Old 01-26-2011, 09:54 PM   #1251
MConte05
Member#: 158579
2005 Lotus Elise SC
94 Legacy Rally Car
Some pictures of my DP issue. The unwrapped one is the JDM HKS catted twinscroll pipe. The wrapped one is a USDM Perrin Divorced Wastegate catless downpipe.
Obviously some differences....
MConte05 is offline   Reply With Quote
Old 01-26-2011, 10:01 PM   #1252
Clark Turner
Member#: 178047
02 WRX STI Spec C
ITs a normaly and simple job.. Cut the pipe, add some pipe, and reweld it.. then your all set
c
Clark Turner is offline   Reply With Quote
Old 01-26-2011, 10:33 PM   #1253
MConte05
Member#: 158579
2005 Lotus Elise SC
94 Legacy Rally Car
You would think.... but the shops here in Arkansas practically refuse to do anything without the car being there to make sure it fits. Despite me saying I don't care if it is off a little bit... Or else they want to charge an asston.
Would be cheaper for me to buy a welder and be done with it... though right now the crossmember change is the cheaper route.
Old 01-26-2011, 10:56 PM   #1254
i2cou4u2
Member#: 246455
2004 WRX Wagon
I just received my Version 8 EJ207 today and I have a few questions. I received the JDM boost solenoid and I was wondering if I should use that one or the USDM one. Aslo I noticed that their is a "T" connector in the vaccum line that connects to the Blow of Valve with another smaller vaccum line that was cut about 6 inch's from the "T" connector. I am not sure what this line is supposed to go to, but I am dieing to find out.
Tom
i2cou4u2 is offline   Reply With Quote
Old 01-26-2011, 11:32 PM   #1255
MConte05
Member#: 158579
2005 Lotus Elise SC
94 Legacy Rally Car
Meant to go to a boost gauge.
Old 01-27-2011, 02:13 PM   #1256
K.Linchpin
Member#: 97984
2015 2.5i Foz w/6pd
Originally Posted by Sir Mangina III View Post
Ok, that's exactly what I though. Thanks for the help! How much torque are you running on your stock STi clutch and flywheel? I know that they are pretty stout but I just want to make sure I'm not going to have any problems with my goals down the line.
I got this from the Clutch and Flywheel FAQ Sticky.
How much torque will the OEM 5MT and 6MT clutches hold? Though no one knows for sure, common knowledge say that the 5MT will hold 300 TQ and the 6 MT will hold 400 TQ.
I would prefer the effort of a stock 5 spd clutch now that I have my ACT Heavyduty street clutch on. The effort of the 6 spd is even lighter than that of the 5 spd, but if you don't plan on making more than 400 tq, I wouldn't mess w/it. Traffic is unavoidable.
K.Linchpin is offline   Reply With Quote
Old 01-27-2011, 03:40 PM   #1257
Sir Mangina III
Member#: 129260
2002 WRX Wagon
Yeah, I saw that but I just wanted to get a feel for what people are actually running. I'm assuming that 400 tq is at the crank (not positive though?) and I've been reading conflicting things on the forums as to what the actual drive train loss is on a Subaru. Just looking for some real world advise from people who have done it. Thanks for the input!
Last edited by Sir Mangina III; 01-27-2011 at 07:46 PM. Reason: again, posted something stupid w/o thinking
Sir Mangina III is offline   Reply With Quote
Old 01-27-2011, 03:41 PM   #1258
Sir Mangina III
Member#: 129260
2002 WRX Wagon
Originally Posted by lil'redwagon View Post
the third accessory is the alternator. i don't recall if there were any issues with the JDM one, can't imagine there would be, but i just switched all three while i was at it. but it is worth mentioning that some people run the JDM AC compressor because it's lighter. i guess they get the lines that connect directly to it, and figure out the connectivity of the condenser side of them.
i'm running 346 lb/ft through the stock STi clutch, as per Airboy road dyno software. it's been holding for about 15K so far with no issues.
Fantastic, thanks for the input!
Old 01-27-2011, 03:44 PM   #1259
Sir Mangina III
Member#: 129260
2002 WRX Wagon
Originally Posted by 02 Scoob-TN View Post
Sir mangina, you can use the jdm accessories fine I did, The usdm ac line only has one bolt in it and needs a little bend to reach perfectly but mine sealed fine with only one bolt. Same with the P/S you just have to bend it a bit and make sure your threads match, if they don't, remove the adapter you'll find in the JDM pump and your usdm hose should now connect to it fine. Use the lower mile accessories if you get them , why wouldn't you right?
Edit added some pics.
