Old 11-01-2010, 09:47 PM   #1
bobaab
Member#: 58592
2011 WRX WRB 5-Door
1991 MR2
Default Vibration/grittiness through the clutch pedal
I just started noticing this yesterday. The car has 620 miles on it at the moment.
When I depress the clutch pedal, I feel a sort of grittiness or vibration through it. When I hold it in one location, I don't feel anything, but when the pedal is being moved, I feel something. It sure wasn't there before.
90% of the time I shift now, I feel it. Is this pretty normal for a new car or is my clutch about to blow up?
Any advice will be great...otherwise, I'm contacting the dealer soon. Thanks guys.
bobaab is offline   Reply With Quote
Old 11-08-2010, 10:18 AM   #2
SnapWrx
Member#: 263351
I Had the same problem an my clutch fluid was almost black i had subaru flush it an now it seem to be a little better but the cluch was newer an have know idea how it got like this.
SnapWrx is offline   Reply With Quote
Old 11-08-2010, 10:21 AM   #3
lavid2002
Member#: 226864
My clutch is a little rough and squeaks in the forester.... When I pulled my impreza engine I cleaned up the clutch fork (All the build up made it squeak) This did the trick.
Doubt this is the problem on a brand new car though.
Old 11-09-2010, 10:47 PM   #4
Tigerotor77W
Member#: 250237
2010 WRX
My clutch used to be buttery smooth. I took it in for an oil change and then it got that grittiness... now it's better, but I still feel more "judder" than I did when I picked it up. Not sure if they did anything or what that did to cause it...
Tigerotor77W is offline   Reply With Quote
Old 11-09-2010, 10:52 PM   #5
scooby24
Member#: 56414
2004 Forester XT 5MT
Get up under the dash and take a look at the pedal assembly. There's probably something binding there.
I had a terrible squeaking from my G35's clutch and it turned out to be a spring in the assembly that needed lubrication. It squeaked from day one until the day I hosed it down with some lithium grease.
scooby24 is offline   Reply With Quote
Old 11-29-2010, 01:20 PM   #6
Jchon3
Member#: 265290
2011 Impreza WRX
WR Blue Mica
heyy bobaab, im having the same EXACT "issue" with my 11' WRX sedan. and i'm not sure if i should take it to the dealer or not.
if you got it checked up can you shoot me a pm with the verdict? would be much appreciated.
thanks!
Jchon3 is offline   Reply With Quote
Old 11-29-2010, 06:42 PM   #7
wayward167
Member#: 253998
13 BRZ
Hhhmmm I have 4k on mine and no vibration but my exhaust vibrates the damn rear deck all the time......bad roads will do it as well....
wayward167 is offline   Reply With Quote
Old 12-03-2010, 04:16 AM   #8
wayward167
Member#: 253998
13 BRZ
Guy at the local dealer had a bad transmission in his 11 wrx hatch... 1600 miles. ; (
Old 12-05-2010, 11:36 AM   #9
kneedraggin
Member#: 128013
2005 STI
PSM or silver
That happened to my car 02 Wrx it was the throwout bearing
kneedraggin is offline   Reply With Quote
Old 01-03-2011, 10:50 PM   #10
drunkpark
Member#: 268938
News
Bobaab, any updates on the issue?
drunkpark is offline   Reply With Quote
Old 02-22-2011, 08:45 PM   #11
pushatam
Member#: 258897
2011 Impreza WRX
Dark Grey Metallic
I have this same exact issue on my 2011 5 dr with 6,200 miles. it recently started too! I am goin to check the pedal as scooby24 suggests when I get home.
pushatam is offline   Reply With Quote
Old 02-24-2011, 04:45 AM   #12
blackmamba11
Member#: 266458
2011 WRX sedan
black
This thread caught my attention because I have 11 sedan and now im definitely going to pay more attention to the clutch pedal..I haven't really noticed anything and im coming up on 5000miles...had a bad wheel bearing though just recently changed..under warranty thank god..fckin pot holes
blackmamba11 is offline   Reply With Quote
Old 03-01-2011, 02:22 PM   #13
imprezed2011wrx
Member#: 267998
2011 Impreza Wrx
Yea same for me but when I press the clutch in I sometimes here a clicking noise. Not like a relay click but a click sound from the spring behind the clutch pedal. Then sometimes it's smooth
imprezed2011wrx is offline   Reply With Quote
Old 03-02-2011, 12:05 PM   #14
koitsu7563
Member#: 218709
im not sure if my issue is common i have a 11 wrx 5mt with 1500 miles. its only when i push down on the clutch all the way that last inch before it hits the wall then it makes a squeak, the sound is comin from the engine. when its cold the sound is gone but after 10 min of driving its back.
I have that gritty feeling in the morning but it goes away after a min then it starts to feel like butter
koitsu7563 is offline   Reply With Quote
Old 03-10-2011, 03:11 PM   #15
riderome
Member#: 210603
2005 STI
I've had that vibration feeling both in my 02 bugeye and my 05 sti before and after I installed my act clutch.
riderome is offline   Reply With Quote
Old 03-11-2011, 01:59 PM   #16
chazzer9
Member#: 275129
2011 STi
I have a 11 STi sedan with about 300 miles on it and just yesterday I noticed a grinding noise while in 1st and 2nd gear. Almost sounds like I am dragging something under the back of my car.
chazzer9 is offline   Reply With Quote
Old 03-11-2011, 02:06 PM   #17
riderome
Member#: 210603
2005 STI
Grinding when deaccelerating? I have the same thing in my 05 sti as well. Switching from a wrx to an sti, I noticed alot of noises from the transmission. I've had the car for 2 months so they seem quite normal to me know. Nothing getting worse.
