Old 02-18-2011, 03:53 PM   #1
Pikey_STi
Member#: 264297
1996 Plymouth Neon
Red W/ Green Hood
Default 2006 STi into 99RS
Hey i was looking to get a 2011 STi but i had a more cost savings idea in mind.
looking to take a 2006 STi engine and Suspention and put it in to a 99RS coupe (less on insurance and sleeper 101) now i have alots of questions adn i went thoguht 50 pages of forms and i couldnt fined the answer i was looking for. can some one direct me in the right driection
1. i want to keep the STi breaks and wheels. do i swap the whole hub or
2. can some one give me a parts list of what comes from the STi, the RS and what has to be custom
3. what springs do i use the sti or RS (more for coilover options)
4. want to keep the STi gaudge clustor with shift light
2006 STi (ill talk him down in price) http://toronto.kijiji.ca/c-cars-vehi...AdIdZ231506693
Wireing: http://forums.nasioc.com/forums/show...82&postcount=2
Pikey_STi is offline   Reply With Quote
Old 02-18-2011, 04:24 PM   #2
Badler
Member#: 133597
Just get the 2011 or buy one already swapped.
Badler is offline   Reply With Quote
Old 02-18-2011, 04:44 PM   #3
Pikey_STi
Member#: 264297
1996 Plymouth Neon
Red W/ Green Hood
the only reason im still leaning to the 2011 is the warenty and the longevity is going to be much better on it but for sleeper factor i want to do this plus good feeling to say "i bulit this" and already swaped is a option
Old 02-18-2011, 07:24 PM   #4
Badler
Member#: 133597
Set aside at least $15k+ to do it right then. Turbo RSs are hardly sleeper anymore.
Old 02-18-2011, 07:56 PM   #5
Enlefo
Member#: 235627
07 STI
Ask yourself one question: Do you want a car you can turn the key and go or do you want a car that will require an endless amount of researching, tinkering, fabricating, buying parts for and modifying to even be able to leave the garage. Option 2 is perfect valid way to go... but they are very different paths.
Enlefo is offline   Reply With Quote
Old 02-18-2011, 10:10 PM   #6
Boxologist
Member#: 21118
unless u really have a hard on for a v1-6 looking turbo, an OEM factory turbo car from the past 5 years has a far superior fit and finish. If it's ur dream car, then continue to chase it.
Boxologist is offline   Reply With Quote
Old 02-19-2011, 12:15 AM   #7
slavik.86
Member#: 238300
00 2.5rs built
ej255 swap
i say do the swap. its fun. most stuff should be plug and play besides for wiring. and ya u would be swapping the whole hub. im finishing up my 05 wrx everything into 97 obs. everything just fits right up. but i had a entire wrecked wrx so i had every part needed and swapped over every part including dashboard and all.
slavik.86 is offline   Reply With Quote
Old 02-21-2011, 01:53 PM   #8
mtbrider
Member#: 269144
2001 RS
Go for the swap. I'm working on saving up some cash to do some work on my '01 2.5RS, and I was already thinking of doing this type of engine & tranny swap rather than building up the motor. It would be pretty rad to see how it goes.
mtbrider is offline   Reply With Quote
Old 02-21-2011, 09:58 PM   #9
Pikey_STi
Member#: 264297
1996 Plymouth Neon
Red W/ Green Hood
So the hub swap right over, i was hearing some where that their was steering issue when useing the knuckles.
maybe i read wrong, are their any bulid pictures any where
Old 02-22-2011, 02:07 PM   #10
Reebis
Member#: 126157
'01 2.5RS Coupe
BRP
Search is your friend....
And you might want to head over to rs25.com. Lots of swaps over there...
Reebis is offline   Reply With Quote
Old 02-22-2011, 03:13 PM   #11
jnorth85
Member#: 76785
2000 580Whp The RSTI
SRP
check out my build thread on RS25 it should answer a lot of questions.
jnorth85 is offline   Reply With Quote
2006 sti tranny into 2006 wrx renosubby Subaru Conversions 5 09-25-2007 02:32 PM
2006 Sti engine into a 2006 2.5i gilbert_0004 Normally Aspirated Powertrain 20 08-11-2007 03:50 PM
pinout map for jdm mirror going into 99rs dromango Subaru Conversions 0 02-01-2006 11:40 AM
USDM WRX rear into 99RS AWD/RWD.. QUE? Fat Tits Transmission (AT/MT) & Driveline 3 11-19-2003 12:09 PM
sti setup into 99RS ScoobyTime Subaru Conversions 5 09-29-2003 04:48 PM
