#1 |
Member#: 168000
Vehicle:1999 legacy sus black, 30th anniversary |
Do head bolts need to be replaced on a 99 legacy sus 2.5 when replacing the head gaskets?
Anyone have the torque spec and procedure for the heads and camshafts. This one has dual overhead cams.
#2 |
Member#: 28685
Vehicle:2004 FXT 4EAT very STi'd |
No, they do not need to be replaced. Some googling will turn up the torque sequence.
#3 |
Member#: 238379
NESIC
Vehicle:2000 Outback Sport Two-Toned Silver/Brown |
They do not need to be replaced, however, it is never a bad idea to.
#4 |
Member#: 71092
MWSOC
Vehicle:2005 2.5RS Wagon Regal Blue Pearl |
There's substantial confusion about wither or not they need to be replaced and it took a long time for me to sort out the truth on it.
The fact that they specify a "torque plus angle" leads a lot of people to conclude that they're "torque to yield" bolts and therefore need replaced every time. On the other hand, the factory service manual doesn't say anything about replacing them each time. Turns out, they are torque to yield bolts, but they're not *THAT* kind of TTY bolt. Traditional TTY bolts are torqued until they stretch (yield) into their plastic deformation range. In other words, you stretch them and they don't quite rebound to normal. This is why you can't re-use this kind of bolt. It's becoming increasingly common on modern engines to get TTY bolts that are stretched into their elastic deformation range, meaning that you stretch them and they go back to normal when you release them. You can re-use these kind of bolts many times. |
#5 |
Member#: 179478
MWSOC
Vehicle:2000 Impreza 2.5 RS Sedona Red Pearl |
All I know is I went to a Subaru dealer to buy new head bolts, and the parts counter- person informed me that they would have to order them, it would take a few days. They also informed me that they don't stock them because when the techs do head gasket jobs, they simply re-use them.
I re-used mine. I didn't have a few days to wait. |
#6 |
Member#: 71875
Vehicle:98 2.5GT my wheels fit |
I've re-used mine twice now. stupid phase 1 2.5l
#7 |
Member#: 266930
Tri-State
Vehicle:2000 Impreza spt wgn |
#8 |
Member#: 104453
MAIC
Vehicle:2010 FXT OBP |
^ i don't think that caused your engine failure twice in a row.
#9 | ||
Member#: 71875
#10 |
Member#: 28685
Read jamal's post. Your gasktes failed because of the combination of cheap ebay gaskets and the shadetree "surfacing" of the mating surfaces. Until you get the block and heads resurfaced professionally, you're going to be repeating this job.
#11 | |
Member#: 71092
MWSOC
![]() Seriously, though, your bolts weren't the problem, your technique and choice of gaskets were the problem. |
#12 |
Member#: 556
Vehicle:1999 BG9 Outback Silver |
They don't have to be replaced, but I used ARP head studs when I replaced the head gaskets on my 99 Outback.
Jake |
#13 | |
Member#: 270791
#14 |
Member#: 266930
Tri-State
Now tell me why the **** you think you think it's hilarious and laugh at someone who is trying to learn where they went wrong in doing a project such as that and take the learning experience to prevent it from happening 3,4,5,6+ more times. If you were serious about your choice of car and had care about any thing besides your ego you would have looked at this and admired the fact that I was willing to put myself up on the line for answers despite MY pride and ego. You claim i'm a dumb ass, No, I simply didn't know to not use a scotch brite disk, I simply didn't know that a little bit of oil could cause failure like that. Your "typical, overly used" comment is worth a penny. Flame away **** sucker ...just flame away.
#15 |
Member#: 71092
MWSOC
/me just laughs his ass off
Dude, start paying attention to the username on the first post of about 1/3 of the HOWTO or testing results posted around here. |
#16 |
Member#: 266930
Tri-State
#17 |
Member#: 71092
MWSOC
#18 |
Member#: 266930
Tri-State
To the op of this thread, I apologize for taking this over and bringing this bitch chat into it.
#19 |
Member#: 154586
BAIC
Vehicle:1996 ej22 Outback White |
#20 | |
Member#: 154586
BAIC
I am all for DIY and learning as you go. I was a member of this forum for a couple of years before I made my first post....simply because I didn't have anything useful to add. Don't take offense to what people say on the forum...they usually don't mean it to be offensive. Sarcasm is hard to hear when reading. OP - I just did a headgasket job and re-used the bolts. 3 days later it is still fine. Will it hold? I think so. |
#21 | |
Member#: 28685
#22 | |
Member#: 266930
Tri-State
#23 | |
Member#: 248213
Tri-State
#24 | |
Member#: 179478
MWSOC
#25 | |
Member#: 266930
Tri-State
Laugh a little would ya |
| Thread Tools | |
| Display Modes | |
| PDE camber plate owners--replace your allen head bolts | gregr01 | Brakes, Steering & Suspension | 1 | 08-13-2009 09:51 PM |
| WTB: ej257 gasket kit, ARP head bolts and case bolts | 69_Lex | Private 'Wanted' Classifieds | 3 | 02-20-2008 10:38 AM |
| do i need to replace the head bolts? | cudaeh | Normally Aspirated Powertrain | 8 | 07-01-2005 12:40 PM |
| Can I reuse block bolts/head bolts | Tattoo Collector | Normally Aspirated Powertrain | 19 | 01-22-2005 01:35 AM |
| Head Bolts & Cams Bolts Torque Specs | Imprezd | Factory 2.0L Turbo Powertrain | 3 | 03-20-2003 07:30 AM |
