Old 01-20-2011, 06:55 AM   #126
RallyBlueBill
Member#: 267118
2011 WRX 4 door
Great job, xluben!
Same winter tire/wheel combo here, too.
Subscribed.
RallyBlueBill is offline   Reply With Quote
Old 01-20-2011, 07:23 AM   #127
wrx0218
Member#: 186536
2002 Impreza WRX
excellent job so far....I have the same wheel and tire setup for winter as well.
wrx0218 is offline   Reply With Quote
Old 01-20-2011, 07:43 AM   #128
xluben
Member#: 261612
2002 WRX - 750WHP
9.5s @ 150mph
Originally Posted by jockeygolfs View Post
Awesome! Subscribed...
Awesome!
You need a thread like this for your car. I'd love to ogle all the stuff you have for it
Originally Posted by havok4619 View Post
Just put my order in for the obp hatch
You'll enjoy it. I love black cars. Had to get OBP when I got my WRX.
Originally Posted by RallyBlueBill View Post
Great job, xluben!
Subscribed.
Thanks. I am really liking the General's. Lots of snow in MN this year.
Had steelies on my last car for winter as well. I actually kind of like the look.
Old 01-20-2011, 08:11 AM   #129
jockeygolfs
Member#: 260868
2011 STI
Originally Posted by xluben
Awesome!
Too much work lol!!
jockeygolfs is offline   Reply With Quote
Old 01-20-2011, 09:09 AM   #130
AG206
Member#: 269794
2011 WRX Premium
Really digging the murdered out look.
Do your mods void warranty? or are you not worried about it?
I'll probably follow you on the steelies.
tint?
AG206 is offline   Reply With Quote
Old 01-20-2011, 10:12 AM   #131
RallyBlueBill
Member#: 267118
2011 WRX 4 door
The mods won't "void" the warranty but they do open the door WIDE for the dealer to DENY warranty coverage.
In all honesty, the part(s) you install should be proven to have caused the failure of the item you're trying to warranty.
But OH the battle that would insue over that!
Unless you're REAL tight with the dealer somehow or other, ANY performance mods (other than SPT) are playing with fire, warranty-wise.
Chose your mods carefully and don't expect your dealer to fix what a bunch of HP/TQ increases break.
Old 01-20-2011, 11:29 AM   #132
xluben
Member#: 261612
2002 WRX - 750WHP
9.5s @ 150mph
Originally Posted by .David. View Post
Ditto. Love the all black.
Thanks. I wouldn't mind some tint, but it's pretty low on my list of things to do. Maybe eventually.
Old 01-23-2011, 04:58 PM   #133
xluben
Member#: 261612
2002 WRX - 750WHP
9.5s @ 150mph
I have mine installed with a Defi boost gauge on the right side, and a gauge pod blank on the left.
Actual view (wheel adjusted as I actually use it):
Left Side:
Right Side:
Which one is OEM?
The pod looks excellent. The finish is a near perfect match. Unless you told someone it was a new piece, there's no way they'd notice on their own. Even after being told 99% of people would say it looks identical. The gauge placement is very good. From where I sit the "MPH" is partially blocked on the speedometer, and a little bit of the temp gauge is blocked.
The blinker/wiper levers do get in the way of the gauge pods a little bit depending on where you have the wheel adjusted to. Moreso on the left side where I have the blank. On the right side the wiper lever blocks a little bit of my boost gauge, but nothing that I need to see. Overall I am 100% happy with the pod, and would recommend it to anyone!
Old 01-23-2011, 09:10 PM   #134
Braves Nation
Member#: 246640
2007 WRX limited
cgm
That cluster looks great, looks like oem.
Braves Nation is offline   Reply With Quote
Old 01-23-2011, 10:31 PM   #135
xluben
Member#: 261612
2002 WRX - 750WHP
9.5s @ 150mph
Thanks. Cluster does look amazing!
Old 01-29-2011, 08:30 PM   #136
xluben
Member#: 261612
2002 WRX - 750WHP
9.5s @ 150mph
Walbro 255 fuel pump went in on Thursday. Needed to do the double o-ring trick to get any fuel pressure at all. Took me a while, but everything is in and working well. Little bit louder than stock, but not bad with the rear seat back in place. The only time you can really hear it is when you turn the car on, once you're driving it's not noticeable.
More info on getting the pump to properly seal up can be found here:
http://forums.nasioc.com/forums/show....php?t=2130397
Old 01-29-2011, 08:33 PM   #137
xluben
Member#: 261612
2002 WRX - 750WHP
9.5s @ 150mph
Kartboy Shifter Bushings finally went in today. I've had them for months, but never got around to putting them on. Turns out it is very, very easy on the newer WRX's. Jack up the car on jack stands, remove rear tranny brace, unscrew bolt holding in the stock bushing, pop out the bushing, and then install the new bushings and put it all back together.
