Welcome to the North American Subaru Impreza Owners Club Saturday September 24, 2016
Old 02-28-2011, 08:29 AM   #201
stanrc
Member#: 266177
2006 MX-5
RED
Yeah, I was thinking about doing that, or just trimming up the sides so they are even. Not sure yet.
stanrc is offline   Reply With Quote
Old 02-28-2011, 02:47 PM   #202
9an3qter
Member#: 208530
2011 WRX Hatch
Lightening Red
new favorite thread. great reviews on products and amazing photography good work. keep it up i cannot wait till my 2011 gets in next week
9an3qter is offline   Reply With Quote
Old 02-28-2011, 03:03 PM   #203
GodWhomIsMike
Member#: 102287
2014 Crosstrek Ltd.
Tangerine Orange
Weather forecast today:
Time for the winter tires! 16x6.5" steel wheels with 215/55R16 General Altimax Arctic's.
Rear 3/4
Front 3/4
I dunno, I think it looks pretty awesome actually.
GodWhomIsMike is offline   Reply With Quote
Old 02-28-2011, 03:57 PM   #204
xluben
Member#: 261612
2002 WRX - 750WHP
9.5s @ 150mph
Yeah, that might turn out even better actually. More coverage higher up. I did it this way because it's reversible. If I change my mind, I can always use the other holes and then trim the sides later.
Thanks! Have fun with the car!
I like it too. I think it looks better on a black car, IMO.
Old 02-28-2011, 05:16 PM   #205
Overboosedsti
Member#: 233010
not a regular fan of the 5 door but the car is looking good!
Overboosedsti is offline   Reply With Quote
Old 02-28-2011, 06:24 PM   #206
Celery GT-5
Member#: 98210
2016 Forester XT CWP
2002 WRX SRP
its pretty much externally stock so that doesn't make much sense
Celery GT-5 is offline   Reply With Quote
Old 02-28-2011, 06:30 PM   #207
RallyBlueBill
Member#: 267118
2011 WRX 4 door
Great info and pics as usual, xluben.
I have a Perrin DP, a SPT catback and Perrin CAI waiting in the garage for the salt-laden roads to let up here.
You and Jockeygolfs are the two "bad influences" that made me buy them. LOL!
RallyBlueBill is offline   Reply With Quote
Old 02-28-2011, 06:38 PM   #208
jockeygolfs
Member#: 260868
2011 STI
Hahahaha!!! Don't use us as scape goats.
jockeygolfs is offline   Reply With Quote
Old 02-28-2011, 10:29 PM   #209
KWIL
Member#: 40848
2011 Impreza WRX
5-Door, DGM
This = true. I wonder how many of us are following these guys?
KWIL is offline   Reply With Quote
Old 03-01-2011, 12:39 AM   #210
nighthawk06si
Member#: 267490
2011 WRX Hatch S2+SF
guilty......
nighthawk06si is offline   Reply With Quote
Old 03-01-2011, 05:41 PM   #211
xluben
Member#: 261612
2002 WRX - 750WHP
9.5s @ 150mph
AEM Cold Air Intake went on and had the MAF scaled last night. Definitely way more intake/turbo sound as well as much louder BPV sound. More photos and info later.
Old 03-01-2011, 05:44 PM   #212
xluben
Member#: 261612
2002 WRX - 750WHP
9.5s @ 150mph
GrimmSpeed EBCS and MBC also went on last night. Tuned for hybrid boost control:
http://forums.nasioc.com/forums/show....php?t=2135421
http://forums.nasioc.com/forums/showthread.php?t=602674
Mock up of install. Final install used hose clamps and plugged the port on the right side of the EBCS.
More info and photos of the final install coming later.
Old 03-01-2011, 07:59 PM   #213
nighthawk06si
Member#: 267490
i thought you said you were done till spring!?!?! ahh you're a bad influence on my already bad mod bug... :P
Old 03-01-2011, 08:35 PM   #214
09wrxVF52
Member#: 267024
2009 WRX Sedan
How are you liking the AEM intake xluben? I told you the intake would increase the BPV noise a lot. I think it sounds awesome hearing the turbo spool up.
09wrxVF52 is offline   Reply With Quote
Old 03-01-2011, 08:55 PM   #215
xluben
Member#: 261612
2002 WRX - 750WHP
9.5s @ 150mph
Oops forgot
Yeah, you were totally right. Waaay louder than before. Definitely some cool noises, but I did like how low key it was before. If it helps to free up some power then it's worth it, and it does sound really cool when I'm in the mood
Old 03-02-2011, 03:52 PM   #216
makopolo
Member#: 260046
2011 WRX Hatchback
Have been following this thread since the begining and its probably a similar order as I will go with my WRX. Finally got a Tactrix cable to work on my OP tune.
