Welcome to the North American Subaru Impreza Owners Club Sunday February 7, 2016
Old 01-24-2011, 09:55 AM   #2051
02RexWI
Member#: 165141
Originally Posted by STiled_04 View Post
I believe I am 4th on list
Tied with me, exact same ET and MPH.
Mine was in a buddy's WRX with a 2.5 hybrid and PPG box though, I'll see if he has the timeslip.
His was on an FP HTA green.
02RexWI is offline   Reply With Quote
Old 01-24-2011, 12:14 PM   #2052
wrxsubiemod
Member#: 165104
E85 SoCalPorting
Owner
If anyone has a good set of 1200+cc side feeds LMK
Old 01-24-2011, 03:33 PM   #2053
STiled_04
Member#: 210933
2004 Impreza STi
Platinum Silver Metallic
Haha, nice! I will have to look at the time ticket and see what the hundredths of seconds was. I doubt we have exactly the same time, one of us will be ahead. I will post a pic.
STiled_04 is offline   Reply With Quote
Old 01-24-2011, 03:49 PM   #2054
02RexWI
Member#: 165141
I believe my exact time was 11.73 @ 123.xx MPH, hopefully he still has the timeslip... Otherwise I'll have to go run again on the new engine I built for him.
Old 01-24-2011, 09:39 PM   #2055
STiled_04
Member#: 210933
2004 Impreza STi
Originally Posted by maxpowr
stiled04...pm me or post up some details of your build.
50 more whp to be made on e85 compared to 93 has my interest peaked.
Here is the link to my member gallery thread. That has a list of all the goodies I have.
http://forums.nasioc.com/forums/show....php?t=2101846
Old 01-24-2011, 11:22 PM   #2056
STiled_04
Member#: 210933
2004 Impreza STi
Ok your 4th...11.7819 @ 123.35
Old 01-24-2011, 11:51 PM   #2057
maxpowr
Member#: 159243
sg3 Turbo Tek Tuned
Hakt Ecu e85 30r 6spd
gonna have to go after 4th son!
mid west vs south west showdown!
maxpowr is offline   Reply With Quote
Old 01-25-2011, 03:13 AM   #2058
02RexWI
Member#: 165141
4th is yours if I cant find the timeslip, but I guess the time and MPH should still be listed in the MWSOC shootout thread from last year. I took 3rd.
Old 01-27-2011, 02:38 AM   #2059
evoevo
Member#: 166301
04 500 hp evo
Wow it's amazing how much of a difference E85 can make. I made a 100 extra hp to the wheels just from E85. Lets all have a moment of silence for the corn. lol
evoevo is offline   Reply With Quote
Old 01-27-2011, 04:43 PM   #2060
STiled_04
Member#: 210933
2004 Impreza STi
True, e85 is sweet....but my days of it were short lived
I damaged my head gaskets, by running 27-28 psi, on a stock 2.5 with 65K miles.
I'm still leaking coolant at low boost levels, so until they are fixed, most of the fun is gone. Sigh....
Old 01-27-2011, 04:47 PM   #2061
maxpowr
Member#: 159243
sg3 Turbo Tek Tuned
28psi on stock bottom end...
Old 01-27-2011, 04:49 PM   #2062
Maxwell Power
Member#: 190729
that's rare and odd that the HG's failed. You must have had some detonation, overheated or possibly even a hydro lock at some point.
Maxwell Power is offline   Reply With Quote
Old 01-27-2011, 05:05 PM   #2063
amalgrover
Member#: 183480
2011 Audi A3 Quattro
2009 Forester XT
careful driving that...that is i am in the predicament i am in right now. my headgasket started seeping, and i tried to limp it for the last couple weeks before i deployed...well, when i pulled the motor apart the day before i left, the heads and block are scored from the combustion gases being pushed into the coolant passages. the block is scored to the point where sleeving is the only option to fix it...if i would have just parked it and toughed it out that last couple weeks i wouldn't be doing anything but changing a headgasket. what could have been a couple hundred dollar fix is now a couple thousand...
amalgrover is offline   Reply With Quote
Old 01-27-2011, 06:30 PM   #2064
Maxwell Power
Member#: 190729
my buddy did the same thing with his evo. Destroyed the head and the block from combustion gases going back and forth between cylinders. Pretty awesome failure.
