Old 01-26-2011, 02:37 AM   #1
Tetegra
Member#: 268356
Question 2011 WRX/STI: How to remove front bumper vents?
I'm trying to adjust the level of the fog lights on my 11 rex. I've read some threads and the first step is to remove the front bumper vents. Does anyone know how to remove them?
Tetegra is offline   Reply With Quote
Old 01-26-2011, 02:52 AM   #2
ejicon
Member#: 2452
08 2.5 WRX
WRB Mica
Are you sure through the vent? I think you either have to go underneat the bumper or simply remove it... Hmm...
ejicon is offline   Reply With Quote
Old 01-26-2011, 03:00 AM   #3
Tetegra
Member#: 268356
All I know about the fog light adjustment comes from this thread... But I don't know how to perform that "push and pull" : (
http://www.iwsti.com/forums/gr-gener...djustable.html
Old 01-26-2011, 03:01 AM   #4
Yeah Its A Wagon
Member#: 229506
02 wagon
wrb
unclip the 3 clips on the bottom of the fender liner that on the bumper and reach your hand in and the vents pop out, there just clipped in ..
Yeah Its A Wagon is offline   Reply With Quote
Old 01-26-2011, 11:48 AM   #5
littlewhitewagon
Member#: 103068
11 STI sedan
^^^^ Yup, the 3 that are right in front of the wheel that are closest to the bottom corner of the bumper. This is the easiest way without getting under the car.
littlewhitewagon is offline   Reply With Quote
Old 02-22-2011, 01:49 PM   #6
rex777
Member#: 270632
Chapter/Region: HIIC
2011 WRX AWD Hatch
white
Hey all that are following this thread,
What method are you using to re-position / re-aim your fog lights?
For example, are you parking the car X feet from a wall and then using the screw adjustment to aim the fog lights slightly below the headlights by a certain amount of inches on the wall, but higher than where they were originally? Etc.
rex777 is offline   Reply With Quote
Old 02-22-2011, 03:10 PM   #7
Landin2010
Member#: 231674
2010 Impreza WRX
Obsidian Black Pearl
fog lights are meant to aim a lot lower than the headlight,s if you are 10 ft from a wall and you aim them a foot below the headlight then when youre 100ft away from something theyll be shooting to the stars. you want them to be level period. park the car on a level surface and make sure theyre aiming level it will be a lot better when you end up in actual fog.
Landin2010 is offline   Reply With Quote
Old 03-10-2011, 07:48 PM   #8
gmack28
Member#: 276430
Default Front Bumper Vents '11 WRX STI
Does anyone know what the part number is and/or where I can order these?
gmack28 is offline   Reply With Quote
Old 03-11-2011, 11:12 PM   #9
littlewhitewagon
Member#: 103068
11 STI sedan
Left and right side are different. Different colors are different part numbers. Go to your dealer or subarugenuineparts.com
Old 09-18-2011, 07:49 PM   #10
NoSubs
Member#: 262469
2011 WRX STi
Somehow this vent came loose on my STi. I know the person who did my clear bra removed these vents, it is possible they did not put it back properly. I noticed it was loose while giving it a wash this weekend.
It was not snapped in properly and I could not snap it back in, so I searched and surprisingly found this very helpful thread! Thanks.
I was able to undo those three clips in the wheel well (and also one on the bottom of the bumper), then just reach in and snap the vent in from the inside.
Unfortunately one of the three clips that snap in the actual vent is missing, but with the top and bottom one secure I'll wait until I am at the dealer next time to pick up another one for the middle. It seems the middle clip is largely redundant because there is very minimal, if any, play in the vent when using only two of the three.
NoSubs is offline   Reply With Quote
Old 09-19-2011, 04:54 AM   #11
HXC573
Member#: 268007
Ice Silver Metallic
Me and my friend said F**k It to ours and just put a bead of strong glue around the inner edge of the two vents so you never have to worry about that poorly made side design vent and clips again haha
HXC573 is offline   Reply With Quote
Old 09-19-2011, 03:38 PM   #12
shaggydog
Member#: 247390
'11 STi
Heres the part if you really want to know. FYI for future people.
shaggydog is offline   Reply With Quote
Video How To Remove Front Bumper Impreza WRX 08+ thomazwrx Interior & Exterior Modification 32 11-25-2014 03:22 PM
How to remove front bumper / grill? HALP! T-Squared Newbies & FAQs 0 08-06-2010 06:28 PM
how to remove front bumper on 04 sti 04silverscooby Interior & Exterior Modification 6 10-10-2005 11:50 PM
how to remove front bumper deluxsti Interior & Exterior Modification 0 06-03-2005 07:36 PM
How to remove front bumper on '04? imminence Interior & Exterior Modification 2 11-20-2003 10:22 PM
