Go Back   NASIOC > NASIOC Technical > NASIOC Project Cars
Old 11-11-2010, 09:46 AM   #151
Homemade WRX
Member#: 33782
96 bastard child
search FIRST, then PM!!!
not that I know of. If there is one out there, I'm sure it's probably a 1 off.
It shouldn't be too hard or complex to make an effective pan.
Old 11-15-2010, 05:43 PM   #152
SVXelerator
Member#: 78963
RallyBob is the only one I know of who has fabricated a baffled pan for the EG33. Dry sump has not graced the EG33 to date.
SVXelerator is offline   Reply With Quote
Old 11-20-2010, 03:34 AM   #153
wsc
Member#: 182830
2008 Porsche WSC LMP
dark blue
probably a dumb question but while i was playing around with the engine today the one thing i didnt see was an oil pressure sender, where is it located on the EG33?
cheers John
wsc is offline   Reply With Quote
Old 11-20-2010, 04:36 AM   #154
tino
Top Scoob 019
Member#: 43630
2004 GT40R-built 2.5
604 whp @1.8 BAR on VP109
Any more updated pics??
of body on shell etc etc??
tino is online now   Reply With Quote
Old 11-22-2010, 07:00 AM   #155
wsc
Member#: 182830
dark blue
no more progress on body plug, have been busy fitting engine trans etc so i can start on the rear section,will post some more pics when i have something worth showing off
cheers John
Old 11-22-2010, 09:04 AM   #156
Homemade WRX
Member#: 33782
96 bastard child
cheers John
you can see it at roughly the 11 o-clock position from the crank. Little black round thing. It sends pressure seen just before the oil splits and goes to the mains galleries. Same place as an EJ engine.
Old 11-22-2010, 04:57 PM   #157
wsc
Member#: 182830
dark blue
Ah ha, so its hidden under the Alt and power steer pump , no wonder i didnt se it, would it be safe to tee of there for my turbo feed?, or do the turbo engines have another oil feed somewhere.
cheers john
Old 11-22-2010, 05:28 PM   #158
Homemade WRX
Member#: 33782
96 bastard child
cheers john
well, you can see that little hex head fitting that it sits in? well there is another blank plug along the same gallery but towards the back of the block (you can barely see part of it in this pic, stupid fuel lines). I'd buy the same hex plug/adapter from the dealer, put in in the rear plugs location and feed turbo oil from there.
Either that or you can feed it off the back of the heads where there is a smaller port that feeds the heads. I'd personally run off the gallery
Old 11-22-2010, 05:53 PM   #159
eg33GC
Member#: 206851
56 Belair
Pro Street
Tarbo feed line where the pressure sensor is? INTERESTING...
Old 11-23-2010, 02:58 AM   #160
wsc
Member#: 182830
dark blue
thanks bloke , i see the other port plug you mean so a simple fitting will do the trick. one other question, as i know sod all about these engines at this stage, where is the best place to route an oil cooler
cheers John
Old 11-23-2010, 08:48 AM   #161
Homemade WRX
Member#: 33782
96 bastard child
you can get a nice thermostated oil plate ("sandwich") that goes where the factory oil filter is.
there are a few companies that make them with varying designs. Check the build motor section for oil coolers and you'll see a few threads where the discussions have come up before.
Don't worry about searching for EG33 specifically as they really are just an EJ2x with two more cylinders for 95% of their design. In other words the EJ's oil cooler setups will work for you. You may want to get a bigger cooler however since you'll have much more oil ALTHOUGH you're flow rate is only that of a 12mm oil pump, as that's the size of your oil pump.
Old 11-30-2010, 03:47 AM   #162
wsc
Member#: 182830
dark blue
finaly picked up the engine from the wharf the other day so it was trial fit time, a few minor alterations to get everything where i wanted them and all is well, trans is now locked into 2WD only.
getting there slowly
cheers John
Old 12-01-2010, 10:19 AM   #163
Homemade WRX
Member#: 33782
96 bastard child
it looks at home in there. I'm still going to be interested to see your shifter solution.