Can you provide an explination of your hybrid boost control strategy. I have read the FAQs but some things are still unclear.
makopolo is offline   Reply With Quote
Old 03-03-2011, 07:04 AM   #217
xluben
Member#: 261612
2002 WRX - 750WHP
9.5s @ 150mph
For hybrid boost control, the EBCS and MBC are hooked up in parallel. The MBC is set to control your max boost. The MBC will generally have a very quick response (allows the turbo to spool up as fast as possible), and will also have a very solid boost curve.
The EBCS is tuned so that it will control boost just like normal at all positions except WOT. This allows the car to control boost based on throttle position and avoid partial throttle, full boost. It will give you a much more linear power response, instead of pushing down the throttle halfway and going straight to full boost (like can happen with a MBC only).
The tune is set up so WOT (throttle position at 100%) will set the WGDC (for the EBCS) to 100%. This means that any time you floor it, the EBCS closes, and all of the air goes through the MBC. This allows you to have the ultra fast and stable boost response of a MBC at WOT, and the added control and linearity of an EBCS at partial throttle. It is a good setup, but definitely not a necessity.
Old 03-03-2011, 09:55 AM   #218
Stlgrndskeeper
Member#: 272647
2011 WRX stg 2
Tell me about it, I got it real BAD
Stlgrndskeeper is offline   Reply With Quote
Old 03-03-2011, 01:20 PM   #219
makopolo
Member#: 260046
2011 WRX Hatchback
Thanks for the thorough response, exactly what I wanted to know. Do you still run the stock restrictor pill?
Old 03-03-2011, 01:29 PM   #220
xluben
Member#: 261612
2002 WRX - 750WHP
9.5s @ 150mph
Once you get away from the OEM "bleed" based system you no longer need to control flow rates. With an interrupt system pressure is all that really matters. So, no, I'm not using a restrictor pill.
Old 03-03-2011, 03:25 PM   #221
1RandomW
Member#: 269224
'11 WRX-4 Door, SWP
I cannot wait to see what this puppy will do in 1/4 once is all finished !!!
1RandomW is offline   Reply With Quote
Old 03-05-2011, 10:26 PM   #222
xluben
Member#: 261612
2002 WRX - 750WHP
9.5s @ 150mph
Along with some local Subaru guru help, I installed the Fiveo 1200cc Injectors today:
http://www.fiveomotorsport.com/impor...s/?itemid=1263
Took about 3hrs or so with two people working on the install. It was a pretty big pain to get the driver's side bracket out. Injectors went in without any problems.
Old 03-05-2011, 10:29 PM   #223
xluben
Member#: 261612
2002 WRX - 750WHP
9.5s @ 150mph
After the injectors were scaled on pump gas, I made the switch to E85! The car runs great and the power feels amazing!
Old 03-05-2011, 10:33 PM   #224
vanquish88
Member#: 165842
1999 Gc8
Glacier white
wat are you putting down now?
vanquish88 is offline   Reply With Quote
Old 03-05-2011, 10:54 PM   #225
xluben
Member#: 261612
2002 WRX - 750WHP
9.5s @ 150mph
I don't have the log, but I think it was around 360WHP/390WTQ on the Virtual Dyno Dynojet setting (reads higher than an Airboy or Mustang Dyno). It was a conservative tune due to the winter mix of E85 (actually around E70) and since I still had a few gallons of pump gas in the tank.
I'll be getting a touch up tune once all of the pump gas is out. And probably another tune when the gas stations switch to true E85. Even without an aggressive tune the difference is incredible. The car feels amazing now, and runs perfectly. It is smooth from idle to redline and pulls hard the entire way. I love my tuner
xluben's Pictures and Review of the SPT Exhaust for the 2011 WRX 5 Door Hatch xluben Car Part Reviews 26 11-08-2012 06:55 PM
My first post and my first Subaru, a 2011 WRX 5 door in white. Decade240 Newbies & FAQs 25 06-20-2012 01:48 PM
2011 wrx 5 door hatch with Rota 17"x7.5 +48 5x100 wheels? BretCutler Tire & Wheel 4 01-14-2011 08:05 AM
2011 WRX 5 Door Ruz4life General Community 55 10-13-2010 11:37 PM
2011 WRX 5 Door Ruz4life General Community 10 10-04-2010 04:02 PM
