Old 02-17-2011, 10:48 AM   #26
2011 STI SEDAN
Member#: 271872
2011 WRX STI SEDAN
Gray Metallic
Originally Posted by cdoliver View Post
I hope they told you to keep an eye on your stock wrx intercooler endtanks. They will come apart at 18+psi after a few miles. Watch the tabs, they will start to get loose.
Being new at this...please explain...also, can you reach that high of boost with just an AP stage 1 flash?
2011 STI SEDAN is offline   Reply With Quote
Old 02-17-2011, 11:03 AM   #27
b16b
Member#: 247157
2011 WRX Limited
Satin white pearl
Do you have a link or proof of this?
b16b is offline   Reply With Quote
Old 02-17-2011, 11:42 AM   #28
xluben
Member#: 261612
2002 WRX - 800HP
9.5s @ 150mph
Good point, but I think that's part of the reason he stuck to the 16psi tune.
The COBB OTS Stage 1 tune peaks at 16.5psi of boost, so it shouldn't be a problem.
Search the Legacy GT forums. They have had the same TMIC for a few years longer and there are quite a few pictures of them blown apart. I think some of them even happened at stock, or near stock boost levels.
Old 02-17-2011, 11:45 AM   #29
Breezio
Member#: 234357
2009 WRX
Sportwagen zum einbauen!
Thanks I appreciate the response. I "had" a 2004 WRX a few years back. I had a COBB version two AP. But I did and up pipe, down pipe, with Turbo XS all at once. Woke up the car BIG TIME!
I wanted to verify that on a stock STI that a Stage one flash was "felt" and or worth it.
Just remember, he got a custom protune 'stage 1'.
He's not using an off the shelf stage1 map.
There can be a big difference between the two.
Breezio is offline   Reply With Quote
Old 02-17-2011, 12:05 PM   #30
2011 STI SEDAN
Member#: 271872
2011 WRX STI SEDAN
Gray Metallic
Sorry for the greenhorn question...But could you please explain? I understand the off the shelf COBB AP. But when you say protune, you lost me in that concept. Need help in understanding when this would be required, needed. or wanted...Please help?
Old 02-17-2011, 12:07 PM   #31
scooby24
Member#: 56414
2004 Forester XT 5MT
There is a big difference, but the OTS stage 1 map on the '11's are pretty nice. It definitely is a nice improvement.
scooby24 is offline   Reply With Quote
Old 02-17-2011, 12:12 PM   #32
scooby24
Member#: 56414
Protune is simply tuning a map to be specific for your car. Every car is different. For example, my car with the graph above had a 10.5:1 AFR instead of the 11.2:1 target that the OTS map should be hitting. If I protuned for my car, we could get the AFR's back where they should be and I'd make more power than the Off the shelf map and still be safe.
Old 02-17-2011, 12:13 PM   #33
2011 STI SEDAN
Member#: 271872
2011 WRX STI SEDAN
Gray Metallic
So, if I am staying stock other than a K&N drop filter, and an AP from COBB (at a stage one flash) a Pro tune (?) is not needed or required...correct. I just want to protect the investment.
Thanks and sorry for the lack of knowledge here, but trying to learn a bit more every day...
Old 02-17-2011, 12:29 PM   #34
xluben
Member#: 261612
2002 WRX - 800HP
9.5s @ 150mph
A pro tune (custom tune) is not required, but it can be done at any point. OTS tunes are conservative. With a custom tune you could choose to push the car further if you'd like. If you plan on staying at Stage 1 forever, you might want to consider a pro tune. If you are ever going to upgrade, you could just use the OTS tune until you get all of your upgrades done, and then get a pro tune (to save money on paying a tuner).