Old 12-01-2010, 06:44 PM   #164
wsc
Member#: 182830
dark blue
setting up the shifter is very easy, just use an old steering uni, this is how i did the last one, works a treat.
from another angle
cheers John
Old 12-04-2010, 11:58 AM   #165
Homemade WRX
Member#: 33782
96 bastard child
ok, not bad. I was curious if you were going to go with morse cables or a linkage and now I know.
Old 12-06-2010, 10:13 PM   #166
nic0
Member#: 265853
so dope
nic0 is offline   Reply With Quote
Old 12-07-2010, 08:09 PM   #167
wsc
Member#: 182830
dark blue
so dope
Thats what i love about this forum, interlectual and meaningfull replies?
cheers John
Old 12-07-2010, 10:50 PM   #168
sicksubie
Member#: 101206
1992 Built, S/C'd,
6MT SVX #122 400whp
cheers John
I was going to "lol" at this comment and then realized the irony in it if I did...
sicksubie is offline   Reply With Quote
Old 12-08-2010, 04:45 AM   #169
wsc
Member#: 182830
dark blue
under stand what you mean,
any way a question re the coolant shortfalls, would another outlet on the left hand head direct out the front then join the right hand one before heading to rad be a possible solution, ie that way the restricted x over wouldnt be an issue. [ i would leave the x over manifold there just weld an elbow onto it to take a 2" hose]
your thoughts oh great knowledgeable one
cheers John
Old 12-08-2010, 09:38 AM   #170
Homemade WRX
Member#: 33782
96 bastard child
that's not me but I'll give you my $0.02.
I've been looking into improving the cooling and specifically reverse cooling EJ (and EG) motors and it's a pain in the butt because of how the flow of these blocks is laid out. It flows top to bottom but stops to cool the heads along the way. So they engine does get parallel cooling, cooling to both sides, but not in a favorable or easy to modify way.
I honestly don't have any good solution for improving cylinder head cooling.
What did you have in mind when you say other head? the coolant enters the top of the block halves...now I'm looking for a diagram I had of this.
Flow goes from block -> heads -> block...negating any ancillary lines.
Old 12-10-2010, 02:14 AM   #171
wsc
Member#: 182830
dark blue
hi mate , my idea was to fit anther 2"outlet on the left hand side of the x over manifold where it goes into the block [of course] therby bypassing the restriction in the x over manifold, then joining the two at the front of the engine then onto the top of the rad.
i intend to run an electric water pump without a thermostat and control temp through the pump via ECU, [ have done this on my last race car and it works extremely well ] and no heat soak after a race, as i run the pump through a turbo timer.
cheers John
Old 12-10-2010, 09:39 AM   #172
Homemade WRX
Member#: 33782
96 bastard child
ok, gotcha. Well that setup sounds pretty slick (the thermostatless water pump setup especially). Please share pics of the setup once you have it together. Also who's pump are you looking to run on the car?
I don't know of anyone having logged coolant temps on the two block halves or heads, though I'm sure Subaru has at the factory. In other words, I don't know of it to be an issue nor have I seen anyone research it but your solution would fix it if it existed.
Old 12-10-2010, 06:11 PM   #173
wsc
Member#: 182830
dark blue
I'll run a Davis Craig same as in the past, 80 lp/m great pumps
http://www.daviescraig.com.au/Electr...5-details.aspx
cheers John
Old 01-28-2011, 06:12 PM   #174
madmax_087
Member#: 197077
1992 Dodge Ram W150
BAN CORINATOR
Question
Sooo... does this thing run yet?
madmax_087 is offline   Reply With Quote
Old 01-30-2011, 04:35 AM   #175
wsc
Member#: 182830
dark blue
no not quite, but getting closer by the week
cheers John
My 2010 Race Car Build - From the Ground Up boost junkie Motorsports 2521 Today 01:44 PM
SMS/EQ Tuning GC8 Race Car Build Thread rrsettgast Member's Car Gallery 147 05-27-2012 08:46 PM
Forged Performance 370Z Race car build first track test...impressions Forged Performance NASIOC Project Cars 44 12-06-2010 10:12 PM
BLEE's continuing 04 STI race car build Blee Member's Car Gallery 37 05-03-2010 11:17 PM
JC Meynet/Harman Motive 2009 race car build mxpop Member's Car Gallery 32 03-21-2009 02:36 PM
