Old 03-13-2011, 05:18 PM   #1
dangerousatom
Visiting NASIOC Timeout
Member#: 70710
2002 04STi Swaped RS
w/PPGS & 02 Wagon w/PPGs
Default The Mods continue on the 03 WRX Wagon
After the totaling of my daily beater a 2002 WRX swapped 97 Subaru OBS :cry: I have started on a new DD a 2002 WRX Wagon. 147k on the motor with crashed valves. So after acquiring a 04 WRX long block with 64k and gathering parts, along with a ton of left overs from other builds I have finally started the build and a serious engine bay clean-up. Luckily every suspension mod swaps over from one car to the other.
The body is in great shape minus a few dings in the hood. With all the weather sucking with snow and all its been hard to get any good shots of the car. As you can see the bay was filthy, the previous owner just drove it and did not really keep things clean.
All motor bits are cleaned and painted. I quickly port matched the heads to the intake manifold & intake risers. The stock EVAP system has been basically deleted and the fuel system has been re-routed to be a parallel feed. TGV deletes along with the 16g turbo from the last car and a APs hard inlet are going on the motor. The 97 Subaru was tuned to 19 psi and I am planning on keeping it there.....it was plenty fast for a daily driver. With the transferred suspension mods and a few other bits I have picked up over the last few months the car should drive like its on rails.
It took a few weeks to get more pic's of the car and the motor going in ....snow and weather along with work are not making things easy to get this done fast. But finally its done!!!
with most of all the previous mods transferred over plus a few extra bits. After it smoking like a freak for the first start up,due to not venting any of the crank or head breather. It now is running great!!
Rerouted all vacuum lines to a distribution block with the uses of 1/4" push lock lines and fittings. Reran all the EVAP lines into a cheep Ebay catch can, with the same type lines and fittings and nothing is returned to the intake....VTA.
The transferred & new mod list:
-BC coilovers
-20mm Whiteline front sway bar with solid end links
-22-26mm Whiteline rear sway bar with solid end links
-Rear Whiteline stout mounts
-Rear sub-frame lock down kit
-Rear sub-frame ploy bushings
-Trans poly bushings
-Steering rack poly bushings
-Whiteline Rollcenter Kit
-STi aluminum control arms
-Rear Powerslot brake rotor upgrade w/EBC Green Pads
-Ebay 2 core aluminum racing radiator with slim fans
-Blouch 16g turbo
-STI Pink injectors
-Port matched Header w/GS crossover pipe
-Some cheep Stainles Steel Ebay UP
-Ebay 3" DP
-Greddy nock off Evo 2 cat back
-STi TMIC
-APS hard turbo inlet
-SPT Short ram intake
-Deleted TGVs
-GS 8mm intake maniflod spacers
-home made parallel fuel line system w/Summit regulator and pressure gauge. The first FPR was ditched due to it being a total piece of ebay crap!!!
-Chopped GFB short shifter
-17" Rota Attacks powder coated in Ink Black with Moon Dusk.....by LPC
-225/45 General Altimax Arctic Snow tires.....these things grip like crazy and ware like iron, I run them all season!!
-the Rally Innovations Light bar will be going back on from the old wagon with Hella 500 high beams
Needs to be washed bad!!
Last edited by dangerousatom; 07-10-2012 at 04:10 PM. Reason: The title is old and not accurate
dangerousatom is offline   Reply With Quote
Old 03-13-2011, 05:18 PM   #2
dangerousatom
Member#: 70710
Old 03-13-2011, 05:22 PM   #3
hiimdreh
Member#: 170823
2002 JdmYo! Bugeye
hiimdreh is offline   Reply With Quote
Old 03-13-2011, 06:12 PM   #4
remotehuman
Member#: 201995
2005 bugeye
Flat White & whatnot
looking good, getting there. I like the intake manifold. Where did you relocate your boost controller to?
remotehuman is offline   Reply With Quote
Old 03-13-2011, 06:27 PM   #5
dangerousatom
Member#: 70710
The BC and other bits that are located in that harness are just pulled through the brake proportioning valve line bends and located above the cruse control box. You can see the four pin plug for the font 02 sensor and other sheathed/loomed wires in the last pic just to the passenger side of the TMIC near the prop-valve.
The BC is not going to stay for long anyway......Im not a fan of electronic BC so a manual one is going is soon.
Old 03-13-2011, 06:37 PM   #6
jonnylin1
Member#: 232228
2008 SWP WRX -BYE <3
WHITE FTW - AW e92 335i
lol, i wish i had a beater like this =]
jonnylin1 is offline   Reply With Quote
Old 03-13-2011, 07:23 PM   #7
dangerousatom
Member#: 70710
Heh it seems like everyone says that. Working at a church ( facility's manager ) and having all the car know how is a big help. I can go weeks and months with out a car due to the ability to used the church vans when ever needed. So I can take my time and do it rite-well the first time.
My good show car is a bit over the top too........... seriously need updated pics
http://forums.nasioc.com/forums/show...highlight=swap
Old 09-24-2011, 11:51 PM   #8
dangerousatom
Member#: 70710
Rear C-D Pillar to Strut Tower Brace
Full Build Thread
http://forums.nasioc.com/forums/show...ighlight=wagon
V2.0
I finally have started the 02-03 wagon C-D bar.
