Old 03-10-2009, 07:54 PM   #76
Peaty
Techno Sapien
Member#: 449
2016 BRZ Limited
Ice Silver Metallic
Peaty is offline   Reply With Quote
Old 10-30-2009, 03:48 PM   #77
Arnie
Member#: 1725
99 Subaru Impreza
GF silver
I just installed an 05+ STi steering wheel into my 02 WRX. was fairly straightforward. the main issues are airbag, horn and cruise control.
Here's some pics so you guys can have an idea what it all looks like in there:
02 WRX MOMO
05+ STi
02 WRX Airbag
STi airbag
02 WRX charge removed
STi charge removed
Charges from the top
Charges from the side. You can see how the dual stage charge is taller.
Fitment of 02 WRX charge into STi airbag. Okay, this was my solution. Have no idea if it would work or how properly. I figure, the single charge is enough to inflate enough of the bag in the event of something, right? Yeahhhh. Hopefully I won't ever find out. Knocks on wood.
But it makes wiring a piece of cake as it just plugs right in.
So next issue was the horn. No pictures for this. But currently I have simply stuffed a piece of wire into the horn spade in the plug of the STi wheel and into the plug of the car harness. Its the green wires on both wheel and car. Beep Beep. works fine.
Next will be cruise. i think i'll try the wire stuffing technique with that as well. see if it works. so far haven't had to cut a single wire.
Installed. I love this wheel. The smaller diameter is so much nicer.
Arnie is offline   Reply With Quote
Old 10-30-2009, 05:11 PM   #78
antho!
Member#: 159057
2004 ts wagon
aspen white
^ nice! check out my diy for the cruise control http://forums.nasioc.com/forums/show....php?t=1706769
antho! is offline   Reply With Quote
Old 10-30-2009, 05:13 PM   #79
Arnie
Member#: 1725
99 Subaru Impreza
GF silver
cool thanks! i was just going to search for that page. i recall seeing it awhile back. it will be a big help to me.
Old 03-24-2010, 03:28 AM   #80
crpwrx
Member#: 180710
2006 Sti WRB
WFC# 229
Swapping an 05 sti wheel into 02wrx, what wire powers the horn? I swapped over bag charges to keep my wrx harness and wired it in. Also wired for cruise control with 05 controller. Just need to know where to hook up for the horn.
crpwrx is offline   Reply With Quote
Old 04-17-2010, 04:10 PM   #81
pezcore
Member#: 178045
06 WRX
BUMP for the answer to this. The wire that clips on to the airbag, is that positive or negative?
(diagrams I've seen lead me to believe it's positive, but I don't want to fry something)
pezcore is offline   Reply With Quote
Old 01-08-2011, 05:22 PM   #82
Rizzo314
Member#: 42215
2002 WRX being built
and going for 10s :evil:
Sorry it's taken so long, but I'm finally re-hosting the pictures from the original post.
Check back in a little bit, and they should be working.
Rizzo314 is offline   Reply With Quote
Old 02-15-2011, 04:09 PM   #83
TURBS
Member#: 259411
white
thanks for the write up.... I switched the airbag charges and did the little tweeks for the curiz knob and it all went together great...!
04 STi wheel with alcantara and blue stitching in 03 Bugeye....
TURBS is offline   Reply With Quote
Old 02-15-2011, 04:14 PM   #84
12sechatch
Member#: 132458
Okie Dokie Fine
looks good, but why did you swap charges? 04 sti is single stage?
12sechatch is offline   Reply With Quote
Old 02-15-2011, 07:39 PM   #85
TURBS
Member#: 259411
white
just made it easier to do the wheel swap...
Old 02-16-2011, 05:57 AM   #86
Stealth_RS
Member#: 95677
2004 WRX
Did you re wrap the wheel yourself DIY for that would be awesome!
Stealth_RS is offline   Reply With Quote
Old 02-16-2011, 06:09 AM   #87
Kentrik
Member#: 125937
03 WRX I do not
like your tweed, chap.
The charge swap was for a 2005+ wheel. I should find an old 2002 charge and swap it so that my airbags are legit, just in case.
Has anyone figured out a way to get the 05+ cruise control to work in such a way that I can get rid of the switch down on the kick panel?
Kentrik is offline   Reply With Quote
Old 02-16-2011, 11:28 AM   #88
TURBS
Member#: 259411
white
i compared the charge from the 04 sti and 03 WRX... and they are exactly same build and size... only plug was different.. i felt more comfortable using the charge from the 03 which i know will charge upon impact...
Airbag is pretty direct yes.. but has to be very universal.. as a impact of 30mph.. or 80mph.... the airbag should do its job in both... i feel the charge if different.. will not change much..
i could be wrong... i hope i never find out..!
