Old 06-19-2009, 12:11 PM   #101
design1stcode2nd
Member#: 112178
What actual WHP can you expect to loose between an aftermarket EL and UEL header? People have mentioned 20-30hp gained from stock but would this be the same on aftermarket UEL headers as well?
design1stcode2nd is offline   Reply With Quote
Old 06-19-2009, 01:48 PM   #102
kellygnsd
Member#: 32669
2007 2.34LR, EFR7670
LINK G4 hybrid STi
That would mean by your logic there are no gains from stock to aftermarket UEL headers and that is not the case. No single hp number is going to quantify the increase in performance between headers since all setups are different. A short answer is EL>UEL>stock.
Old 06-22-2009, 01:52 PM   #103
design1stcode2nd
Member#: 112178
Thought I explained it but I'll try to clarify. I assumed there would be a HP increase going from stock headers to aftermarket UEL headers. Yes I know it will vary depending on who makes the part. What I'm trying to quantifiy is are you sacrificing the boxer rumble (if you like it and I do) for a "guesstimate" of 5 hp when compared to the theoretical same EL header or is it a good bit more?
So Acme UEL header gets you 12.5hp over stock and Acme EL header gets you 25hp over stock. So you have to decide if the 12.5hp difference in this make-believe scenario is worth the change in engine/exhaust sound.
Guessing the answer is no one is really going to know so perhaps a different question. Does anyone know what increase your UEL headers gave you and what brand did you use?
Old 06-22-2009, 08:59 PM   #104
mls1
Member#: 167607
2008 WRX
I think it would depend on your mods/power level. You might not see any increase or even a slight decrease at a certain power level yet at higher power levels you may see significant gains. I think with the given info it would be hard for anyone to answer that with any accuracy.
mls1 is offline   Reply With Quote
Old 06-22-2009, 09:06 PM   #105
jutes85
Member#: 127232
E90 M3
98' Foz
Thought I explained it but I'll try to clarify. I assumed there would be a HP increase going from stock headers to aftermarket UEL headers. Yes I know it will vary depending on who makes the part. Does anyone know what increase your UEL headers gave you and what brand did you use?
All aftermarket UEL headers are made by the same company. Not one will give you more hp than another. I would not go to and EL headeR to gain 2hp and lose the sound, I don't want another civic.
jutes85 is offline   Reply With Quote
Old 06-22-2009, 09:20 PM   #106
zeropsi
Member#: 175453
AE86 GT-S coupe
i <3 alqonquin homosauce
I wouldn't say all aftermarket UEL headers are manufactured by the same company - a lot of them may share, but they're not all the same.
And your insight about EL headers? Really? 2hp and sounding like a Civic? You need to stop reading about headers and actually find an EL header Subaru.
zeropsi is offline   Reply With Quote
Old 06-22-2009, 09:23 PM   #107
CoolRex
Member#: 85813
2002 E46 M3
2006 RC51
Obviously you didn't see the PROVEN dyno chart that I posted. The ONLY difference was headers. The lowest chart is stock headers tuned. Highest is EL headers tuned.
CoolRex is offline   Reply With Quote
Old 06-22-2009, 09:26 PM   #108
jutes85
Member#: 127232
E90 M3
98' Foz
I've heard one in person and it did not impress me at all. Same thing with the new Ken Block video...that car SOUNDS like ass.
Old 06-22-2009, 09:30 PM   #109
CoolRex
Member#: 85813
2002 E46 M3
2006 RC51
To each his own man. If you don't like it that is your opinion. But while you aren't liking the 'sound' others are making a ton more power
Old 06-22-2009, 09:34 PM   #110
zeropsi
Member#: 175453
AE86 GT-S coupe
Maybe I'm just strange, but I still don't get how this is even a choice people have to think about.
Old 06-22-2009, 09:47 PM   #111
STiled_04
Member#: 210933
2004 Impreza STi
Platinum Silver Metallic
Originally Posted by Ferraz View Post
That is new to me... Always thought it was the othre way around.
Same here. I wrapped a ceramic coated bosal header and it cracked after about 10mos. Took it off and unwrapped the thermo tech and there were metal coating just flaking all over. Think wrapping helps carbonize the metal.
STiled_04 is offline   Reply With Quote
Old 06-26-2009, 12:23 PM   #112
badmammajamma
Member#: 84419
2005 WRX STi
380whp ATP 35r
I really looked into this EL header thing and then was convinced I had to PnP my stockers then I was looking at PERRIN then TOMEI. Upshot is at Stage 2 this is not going to mean much and will cost $$ and will most likely degrade reliability and then there is the sound this is a no brainer.
badmammajamma is offline   Reply With Quote
Old 07-01-2009, 01:35 AM   #113
JASWRX
Member#: 40742
That is funny. but not true at all!
JASWRX is offline   Reply With Quote
Old 07-01-2009, 02:36 AM   #114
crand002
Member#: 129765
2006 EVO
439whp/412wtq (MD)
The EL header is intended for the STi, period. Subaru of America believes sound outweighs spool and overall power which is mind blowing. I have never met one person who thinks my car sounds like Honda but even if it did I prefer the performance over sound. If I wanted sound I would have bought a Mustang. Not to mention I like separating myself from a 95 Legacy Wagon with an exhaust, no offense to those with those cars.
crand002 is offline   Reply With Quote
Old 07-01-2009, 08:34 AM   #115
j.r
Member#: 201800
2007 STI
gt30r
EL is JDM YO!