The clutch setup I currently run and recommend:
Stock newer version pressure plate
ACT 6 puck sprung or sprung full faced if your scared
mid-weight flywheel 11-12 lbs.
Stock disc material is old school tech, heats up and burns up too easily if you ask me. Plus this setup can be had for cheap, I did mine for under 300 with flywheel. You can use any clutch if you know how to properly shift. Im on the glass 5-speed and launch perfect all day.
Those pics will help out a lot, thank you. I've read a little bit about this set up and that is what I'm leaning towards, though probably with a standard weight flywheel. This seems like a very streetable set up that would be good for auto-x and light track use which is exactly what I'm aiming for.
Old 01-29-2011, 02:19 PM   #1260
i2cou4u2
Member#: 246455
2004 WRX Wagon
Has any one used a F1 Racing clutch on their 207?
Like this one...http://cgi.ebay.com/ebaymotors/F1-RA...Q5fAccessories
Also what are every one's opinions on the stock boost control solenoid? Or should I just get a Grimmspeed bcs?
Tom
Old 01-29-2011, 07:07 PM   #1261
ej20ajk
Member#: 113223
08 WRX NB R180
Cool
Originally Posted by i2cou4u2 View Post
After reading through all 49 pages of this glorious thread, I have pulled the trigger on a JDM 2003 V8 207 motor for my 2004 WRX Wagon. I got it from a company called EagleJapanMotor.com out of Canada.
Eagle Motors is great, I got 3 motors off him, all excellent shape and no issues - most are in 25-50k km on the clock. He is local to me, one of the better places to buy EJ207... Did you get a complete swap or just motor only? If its a complete swap then its simple to run a compression test.
To wire AVCS dont buy IA harness just open/slice open the JDM harness and use the OEM wires which are shielded. PS pump and A/C comp is good to go.
ej20ajk is offline   Reply With Quote
Old 01-29-2011, 09:46 PM   #1262
04 Slo Sti
Member#: 156478
06 330i
8 grand for a complete swap... wish i had your guys money
04 Slo Sti is offline   Reply With Quote
Old 01-29-2011, 10:18 PM   #1263
i2cou4u2
Member#: 246455
2004 WRX Wagon
I got the complete engine swap from him. That included engine, ECU, engine wiring harness, downpipe, and twin scroll turbo setup. I already bought the IA Performance wiring harness so...I will just use that since i already spent the money on it.
What is everyone using for tuning on their 207's? My tuner uses "Open Source", but I cannot seem to find it anywhere on the Internet to download. I already have a Tactrix OpenPort 2.0 cable, and the only software that I can find is "OpenECU" on the Tactrix website. If my tuner is sending me tunes that he has tweeked on his "Open Source" tuning software, will I be able to flash them to my ECU through "OpenECU"?
Thanks for all the help and input
Tom
Old 01-29-2011, 10:26 PM   #1264
Duncan_Idaho
Member#: 192018
2003 WRX
Tom, you'll want to visit romraider.com. You can find all the info you need there about Open Source tuning and the programs to do it. HTH
Mike
Duncan_Idaho is offline   Reply With Quote
Old 01-29-2011, 11:03 PM   #1265
i2cou4u2
Member#: 246455
2004 WRX Wagon
Mike
Thanks, I got it all figured out
Tom
Old 01-30-2011, 09:39 AM   #1266
ej20ajk
Member#: 113223
08 WRX NB R180
If you need a base tune I run on 93/94 E10 octane fuel here in Canada, I have been running it for last 2 years. No issues on my end, but use at your own risk.
https://docs.google.com/leaf?id=0B4s...NzczMjY2&hl=en
Old 01-30-2011, 01:29 PM   #1267
i2cou4u2
Member#: 246455
2004 WRX Wagon
Thanks for the base tune, I just downloaded it. What turbo are you running with that tune?
Tom
Old 01-30-2011, 01:29 PM   #1268
scoobystas
Member#: 26568
2003 Yellow Bugeye
Version 8-Vf37
ej20ajk,
do you have any logs of that map. I'm going to assume your using the turbo it was designed for...vf37.
some strange wgdc compensations in that map. whats the point of adding 10% duty cycles after IAT of 68* to 230*? I mean if its 50* ambient and you sit in traffic for a minute your IATs are well into the 90s*. Just seems sorta strange to me with the already high wgdc in the tables.
Have you tweaked the map at all or have you just ran it as is for 2 years?
scoobystas is offline   Reply With Quote
Old 01-30-2011, 06:02 PM   #1269
ej20ajk
Member#: 113223
08 WRX NB R180
Cool
VF37 - pretty much stock V8 EJ207, with exception of exhaust
No logs, haven't kept them, occasional Learning View, just to check on th car. Yes its VF37 equipped.