Bolts all came out easily. Rear brace slides out, even with the COBB downpipe in place. And I had absolutely no trouble getting the old bushing out, or the new bushings back in. This install was really a piece of cake. Didn't take me more than 30 minutes. Real quick and easy.
The difference in shifting feel is incredible. Much more firm and crisp. Notchiness is up a bit, but it feels great. Absolutely no question when you put the car into gear. Seems much easier to shift quickly and accurately. The bushings are a great pair with the MODE short shifter. Both are highly recommended.
Old 02-01-2011, 09:51 AM   #138
xluben
Member#: 261612
2002 WRX - 750WHP
9.5s @ 150mph
Updated thread title. Thanks Ferg!
Old 02-01-2011, 03:12 PM   #139
SubieMobbin
Member#: 183361
2008 STi
May I ask what gauge pod you purchased and where you purchased it from? Also, I see the Defi gauges you bought, where did you purchase those from?
Thanks for your time
SubieMobbin is offline   Reply With Quote
Old 02-01-2011, 03:56 PM   #140
xluben
Member#: 261612
2002 WRX - 750WHP
9.5s @ 150mph
The gauge pod is from SMY Clustermaker:
http://www.smyclustermaker.com/
The gauge is a Defi Red Racer that I bought from Rally Sport Direct:
http://www.rallysportdirect.com/
Old 02-01-2011, 03:57 PM   #141
SikofFalln
Member#: 53217
Great thread! I hope to pick up a 2011 WRX towards the end of summer after I graduate from nursing school. I can't wait, and reading threads like this is making the wait that much more difficult.
SikofFalln is offline   Reply With Quote
Old 02-01-2011, 04:05 PM   #142
RallySport Direct
NASIOC Storefront Vendor
Member#: 33174
We are Open Late!
888-457-2559 Every day!
Ben,
Cant believe I have missed this thread.
The car is looking great, and as always your photography is amazing. Keep up the good work
Kirill
RallySportDirect.com
RallySport Direct is offline   Reply With Quote
Old 02-01-2011, 04:40 PM   #143
arturdc5
Member#: 242657
pretty sick
arturdc5 is offline   Reply With Quote
Old 02-01-2011, 05:34 PM   #144
xluben
Member#: 261612
2002 WRX - 750WHP
9.5s @ 150mph
Originally Posted by arturdc5 View Post
pretty sick
Thanks to both. I am very happy with the 2011 WRX so far!
Originally Posted by RallySport Direct View Post
Ben,
Kirill
Thanks! RallySportDirect, and you particularly, have been great to work with. Highly recommended vendor!
Old 02-01-2011, 05:56 PM   #145
Nsj77h
Member#: 65856
2000 S4 Black
1992 Miata Red
You have a great looking '11!
Keep up the clean work
Nsj77h is offline   Reply With Quote
Old 02-02-2011, 07:40 AM   #146
xluben
Member#: 261612
2002 WRX - 750WHP
9.5s @ 150mph
Thanks! Not too much more planned, but we'll see how long that lasts, LOL.
Old 02-02-2011, 11:09 AM   #147
SubieMobbin
Member#: 183361
2008 STi
Thanks a ton, that was helpful, think I'll be going with the same set up.
Old 02-04-2011, 07:31 AM   #148
xluben
Member#: 261612
2002 WRX - 750WHP
9.5s @ 150mph
Do it! Looks great. I think I'm going to do a Defi Red Racer oil pressure gauge in the other pod, but I don't know when that will be.
Old 02-04-2011, 01:11 PM   #149
OrbitalEllipses
Member#: 178811
2011 White Corolla
Over 400hp
Might want to consider an oil temperature gauge instead.
Old 02-04-2011, 01:37 PM   #150
xluben
Member#: 261612
2002 WRX - 750WHP
9.5s @ 150mph
Why temp instead of pressure?
xluben's Pictures and Review of the SPT Exhaust for the 2011 WRX 5 Door Hatch xluben Car Part Reviews 26 11-08-2012 06:55 PM
My first post and my first Subaru, a 2011 WRX 5 door in white. Decade240 Newbies & FAQs 25 06-20-2012 01:48 PM
2011 wrx 5 door hatch with Rota 17"x7.5 +48 5x100 wheels? BretCutler Tire & Wheel 4 01-14-2011 08:05 AM
2011 WRX 5 Door Ruz4life General Community 55 10-13-2010 11:37 PM
2011 WRX 5 Door Ruz4life General Community 10 10-04-2010 04:02 PM