Old 02-16-2011, 11:31 AM   #89
12sechatch
Member#: 132458
Okie Dokie Fine
Yes, there is a DIY around here somewhere....
edit:
Old 02-16-2011, 11:32 AM   #90
TURBS
Member#: 259411
white
naw.. i had it done professionally...
Old 02-19-2011, 03:42 AM   #91
sagelwwa
Member#: 53975
2004 Forester XT
Java Black Pearl
I swapped an 04 STi wheel into my 04 FXT awhile back with some help from this thread. Time has come for the STi wheel to come out and the FXT wheel is now back in. Thanks for all the info and if anyone is looking for an 04 STi wheel, I have one posted in the classifieds
sagelwwa is offline   Reply With Quote
Old 02-19-2011, 04:18 AM   #92
Kentrik
Member#: 125937
03 WRX I do not
edit:
Sweet! Thanks for the find. I followed the one to just hook up the cruise control with mine like 3 years ago, but I never did figure out how to get the button to work right.
Old 04-24-2011, 11:25 PM   #93
wrxtacular
Member#: 181711
2004 278whpVF34wagon
Jorge Tuned
Can someone please clarify: I have read that the Sti airbag switched to dual stage in 05 or 06. I would like to keep with a single stage since that is what my 04 WRX charge is meant for. I like the look and smaller diameter of the 3 spoke STi (I prefer the all back 05), but don't want to re-wire the airbag (cruise and horn I can re-wire). I'm tempted to just have the Momo re-wrapped just to be sure my airbag still works.
wrxtacular is offline   Reply With Quote
Old 04-24-2011, 11:30 PM   #94
fastwrx25
Member#: 126441
03 bugeye
you can just swap your current 04 airbag charge into the 05+ steering wheel. it fits, and you it plugs straight up. Thats what I did when I installed a 07 sti steering wheel into my bugeye. install is pretty simple.
Old 04-25-2011, 08:04 PM   #95
wrxtacular
Member#: 181711
Jorge Tuned
has anybody added a cruise control stalk to a JDM STi steering wheel? I bought a wheel today, and realized it doesn't have a cruise control stalk.
Old 08-24-2011, 11:39 AM   #96
arco
Member#: 57156
2007 V.8 207 STi
Mercedes Polar White
Unfortunately I have. I bought my 04 JDM wheel 4-5 years ago and just cut in.
arco is offline   Reply With Quote
Old 09-18-2011, 04:41 PM   #97
simann
Member#: 223159
2004 STi
Grigio Avalon Grey
What about swapping a 2005 STi steering wheel into a 2005 WRX ? Since they changed over the interior, wouldn't the WRX's air bag be dual-stage just like the 2005 STi?
simann is offline   Reply With Quote
Old 10-22-2011, 04:36 PM   #98
sackytar
Member#: 149262
03WR Rallycar/FXT/OB
PrimerGrey
Is there a way to remove the clock spring for aftermarket wheels. Where the the harness tie into the column.
Old 02-19-2012, 12:16 PM   #99
fourage20
Member#: 136149
2002 WRX EJ207
I'm bringing an old ass thread back. Lol. I've been trying to research this but can't really get a straight answer. I have a 02 WRX and trying to put in a 05 Sti steering wheel. I have a 04 Sti clock spring with it. Is everything just plug and play? Can I use the 05 Sti cruise control controls? I know to turn on cruise control I still need to use the button on the dash but is there any type of wiring I need to do?
fourage20 is offline   Reply With Quote
Old 12-21-2012, 11:15 PM   #100
SneakySh0rty
Member#: 280516
03 WRX v9 trans
Sorry to bring this back from the dead. But out of sheer curiosity, im wondering for those who swapped their steering wheels with different model years. If you were unfortunate enough to get into a car accident, did your swapped steering wheel airbag deploy effectively/properly?
SneakySh0rty is offline   Reply With Quote
DIY: How to swap an 08 STi steering wheel into an 05 STi xxscaxx Interior & Exterior Modification 113 06-18-2016 02:02 PM
putting an 08+ STI steering wheel into an 07 WRX? NMZ_WRX Interior & Exterior Modification 1 05-19-2010 07:57 AM
installing a 2004 sti steering wheel in a 2002 wrx mhwrx02 Interior & Exterior Modification 0 06-28-2009 10:47 AM
FS in MD: 2004 silver sti bbs wheels w/ tires; 2002 wrx wheels w/ snow tires ALaDDiN MAIC Private Classifieds 26 03-09-2008 03:02 AM
How to put a 2007 usdm sti 6 speed into my 2003 WRX InfamousDX Transmission (AT/MT) & Driveline 11 10-27-2007 12:54 AM
