Welcome to the North American Subaru Impreza Owners Club Sunday July 31, 2016
Old 12-07-2010, 11:57 PM   #26
S4evr
Member#: 209420
looks pretty good, how much would you say the whole thing weights?
S4evr is offline   Reply With Quote
Old 12-08-2010, 09:51 AM   #27
ZeroDrift
Member#: 184324
1999 Impreza 2.5RS
I'd say about 3 or 4 pounds for the upper and lower pieces. I am currently planning to make this whole thing from fiberglass and if that works out, carbon. Should be a while before I get to it though.
ZeroDrift is offline   Reply With Quote
Old 12-09-2010, 03:45 AM   #28
sorrowfulkiller
Member#: 170439
I <3 Lamp
why don't you go easy on yourself and put spectre covered filter in line with some tubing that goes into the fender and pulls air from behind the foglight, or better yet do that with a large hks funnel on the end, thats what I'm planning on doing with my bugeye anyways.
sorrowfulkiller is offline   Reply With Quote
Old 12-09-2010, 01:37 PM   #29
zozza8
Member#: 118486
maybe putting in a little clef area to block the water and allow air to pass, like the stock snorkel but smaller?
zozza8 is offline   Reply With Quote
Old 12-09-2010, 02:59 PM   #30
ZeroDrift
Member#: 184324
1999 Impreza 2.5RS
Care to explain?
Old 12-14-2010, 03:20 PM   #32
ZeroDrift
Member#: 184324
1999 Impreza 2.5RS
Old 01-05-2011, 06:11 PM   #33
EJMFAB
Member#: 197017
2006 WRX Wagon
91' Civic Hatch GT35R
I came across a fabricator on HT today that posted this picture of a setup he did on a Subaru and then stumbled across this thread. Pretty neat/simplified version of what you did, granted the turbo location really helped him out. Water also seems like it would be a problem with this setup, but it doesn't necessarily seem like a car I would be driving in the rain much anyway lol.
EJMFAB is offline   Reply With Quote
Old 01-18-2011, 10:31 AM   #34
ZeroDrift
Member#: 184324
1999 Impreza 2.5RS
That is a nice setup in the picture EJMFAB.
Quick update: No issues with snow as of yet. Not a great deal of snow here aside from occasional few inches of powder though.
Old 01-19-2011, 10:42 PM   #35
McRussellPants
Member#: 234144
Thats my car, Colin did the welding on the intake box and catch tank. Figured there was that rowdy hood scoop there, might as well use it for something.
McRussellPants is offline   Reply With Quote
Old 02-05-2011, 11:16 AM   #36
Striker289
Member#: 272988
Absolutly brilliant.
Striker289 is offline   Reply With Quote
Old 02-05-2011, 12:25 PM   #37
ZeroDrift
Member#: 184324
1999 Impreza 2.5RS
McRussellPants, Does your setup seal against the hood?
If there is enough interest I may start a vendor account and do a batch of these in both aluminum and an affordable ABS/Acrylic plastic. I'm currently looking for a larger shop space with heat and power that will allow me to produce a few products.
Please notify me via PM if interested.
This is just a feeler at the moment.
Old 02-10-2011, 08:08 PM   #38
DKG-GT
Member#: 45315
07 WRX Wagon
Thumbs up
Nice idea well executed. I wonder if fitting the inside with some type of vortex generators would increase the flow by speeding up the air that passes through.
DKG-GT is offline   Reply With Quote
Old 02-10-2011, 10:45 PM   #39
jaegmeister
Member#: 236092
2004 wrx full exhaus
vf48 aps big tmic nstuff
Project came out awesome. I'm discouraged by the HP gain per degree in intake temp drop that engineers will tell you is feasible. It's really hard to make a big difference in HP with a tiny bit colder air... So I have little faith in your but dyno. but nice welds and stuff, I'm sure what you did only helped...
jaegmeister is offline   Reply With Quote
Old 02-10-2011, 11:07 PM   #40
ZeroDrift
Member#: 184324
1999 Impreza 2.5RS
I understand your doubts about temperature vs power (worth the cost/effort I'm sure). Just keep in mind that temperature controls under the hood have more to do with power consistency and power band rather than peak power. Besides, I never mentioned anything about an increase in power.