Here is an example of how a protune can provide larger gains over an OTS tune. The top line is the OP's Stage 1 18psi tune. The middle line is the COBB OTS Stage 1 tune. Not saying that a custom tune will magically (and safely) gain 20hp and 20ft-lbs of torque (in fact a custom tune may gain you very little), but there is the possibility for better gains with a custom tune. A custom tune could also notice spots in the OTS tune that don't look right (if there are any), and correct those. There really aren't any downside except for cost.
Old 02-17-2011, 01:32 PM   #35
2011 STI SEDAN
Member#: 271872
2011 WRX STI SEDAN
Gray Metallic
Ok... Back from lunch now...
So, a Pro Tune is kind of "my car" car specific rather than an AP is just mass produced car specific...?
Old 02-17-2011, 01:36 PM   #36
JohnnyG
Member#: 164671
2009 WRX 265
A OTS map that comes on the AP itself is a good tune that will work everywhere under many varying conditions, made to be safe.
A custom tune is custom for your car, how you drive, where you drive, whether you want full out power bragging or something with more area under the curve.
JohnnyG is offline   Reply With Quote
Old 02-17-2011, 01:42 PM   #37
2011 STI SEDAN
Member#: 271872
2011 WRX STI SEDAN
Gray Metallic
Another dumb question...If I may...?
I know the 2009 + WRX and up are the ones to get. 08 not so much. But, when speaking about the boost etc...are the turbos and the boost amounts the same when utilizing the AP and tuning?
STI and the WRX ...Any differences ?Thanks guys...
Old 02-17-2011, 01:42 PM   #38
2011 STI SEDAN
Member#: 271872
2011 WRX STI SEDAN
Gray Metallic
Now it makes sense...THANKS
Old 02-17-2011, 11:27 PM   #39
KWIL
Member#: 40848
2011 Impreza WRX
5-Door, DGM
This thread had some activity while I was working today!
To add to the conversation about protune versus OTS, everything said above is correct--to elaborate on why I went protune:
I read and debated for months on buying just the AP, getting a protune, or doing an open source etune. (see Unabomber's complete guide on tuning)
I decided on the protune mainly because I read a couple bad stories about AP OTS stage 1 maps gone wrong (knowing most forum horror stories are either not accurate, lacking full mod disclosure, or are simply just corner cases). Still, I was nervous about whether I needed to log and learn about knock tables, etc...and what good/bad logs look like.
Given Surgeline's reputation and their 1/2 off deal when you buy the AP from them, I paid a little extra to "set it and forget it." I'm new and lack confidence so my primary goal was a safe, trustworthy tune. I got the max power I could for my individual vehicle and don't have to worry that the map isn't lining up right somewhere.
OTS maps are supposed to be very conservative to work with all cars + variation and should be plenty safe. It was a peace of mind thing for me.
If I want to risk some safety for power, I have a 17.5psi map I can use. Surgeline advised not using it on 100+ deg days and using higher quality octane fuel if available.
The experience of getting your car strapped to the dyno was pretty sweet, I learned a lot from that process, too.
KWIL is offline   Reply With Quote
Old 02-18-2011, 12:35 AM   #40
Breezio
Member#: 234357
2009 WRX
Indeed it is. Loved getting the baseline on mine, wish I took some video...
Old 07-10-2011, 07:42 PM   #41
pet3r
Member#: 283134
2008 STi AW
550whp - 530wtq
Not trying to stir a pot, but, did anyone else notice the weirdness in these two maps that the OP has shared?
If you look at the "Stage 1 - green" vs "Stage 2 - blue", they are identical. Something can't be right about these two. Both claim 18psi boost, Stage2 was an Invidia DP, but their curve and numbers are identical. So, something is lying about these numbers
Could be that the tuner is trying to post bigger specs for their tunes than are realistic maybe?
pet3r is offline   Reply With Quote
Old 07-11-2011, 07:00 PM   #42
mls1
Member#: 167607
2008 WRX
Good day guys...
I recently bought a 2011 STI sedan. It is my goal to keep things as stock as possible (for warranty). I was just wondering for those who have the COBB stage one flash..."What was your driving impressions after the flash?"