Unknowing to me the 02 & up wagons have rear height adjustable seat belts. So that meant a total re-engineering of the side brackets. after about 3-4 hours or figuring and measuring I finally got it worked out. The V2.0 setup is going to be far more rigid than the 1st bar set that I made for the GC wagon. The 1st set's side brackets actually where bending from the amount of force I could but on then via the turn buckles. So the side bars are now 1" square tube upgraded from 1/2". The front mounting point on the side bar is a pipe anchor style and no longer attached to the seat belt directly, so seat belt mounts/function is unchanged. The rear mount is the same as the previous C-D bar. Instead of using cheap ebay rear tower bar mounts I had plate steel plasma cut and made my own.....far stronger and closer fitment. Also making my own turnbuckles again was out of the question. The 1st set litterly ripped the threads out of the female pipe ends, so I out sourced grade 8 turnbuckles along with all grade 8 universal/heim joints and pipe ends. Im figuring with the added strength I may be able to influence camber by .5+/- degrees depending on if the bars are in pulling or pushing tension mode......that remains to be seen appon rear alignment.
Here is what is finished so far:
Rear Side Bar Mounting Points
Front Side Bar Mount Points
Side Bars
Rear Strut Tower Mounts
Turnbuckle/Heim Joint Assembly
Old 09-24-2011, 11:51 PM   #9
dangerousatom
Member#: 70710
Upper and Lower Bars Installed
Hopefully tomorrow I will be finishing things up and welding in the bars that connect the Upper and Lower bars together. Then its off to powder coat.
Well after about 18 hours of fab work-running back and forth to Lowes and other places along with modifying the new tubing notcher all that is left to do now is pull everything out and clean up the welds and edges.
Already I can feel the difference in rear suspension response and rigidity on the 5 mile drive home from the shop.....cant wait the give it a good thrashing to see if there are any problems or odd noises.
Old 09-24-2011, 11:54 PM   #10
dangerousatom
Member#: 70710
Ya its back from LPC!!
Also the fuel rails are in and everything is re-plumbed
Old 09-25-2011, 12:54 AM   #11
Srtkr
Member#: 228025
00 Forester
holy **** that came out flawless
Srtkr is offline   Reply With Quote
Old 09-25-2011, 01:12 AM   #12
|Rev|
Member#: 100651
2010 STI
That came out really nice, good work!
|Rev| is offline   Reply With Quote
Old 09-25-2011, 12:38 PM   #13
dangerousatom
Member#: 70710
.......Thanks Guys
Old 09-25-2011, 01:39 PM   #14
mac1124
Member#: 286146
2003 2.5 TS Wagon
Blue Ridge Pearl
Nice! Great work.
mac1124 is offline   Reply With Quote
Old 09-26-2011, 12:03 AM   #15
stg2wgn
Member#: 182387
2004 Wrx Wagon
WRB - stg. 2
omg i want one of those rear bars TOUGH.
stg2wgn is offline   Reply With Quote
Old 10-01-2011, 01:59 PM   #16
dangerousatom
Member#: 70710
Installed my "knock-off" Takata harness and Mag light seat holder today, along with a UR over drive crank pulley.
Old 10-22-2011, 08:15 PM   #17
BONFIRE074
Member#: 166936
04 2.0 18g-11.8@11
5.7..Hybrid t60r 435whp
nice "beater"
BONFIRE074 is offline   Reply With Quote
Old 10-22-2011, 10:41 PM   #18
100_Percent_Juice
Member#: 126042
2004 W Ŕ X
Why no timing belt cover?
100_Percent_Juice is offline   Reply With Quote
Old 10-22-2011, 10:58 PM   #19
philstar
Member#: 298639
i like all the custom welding, looks like a fun "beater" haha
philstar is offline   Reply With Quote
Old 10-22-2011, 11:31 PM   #20
dangerousatom
Member#: 70710
In those pice the motor was only in for 2-3 days from being re-timed.
Also I have a 2nd rear bar assembly for sale in Gloss Rock Star Black that was made for someone who backed out of the deal due to their cars totally crapping out........PM me if your interested
Old 10-22-2011, 11:43 PM   #21
Whiplash215
Member#: 290387
Sweet ... Beater...
Whiplash215 is offline   Reply With Quote
Old 10-22-2011, 11:57 PM   #22
Will_B1989
Member#: 194775
2000 2.5 RS
Wish I had a "beater"
Will_B1989 is offline   Reply With Quote
Old 10-23-2011, 12:04 AM   #23
axleon2
Member#: 154117
2004 WRX
JAVA BLACK PEARL
Beater?
axleon2 is offline   Reply With Quote
Old 10-23-2011, 01:16 AM   #24
dangerousatom
Member#: 70710
Originally Posted by axleon2 View Post
Beater?
Actually it is my beater.... compared to my other "show car"
Old 10-23-2011, 01:20 AM   #25
mac1124
Member#: 286146
2003 2.5 TS Wagon
Blue Ridge Pearl
^ Wow! Sweet show car.
Is this a good deal for a DD Beater? memma Off-Topic 18 07-23-2010 01:48 PM
Looking for cheap DD/Beater/Commuter. heavyarmscustoms NESIC Private Classifieds 14 07-09-2010 11:57 AM
Dangerousatom's new turbo crap box "91 Leg SS" dangerousatom Member's Car Gallery 45 06-19-2010 12:27 AM
FS: Great DD/beater - 2006 Nissan Sentra 1.8S AT JeromeS13 SWIC Private Classifieds 2 05-15-2010 02:27 AM
(feeler)WTB DD beater jeep cherokee or grand cherokee bjwk89 Tri-State Area Private Classifieds 4 06-20-2008 10:12 PM
Message Board Statistics All times are GMT -4. The time now is 06:32 AM.