Old 03-11-2011, 03:08 PM   #18
chazzer9
Member#: 275129
2011 STi
Yeah, I noticed it when I was driving through a parking lot at about 10mph max. I did have my radio off at the time so that might have been why I noticed it. Wondering if I should have it checked out before I use my new Cobb Accessport w/stage 1 map.
Old 03-13-2011, 12:24 PM   #19
Evil-e
Member#: 276607
I have the same issue on my '11 WRX but I figured it was a normal trait of the car. I noticed it on the intial test drive I took in it and it's still there with 490 miles on it.
Evil-e is offline   Reply With Quote
Old 03-14-2011, 07:10 PM   #20
artyj29
Member#: 217746
2011 WRX Ltd.
Check out this thread...mine does it every once in a while too
http://forums.nasioc.com/forums/show...ht=pedal+click
artyj29 is offline   Reply With Quote
Old 04-11-2011, 11:04 PM   #21
bobaab
Member#: 58592
2011 WRX WRB 5-Door
1991 MR2
Forgot about this thread, but here's an update.
I have 10k miles on the car now and everything is very smooth. I don't notice anything out of the ordinary now. It's been fine for a while now.
The clutch pedal did make some noise every so often...just a click every time I pressed the pedal down. I haven't hear this for a while either.
I suspect it is either the car going through break-in or it was the colder temps we saw during winter.
Old 04-17-2011, 07:16 PM   #22
Member#: 280104
2011 Subaru STi
Red
I took my 2011 sti to the dealer with the same problem. After a check up the service manager said everything is ok. I have notice the car does it when engine is cold. If I let the rpms drop and easy in 2nd gear the transmission is ok. After the engine is warmed up on the street or track...no problem
On another note I was autocrosing Saturday and I push the c differential to lock while the car was slow moving......the transmition start complaining very loudly...did I screw anything up?
Theo@theoharris.com is offline   Reply With Quote
Old 05-11-2011, 09:12 PM   #23
Sublimedgb
Member#: 279952
Bump
2011 WRX same intermittent issue, I have not found a way to reproduce it yet, but then again i have not really tried...It has happened to me 3 times so far in the last week. Car has 3400 miles on it, drive about 100 miles a day thru the week no other issues. What i can say is that it was 90+ degrees outside (Tampa) and the car was plent warm as it had been running for at least 30 minuts prior to the occurences. I have the first oil change scheduled for this friday and will mention it to the service department...along with showing them this thread. Will post update if i gain any good info. This topic also has another thread that runs back a few years...
http://forums.nasioc.com/forums/show...1927112&page=4
Sublimedgb is offline   Reply With Quote
Old 01-14-2012, 11:42 PM   #24
rationull
Member#: 297202
2011 Impreza WRX
Just wanted to chime in and say I've noticed this on my 2011 WRX as well. I'm not sure when it started, but I'm pretty sure it wasn't like that when it was brand new (7xxx miles on it right now). Just the "grittiness" feeling described, very slight vibrations only when moving the pedal. At first I thought it was temperature related (only when the engine is cold) but from testing, it turns out that it happens when the engine speed is above 1500 RPM or so. At normal hot idle the pedal is smooth, at cold idle I can feel the roughness, and while driving if I shift at those engine speeds I can feel it, although it's hard to feel over road vibrations. I can reproduce it easily by holding the engine at 1500 RPM in neutral and pumping the clutch.
I've had plenty of cars with hydraulic clutches in the past and never felt anything like this, but the WRX seems to have a fairly convoluted pedal linkage setup and a short hydraulic circuit that I suppose I could see transferring more driveline vibration than some other designs. The fact that it seems to be engine speed related makes me think (hope) it's just driveline vibration, but I'm not sure why it would only be felt when moving the pedal (or why it would be felt through the clutch at all for that matter).
For now I'm assuming this is nothing to worry about -- the car shifts and drives great. I thought about taking it in but I don't really want anything to be taken apart if it doesn't need to be.
rationull is offline   Reply With Quote
Old 01-15-2012, 08:38 PM   #25
_nut_
Member#: 259980
2011 WRX Ltd Sedan
I've had this problem off and on the last month now ('11 with 21k). Im one to engine break a lot and rev match. Had the problem the other night.. 5th engaged to brake ... Down to the point of stall. No idea why but that stopped it. She's back to buttery smoothe. Oil change is due tues... So I'm not sure if I want to have them check it out or not (as one other alluded to - impossible to replicate)
_nut_ is offline   Reply With Quote
Heard a Loud Crack and then the Clutch Pedal Flew to the Floor :( greenc51 Transmission (AT/MT) & Driveline 16 09-17-2009 01:32 AM
Wierd subtle vibrations in acceleration and clutch pedal. GlenCastleberry Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 5 03-16-2005 01:45 PM
Is It Possible to Lighten the Clutch Pedal? stewgod Transmission (AT/MT) & Driveline 13 09-29-2004 02:06 PM
Whats a good aftermarket clutch that isn't too stiff on the clutch pedal edkwon Transmission (AT/MT) & Driveline 6 09-09-2002 11:15 PM
We're midway through the clutch install BugBomb Mid Atlantic Impreza Club -- MAIC 3 09-09-2001 09:26 AM
