Old 03-07-2011, 09:36 PM   #1
subie is a monster
Member#: 273302
1993 legacy sport
white
Default 2.2 rebuild/upgrade
Hello i am new to the site i own a 94 legacy wagon n/a. I have been looking around and thare are alot of options to choose from.
i am looking to upgrade the hp and torque and possibly with out messing with the ecu any suggestions will help thanks.
subie is a monster is offline   Reply With Quote
Old 03-07-2011, 09:50 PM   #2
grafton
Member#: 187936
07 WRB STi
2.2/2.5 hybrid.
/thread
grafton is offline   Reply With Quote
Old 03-08-2011, 08:03 PM   #3
Jonlegacy98
Member#: 275412
1998 Legacy L
green
I own a 1998 legacy l with a 2.2 also. to my knowledge we cant do much with our engines. our engines basically stay stock. i have been searching for a year and i only found one thing and it is out of stock everywhere. it is a single port exhaust header.
Jonlegacy98 is offline   Reply With Quote
Old 03-10-2011, 03:50 AM   #4
BlaxTrax
Member#: 139989
C6 05 Vette 11 WRX
00 Impreza, 03 WRX
I heard you can put 251 cams in to increase throughout the entire power band without any modification to the ecu.Also another option is to find a junkyard 2.5 longblock and drop that in.
BlaxTrax is offline   Reply With Quote
Old 03-10-2011, 04:08 AM   #5
grafton
Member#: 187936
07 WRB STi
251 cams only for phase 2 2.2's
a 2.5 long block is a wiring challenge
apart from forced induction the 2.5l short block 2.2l head combo is the most cost efficient way to make more power
op get a NA 2.5L (doesn't matter what year just as long as it's an ej series) and bolt your 2.2L heads to it, run 89 octane and be done with it
Old 03-10-2011, 10:31 AM   #6
subie is a monster
Member#: 273302
1993 legacy sport
white
with the 2.2/2.5 will everything match up if not what will i half to rework or change
right now i am working on the heads and i am finding it very difficult to compress the valve springs any tips on the best tool for the job
thanks for the help
Old 03-10-2011, 04:07 PM   #7
grafton
Member#: 187936
07 WRB STi
everything should match up perfectly, only change is the head gasket and the crank sprocket ( use the one from you 2.2L )
with MY94 heads I'd figure the comtec gaskets designed for this combo would be your best ( read this thread too: http://forums.nasioc.com/forums/showthread.php?t=631527)
you can rent a valve spring tool from advance or auto zone that looks like this:
makes taking the valve train apart much easier
Old 03-10-2011, 10:14 PM   #8
l88m22vette
Member#: 142972
Does anyone have part numbers to look for?
l88m22vette is offline   Reply With Quote
Old 03-14-2011, 09:14 PM   #9
subie is a monster
Member#: 273302
1993 legacy sport
white
thanks for the help
FS : Sold jaybirde978 1993 - 2001 Impreza Specific Parts 6 03-14-2011 07:26 PM
costs of a 2.2 rebuild/upgraded internals? legacy2003 Normally Aspirated Powertrain 9 05-03-2004 04:06 PM
2.2 rebuild options serious Legacy Forum 0 12-06-2002 03:30 PM
Turbo 2.2 rebuild serious Legacy Forum 13 10-22-2002 10:57 AM
Who can rebuild/upgrade an IHI VF23? 2OHOH2WRX Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 7 09-05-2002 08:34 AM
