270wtq    /   thefoos       /02 WRX      /EJ20 + VF43              /825cc + 83%            /700 ft
12.[email protected]       /363whp 460wtq          /ChandlerWRX06       /06 WRX      / EJ255 + VF39       /850cc + 75%           /1100 ft
13.                       /351whp and 328wtq    /     JSarv       /02 WRX      /EJ20 + TD05-18g 7cm2 3"  /1000cc + 75-80%        /500 ft
14.                       /550whp 480wtq / Scuba Steve    /04 WRX STI  /EJ257 + 35R .82AR"       /1680 cc + 88%         /6200 ft
14.                       /325whp 360wtq             /TDagen      /02 WRX      /EJ257+ Tdo5 18g          /740cc + 95%    /
10.                       /508whp 495wtq         / swiftwrx1      /06 WRX STI  / EJ257 + gt65            /1100 cc + 85%            /0 ft
11.                       /312whp 359wtq      /   Silverstg2      /02 WRX      / EJ257 + VF39            /765cc + 85%           /1200 ft
12.                       /354whp 373wtq        /Kastley85891     /08 WRX STI  / EJ257 + Tdo5 20g 8cm    /850cc + 97%            /500 ft
13.                      /460whp 452wtq         /mick_the_ginge  /03 WRX wagon/ EJ257 + 35R .82 AR      /1100cc + 75%           /600 ft
14.                      /150whp 150wtq         / HamFist        /2.5 RS      / none :lol:              / 280cc + %             /5280 ft
15.                      /331whp 381wtq        /modliving       /08 FORESTER FX/ EJ257 + VF48           /850cc +  ??    /
16.                      /338whp 398wtq          /putz           /06 WRX TR   / EJ255 + Td06h 20          /1150cc +  ??          /1030 ft
17.                      /326whp 408wtq      /  roninsoldier83  /06 WRX STI      / EJ257 + VF39           /811cc + 75%           /6000 ft
18.                     /752whp 605wtq        /bertune          /04 WRX STI  / EJ257 + P6765           /1600 cc maxed         /0 ft
19.                     /586whp ???wtq        /billionaire7     /06 WRX STI  / EJ257 + GT4088 1.08 AR  /1600 cc               /5300 ft
20                      /265whp 247wtq    /      rexblake       /02 WRX      / EJ20 + 16g              /750cc                 /1200 ft
11.                      /341whp 315wtq          /neversummer489           /02 WRX    / EJ20 + HTA68/                                 /820cc +  ??          /
19.                      /268whp 268wtq    /      Adamlavender       /02 WRX      / EJ20 + VF39  /                                      /820cc                 /6500 ft
11.                      /341whp 379wtq          /tazswing           /09 OXT    / EJ255 + HTA68/                                 /850cc +  95%          /800ft
9.                        / 409whp 394wtq          /pignoseSTI   /06 WRX STI  / EJ257 + 3076R .63 AR  /                                                   /1200cc +             /120 ft
I believe I am 4th on list
Old 01-24-2011, 08:47 AM   #2050
maxpowr
Member#: 159243
sg3 Turbo Tek Tuned
Hakt Ecu e85 30r 6spd
stiled04...pm me or post up some details of your build.
50 more whp to be made on e85 compared to 93 has my interest peaked.
Motion Lab Tuned: Juanmedina's 2007 WRX E85 ARMY Motion Lab Tuning Proven Power Bragging 125 04-12-2010 02:57 AM
jid2 Track Car - e85 ARMY jid2 Member's Car Gallery 38 01-22-2010 10:44 PM
The Honduran army is the bravest in the world... wrxcelent Off-Topic 36 07-07-2009 08:21 AM
Spacific E85 Tuning thread Here ? discopotato03 Engine Management & Tuning 1 09-09-2008 11:01 AM
Did anyone hear the one about the Italian army and the IRAQI satiation? Asinine Off-Topic 3 09-20-2005 07:06 PM