FYI...
Subaru can tell if you have flashed your ECU with a AP.
mls1 is offline   Reply With Quote
Old 07-12-2011, 06:53 PM   #43
csullivan
Member#: 111653
2011 WRX STi
How? What makes you think so?
csullivan is offline   Reply With Quote
Old 07-12-2011, 07:05 PM   #44
Kunk
Member#: 269732
2015 STI
CWP
Originally Posted by mls1 View Post
FYI...
What if you flash it back to the original stock tune before you take it in for service? I was thinking of picking up an AP after I saw this thread, but if they can tell its been flashed then they will probably deny my claim if I ever have one.
Kunk is offline   Reply With Quote
Old 07-13-2011, 11:49 AM   #45
mtbiker278
Member#: 242578
2010 WRX
Spark Silver
I've read that there's a counter on the ECU that counts the number of times the ECU has been flashed. Assuming you start with 1 as the stock map, flash to a aftermarket map, then back to stock the counter would show 3 instead of 1. However they only way they could tell you did this is if your car was hooked up to their ECU programmer. Depending on what you take your can in for may lead them to try and trouble shoot the ECU.
mtbiker278 is offline   Reply With Quote
Old 07-13-2011, 12:21 PM   #46
Kunk
Member#: 269732
2015 STI
CWP
That stinks tremendously. After looking at all the charts I really want to get an AP for just a stage 1 tune, but I REALLY don't want to risk it. Darn you Subaru for putting a bad tune on it initially.
Old 07-13-2011, 12:40 PM   #47
cdoliver
Member#: 34084
2002 wrx
The only thing they can tell is how long its been since the ecu was reset. This is what the counter does. Same thing happens when you disconnect the battery. So flashing back to stock looks the same to them as disconnecting/reconnecting the battery. This comes from a buddy that works at subaru.
cdoliver is offline   Reply With Quote
Old 07-13-2011, 01:53 PM   #48
flycaster
Member#: 60142
Grey
...So flashing back to stock looks the same to them as disconnecting/reconnecting the battery...
IF that's the case, then a re-flash back to stock wouldn't matter. Batteries are frequently disconnected in service bays to avoid unintentional grounding or shocks. So, what good does this supposed "counter" do them? Nada. Heck, I just had some stereo work done and I know the battery was disconnected and reconnected at least 3 times...so SOA would accuse me of "re-flashing" my ECU 4-5 times? BS, they are not that stupid.
I just called my dealer, who's a friend of mine, and asked him about this. He laughed, then told me as long as there isn't a DP on the car, they don't hunt for tunes. Maybe other dealers are different, I dunno.
flycaster is offline   Reply With Quote
Old 07-13-2011, 02:03 PM   #49
Kunk
Member#: 269732
2015 STI
CWP
I read in another post awhile back that somebody claimed the same exact thing as cdoliver said, so now I'm on the fence.
Old 07-13-2011, 02:13 PM   #50
OrbitalEllipses
Member#: 178811
2011 White Corolla
Over 400hp
Pop a motor or blow a tranny...they'll hunt for tunes then.
2011 WRX - Stage 2 - COBB Downpipe and SPT Exhaust (VIDEO) xluben General Community 47 01-19-2011 02:32 AM
Stock 2011 WRX Dyno numbers MotorrBoatrr Proven Power Bragging 75 10-26-2010 07:59 PM
STOCK 2011 WRX/STi Coming in September! Evanston Subaru MWSOC Vendor Classifieds 12 09-01-2010 03:39 PM
Dyno Tune: 2.5l wrx+ ATP 3076r Stock location syagbraves7 Proven Power Bragging 9 03-25-2010 05:43 PM
Agile Dyno Day - MY 07 WRX Stage 2 96accord Proven Power Bragging 38 03-07-2008 06:27 PM