WDC(IAT) are stock tables from my original ROM, never looked them or adjusted. WDC was adjusted originally by the tuner.
I have been working on the following map, its based on two other ej207 roms I have obtained...its more conservative and should be good for 91 octane.
-=USE AT YOUR OWN RISK=-
https://docs.google.com/leaf?id=0B4s...OGYwNGI4&hl=en
Old 01-30-2011, 07:28 PM   #1270
fellstar
Member#: 205280
2012 Jeep Wrangler
Bright Silver
Finally tuned by STi Mikey. Cars running fantastic it feels awesome.
Mod List:
Complete V8 EJ207 Swap, Twin Scroll setup, JDM STi TMIC
JDM 6-Speed
Tomei EL Headers - Wrapped
Tomei Twin scroll DP modified for USDM catback - Wrapped
AP Suretrac Rear Differential
Mishimoto Radiator
Hard Turbo inlet
Zero/Sports TMIC Splitter
Walbro255
AEM Uego Wideband
Group N Motor Mounts, Trans Mounts, Pitch Stop
Rallitek AVO Exhaust
DCCDPro Deluxe DCCD Controller
JDM STi Hood Scoop
Kevlar timing belt
Tomiko timing belt guide
HOA boost control solenoid
Samco radiator hoses
Exedy stage 1 clutch
fellstar is offline   Reply With Quote
Old 01-31-2011, 12:24 PM   #1271
Squillo
Member#: 193400
2016 Subaru WRX
Bluuu
ok so im looking into getting a ver7 ej207, im considering getting the 6speed trans with it because my current motor blew and idk about putting a more powerful motor on my stock 02 trans. i just installed a new act clutch and the motor went so would you guys say 6 spd or leave stock til it blows or look into ppg gears. right now the trans is ok shifts fine. also i plan on ordering from jdmmtors here and there package deal includes everything to put the motor/trans in my 02 im just wondering what other stuff i need to install i know the motor needs the avcs wires but do i need anything for the trans.
also the ej207 comes with a vf30 right what size injectors does it have. im trying to see if my vf48 650 and fmic would be a better setup.
Squillo is offline   Reply With Quote
Old 01-31-2011, 12:41 PM   #1272
MConte05
Member#: 158579
2005 Lotus Elise SC
94 Legacy Rally Car
If you can afford the trans, no reason not too, less work to do right now rather than if it blows.
Old 01-31-2011, 12:48 PM   #1273
Squillo
Member#: 193400
2016 Subaru WRX
Bluuu
well either way im gona have to take out a loan for this so its a matter of how much i have to borrow. but i was thinking about ppg but i just realized when you buy the deal its 6900 where just the motor is 4100 so the trans is like 2800 and i dont think i can get ppgs installed for around 2800.
Old 01-31-2011, 02:16 PM   #1274
MConte05
Member#: 158579
2005 Lotus Elise SC
94 Legacy Rally Car
It will indeed be cheaper to do everything as a bundle pack. If I could have afforded to I would have. I have a 5-speed with RA gears in it already, so didn't want to wait another 2-3 months to save up for a 6-speed with it too. However going to keep my "emergency" fund with enough for a 6-speed swap if it ever comes down to that. Hopefully won't though, and not really expecting it too.
However, taking a loan out to do car upgrades? IMO not exactly the smartest move... I'd take out as little as you need to get the job done if the car is down and NEEDS to be back and running ASAP.
Old 02-03-2011, 12:34 AM   #1275
Clutch Dog
Member#: 258967
2007 Charger R/T
Real Steel
anyone know where to import one of these motors.. ai friend linked me to here.
and i have no way of knowing if its good or not
http://www.jdmenginescorp.com/engine...gine-jdm-ej20t
Clutch Dog is offline   Reply With Quote
ej207 owner wants opinions adbramsay Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 2 02-26-2011 07:29 PM
Ej207 V6 AndrewFD3 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 10 06-03-2010 04:53 PM
JDM Sti EJ207 V9 crank 75mm or billet crank (K1, Manley) VENDORS ??? L'frise Private 'Wanted' Classifieds 7 06-03-2010 09:24 AM
08 ej207 JDM dual AVCS heads on a built v7 ej207 icev7 Built Motor Discussion 17 02-21-2010 03:21 PM
Ver 8 EJ207 Owners Check In spoolinsuby Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 21 10-17-2005 01:56 AM