The peak power and torque are most likely unchanged, but what was immediately notable was turbo spool and consistency of power delivery. I am in the process of getting data on temperatures and pressure with and without the system. I met with an engineer this morning and was discussing theory and acquiring a data acquisition system for this project.
Old 02-15-2011, 01:38 PM   #41
ZenkiS14
Member#: 274029
1997 Nissan S14
Wow man, very nice, and good idea. GM uses something similar to that for the old F-Body LS1 SS Camaros.
Looks solid though!
ZenkiS14 is offline   Reply With Quote
Old 03-05-2011, 09:32 PM   #42
wrx603
Member#: 274473
05 wrx wagon
psm
forgive me if im missing the obvious...what about rain?
oh..."Water also seems like it would be a problem with this setup, but it doesn't necessarily seem like a car I would be driving in the rain much anyway lol. "
gottcha...
wrx603 is offline   Reply With Quote
Old 03-06-2011, 02:12 PM   #43
ZeroDrift
Member#: 184324
1999 Impreza 2.5RS
gottcha...
That was regarding to this setup:
Originally Posted by McRussellPants View Post
Regarding my setup (not the one in the picture above), there are no issues to report with rain/heavy snow.
Old 03-29-2011, 08:11 AM   #44
cr4zy3lgato
Member#: 265179
very nice! good job
if you're still searching for sealing, look at mcmaster's website! lol they have almost everything you'll ever need :P
I'm planning to do something similar this summer, i was going to go with aluminium, but after doing projects in carbon fiber, i'll probably go with that... only thing is that right now i think there is a shortage...
I'm still not decided whether i want it completely sealed or not... i fear it might trap too much humidity...
cr4zy3lgato is offline   Reply With Quote
Old 03-29-2011, 09:34 AM   #45
ZeroDrift
Member#: 184324
1999 Impreza 2.5RS
Originally Posted by cr4zy3lgato View Post
very nice! good job
I actually did just that a few weeks ago. I found several different types and sizes of gasket material. Of course I ordered several types and found one that works quite well.
Old 03-29-2011, 05:56 PM   #46
ZeroDrift
Member#: 184324
1999 Impreza 2.5RS
There is a members journal available for this car on RS25.com: http://www.rs25.com/forums/f145/t153...dventures.html
This summer we will be doing an overhaul on the car and making some changes to things.
Old 07-10-2011, 09:57 PM   #47
5lipstream
Member#: 124663
2003 AW WRX
2008 GG Evo X MR
Edited.
5lipstream is offline   Reply With Quote
Old 07-12-2011, 11:38 PM   #48
ZeroDrift
Member#: 184324
1999 Impreza 2.5RS
There is enough of an opening at the bottom to allow rain and some airflow out. The engine takes in enough air to make a nice low pressure zone within the box- especially at WOT. The design works very well. I plan to make some finishing touches to it very soon though.
Old 08-01-2012, 01:50 PM   #49
VTEC boost
Member#: 320577
2007 Subaru Impreza
Grey
This is very helpful. I've been wanting to do this for a while now and this looks like the best way of doing it. Thanks!
VTEC boost is offline   Reply With Quote
My take on hauling tires on the hitch. GLwagon Tire & Wheel 11 03-19-2007 09:08 PM
My Take On My New AccessPort,Feeback Please EagleRockWrex Engine Management & Tuning 7 12-15-2005 02:40 PM
My take on the Prodrive WR Sport Back Box supermarkus Car Part Reviews 0 04-04-2002 02:15 AM
My take on ClubSi.com 's downfall (dont let this happen to this club!!) ProgSi General Forum Archive 22 05-27-2000 07:36 PM