Running EL with my rotated 30R setup. Love the performance. I don't miss the sound too much. I'm faster than all the subaru I hang out with that have UEL
j.r is offline   Reply With Quote
Old 07-01-2009, 03:36 PM   #116
Beam
Member#: 29742
2011 STI
15 S1000R
Originally Posted by CoolRex View Post
Yes definately. But you also have to use a good setup. I liked the maddad's because the 1.6" piping. That's bigger than stock. The only downside is that you have to heat them up to get full power but header wrapping them solves that issue. Mine are ceramic coated but when I put the built 2.5L I will be header wrapping them.
Among many other things, I have Tomei Headers. They come with a wrap, but I ceramic coated them as well- enthalpy is a turbine's best friend afterall
Anyway, I also noticed there is a big difference between a hot header and a cold one. It spools harder and quicker when it's hot.
BTW, I went with UEL- it's my one "rice" mod...I wanted to keep the sound!
Beam is offline   Reply With Quote
Old 07-21-2010, 05:34 PM   #117
ivansit0
Member#: 155845
2006 wrx sti
steel gray
Wont Equal length lower your EGT??
ivansit0 is offline   Reply With Quote
Old 02-10-2011, 02:55 PM   #118
Hondaeat-r
Member#: 228378
2002 Bug WRX Wagon
Yes. ^
Boxer rumble is more an effect of UEL than firing order. There is a reason that Subarus have tons of issues with specifically Cylinder 4 Detonation.... Find the cylinder lay-out, find cylinder #4, then look at an UEL header. It's a joke, and takes the mystery out of things.
If you have $ to spend, get EL, tune it, and deal w/ the loss of "rumble". With 3" TBE, it'll sound like a Porsche. AKA, better than a Subaru. I know this is an old post, but as an Engineer, I can't ignore misinformation being spewed.
Edit: http://rusubaru.com/equal-length-vs-...ength-headers/
Hondaeat-r is offline   Reply With Quote
Old 02-11-2011, 08:50 PM   #119
al82
Member#: 177913
2011 WRX STi PBP
Yea cuz I was just about to say it's since last year....I have an agency power elh with a Greddy turboback and it sounds awesome...the lope is still there but not as much as unequal length ofcourse.
al82 is offline   Reply With Quote
Old 02-11-2011, 09:29 PM   #120
Ferraz
Member#: 173553
1996 Civic VTi
Dark blue
I see you have a 06 WRX... Did you have to mod the oil cooler?
Ferraz is offline   Reply With Quote
Old 02-12-2011, 12:04 AM   #121
al82
Member#: 177913
2011 WRX STi PBP
Yea, someone had a thread with the part numbers, pretty straight forward. The only problem I had was a little piece of the radiator support at the bottom had to be trimmed for it to fit properly.
Old 02-12-2011, 03:46 PM   #122
boost4life
Member#: 75129
09 WRX stg 2+
Lost the boxer rumble
this is one reason I went EL , I run the perrin catback and it sounds nice, Not like a honda others are saying...
Originally Posted by Hondaeat-r View Post
Yes. ^
boost4life is offline   Reply With Quote
Old 02-12-2011, 07:59 PM   #123
Hondaeat-r
Member#: 228378
2002 Bug WRX Wagon
A turbo Subaru will never sound like a Honda. When I get some more $$ saved up for a proper tune, I'll go EL header too.
Old 02-12-2011, 09:01 PM   #124
SeeeeeYa
Member#: 129681
2017 FXT-T ES
SBM/SBL
QFT.
I had what I consider the best EL header on my 05 LGT, the APS Equal Length Split Pulse Header. It sounded different, of course, but still like a Subaru. With a total cost of nearly $1400 including their proprietary metal "wrap" the cost per hp scared most people off. But they were in context with that build and enabled me to make power a stock or AM UEL couldn't touch. I don't think APS is supplying the US market at present.
FWIW my earlier NA Subaru Legacys came stock with EL headers, and sounded unmistakably like what they were, a Subaru. People.
SeeeeeYa is offline   Reply With Quote
Old 02-13-2011, 08:27 AM   #125
badmammajamma
Member#: 84419
2005 WRX STi
380whp ATP 35r
I went with the FullRace set-up and I am very happy with performance and SOUND...
GT-Spec equal length vs. unequal length headers SW00P_G Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 31 02-17-2009 07:40 AM
equal vs unequal length headers on an 06 TR VRT Gump Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 25 08-06-2007 04:28 PM
Please compare equal vs. unequal length headers... shemoves Normally Aspirated with bolt-on Forced Induction Powertrain 6 09-02-2006 02:44 PM
Equal length vs. Unequal length headers 4080wrx Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 6 09-21-2004 10:03 PM
Equal Vs Unequal length headers Onederer Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 2 05-10-2002 02:13 AM
