#1 |
Member#: 187181
NWIC
Vehicle:93 maroon impreza maroon |
ok so i recently just put a 22e in my 93 impreza and put my buddies act lightweight flywheel in my car that he had in his 07 impreza 2.5i to get to the point i have replace 2 rear main seals in the past 2 weeks cuz they keep leaking oil could the flywheel be doing this cuz i never had this problem unil i put the flywheel in and my clutch keeps slipping i bought a new clutch and had the flywheel resurfaced.
#2 |
Member#: 154175
NWIC
Vehicle:07 Impreza Wagon 2.5i??? |
chief your clutch is probably slipping because the main seal is leaking oil on it
#3 |
Member#: 250463
Vehicle:2010 Impreza 2.5i Silver |
Did you build the engine? What's your end play on the crankshaft? Did you put the right thrust bearing in?
If the crankshaft is moving back and forth more than it should it can roll the seal out. |
#4 |
Member#: 5218
MWSOC
Vehicle:96L Most Over- Developed Beater |
I'd be more concerned with the condition of the crank and/or installation method.
If the crank has a burr on it, it'll just tear a perfectly good seal in no time. If you drive the seal in too far, it can (will) leak. A deep groove worn in the crank will also fail to seal. Jay |
#5 |
Member#: 41986
NWIC
Vehicle:'06 STI/'85 Brat |
| Thread Tools | |
| Display Modes | |
| Possible problems with rear main seal install | cdigerlando | Service & Maintenance | 5 | 01-13-2011 02:53 PM |
| Rear Main Seal problem | rivman05 | Service & Maintenance | 2 | 12-01-2007 08:02 AM |
| Replaced front main seal and oil pump o-ring | archer | Normally Aspirated Powertrain | 4 | 12-28-2001 03:28 AM |
| ('93-'01) Rear main seal gone - 650kms? Help! | JNaubur | Impreza Forum | 6 | 05-25-2001 12:29 AM |
| Front main seal, timing belts -oil pump&water pump? | immortal_suby | SVX Forum Archive | 3 | 06-25-2000 07:15 PM |