Old 01-27-2011, 07:57 PM   #2065
STiled_04
Member#: 210933
2004 Impreza STi
It's a couple thousand for me no matter what. I am not going to install the gaskets myself (don't have the means to pull out the engine), and I am also buying an arp head bolt set. Gonna replace the timing belt and all that stuff too, might as well. All said and done, bout 2500.
Old 01-27-2011, 08:11 PM   #2066
Maxwell Power
Member#: 190729
it's more than that if you ruin the heads or block. That's what he's getting at.
Old 01-27-2011, 08:25 PM   #2067
STiled_04
Member#: 210933
2004 Impreza STi
Yeah I know, I more was more commenting about spending a few hundred for replacing gaskets.
Old 01-27-2011, 08:30 PM   #2068
STiled_04
Member#: 210933
2004 Impreza STi
With stock head studs?
Old 01-28-2011, 02:13 AM   #2069
climberd
Member#: 183019
05 LGT Stg3 Wgn
how much timing were you running at peak tq and redline with that 28psi?
climberd is offline   Reply With Quote
Old 01-28-2011, 04:45 AM   #2070
amalgrover
Member#: 183480
2009 Forester XT
has anyone played with the new definitions (well...newish...i just found them yesterday) with the ignition dwell tables? if so, what kind of changes are working for everyone? i read over on romraider that people are seeing great results by increasing dwell anywhere from .2-.6 across the board, but this is for pump gas applications. i am just curious if anyone has seen any good results with e85.
Old 01-28-2011, 08:18 PM   #2071
john 1badSTI
Member#: 77470
04 sti 10.51@138.5
on e85@ 30psi--spinning
remember dwell time is how long the coil is energized,be careful too much dwell can overheat the coils and burn them up---it may only be a quick bandaid on an insufficient ignition system and cost you some coils in the end.I would not tweak the dwell more then .2-.3,just my opinion.
john 1badSTI is offline   Reply With Quote
Old 01-29-2011, 12:26 PM   #2072
maxpowr
Member#: 159243
sg3 Turbo Tek Tuned
i was recently told i shouldn't use any rubber fuel lines for fuel when running e85. guy told me AN only.
that alone may push me closer to meth.
Old 01-29-2011, 02:00 PM   #2073
john 1badSTI
Member#: 77470
04 sti 10.51@138.5
no you don't HAVE to run AN most premium FI fuel line will be sufficient jake,just make sure it is rated for your pressure.
Old 01-29-2011, 03:29 PM   #2074
maxpowr
Member#: 159243
sg3 Turbo Tek Tuned
Thanks john, I had my doubts...i dont think flex fuel vehicles have an fittings/hoses...
Old 01-29-2011, 04:07 PM   #2075
Phatron
Member#: 36033
CEO PhatBottiTuning
2006 STi GTX3582 + Meth
Motion Lab Tuned: Juanmedina's 2007 WRX E85 ARMY Motion Lab Tuning Proven Power Bragging 125 04-12-2010 03:57 AM
jid2 Track Car - e85 ARMY jid2 Member's Car Gallery 38 01-22-2010 11:44 PM
The Honduran army is the bravest in the world... wrxcelent Off-Topic 36 07-07-2009 09:21 AM
Spacific E85 Tuning thread Here ? discopotato03 Engine Management & Tuning 1 09-09-2008 12:01 PM
Did anyone hear the one about the Italian army and the IRAQI satiation? Asinine Off-Topic 3 09-20-2005 08:06 PM
